F@H pausing itself?
vica153
F@H pausing itself?
Post by vica153 »
When I come back to my PC in the morning, F@H is often paused even though I left it running. 'While on Battery' and 'Keep Awake' are both checked.
Still working the bugs out or am I missing something?
Re: F@H pausing itself?
Post by muziqaz »
Logs would tell you what has happened. If fahclient web ui page has yellow borders around your resource, that means something failed, and failed enough for client to pause any further attempts to fail again.
FAH Omega tester
vica153
Post by vica153 »
22 WU complete without issue over 5 days, then 10 fails in a row.
06:22:54:I1:WU154:An exception occurred at step 6525: Particle coordinate is NaN. For more information, see https://github.com/openmm/openmm/wiki/F ... stions#nan
06:22:54:I1:WU154:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
06:22:54:I1:WU154:ERROR:114: Max number of attempts to resume from last checkpoint reached.
05:04:29:E :WU145:Core returned BAD_WORK_UNIT (114)
06:14:10:E :WU146:Core returned BAD_WORK_UNIT (114)
07:02:33:E :WU147:Core returned BAD_WORK_UNIT (114)
07:40:49:E :WU148:Core returned BAD_WORK_UNIT (114)
08:34:55:E :WU149:Core returned BAD_WORK_UNIT (114)
04:55:36:E :WU150:Core returned BAD_WORK_UNIT (114)
05:17:47:E :WU151:Core returned BAD_WORK_UNIT (114)
05:22:30:E :WU152:Core returned BAD_WORK_UNIT (114)
06:02:57:E :WU153:Core returned BAD_WORK_UNIT (114)
06:23:12:E :WU154:Core returned BAD_WORK_UNIT (114)
Post by muziqaz »
You can search each individual Wu logs in web UI log section by entering Wu number (for example WU145) in to search bar. Post all the failed Wu logs here, please
FAH Omega tester
vica153
Post by vica153 »
Unpaused it and got 8 more fails in a row and it paused itself.
04:49:40:I1:WU145:Folding@home Core Shutdown: CORE_RESTART
04:49:42:I1:WU145:Core returned CORE_RESTART (98)
04:49:42:I1:WU145:Retry #1 in 2 secs
04:49:44:I3:WU145:Started FahCore on PID 22856
04:49:44:I1:WU145:*********************** Log Started 2025-02-02T04:49:44Z ***********************
04:49:44:I1:WU145:*************************** Core23 Folding@home Core ***************************
04:49:44:I1:WU145: Core: Core23
04:49:44:I1:WU145: Type: 0x23
04:49:44:I1:WU145: Version: 8.0.3
04:49:44:I1:WU145: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:49:44:I1:WU145: Copyright: 2022 foldingathome.org
04:49:44:I1:WU145: Homepage: https://foldingathome.org/
04:49:44:I1:WU145: Date: Aug 3 2023
04:49:44:I1:WU145: Time: 08:39:06
04:49:44:I1:WU145: Compiler: Visual C++
04:49:44:I1:WU145: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:49:44:I1:WU145: -DOPENMM_VERSION="\"8.0.0\""
04:49:44:I1:WU145: Platform: win32 10
04:49:44:I1:WU145: Bits: 64
04:49:44:I1:WU145: Mode: Release
04:49:44:I1:WU145:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
04:49:44:I1:WU145: <peastman@stanford.edu>
04:49:44:I1:WU145: Args: -dir H_LCxvPl4S9gd2ocSxrHaFdmTd3Lq1pI-Fxo06IK5WQ -suffix 01
04:49:44:I1:WU145: -version 8.4.9 -lifeline 1680 -gpu-platform cuda -gpu-vendor amd
04:49:44:I1:WU145: -opencl-platform 0 -opencl-device 0 -gpu 0
04:49:44:I1:WU145:************************************ libFAH ************************************
04:49:44:I1:WU145: Time: 08:37:55
04:49:44:I1:WU145:************************************ CBang *************************************
04:49:44:I1:WU145: Version: 1.7.2
04:49:44:I1:WU145: Org: Cauldron Development LLC
04:49:44:I1:WU145: Copyright: Cauldron Development LLC, 2003-2023
04:49:44:I1:WU145: Homepage: https://cauldrondevelopment.com/
04:49:44:I1:WU145: License: GPL 2+
04:49:44:I1:WU145: Time: 08:37:14
04:49:44:I1:WU145:************************************ System ************************************
