Noticed that half the times i start the computer after pressing pause (then waiting until it seems to have paused) then pressing finish (waiting for it to seemingly finish) then shutting down the computer.
When starting up again it seems to half the times start over at 0% when it was at like 25% 40% 70% or whatever work was done the day before.
This is the part of the logfile making me think something goes wrong, and i really dont know what to do to not cause problems.
Any ideas?
I'll place ********* before lines that i think is important
Noticed that one line says "-service", i have no intention to have it installed as a service, does this mean that i might be running it as a service and then i also start it as an application? am i then running it twice?
The CPU utilization make me think it is run once, but the "-service" make me think i might be wrong.
08:58:43:WU00:FS00:0xa8:ERROR:Guru Meditation #81f003ca05301cf9.7e9929a13bd116e4 (956986.957306) '00/01/dhdl.xvg'
*********08:58:45:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
08:58:45:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
*********08:58:45:WARNING:WU00:FS00:Too many errors, failing
08:58:45:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:12422 run:48 clone:3 gen:67 core:0xa8 unit:0x43000000030000003000000086300000
08:58:45:WU00:FS00:Connecting to 129.32.209.203:8080
08:58:45:WU01:FS00:Connecting to assign1.foldingathome.org:80
08:58:46:WU00:FS00:Server responded WORK_ACK (400)
08:58:46:WU00:FS00:Cleaning up
08:58:47:WU01:FS00:Assigned to work server 129.32.209.203
08:58:47:WU01:FS00:Requesting new work unit for slot 00: cpu:24 from 129.32.209.203
08:58:47:WU01:FS00:Connecting to 129.32.209.203:8080
08:58:48:WU01:FS00:Downloading 3.52MiB
08:58:54:WU01:FS00:Download 92.38%
08:58:54:WU01:FS00:Download complete
08:58:54:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12422 run:54 clone:5 gen:34 core:0xa8 unit:0x22000000050000003600000086300000
08:58:54:WU01:FS00:Starting
08:58:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" *********C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 3572 -checkpoint 15 -np 24 -service
08:58:54:WU01:FS00:Started FahCore on PID 1968
Client starting over the day after half the times i start up again
Re: Client starting over the day after half the times i start up again
The core -service flag is normal, and is
Ignore user logout or hangup and interrupt signals
On Windows, it is safest to quit the client before logout or shutdown/restart.
Use sys tray F@h Quit menu item.
The core crash you posted isn't something I know anything about.
