How to link F@H account PC
Clive
Hardware configuration: Alienware desktop running Intel i7-8700K CPU, 16 Megs Ram, Nvidia 1100 GPU
Post by Clive »
Hi
F@H is showing that the computer that I am using for F@H is "unlinked" to my account. How do I fix this?
Clive
Re: How to link F@H account PC
Post by muziqaz »
V8.4.9?
Click on the cog, and there is a chain icon on the right hand side, click on that, it should link it.
It should have popped linking message first time you started the client, though
FAH Omega tester
Post by calxalot »
You need to login to your account, which you registered/created via web control.
Clive
Post by Clive »
Hi:
Thank you for assisting me in successfully getting my first PC linked to my account. I have tried to link my laptop to my F@H account, but I am getting an invalid password error.
Is there a fix for this?
Clive
Post by calxalot »
Note that your passkey is not a password.
Post by calxalot »
You might want to reread the guide
https://foldingathome.org/guides/v8-4-client-guide/
