Unable to Register
Taiyri
Unable to Register
Post by Taiyri »
Hello, I'm running into an issue with registering a new account through the web interface.
I have entered my email address, generated a passphrase using the refresh button, and entered my username, team #, and passkey. However, I keep getting a API call PUT /register failed (HTTP_BAD_REQUEST).
I perused some other threads and have gathered that something put into the form is incorrect but I've triple checked everything. One suggestion I saw from back in July was to leave the passphrase blank but the register button is grayed out if I do that. Anything else I should try?
Re: Unable to Register
Post by calxalot »
Usually it’s an invalid passkey
Post by calxalot »
Passkey is generated by
https://apps.foldingathome.org/getpasskey
It is not a password. Don’t let your password manager make it up.
Taiyri
Post by Taiyri »
I thought the passkey was the same for all members of a team. It's generated based on each member?
Post by calxalot »
Yes. It is an individual id.
Post by calxalot »
User names are not unique
Taiyri
Post by Taiyri »
Thank you for the clarification. All good to go!
