Question about stats.
RyanMcCarley
Hardware configuration: (2X)AMD Ryzen 9950X3Ds, AMD Ryzen 9 7950X3D, (2X), AMD RYZEN 9 4900H, (2X) AMD RYZEN 7 5825U, AMD Ryzen 9 8945HS, AMD Ryzen 9 6900HX, AMD Ryzen 7 8845HS, AMD Ryzen 3 5425U, Ryzen 5 5600U, AMD Ryzen 9 7940HS,
NVIDIA GeForce RTX 5080s, NVIDIA GeForce RTX 5070TI, NVIDIA GeForce RTX 4070TI, NVIDIA GeForce RTX 3050
Post by RyanMcCarley »
I use to fold years ago and recently came back to fold once more. The stats page does not seem to update with the WU I complete and show my contribution to the team I have selected. All I see is old stats and the old team I did it under. Any suggestions to remedy this problem?
Re: Question about stats.
Post by muziqaz »
Give it some time, and make sure you have same username entered. Stats do not update straight away
FAH Omega tester
RyanMcCarley
muziqaz wrote: Fri Jan 24, 2025 6:56 am Give it some time, and make sure you have same username entered. Stats do not update straight away
I had it folding for a few days with no updates. Just deleted the account and made a new one, that solved it to my liking. Everything is tracking like it should.
Post by muziqaz »
It is possible that previous interaction of the username had different passkey attached to it
FAH Omega tester
