03:42:28:I1: Version: 8.3.18
03:42:28:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:42:28:I1: Org: foldingathome.org
03:42:28:I1: Copyright: 2023-2024, foldingathome.org
03:42:28:I1: Homepage: https://foldingathome.org/
03:42:28:I1: License: GPL-3.0-or-later
03:42:28:I1: URL: https://v8-3.foldingathome.org/
03:42:28:I1: Date: Jul 12 2024
03:42:28:I1: Time: 13:26:51
03:42:28:I1: Revision: 99ae953ee7b1c0b3070161cfcf9150184f76bd96
03:42:28:I1: Branch: master
03:42:28:I1: Compiler: Visual C++
03:42:28:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
03:42:28:I1: /Zc:throwingNew /MT
03:42:28:I1: Platform: win32 10
03:42:28:I1: Bits: 64
03:42:28:I1: Mode: Release
03:42:28:I1: Args: --open-web-control
03:42:28:I1:****************************** CBang ******************************
03:42:28:I1: Version: 1.7.2
03:42:28:I1: Org: Cauldron Development
03:42:28:I1: Copyright: Cauldron Development, 2003-2024
03:42:28:I1: Homepage: https://cauldrondevelopment.com/
03:42:28:I1: License: LGPL-2.1-or-later
03:42:28:I1: Date: Jun 24 2024
03:42:28:I1: Time: 13:29:54
03:42:28:I1: Revision: 1b05ea96f0ed3043c32b78a66dbf50a9b2002289
03:42:28:I1:***************************** System ******************************
03:42:28:I1: CPU: Intel(R) Core(TM) i7-14700KF
03:42:28:I1: CPU ID: GenuineIntel Family 6 Model 183 Stepping 1
03:42:28:I1: CPUs: 28
03:42:28:I1: Memory: 31.82GiB
03:42:28:I1:Free Memory: 25.22GiB
03:42:28:I1: OS Version: 6.2
03:42:28:I1:Has Battery: false
03:42:28:I1: On Battery: false
03:42:28:I1: Hostname: BUG-III
03:42:28:I1: UTC Offset: -5
03:42:28:I1: PID: 11568
03:42:28:I1: CWD: C:\ProgramData\FAHClient
03:42:28:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
03:42:28:I1:*******************************************************************
03:42:28:I2:<config/>
03:42:28:I1:Opening Database
03:42:28:I1:F@H ID = 7G_eZBu2_OxKMt_U0RoP2KeiewFyyi3WVu7yz4LKNC0
03:42:28:I3:Loading default group
03:42:28:I3:Loading default resource group
03:42:28:I1:Listening for HTTP on 127.0.0.1:7396
03:42:28:I3:WU10:Loading work unit 10 with ID vVD5LjqvgyKrfKZbhW_F1nvYTBkc897layeCOacvAP8
03:42:28:I3:WU11:Loading work unit 11 with ID MbWj_QZCKcVkBKUpZ39oqD07QDqj1lgyp3WMOcuU1r4
03:42:28:I3:Loaded 2 wus.
03:42:28:I1:Started Windows systray control
03:42:29:I3:gpus = {
03:42:29:I3: "gpu:01:00:00": {
03:42:29:I3: "vendor": 4318,
03:42:29:I3: "type": "nvidia",
03:42:29:I3: "description": "NVIDIA GeForce GTX 1050 Ti",
03:42:29:I3: "uuid": "a9bd1a21-e9f7-ea0f-d1a2-abfb5f7007a4",
03:42:29:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "566.36"},
03:42:29:I3: "cuda": {"platform": 0, "device": 0, "compute": "6.1", "driver": "12.7"},
03:42:29:I3: "device": 7298,
03:42:29:I3: "supported": true
03:42:29:I3: }
03:42:29:I3:}
03:42:29:I1:OUT1:> GET https://api.foldingathome.org/machine/7G_eZBu2_OxKMt_U0RoP2KeiewFyyi3WVu7yz4LKNC0 HTTP/1.1
03:42:29:I1:OUT1:< HTTP/1.1 200 HTTP_OK
03:42:29:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
03:42:29:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
03:42:29:I1:Logging into node account
03:44:55:I1:Loaded cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe
03:44:55:I1:Loaded cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe
03:44:55:I3:WU10:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir vVD5LjqvgyKrfKZbhW_F1nvYTBkc897layeCOacvAP8 -suffix 01 -version 8.3.18 -lifeline 11568 -np 26
03:44:55:I3:WU10:Started FahCore on PID 16380