04:49:44:I1:WU145: CPU: Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
04:49:44:I1:WU145: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
04:49:44:I1:WU145: CPUs: 24
04:49:44:I1:WU145: Memory: 31.94GiB
04:49:44:I1:WU145:Free Memory: 22.83GiB
04:49:44:I1:WU145: Threads: WINDOWS_THREADS
04:49:44:I1:WU145: OS Version: 6.2
04:49:44:I1:WU145:Has Battery: false
04:49:44:I1:WU145: On Battery: false
04:49:44:I1:WU145: UTC Offset: -7
04:49:44:I1:WU145: PID: 22856
04:49:44:I1:WU145: CWD: C:\ProgramData\FAHClient\work
04:49:44:I1:WU145: Exec: C:\ProgramData\FAHClient\cores\openmm-core-23\windows-10-64bit\release\fahcore-23-windows-10-64bit-release-8.0.3\FahCore_23.exe
04:49:44:I1:WU145:************************************ OpenMM ************************************
04:49:44:I1:WU145: Version: 8.0.0
04:49:44:I1:WU145:********************************************************************************
04:49:44:I1:WU145:Project: 16525 (Run 67, Clone 0, Gen 139)
04:49:44:I1:WU145:Digital signatures verified
04:49:44:I1:WU145:Folding@home GPU Core23 Folding@home Core
04:49:44:I1:WU145:Version 8.0.3
04:49:44:I1:WU145: Checkpoint write interval: 50000 steps (2%) [50 total]
04:49:44:I1:WU145: JSON viewer frame write interval: 25000 steps (1%) [100 total]
04:49:44:I1:WU145: XTC frame write interval: 25000 steps (1%) [100 total]
04:49:44:I1:WU145: Global context and integrator variables write interval: disabled
04:49:44:I1:WU145:There are 3 platforms available.
04:49:44:I1:WU145:Platform 0: Reference
04:49:44:I1:WU145:Platform 1: CPU
04:49:44:I1:WU145:Platform 2: OpenCL
04:49:44:I1:WU145: opencl-device 0 specified
04:51:27:I1:WU145:Attempting to create OpenCL context:
04:51:27:I1:WU145: Configuring platform OpenCL
04:52:04:I1:WU145: Using OpenCL on OpenCL platformId 0 and gpu 0
04:52:04:I1:WU145: GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
04:52:04:I1:WU145: GPU info: PlatformIndex: 0
04:52:04:I1:WU145: GPU info: Device: gfx1010:xnack-
04:52:04:I1:WU145: GPU info: DeviceIndex: 0
04:52:04:I1:WU145: GPU info: Vendor: 0x1002
04:52:04:I1:WU145: GPU info: PCI: 03:00:00
04:52:04:I1:WU145: GPU info: Compute: 2.0
04:52:04:I1:WU145: GPU info: Driver: 3628.0
04:52:04:I1:WU145: GPU info: GPU: true
04:52:06:I1:WU145:Completed 0 out of 2500000 steps (0%)
05:04:10:I1:WU145:An exception occurred at step 17067: Particle coordinate is NaN. For more information, see https://github.com/openmm/openmm/wiki/Frequently-Asked-Questions#nan
05:04:10:I1:WU145:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
05:04:10:I1:WU145:ERROR:114: Max number of attempts to resume from last checkpoint reached.
05:04:10:I1:WU145:Saving result file ..\logfile_01.txt
05:04:10:I1:WU145:Saving result file science.log
05:04:10:I1:WU145:Saving result file state.xml
05:04:27:I1:WU145:Saving result file xtcAtoms.csv.bz2
05:04:27:I1:WU145:Folding@home Core Shutdown: BAD_WORK_UNIT
05:04:32:I1:WU145:Uploading WU results
05:05:09:I1:WU145:Credited
07:23:49:I1:WU155: Copyright: 2022 foldingathome.org
07:23:49:I1:WU155: Homepage: https://foldingathome.org/
07:23:49:I1:WU155: Date: Jul 25 2024
07:23:49:I1:WU155: Time: 05:42:49
07:23:49:I1:WU155: Revision: cf9f0139862b8945a2091772770e4631aac37792
07:23:49:I1:WU155: Branch: HEAD
07:23:49:I1:WU155: Compiler: Visual C++
07:23:49:I1:WU155: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
07:23:49:I1:WU155: /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
07:23:49:I1:WU155: Platform: win32 10
07:23:49:I1:WU155: Bits: 64
07:23:49:I1:WU155: Mode: Release
07:23:49:I1:WU155:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:23:49:I1:WU155: <peastman@stanford.edu>
07:23:49:I1:WU155: Args: -dir lhDEv7iGretWp9Hzve07HQctsp07_NSu5VwLvNiQ2yU -suffix 01
