Error continues to appear on the client even after being fixed
g_moreno
Post by g_moreno »
When an error occurs, I pause the client and remove the process that is stuck and start it again, but the processes in error that have already been deleted continue to be shown, polluting the view.
https://prnt.sc/5zl8AnvhMEX6
https://prnt.sc/PehVIjpD1QYf
And also in this new version 8-4 the status information is not loaded in the browser, however I can see it using the version 8-3 link and modify it normally. And Thank you for fixing numerous bugs that are no longer occurring in this beta version.
https://prnt.sc/xXY94nWYBxY4
enroscado
Re: Error continues to appear on the client even after being fixed
Post by enroscado »
I am having the same issue, has been going on for a week now.
https://prnt.sc/LHJE0IoyCW_4
Post by calxalot »
A workaround to try is to create separate resource groups for cpus and each gpu.
Creating groups is explained in the user guide linked to on the download page.
You should set Finish and disable gpus in default group when they are done.
Post by calxalot »
Check web browser javascript console for errors when viewing blank stats tab.
Post by calxalot »
I'm not familiar with the Warning tag. I know it was added recently.
It might indicate that a WU is not expected to finish before deadline.