03:44:55:I3:WU11:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe -dir MbWj_QZCKcVkBKUpZ39oqD07QDqj1lgyp3WMOcuU1r4 -suffix 01 -version 8.3.18 -lifeline 11568 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
03:44:55:I3:WU11:Started FahCore on PID 16996
03:44:56:I1:WU11:*********************** Log Started 2024-12-21T03:44:56Z ***********************
03:44:56:I1:WU11:*************************** Core24 Folding@home Core ***************************
03:44:56:I1:WU11: Core: Core24
03:44:56:I1:WU11: Type: 0x24
03:44:56:I1:WU11: Version: 8.1.4
03:44:56:I1:WU11: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:44:56:I1:WU11: Copyright: 2022 foldingathome.org
03:44:56:I1:WU11: Homepage: https://foldingathome.org/
03:44:56:I1:WU11: Date: Jul 25 2024
03:44:56:I1:WU11: Time: 05:42:49
03:44:56:I1:WU11: Revision: cf9f0139862b8945a2091772770e4631aac37792
03:44:56:I1:WU11: Branch: HEAD
03:44:56:I1:WU11: Compiler: Visual C++
03:44:56:I1:WU11: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
03:44:56:I1:WU11: /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
03:44:56:I1:WU11: Platform: win32 10
03:44:56:I1:WU11: Bits: 64
03:44:56:I1:WU11: Mode: Release
03:44:56:I1:WU11:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
03:44:56:I1:WU11: <peastman@stanford.edu>
03:44:56:I1:WU11: Args: -dir MbWj_QZCKcVkBKUpZ39oqD07QDqj1lgyp3WMOcuU1r4 -suffix 01
03:44:56:I1:WU11: -version 8.3.18 -lifeline 11568 -gpu-vendor nvidia -opencl-platform
03:44:56:I1:WU11: 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
03:44:56:I1:WU11:************************************ libFAH ************************************
03:44:56:I1:WU11: Time: 05:23:50
03:44:56:I1:WU11: Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
03:44:56:I1:WU11: Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
03:44:56:I1:WU11:************************************ CBang *************************************
03:44:56:I1:WU11: Version: 1.7.2
03:44:56:I1:WU11: Org: Cauldron Development LLC
03:44:56:I1:WU11: Copyright: Cauldron Development LLC, 2003-2024
03:44:56:I1:WU11: Homepage: https://cauldrondevelopment.com/
03:44:56:I1:WU11: License: LGPL-2.1-or-later
03:44:56:I1:WU11: Time: 05:22:43
03:44:56:I1:WU11: Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
03:44:56:I1:WU11:************************************ System ************************************
03:44:56:I1:WU11: CPU: Intel(R) Core(TM) i7-14700KF
03:44:56:I1:WU11: CPU ID: GenuineIntel Family 6 Model 183 Stepping 1
03:44:56:I1:WU11: CPUs: 28
03:44:56:I1:WU11: Memory: 31.82GiB
03:44:56:I1:WU11:Free Memory: 24.65GiB
03:44:56:I1:WU11: OS Version: 10.0
03:44:56:I1:WU11:Has Battery: false
03:44:56:I1:WU11: On Battery: false
03:44:56:I1:WU11: Hostname: BUG-III
03:44:56:I1:WU11: UTC Offset: -5
03:44:56:I1:WU11: PID: 16996
03:44:56:I1:WU11: CWD: C:\ProgramData\FAHClient\work
03:44:56:I1:WU11: Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
03:44:56:I1:WU11:************************************ OpenMM ************************************
03:44:56:I1:WU11: Version: 8.1.1
03:44:56:I1:WU11:********************************************************************************
03:44:56:I1:WU11:Project: 18236 (Run 1112, Clone 3, Gen 61)
03:44:56:I1:WU11:Digital signatures verified
03:44:56:I1:WU11:Folding@home GPU Core24 Folding@home Core
03:44:56:I1:WU11:Version 8.1.4
03:44:56:I1:WU11: Checkpoint write interval: 50000 steps (2%) [50 total]
03:44:56:I1:WU11: JSON viewer frame write interval: 25000 steps (1%) [100 total]
03:44:56:I1:WU11: XTC frame write interval: 10000 steps (0.4%) [250 total]