07:23:49:I1:WU155: -version 8.4.9 -lifeline 1680 -gpu-platform cuda -gpu-vendor amd
07:23:49:I1:WU155: -opencl-platform 0 -opencl-device 0 -gpu 0
07:23:49:I1:WU155:************************************ libFAH ************************************
07:23:49:I1:WU155: Time: 05:23:50
07:23:49:I1:WU155: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
07:23:49:I1:WU155: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:23:49:I1:WU155:************************************ CBang *************************************
07:23:49:I1:WU155: Version: 1.7.2
07:23:49:I1:WU155: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:23:49:I1:WU155: Org: Cauldron Development LLC
07:23:49:I1:WU155: Copyright: Cauldron Development LLC, 2003-2024
07:23:49:I1:WU155: Homepage: https://cauldrondevelopment.com/
07:23:49:I1:WU155: License: LGPL-2.1-or-later
07:23:49:I1:WU155: Time: 05:22:43
07:23:49:I1:WU155: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
07:23:49:I1:WU155:************************************ System ************************************
07:23:49:I1:WU155: CPU: Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
07:23:49:I1:WU155: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
07:23:49:I1:WU155: CPUs: 24
07:23:49:I1:WU155: Memory: 31.94GiB
07:23:49:I1:WU155:Free Memory: 22.46GiB
07:23:49:I1:WU155: OS Version: 10.0
07:23:49:I1:WU155:Has Battery: false
07:23:49:I1:WU155: On Battery: false
07:23:49:I1:WU155: Hostname: Snow-PC
07:23:49:I1:WU155: UTC Offset: -7
07:23:49:I1:WU155: PID: 18572
07:23:49:I1:WU155: CWD: C:\ProgramData\FAHClient\work
07:23:49:I1:WU155: Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
07:23:49:I1:WU155:************************************ OpenMM ************************************
07:23:49:I1:WU155: Version: 8.1.1
07:23:49:I1:WU155:********************************************************************************
07:23:49:I1:WU155:Project: 18251 (Run 158, Clone 0, Gen 161)
07:23:49:I1:WU155:Digital signatures verified
07:23:49:I1:WU155:Folding@home GPU Core24 Folding@home Core
07:23:49:I1:WU155:Version 8.1.4
07:23:49:I1:WU155: Checkpoint write interval: 12500 steps (5%) [20 total]
07:23:49:I1:WU155: JSON viewer frame write interval: 2500 steps (1%) [100 total]
07:23:49:I1:WU155: XTC frame write interval: 5000 steps (2%) [50 total]
07:23:49:I1:WU155: TRR frame write interval: disabled
07:23:49:I1:WU155: Global context and integrator variables write interval: disabled
07:23:49:I1:WU155:There are 3 platforms available.
07:23:49:I1:WU155:Platform 0: Reference
07:23:49:I1:WU155:Platform 1: CPU
07:23:49:I1:WU155:Platform 2: OpenCL
07:23:49:I1:WU155: opencl-device 0 specified
07:28:24:I1:WU155:Attempting to create OpenCL context:
07:28:24:I1:WU155: Configuring platform OpenCL
07:30:06:I1:WU155: Using OpenCL on OpenCL platformId 0 and gpu 0
07:30:06:I1:WU155: GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
07:30:06:I1:WU155: GPU info: PlatformIndex: 0
07:30:06:I1:WU155: GPU info: Device: gfx1010:xnack-
07:30:06:I1:WU155: GPU info: DeviceIndex: 0
07:30:06:I1:WU155: GPU info: Vendor: 0x1002
07:30:06:I1:WU155: GPU info: PCI: 03:00:00
07:30:06:I1:WU155: GPU info: Compute: 2.0
07:30:06:I1:WU155: GPU info: Driver: 3628.0
07:30:06:I1:WU155: GPU info: GPU: true
07:30:08:I1:WU155:Completed 50000 out of 250000 steps (20%)
07:35:20:I1:WU155:Completed 52500 out of 250000 steps (21%)
07:40:26:I1:WU155:Completed 55000 out of 250000 steps (22%)
07:47:00:I1:WU155:An exception occurred at step 56038: Particle coordinate is NaN. For more information, see https://github.com/openmm/openmm/wiki/Frequently-Asked-Questions#nan
07:47:00:I1:WU155:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
07:47:00:I1:WU155:ERROR:114: Max number of attempts to resume from last checkpoint reached.
