Missing stats
Ježko
Missing stats
Post by Ježko »
Hello,
it's been almost 2 days since I started folding but no stats appear on the stats page of the control app. I also cannot find myself in the donor list. I've used a username with a non 'english' character ž in my username, could that be the problem? Can I change my username or do I have to create a new account if this is the case?
Account registration went ok, I confirmed the mail and even setup a passkey. I have completed several WUs, I should have few milion points by now(judging from the estimate).
Username: Ježko
Thanks.
Re: Missing stats
It is possible that there is a problem using that non-English character, but the stats database usually can handle most character sets. It would help if you could post the beginning section, ~100 lines or so, of the log file which will show the hardware and software configuration of the client. Also a section showing a WU download and return. The stats database can also be queried by you for specific WUs returned, and that would show how the username was entered into the database. That query can be found here - https://apps.foldingathome.org/wu.
Ježko
Re: Missing stats
Post by Ježko »
The link that you provided showed me as an Anonymous for this project from the logs.
Here is the log:
*********************** Log Started 2025-01-05T22:09:21Z ***********************
22:09:21:I1:*********************** Folding@home Client ***********************
22:09:21:I1:    Version: 8.3.18
22:09:21:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:09:21:I1:        Org: foldingathome.org
22:09:21:I1:  Copyright: 2023-2024, foldingathome.org
22:09:21:I1:   Homepage: https://foldingathome.org/
22:09:21:I1:    License: GPL-3.0-or-later
22:09:21:I1:        URL: https://v8-3.foldingathome.org/
22:09:21:I1:       Date: Jul 12 2024
22:09:21:I1:       Time: 13:26:51
22:09:21:I1:   Revision: 99ae953ee7b1c0b3070161cfcf9150184f76bd96
22:09:21:I1:     Branch: master
22:09:21:I1:   Compiler: Visual C++
22:09:21:I1:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
22:09:21:I1:             /Zc:throwingNew /MT
22:09:21:I1:   Platform: win32 10
22:09:21:I1:       Bits: 64
22:09:21:I1:       Mode: Release
22:09:21:I1:       Args: --open-web-control
22:09:21:I1:****************************** CBang ******************************
22:09:21:I1:    Version: 1.7.2
22:09:21:I1:        Org: Cauldron Development
22:09:21:I1:  Copyright: Cauldron Development, 2003-2024
22:09:21:I1:   Homepage: https://cauldrondevelopment.com/
22:09:21:I1:    License: LGPL-2.1-or-later
22:09:21:I1:       Date: Jun 24 2024
22:09:21:I1:       Time: 13:29:54
22:09:21:I1:   Revision: 1b05ea96f0ed3043c32b78a66dbf50a9b2002289
22:09:21:I1:***************************** System ******************************
22:09:21:I1:        CPU: AMD Ryzen 5 7500F 6-Core Processor
22:09:21:I1:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
22:09:21:I1:       CPUs: 12
22:09:21:I1:     Memory: 31.60GiB
22:09:21:I1:Free Memory: 24.50GiB
22:09:21:I1: OS Version: 6.2
22:09:21:I1:Has Battery: false
22:09:21:I1: On Battery: false
22:09:21:I1:   Hostname: Jezek
22:09:21:I1: UTC Offset: 1
22:09:21:I1:        PID: 13560
22:09:21:I1:        CWD: C:\ProgramData\FAHClient
22:09:21:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
22:09:21:I1:*******************************************************************
22:09:21:I2:<config/>
22:09:21:I1:Opening Database
22:09:21:I1:F@H ID = zHHfMsAJIGpTVbjtPGkKslqir215aixGGmWr8bPu5F4
22:09:21:I3:Loading default group
22:09:21:I3:Loading default resource group
22:09:21:I1:Listening for HTTP on 127.0.0.1:7396
22:09:21:I3:Loaded 0 wus.