03:44:56:I1:WU11: TRR frame write interval: disabled
03:44:56:I1:WU11: Global context and integrator variables write interval: disabled
03:44:56:I1:WU10:*********************** Log Started 2024-12-21T03:44:56Z ***********************
03:44:56:I1:WU10:************************** Gromacs Folding@home Core ***************************
03:44:56:I1:WU10: Core: Gromacs
03:44:56:I1:WU10: Type: 0xa8
03:44:56:I1:WU10: Version: 0.0.12
03:44:56:I1:WU10: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:44:56:I1:WU10: Copyright: 2020 foldingathome.org
03:44:56:I1:WU10: Homepage: https://foldingathome.org/
03:44:56:I1:WU10: Date: Jan 16 2021
03:44:56:I1:WU10: Time: 12:29:40
03:44:56:I1:WU10: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
03:44:56:I1:WU10: Branch: master
03:44:56:I1:WU10: Compiler: Visual C++ 2019 16.7
03:44:56:I1:WU10: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
03:44:56:I1:WU10: Platform: win32 10
03:44:56:I1:WU10: Bits: 64
03:44:56:I1:WU10: Mode: Release
03:44:56:I1:WU10: SIMD: avx2_256
03:44:56:I1:WU10: OpenMP: ON
03:44:56:I1:WU10: CUDA: OFF
03:44:56:I1:WU10: Args: -dir vVD5LjqvgyKrfKZbhW_F1nvYTBkc897layeCOacvAP8 -suffix 01
03:44:56:I1:WU10: -version 8.3.18 -lifeline 11568 -np 26
03:44:56:I1:WU10:************************************ libFAH ************************************
03:44:56:I1:WU10: Time: 11:24:13
03:44:56:I1:WU10:************************************ CBang *************************************
03:44:56:I1:WU10: Time: 11:23:53
03:44:56:I1:WU10:************************************ System ************************************
03:44:56:I1:WU10: CPU: Intel(R) Core(TM) i7-14700KF
03:44:56:I1:WU10: CPU ID: GenuineIntel Family 6 Model 183 Stepping 1
03:44:56:I1:WU10: CPUs: 28
03:44:56:I1:WU10: Memory: 31.82GiB
03:44:56:I1:WU10:Free Memory: 24.65GiB
03:44:56:I1:WU10: Threads: WINDOWS_THREADS
03:44:56:I1:WU10: OS Version: 6.2
03:44:56:I1:WU10:Has Battery: false
03:44:56:I1:WU10: On Battery: false
03:44:56:I1:WU10: UTC Offset: -5
03:44:56:I1:WU10: PID: 16380
03:44:56:I1:WU10: CWD: C:\ProgramData\FAHClient\work
03:44:56:I1:WU10:********************************************************************************
03:44:56:I1:WU10:Project: 12423 (Run 74, Clone 7, Gen 29)
03:44:56:I1:WU10:Unit: 0x00000000000000000000000000000000
03:44:56:I1:WU10:Digital signatures verified
03:44:56:I1:WU10:Calling: mdrun -c frame29.gro -s frame29.tpr -x frame29.xtc -cpi state.cpt -cpt 5 -nt 26 -ntmpi 1
03:44:56:I1:WU11:There are 4 platforms available.
03:44:56:I1:WU11:Platform 0: Reference
03:44:56:I1:WU11:Platform 1: CPU
03:44:56:I1:WU11:Platform 2: OpenCL
03:44:56:I1:WU11: opencl-device 0 specified
03:44:56:I1:WU11:Platform 3: CUDA
03:44:56:I1:WU11: cuda-device 0 specified
03:44:56:I1:WU10:Steps: first=145000000 total=150000000
03:44:58:I1:WU10:Completed 3507675 out of 5000000 steps (70%)
03:45:01:I1:WU11:Attempting to create CUDA context:
03:45:01:I1:WU11: Configuring platform CUDA
03:45:02:I1:WU11: Using CUDA on CUDA Platform and gpu 0
03:45:02:I1:WU11: GPU info: Platform: CUDA
03:45:02:I1:WU11: GPU info: PlatformIndex: 0
03:45:02:I1:WU11: GPU info: Device: NVIDIA GeForce GTX 1050 Ti
03:45:02:I1:WU11: GPU info: DeviceIndex: 0
03:45:02:I1:WU11: GPU info: Vendor: 0x10de
03:45:02:I1:WU11: GPU info: PCI: 01:00:00
03:45:02:I1:WU11: GPU info: Compute: 6.1
03:45:02:I1:WU11: GPU info: Driver: 12.7
03:45:02:I1:WU11: GPU info: GPU: true
03:45:02:I1:WU11:Completed 500000 out of 2500000 steps (20%)