07:47:00:I1:WU155:Saving result file ..\logfile_01.txt
07:47:00:I1:WU155:Saving result file positions.xtc
07:47:00:I1:WU155:Saving result file science.log
07:47:00:I1:WU155:Saving result file state.xml.bz2
07:47:02:I1:WU155:Saving result file xtcAtoms.csv.bz2
07:47:02:I1:WU155:Folding@home Core Shutdown: BAD_WORK_UNIT
07:47:08:E :WU155:Core returned BAD_WORK_UNIT (114)
07:47:11:I1:WU155:Uploading WU results
07:48:01:I1:WU155:Credited
Post by muziqaz »
Your system, or maybe just GPU is unstable.
Those WUs which you failed, someone else finished them successfully
FAH Omega tester
vica153
Post by vica153 »
The odd part is that I didn't change anything and it went from 23 consecutive complete to 22 fails out of 24 WU.
vica153
Post by vica153 »
24 fails out of the last 27 WU.
01:13:52:I3:WU172:Started FahCore on PID 17348
01:13:53:I1:WU172:*********************** Log Started 2025-02-06T01:13:52Z ***********************
01:13:53:I1:WU172:*************************** Core24 Folding@home Core ***************************
01:13:53:I1:WU172: Core: Core24
01:13:53:I1:WU172: Type: 0x24
01:13:53:I1:WU172: Version: 8.1.4
01:13:53:I1:WU172: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:13:53:I1:WU172: Copyright: 2022 foldingathome.org
01:13:53:I1:WU172: Homepage: https://foldingathome.org/
01:13:53:I1:WU172: Date: Jul 25 2024
01:13:53:I1:WU172: Time: 05:42:49
01:13:53:I1:WU172: Revision: cf9f0139862b8945a2091772770e4631aac37792
01:13:53:I1:WU172: Branch: HEAD
01:13:53:I1:WU172: Compiler: Visual C++
01:13:53:I1:WU172: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
01:13:53:I1:WU172: /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
01:13:53:I1:WU172: Platform: win32 10
01:13:53:I1:WU172: Bits: 64
01:13:53:I1:WU172: Mode: Release
01:13:53:I1:WU172:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:13:53:I1:WU172: <peastman@stanford.edu>
01:13:53:I1:WU172: Args: -dir EQvz6Am86sMwnKgigQ7n3AYJknR14Caz97l7TTPNv68 -suffix 01
01:13:53:I1:WU172: -version 8.4.9 -lifeline 8804 -gpu-platform cuda -gpu-vendor amd
01:13:53:I1:WU172: -opencl-platform 0 -opencl-device 0 -gpu 0
01:13:53:I1:WU172:************************************ libFAH ************************************
01:13:53:I1:WU172: Time: 05:23:50
01:13:53:I1:WU172: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
01:13:53:I1:WU172: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:13:53:I1:WU172:************************************ CBang *************************************
01:13:53:I1:WU172: Version: 1.7.2
01:13:53:I1:WU172: Org: Cauldron Development LLC
01:13:53:I1:WU172: Copyright: Cauldron Development LLC, 2003-2024
01:13:53:I1:WU172: Homepage: https://cauldrondevelopment.com/
01:13:53:I1:WU172: License: LGPL-2.1-or-later
01:13:53:I1:WU172: Time: 05:22:43
01:13:53:I1:WU172: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
01:13:53:I1:WU172:************************************ System ************************************
01:13:53:I1:WU172: CPU: Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
01:13:53:I1:WU172: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
01:13:53:I1:WU172: CPUs: 24
01:13:53:I1:WU172: Memory: 31.94GiB
01:13:53:I1:WU172:Free Memory: 22.88GiB
01:13:53:I1:WU172: OS Version: 10.0
01:13:53:I1:WU172:Has Battery: false
01:13:53:I1:WU172: On Battery: false
01:13:53:I1:WU172: Hostname: Snow-PC
01:13:53:I1:WU172: UTC Offset: -7
01:13:53:I1:WU172: PID: 17348
01:13:53:I1:WU172: CWD: C:\ProgramData\FAHClient\work
01:13:53:I1:WU172: Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
01:13:53:I1:WU172:************************************ OpenMM ************************************
01:13:53:I1:WU172: Version: 8.1.1
01:13:53:I1:WU172:********************************************************************************
01:13:53:I1:WU172:Project: 18238 (Run 1151, Clone 3, Gen 23)
01:13:53:I1:WU172:Digital signatures verified
01:13:53:I1:WU172:Folding@home GPU Core24 Folding@home Core
01:13:53:I1:WU172:Version 8.1.4
01:13:53:I1:WU172: Checkpoint write interval: 50000 steps (2%) [50 total]
01:13:53:I1:WU172: JSON viewer frame write interval: 25000 steps (1%) [100 total]
01:13:53:I1:WU172: XTC frame write interval: 10000 steps (0.4%) [250 total]
01:13:53:I1:WU172: TRR frame write interval: disabled
01:13:53:I1:WU172: Global context and integrator variables write interval: disabled
01:13:53:I1:WU172:There are 3 platforms available.
