One or more folding processes have failed
Hume Family
Post by Hume Family »
New User - doing what I can because a family member has Huntingtons.
Just downloaded. Seems to be working (Windows 11) but in the hidden icons box on the system tray there is a message attached to the F@H icon which says "One or more folding processes have failed"
Help please.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: One or more folding processes have failed
Post by BobWilliams757 »
It would be helpful if you let us know what your OS is and which version of the folding software you are using.
That said, I have never seen such a message on 7.6.xx, so I'll assume it's one of the new beta versions. Most likely you had some type of issue and it crashed either CPU or GPU folding, if both were running. If your progess bar is still showing activity, likely something IS still running. It might best be to let it run until one of the members more familiar with the beta versions steps in to help you out. I currently am not running any of the beta software. I could help if you were running the 7.6.xx version, but I don't want to risk giving you bad scoop on the beta stuff.
Fold them if you get them!
Post by calxalot »
I believe it’s just a bug in the windows client. Errors aren’t cleared. Probably ok. Just check log for problems.
Post by calxalot »
If you’re using v8, you might want to upgrade to beta v8.4.9
Hume Family
Thanks for the replies.
I'm using fah-client_8.3.18_AMD64 for Windows. Downloaded it yesterday.
The main screen shows 3 CPUs running 18240 and the GPU requesting work.
