Details under machine not visible
kitsched
Post by kitsched »
Hello,
I have FAH installed on both my gaming machine and on a Linux NAS, the clients are working correctly but I can't see the details about the progress on the Machines page ( https://v8-4.foldingathome.org/machines ) which looks something like this:
The Work Units page looks fine:
I know I should be seeing something under each machine's name on the homepage because I saw them for a short while after installing, then they disapeared. Also the buttons on the right of the empty line for logs, info and viewing the protein work fine.
Help appreciated.
kitsched
Re: Details under machine not visible
Post by kitsched »
I have tried multiple browsers:
- Firefox and Chrome under Windows
- Safari and Chrome under Mac
None show the details.
daiko
Hardware configuration: Mac Studio M1 Max
Mac Mini M4 Pro
M2 Macbook Air
Folding since 2005
Post by daiko »
Have you tried clicking your Account icon on the upper right and then choosing the Appearance tab — you should be able to customize your view for your Machines browser page there, though it’s odd that you didn’t get the default view for starters.
USAFSS
Hardware configuration: MacBook Air M3 Mac OS
MacBook Air Intel(R) i7-5650U Mac OS
MacBook Air Intel(R) i5-5250U Linux
MacBook Air Intel(R) i5-4250U Linux
Post by USAFSS »
I'm seeing the same issue with v8.4.9 on a MacBook Air with a M3 chip running macOS 15.2. Everything was fine, including running "Dark mode", when I noticed that "Dark mode" box wasn't checked. Once it was checked that's when details went blank. This happened a couple of weeks ago but I've had very little web access. Currently out of town, but I'll check my other Mac (Intel Chip) and two Linux systems (MacBook Air laptops running Mint Linux) to see if I can duplicate the issue.
FTW
Post by FTW »
Press F12 and you'll see the problem.
downloadable font: Glyph bbox was incorrect (glyph ids 33 55 62 81 82 83 84 87 88 89 90 112 119 120 123 139 159 162 164 166 178 184 185 217 218 272 273 274 275 279 281 284 290 291 292 309 310 319 321 323 326 329 330 331 332 333 334 339 341 347 349 351 352 353 354 357 358 361 366 367 370 371 414 431 436 444 445 458 460 464 465 483 505 508 511 514 516 517 518 520 521 538 539 546 568 574 579 580 585 586 594 596 599 602 603 616 618 622 627 629 630 633 634 638 643 645 651 654 665 675 685 686 688 691) (font-family: "FontAwesome" style:normal weight:400 stretch:100 src index:1) source: https://v8-4.foldingathome.org/fonts/fo ... f2?v=4.7.0
kitsched
Post by kitsched »
daiko wrote: Mon Jan 20, 2025 4:39 pm Have you tried clicking your Account icon on the upper right and then choosing the Appearance tab — you should be able to customize your view for your Machines browser page there, though it’s odd that you didn’t get the default view for starters.
Oh boy, I feel stupid now. It took me a while to understand that that row with the recycling sign shouldn't be empty...
All is well that ends well:
Thanks for your responses!
USAFSS
Post by USAFSS »
I also feel stupid!! I did notice that the recycle sign line was empty, pressed the button and it repopulated. But that didn't fix anytime but I seem to have forgot to hit Save first :oops:. Like kitsched said everything is find now. My question / concern is how did the recycle sign line loose its settings in the first place?
vica153
Post by vica153 »
I definitely didn't just make the same silly mistake.
