New GPUs RTX 5000 series
kiore
Post by kiore »
OK I am impatient and intrigued, is anyone using or trying to use any of the newly released NVidia GPUs?
Stories please.
Re: New GPUs RTX 5000 series
RTX 5090 is in GPUs.txt file. We should get some numbers as soon as people are allowed to talk about its performance.
Mxyzptlk
Hardware configuration: Lots... Look at my website: www.mxyzptlk.us
Post by Mxyzptlk »
Waiting to hear something myself...
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Someone in the discord channel is waiting to pick up a 5090 on the 8th.... So I will assume we will probably hear something at least by the 9th. :mrgreen:
Fold them if you get them!
Breach
Post by Breach »
As apparently an incredibly lucky new owner, I am willing to talk ASAP, but for some reason FAH does not boost. So I'm looking at 5,288,988 at 630Mhz base clock...
Post by muziqaz »
Switch off any power saving things. There is some nonsense setting in Nvidia control panel
FAH Omega tester
Breach
Post by Breach »
muziqaz wrote: Fri Jan 31, 2025 7:30 pm Switch off any power saving things. There is some nonsense setting in Nvidia control panel
Thanks. That and a reboot fixed it. There you go, all stock:
https://imgur.com/a/rxSTmKd
https://imgur.com/a/owotMlD
Looks quite decent, actually. Given that my 4090 was doing less than 30m PPD.
enroscado
Post by enroscado »
Wow, that's some power...
I wonder what it will crunch on Ubuntu/Linux.
Breach
Post by Breach »
Probably 60mil ppd+? Then again it depends on project. And yeah, it's literally "some power" :-) Not sure I'm willing to stand the fan noise and pay 600 watts / hour :-)
favrepeoria
Post by favrepeoria »
Curious what it would do if you started power limiting. I normally end up being at 70-80% power limit and only lose like 5% off the max performance.
cloud7896
Post by cloud7896 »
Breach wrote: Fri Jan 31, 2025 7:52 pm
Hi, which things are switch off in Nvidia control panel ? Is there any screenshot of configuration in Nvidia control panel ?
Breach
Post by Breach »
See here, but strangely enough I don't need it now...? Maybe I was missing a reboot after driver installation.
https://imgur.com/a/kARRG5k
Breach
Post by Breach »
favrepeoria wrote: Sat Feb 01, 2025 4:37 pm Curious what it would do if you started power limiting. I normally end up being at 70-80% power limit and only lose like 5% off the max performance.
Granted, I only waited a couple of frames, so not definitive, but at least it looks like performance doesn't drop drastically with a lower power limit:
p16525
Power limit:
104%: 57,781,649
90%: 57,220,001
80%: 56,768,219
EDIT: And just hit a new record with 104% power limit and an overclock: p16525, 65,694,141 PPD, 1m 08 s TPF. Unfortunately, most other projects can't fully utilise the card.
Mxyzptlk
Post by Mxyzptlk »
That's pretty darn fast... At most I'll only have a 5080, but I'll wait to see some of those numbers before I pull the trigger.
kiore
Post by kiore »
OK well that pretty impressive, not sure I am in the market for one of these yet but well done those who have them.
