How to select preferred 'cause' to work on?
Just switched to 8.4.9. Seems to be working. I don't see any spot select preferred 'cause' type to work on? Is that no longer an option?
Re: How to select preferred 'cause' to work on?
Hi,
click on your avatar icon on the right top corner of the page, and you should be able to select the cause.
Or if you don’t log in, click the gear to edit machine settings.
Thanks. I found the 'cause' option in the account settings by clicking on the avatar in the upper right. No luck under machine settings. Though I may be blind.
You’re not blind.
Linked machines use account settings.