22:09:21:I1:Started Windows systray control
22:09:21:I3:gpus = {
22:09:21:I3:  "gpu:01:00:00": {
22:09:21:I3:    "vendor": 4318,
22:09:21:I3:    "type": "nvidia",
22:09:21:I3:    "description": "NVIDIA GeForce RTX 4070",
22:09:21:I3:    "uuid": "70cba6cc-e0f0-305f-83c8-ea24d606125f",
22:09:21:I3:    "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "566.36"},
22:09:21:I3:    "cuda": {"platform": 0, "device": 0, "compute": "8.9", "driver": "12.7"},
22:09:21:I3:    "device": 10118,
22:09:21:I3:    "supported": true
22:09:21:I3:  }
22:09:21:I3:}
22:09:21:I1:OUT1:> GET https://api.foldingathome.org/machine/zHHfMsAJIGpTVbjtPGkKslqir215aixGGmWr8bPu5F4 HTTP/1.1
22:09:21:I1:OUT1:< HTTP/1.1 200 HTTP_OK
22:09:22:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
22:09:22:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
22:09:22:I1:Logging into node account
22:09:22:I1:Default:Added new work unit: cpus:1 gpus:gpu:01:00:00
22:09:22:I1:WU13:Requesting WU assignment for user Ježko team 249477
22:09:22:I1:OUT4:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
22:09:23:I1:OUT4:< HTTP/1.1 200 HTTP_OK
22:09:23:I1:WU13:Received WU assignment QIDLPPb2gchd7KEuYwGL92V7E3Hu__tZ1OZxR23PJpE
22:09:23:I1:WU13:Downloading WU
22:09:23:I1:OUT5:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
22:09:25:I1:OUT5:< HTTP/1.1 200 HTTP_OK
22:09:25:I1:WU13:Received WU P18236 R890 C3 G77
22:09:25:I1:Loaded cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe
22:09:25:I3:WU13:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe -dir QIDLPPb2gchd7KEuYwGL92V7E3Hu__tZ1OZxR23PJpE -suffix 01 -version 8.3.18 -lifeline 13560 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
22:09:25:I3:WU13:Started FahCore on PID 2948
22:09:25:I1:WU13:*********************** Log Started 2025-01-05T22:09:25Z ***********************
22:09:25:I1:WU13:*************************** Core24 Folding@home Core ***************************
22:09:25:I1:WU13:       Core: Core24
22:09:25:I1:WU13:       Type: 0x24
22:09:25:I1:WU13:    Version: 8.1.4
22:09:25:I1:WU13:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:09:25:I1:WU13:  Copyright: 2022 foldingathome.org
22:09:25:I1:WU13:   Homepage: https://foldingathome.org/
22:09:25:I1:WU13:       Date: Jul 25 2024
22:09:25:I1:WU13:       Time: 05:42:49
22:09:25:I1:WU13:   Revision: cf9f0139862b8945a2091772770e4631aac37792
22:09:25:I1:WU13:     Branch: HEAD
22:09:25:I1:WU13:   Compiler: Visual C++
22:09:25:I1:WU13:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
22:09:25:I1:WU13:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
22:09:25:I1:WU13:   Platform: win32 10
22:09:25:I1:WU13:       Bits: 64
22:09:25:I1:WU13:       Mode: Release
22:09:25:I1:WU13:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:09:25:I1:WU13:             <peastman@stanford.edu>
22:09:25:I1:WU13:       Args: -dir QIDLPPb2gchd7KEuYwGL92V7E3Hu__tZ1OZxR23PJpE -suffix 01
22:09:25:I1:WU13:             -version 8.3.18 -lifeline 13560 -gpu-vendor nvidia -opencl-platform
22:09:25:I1:WU13:             0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
22:09:25:I1:WU13:************************************ libFAH ************************************
22:09:25:I1:WU13:       Time: 05:23:50
22:09:25:I1:WU13:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
22:09:25:I1:WU13:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:09:25:I1:WU13:************************************ CBang *************************************
22:09:25:I1:WU13:    Version: 1.7.2
22:09:25:I1:WU13:        Org: Cauldron Development LLC
22:09:25:I1:WU13:  Copyright: Cauldron Development LLC, 2003-2024
22:09:25:I1:WU13:   Homepage: https://cauldrondevelopment.com/
22:09:25:I1:WU13:    License: LGPL-2.1-or-later
22:09:25:I1:WU13:       Time: 05:22:43
22:09:25:I1:WU13:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
