Projects 12703/12704
PaulTV
Post by PaulTV »
Hi,
Those projects give low PPD even on an RTX 3060 Ti, but okay. They are also assigned to high end GPUs (like my RTX 4090), and then give rediculously low PPD (8.5M PPD, while I'd expect 30M PPD on that card), which is not that okay.
Can PPD please be adjusted for those projects, or have them not being assigned to high end GPUs?
Re: Projects 12703/12704
Post by muziqaz »
Hi, this was reported already to the researcher. It might take a bit for researcher to get the message. Thank you
FAH Omega tester
PaulTV
Post by PaulTV »
Ah, I guess that was due to reports via discord, didn't see it on the forum. Thanks!
Post by muziqaz »
PaulTV wrote: Sat Feb 01, 2025 8:58 pm Ah, I guess that was due to reports via discord, didn't see it on the forum. Thanks!
Indeed, Discord is a bit quicker medium than forum :)
By the way, were you requesting to join Beta some time ago, or am I mixing things up?
If you have access to Beta subforum, you can post there if the project thread has been created when it was going through open beta.
That way researcher will get an email of new post in their thread, since they are auto subscribed to their own thread :)
viewtopic.php?t=42202
FAH Omega tester
PaulTV
Post by PaulTV »
muziqaz wrote: Sat Feb 01, 2025 9:21 pm By the way, were you requesting to join Beta some time ago, or am I mixing things up?
I did request that a long, long time ago, but that got never sorted. I kinda gave up on that, to be honest. I even still run v7, but that's more because my own monitoring and logging app doesn't work with v8 yet.
Post by muziqaz »
PaulTV wrote: Sat Feb 01, 2025 9:26 pm
Your request was noted and we even decided to accept you, I remember, but we could never sort out the logistics side of things to get you in, since somehow we could get permissions sorted or something.
FAH Omega tester
