Folding at home on laptop Bad_Work_Unit
Mark
Post by Mark »
my laptops work units keep failing
22:23:01:E :WU20:Core returned BAD_WORK_UNIT (114)
22:18:09:E :WU16:The folding core did not produce any log output. This indicates that the core is not functional on your system. Check for missing libraries or GPU drivers. Make a post about your issue on https://foldingforum.org/ to get more help.
I keep getting errors like these I have 2 gpu's both amd intagrated and my 6800m as well as my 8 core ryzen 9 5900hx
any help would be appreciated. I also have the latest drivers for amd version 24.12.1
Re: Folding at home on laptop Bad_Work_Unit
Post by calxalot »
What OS and version?
Mark
Post by Mark »
Windows 10 Version 10.0.19045 Build 19045
Post by muziqaz »
Which Project this failing happened?
FAH Omega tester
Mark
Post by Mark »
Project: 15103
Mark
Post by Mark »
It seems to be Just the 6800m failing but thats the main bulk of the processing power it doesnt seem to just be project 15103 its getting others after failing. its id is gfx1031
Post by muziqaz »
gfx 1031 is architectural ISA codename of you GPU.
are you sure that your drivers are provided by AMD and not by idiots at Microsoft? There is a known issue where Windows update hijacks perfectly working AMD (and nvidia) drivers and overwrites them silently without user knowledge. This used to happen to me even mid folding.
But if only 15103 is failing and other projects are running fine, then it might be unstable GPU, where instability is brought out by that project.
15103 did not fail for my 6900xt on Linux during project's testing, so it shouldn't be an issue with the drivers. Have you tried updating the drivers to latest ones?
FAH Omega tester
Mark
Post by Mark »
18228
15104
15103
12294
18251
12295
12295
18238
18238
these are just the top few that failed.
Post by muziqaz »
Ok, so your system is not stable enough to fold. Is your driver from AMD or from Microsoft?
You can usually tell if it is from AMD, if you can right click on the desktop and launch Adrenalin control panel. Updating the drivers from AMD website might sort this issue.
FAH Omega tester
Mark
Post by Mark »
AMD i have the Adrenalin control pannel.
Post by muziqaz »
Try updating the drivers.
Which version of fah are you running?
FAH Omega tester
Mark
Post by Mark »
Latest just downloaded fah 2 hours ago. drivers are as uptodate as they come but ill try the reinstall i guess.
Mark
Post by Mark »
ok so reinstall didnt fix the issue. though it did seem to last longer.
Mark
Post by Mark »
Also i have a new issue not after the reinstall but after i changed my username all the feilds are blank on the folding@home client page now they still exist and tell me if there are errors but there are no progress bars or anything else. I just have the actions buttons.
Post by muziqaz »
You can add new columns by clicking on Avatar icon and Appearance section.
And regarding failing WUs, there is not much we can do, since it seems your GPU is not 100% stable
FAH Omega tester