22:09:25:I1:WU13:************************************ System ************************************
22:09:25:I1:WU13:        CPU: AMD Ryzen 5 7500F 6-Core Processor
22:09:25:I1:WU13:     CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
22:09:25:I1:WU13:       CPUs: 12
22:09:25:I1:WU13:     Memory: 31.60GiB
22:09:25:I1:WU13:Free Memory: 24.42GiB
22:09:25:I1:WU13: OS Version: 10.0
22:09:25:I1:WU13:Has Battery: false
22:09:25:I1:WU13: On Battery: false
22:09:25:I1:WU13:   Hostname: Jezek
22:09:25:I1:WU13: UTC Offset: 1
22:09:25:I1:WU13:        PID: 2948
22:09:25:I1:WU13:        CWD: C:\ProgramData\FAHClient\work
22:09:25:I1:WU13:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
22:09:25:I1:WU13:************************************ OpenMM ************************************
22:09:25:I1:WU13:    Version: 8.1.1
22:09:25:I1:WU13:********************************************************************************
22:09:25:I1:WU13:Project: 18236 (Run 890, Clone 3, Gen 77)
22:09:25:I1:WU13:Reading tar file core.xml
22:09:25:I1:WU13:Reading tar file integrator.xml
22:09:25:I1:WU13:Reading tar file state.xml.bz2
22:09:25:I1:WU13:Reading tar file system.xml.bz2
22:09:25:I1:WU13:Digital signatures verified
22:09:25:I1:WU13:Folding@home GPU Core24 Folding@home Core
22:09:25:I1:WU13:Version 8.1.4
22:09:25:I1:WU13:  Checkpoint write interval: 50000 steps (2%) [50 total]
22:09:25:I1:WU13:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
22:09:25:I1:WU13:  XTC frame write interval: 10000 steps (0.4%) [250 total]
22:09:25:I1:WU13:  TRR frame write interval: disabled
22:09:25:I1:WU13:  Global context and integrator variables write interval: disabled
22:09:25:I1:WU13:There are 4 platforms available.
22:09:25:I1:WU13:Platform 0: Reference
22:09:25:I1:WU13:Platform 1: CPU
22:09:25:I1:WU13:Platform 2: OpenCL
22:09:25:I1:WU13:  opencl-device 0 specified
22:09:25:I1:WU13:Platform 3: CUDA
22:09:25:I1:WU13:  cuda-device 0 specified
22:09:30:I1:WU13:Attempting to create CUDA context:
22:09:30:I1:WU13:  Configuring platform CUDA
22:09:33:I1:WU13:  Using CUDA on CUDA Platform and gpu 0
22:09:33:I1:WU13:  GPU info: Platform: CUDA
22:09:33:I1:WU13:  GPU info: PlatformIndex: 0
22:09:33:I1:WU13:  GPU info: Device: NVIDIA GeForce RTX 4070
22:09:33:I1:WU13:  GPU info: DeviceIndex: 0
22:09:33:I1:WU13:  GPU info: Vendor: 0x10de
22:09:33:I1:WU13:  GPU info: PCI: 01:00:00
22:09:33:I1:WU13:  GPU info: Compute: 8.9
22:09:33:I1:WU13:  GPU info: Driver: 12.7
22:09:33:I1:WU13:  GPU info: GPU: true
22:09:33:I1:WU13:Completed 0 out of 2500000 steps (0%)
Reason: added Code tags to log
Re: Missing stats
I have brought this to the attention of the F@h developer. I don't know if it can be fixed quickly, you may need to change username to have the stats show up other than as user Anonymous. The one positive I am seeing is that the points are at least getting credited to the correct team. The "ž" character is a valid Unicode character, but it is possible the stats database only supports a subset.
Ježko
Re: Missing stats
Post by Ježko »
UPDATE: I changed my name to something with only ascii characters which resolved this issue. All WU points under this name are accredited properly.
Re: Missing stats
We have heard back from the developer, he found that sometime years ago a piece of code was put in for the stats database code to not accept unicode characters. The reason for this is no longer documented or remembered. That caused WUs submitted by users with unicode characters in their usernames to be credited as Anonymous. That restriction has been removed. So in the future credits for usernames with unicode will be entered correctly into the database. The API for the lookups still needs a patch to work with the unicode characters, that is planned to be included in the next update to the API.
