Core26 released to full FAH ?
Nicolas_orleans
Post by Nicolas_orleans »
Hello
I just noticed one of my rig downloaded a new core, Core26, for a 17650 work unit that used to be folding under Core 23. Except the very obvious change from OpenMM 8.0.0 to OpenMM 8.2.0 between those 2 cores, anything else we should know ? Notably, can a trajectory / PRCG mix Core23 and Core26 results ?
20:16:50:I1:WU1087:*********************** Log Started 2025-01-15T20:16:49Z ***********************
20:16:50:I1:WU1087:*************************** Core26 Folding@home Core ***************************
20:16:50:I1:WU1087: Core: Core26
20:16:50:I1:WU1087: Type: 0x26
20:16:50:I1:WU1087: Version: 8.2.0
20:16:50:I1:WU1087: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:16:50:I1:WU1087: Copyright: 2022 foldingathome.org
20:16:50:I1:WU1087: Homepage: https://foldingathome.org/
20:16:50:I1:WU1087: Date: Jan 7 2025
20:16:50:I1:WU1087: Time: 00:35:47
20:16:50:I1:WU1087: Revision: 4f149b599caa4725076ef2de3b47c8d7ce725787
20:16:50:I1:WU1087: Branch: HEAD
20:16:50:I1:WU1087: Compiler: GNU 7.5.0
20:16:50:I1:WU1087: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
20:16:50:I1:WU1087: -fdata-sections -O3 -funroll-loops -fno-pie
20:16:50:I1:WU1087: -DOPENMM_VERSION="\"8.2.0\""
20:16:50:I1:WU1087: Platform: linux 6.8.0-1017-azure
20:16:50:I1:WU1087: Bits: 64
20:16:50:I1:WU1087: Mode: Release
20:16:50:I1:WU1087:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:16:50:I1:WU1087: <peastman@stanford.edu>
20:16:50:I1:WU1087: Args: -dir CeddI94gO-bI8Ageq9jJUp8DuZbjA1qwPSg2bOEixZc -suffix 01
20:16:50:I1:WU1087: -version 8.3.18 -lifeline 1367 -gpu-vendor nvidia -opencl-platform
20:16:50:I1:WU1087: 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
20:16:50:I1:WU1087:************************************ libFAH ************************************
20:16:50:I1:WU1087: Time: 00:29:24
20:16:50:I1:WU1087: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
20:16:50:I1:WU1087: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
20:16:50:I1:WU1087:************************************ CBang *************************************
20:16:50:I1:WU1087: Version: 1.7.2
20:16:50:I1:WU1087: Org: Cauldron Development LLC
20:16:50:I1:WU1087: Copyright: Cauldron Development LLC, 2003-2024
20:16:50:I1:WU1087: Homepage: https://cauldrondevelopment.com/
20:16:50:I1:WU1087: License: LGPL-2.1-or-later
20:16:50:I1:WU1087: Time: 00:28:59
20:16:50:I1:WU1087: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
20:16:50:I1:WU1087: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
20:16:50:I1:WU1087:************************************ System ************************************
20:16:50:I1:WU1087: CPU: Intel(R) Core(TM) i5-3550 CPU @ 3.30GHz
20:16:50:I1:WU1087: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
20:16:50:I1:WU1087: CPUs: 4
20:16:50:I1:WU1087: Memory: 15.57GiB
20:16:50:I1:WU1087:Free Memory: 7.40GiB
20:16:50:I1:WU1087: OS Version: 6.8
20:16:50:I1:WU1087:Has Battery: false
20:16:50:I1:WU1087: On Battery: false
20:16:50:I1:WU1087: Hostname: amandine-MS-7751
20:16:50:I1:WU1087: UTC Offset: 1
20:16:50:I1:WU1087: PID: 189217
20:16:50:I1:WU1087: CWD: /var/lib/fah-client/work
20:16:50:I1:WU1087: Exec: /var/lib/fah-client/cores/openmm-core-26/centos-7.9.2009-64bit/release/fahcore-26-centos-7.9.2009-64bit-release-8.2.0/FahCore_26
20:16:50:I1:WU1087:************************************ OpenMM ************************************
20:16:50:I1:WU1087:********************************************************************************
20:16:50:I1:WU1087:Project: 17650 (Run 51, Clone 1, Gen 409)
20:16:50:I1:WU1087:Reading tar file core.xml
20:16:50:I1:WU1087:Reading tar file integrator.xml.bz2
20:16:50:I1:WU1087:Reading tar file state.xml.bz2
20:16:50:I1:WU1087:Reading tar file system.xml.bz2
20:16:50:I1:WU1087:Digital signatures verified
20:16:50:I1:WU1087:Folding@home GPU Core26 Folding@home Core
20:16:50:I1:WU1087:Version 8.2
I was more expected a Core24 update due to the communication issues between FAH core and client (information from Justin in one thread in this forum), any news on that ? I still see errors only with P18237 with attempts after a free energy error to resume calculations from last valid checkpoint, when no attempt appears to be actually made based on logs ?