01:13:53:I1:WU172:Platform 0: Reference
01:13:53:I1:WU172:Platform 1: CPU
01:13:53:I1:WU172:Platform 2: OpenCL
01:13:53:I1:WU172: opencl-device 0 specified
01:14:11:I1:WU172:Attempting to create OpenCL context:
01:14:11:I1:WU172: Configuring platform OpenCL
01:14:37:I1:WU172: Using OpenCL on OpenCL platformId 0 and gpu 0
01:14:37:I1:WU172: GPU info: Platform: OpenCL: AMD Accelerated Parallel Processing
01:14:37:I1:WU172: GPU info: PlatformIndex: 0
01:14:37:I1:WU172: GPU info: Device: gfx1010:xnack-
01:14:37:I1:WU172: GPU info: DeviceIndex: 0
01:14:37:I1:WU172: GPU info: Vendor: 0x1002
01:14:37:I1:WU172: GPU info: PCI: 03:00:00
01:14:37:I1:WU172: GPU info: Compute: 2.0
01:14:37:I1:WU172: GPU info: Driver: 3628.0
01:14:37:I1:WU172: GPU info: GPU: true
01:14:37:I1:WU172:Completed 600000 out of 2500000 steps (24%)
01:22:33:I1:WU172:Completed 625000 out of 2500000 steps (25%)
01:25:06:I1:WU172:An exception occurred at step 633001: Particle coordinate is NaN. For more information, see https://github.com/openmm/openmm/wiki/Frequently-Asked-Questions#nan
01:25:06:I1:WU172:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
01:25:06:I1:WU172:ERROR:114: Max number of attempts to resume from last checkpoint reached.
01:25:06:I1:WU172:Saving result file ..\logfile_01.txt
01:25:06:I1:WU172:Saving result file positions.xtc
01:25:06:I1:WU172:Saving result file science.log
01:25:06:I1:WU172:Saving result file state.xml.bz2
01:25:06:I1:WU172:Saving result file xtcAtoms.csv.bz2
01:25:06:I1:WU172:Folding@home Core Shutdown: BAD_WORK_UNIT
01:25:07:E :WU172:Core returned BAD_WORK_UNIT (114)
01:25:07:I1:WU172:Uploading WU results
01:25:13:I1:WU172:Credited
Post by muziqaz »
Your GPU (or other components) is unstable, please stop folding and make sure your system is 100% stable
FAH Omega tester
Post by muziqaz »
What driver are you running? Is it from AMD website or from Microsoft. Please update to the latest driver from AMD website
FAH Omega tester
vica153
Post by vica153 »
Yep all the latest drivers. My 5700XT is watercooled and underclocked so it can run all day at 100% and hardly get above 50C. Stable should be the one thing it does well at this point.
Also it doesn't explain how it could be unstable for a few days, then perfectly stable for 5 days straight, and then back to unstable when nothing about the setup has changed.
Post by muziqaz »
It only takes one workload to trip something on your GPU.
I'm not aware of factory water cooled 5700xt, so I take it you done it yourself?
Quite often DYI water-cooling block installation can have negative affects, since sometimes some parts of the GPU is not getting enough cooling, and some parts of the card are not getting enough cooling. Like memory chips or VRMs.
Plus, underclocking has same risks as overclocking
FAH Omega tester
vica153
Post by vica153 »
The waterblock has pads for the VRMs. I can overclock the GPU and game for hours with double the power going thru the GPU without any heat issues. Your points all a decent guesses at possibilities, but the fact that the setup ran perfectly fine for 5 days straight without issue would seem to indicate that the setup is capable of being stable and the GPU isn't getting too hot.
Is there a way to pinpoint the cause of the instability?
Post by muziqaz »
Heat is not indication of instability ;)
FAH Omega tester
vica153
Post by vica153 »
muziqaz wrote: Thu Feb 06, 2025 5:24 pm Heat is not indication of instability ;)
? I didn't say it was. High loads and temperatures are often the cause of instability and I was simply explaining that neither of these are an issue with my setup. The fact there is a stability issue is obvious. I'm trying to figure out what the cause is. Other than F@H being unhappy, there are no other indications of instability.
