Enterprise Support?
BeardMonster
Enterprise Support?
Post by BeardMonster »
Hey all,
I recently found the Folding @ Home project and I'd like to contribute in a more meaningful way.
I'm a Sys Admin for a library system and we have about 800 PCs that are mostly idle day/night.
I have a few questions about and concerns about implementation & management at such a large scale.
Enterprise Support:
Is there any official enterprise-level support for the app? I’m considering proposing this initiative to our Board of Commissioners, as it would not only help the cause but also be great for public relations.
Deployment and Management:
We use MECM (Microsoft Endpoint Configuration Manager) for managing and imaging our machines. While I can easily deploy MSI installers, I noticed the app is an EXE. Is there a way to install and configure it silently via command line for mass deployment?
Proposal Examples:
Has anyone here successfully pitched this project to their organization or board? If you have any templates, documents, or tips, I’d appreciate your insight. Otherwise, I’ll be building a proposal from scratch, and I want to ensure it’s as compelling as possible.
If this post would be better suited for a different board here, please let me know.
Thanks in advance!
Re: Enterprise Support?
I don't know of any official enterprise level support. There has been some work in the past to create containers for deploying on servers, I am not current on that development progress. Also during expansion for COVID in the Spring of 2020 there was some discussion here and as I understand on the F@h discord about how to deploy the client across multiple systems such as at an institution like a school or in your case a library.
Some issues to keep in mind:
The client installs can all use the same username and passkey. The passkey can also be used with more than one username if you want to distiguish between groups of systems.
The client will usually need to be installed separately on each system. However if you do system installs on your systems by creating an image that you clone to each machine, the F@h client can be installed as long as that image doesn't connect to the internet. The first time the client runs and connects to the F@h servers it downloads the updated GPUs list and gets a unique ID assigned.
For the v7 client there are command line options to configure the client. They are not heavily documented here or on the F@h support pages. Most documentation is through the built in help, fahclient --help on the command line. The running client can also be connected with using local telnet on the command line - telnet 127.0.0.1 36330. Either way can be used to start and stop folding as well. The FAHcontrol portion of the install can also be configured to monitor and control multiple systems remotely.
The v7 client is considered obsolete, the last update was a bit over 4 years ago. The current public release is v8.4.9. The web based control for it can be used remotely and monitor and control multiple systems. I don't know if there are any specific limits on how many systems, but it could get tedious scrolling through a long web page for more than a few dozen systems. V8 does not have telnet access, and I am not too familiar with command line options yet.
Post by calxalot »
I believe v8 will detect a change of hardware id and generate a new fah id for the client. I expect this would make mass installation less error prone.
I
BeardMonster
Thanks Joe, I definately did not post this in the right forum. With the busy-ness of work I posted in the forum that didn't say beta on it. The client I downloaded is 8.4.9. I tried the --help on the installer and it just started it up. The FAHClient.exe did produce results. Though I don't think that's going to be helpful.
I might just setup a system and see what changes are made to it, then replicate those changes via script. I did already figure out that the client.db holds the username and passkey. I was able to copy over a generic client.db with that info in it after install (before startup) and it did connect to the web console.
Anyway, I will check out the Discord when I circle back around to this. :) Thanks
Well they just moved the v8.4.9 version from beta to being the pubic release. My understanding is the developer is going to start on a v8.5 version that may get released for beta testing sometime in the future. But that is the future, and no guarantees on when it might happen. In any case I created the forum for the public release of v8.4.9 about an hour after you posted your initial questions, so it still showed as beta before that. I have to populate that forum with some of the standard info still though. So in any case it wasn't there for you to see when you posted.
One note that may also be useful when deploying to multiple systems, the v8 client will read from a v7 style config.xml file as well at startup. However the v8 client will not write to it or modify the config.xml. Not all settings carry over, but the .xml is a bit easier to read or modify if done carefully. A subset of XML is used for the v7 client. It also remains the only way to import a few settings, but those are probably more advanced than you will need to deal with.
BeardMonster wrote: Wed Jan 15, 2025 7:31 pm I'm a Sys Admin for a library system and we have about 800 PCs that are mostly idle day/night.
Just make sure that everyone is aware of the increased power draw of a fully loaded PC and of the associated costs.