Thanks and best regards
Nicolas
AORUS Elite X AX B650E- Ryzen 9 9950X - Inno3D RTX 5080 - Ubuntu 25.04 - 6.14 kernel - 580.95
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super - Ubuntu 25.04 - 6.14 kernel - 580.95
Nicolas_orleans
Re: Core26 released to full FAH ?
Hello
Complement on OpenMM 8.2.0 based on GitHub. I saw no material difference for my Nvidia card compared to Core23, but it could make a difference for recent AMD cards performance / PPD ?
OpenMM 8.2.0
This release is a major update with a focus on improving performance.
For the first time in many years, this release introduces a new platform. It is based on AMD's HIP framework. When running on recent AMD GPUs, it delivers roughly double performance compared to the OpenCL platform. [...]
source: https://github.com/openmm/openmm/releases
Best regards
Nicolas
prcowley
Hardware configuration: Op Sys: Linux Ubuntu Studio 25.04
Kernel: 6.14.0-34-generic (64-bit)
Processor: AMD Ryzen 7 7800X3D 8-Core Processor
Mem: 32 GB
GPU: NVIDIA GeForce RTX 4080 SUPER/PCIe/SSE2
Post by prcowley »
In reading this thread about core 26, I went and had a look to see if I have received any.
Yep, I have been processing some core26 projects for a couple of days.
The main thing I noticed is how short the TPF time is (project 17652) - just 8 seconds or there about. Processing a medium sized project of 40,00 atoms took just 17 minutes on a NIVIDIA 4080 super GPU.
What I found interesting though was that before my successful work unit were multiple failures from other folders. Maybe there needed to be some tweaks to the projects to get them to tun successfully.
Cheers
Pete
Pete Cowley, Gisborne, New Zealand. The first city to see the light of the new day. :D
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Per ToTow on the Discord channel, HIP support is not yet included in the Core 26 release. I sort of assumed that was the case, since none of the AMD crowd was speaking of the performance increases.
I also go the core update, but really paid to attention to it. It might be worth watching to see if there is any performance improvement with the core either way.
Fold them if you get them!
Post by muziqaz »
We are still assessing if there is any performance increase. Core26 in its current incarnation was not targeting performance increase, main target was core errors and possibility to do more variations of "science".
FAH Omega tester
Post by muziqaz »
Core24 p18251 - Radeon VII (Windows) - crash
Core26 p18252 - Radeon VII (Windows) - 2m8s
Core24 p18251 - 6900XT (Linux) - 3m0s
Core26 p18252 - 6900XT (Linux) - 1m50s
FAH Omega tester
The core is not ready for full FAH yet. There has been a few batches released to FAH to test the error rate compared to core 24.
Please report any errors related to core 26 you might have encountered.
boboviz
Hardware configuration: Radeon RX6400
Post by boboviz »
muziqaz wrote: Fri Jan 17, 2025 10:42 pm We are still assessing if there is any performance increase. Core26 in its current incarnation was not targeting performance increase, main target was core errors and possibility to do more variations of "science".
No problem. We will wait Core27 for HIP.....and performance increase on AMD gpu :D
Post by muziqaz »
I hope there is not gonna be another core. I'm getting a headache already with all the different iterations as is
FAH Omega tester
C-A
Post by C-A »
I only have a few, none since probably 1/17. Only log entry I have is 17652, TPF 14s for an RTX 4070. I think this is the one work unit that made my coils really scream, a lot more than usual. :shock:
Kjetil
Post by Kjetil »
5,8 mill on 4090?
prcowley
Mem: 32 GB
Post by prcowley »
Well here we are near the end of April. I see from the F&H Server stats (https://apps.foldingathome.org/serverstats) that core 26 has some public and some beta jobs however I have never received one. Is there some special criteria for these to be chosen?
I have a Nividia 4080 super running on Ubuntu 24.10 - is it excluded or it it just a case of randomly not getting any LOL
Cheers
Pete
Post by muziqaz »
Don't worry about it. It will be superseded by core27 soon. Core26 had issues
FAH Omega tester
arisu
Post by arisu »
What issues was core26 having? I've never experienced any issues with it on Nvidia with OpenCL, Nvidia with CUDA, or AMD with OpenCL.
Post by muziqaz »
arisu wrote: Wed Apr 23, 2025 4:42 am What issues was core26 having? I've never experienced any issues with it on Nvidia with OpenCL, Nvidia with CUDA, or AMD with OpenCL.
Not seeing CUDA on certain OS hardware combinations.
Core folds on CPU if Intel GPU is present.
Core fails on certain AMD hardware scenarios.
No HIP (not an issue, but a ticket to mental institution for certain individual :D )
Core27 still has intel issue and still has no HIP
FAH Omega tester
