macOS Device cannot be linked in web client
winter01942
Post by winter01942 »
I have just installed the F@H client 8.3.18 on my MacOS device (Apple Silicon, Sequoia 15.2), and I am unable to link the machine in the web client.
with v8-3.foldingathome.org/account, nothing happens after clicking the Link button
with v8-4.foldingathome.org, the "Auto-linking client" prompt always appears telling me it has automatically linked however the machine still stays unlinked
thus the machine always shows the following error in the logs
13:04:48:W :CON1:DNS lookup failed for api.foldingathome.org
13:04:48:E :OUT1:Failed response: CONNECT
13:04:48:W :CON2:DNS lookup failed for api.foldingathome.org
13:04:48:W :Failed to update GPUs
I have tried to load / unload the .plist, as well as upgrading to the 8.4.8 alpha release of the F@H client, but no success
Hope someone can guide me to what I am doing wrong, and apologies in advance if I had missed something during the install as this is my first F@H install on a macOS device
Re: macOS Device cannot be linked in web client
Post by calxalot »
Please upgrade to 8.4.9 beta and report back.
Post by calxalot »
Note also that the link button requests linking, which happens asynchronously. It sometimes takes a reload of web control to get current state.
DNS errors might be fixed using the latest beta.
winter01942
Installed the 8.4.9 beta, tried unload / load as well as a full system restart and gave it some time
Still the same behaviour, the prompt telling me "The local machine has been automatically linked to your Folding@home account." comes out when refreshing the client, but machine still remains unlinked. I also did take a look at the browser tools Network tab, and I don't see anything happening when clicking the Link button.
Does upgrading require a full remove + install? So far I have just been installing the new client directly.
Post by calxalot »
You do not need to uninstall before upgrade.
The log does not show errors connecting to api.foldingathome.org?
winter01942
It still does the same
01:16:14:I3:Loading default resource group
01:16:14:I1:Listening for HTTP on 127.0.0.1:7396
01:16:14:I3:Loaded 0 wus.
01:16:14:W :CON1:DNS lookup failed for api.foldingathome.org
01:16:14:E :OUT1:Failed response: CONNECT
01:16:14:W :CON2:DNS lookup failed for api.foldingathome.org
01:16:14:W :Failed to update GPUs
pinging api.foldingathome.org works fine
Chees-Mac-mini ~ % ping api.foldingathome.org
PING fah.foldingathome.org (3.136.33.72): 56 data bytes
64 bytes from 3.136.33.72: icmp_seq=0 ttl=51 time=304.431 ms
64 bytes from 3.136.33.72: icmp_seq=1 ttl=51 time=324.812 ms
64 bytes from 3.136.33.72: icmp_seq=2 ttl=51 time=343.607 ms
Post by calxalot »
How many clients do you have connecting from the same IP address?
The api server imposes temporary bans when its rate limit is reached. I know that was recently raised, but don’t know what the limit is.
winter01942
I only have one machine, but good call nevertheless
Switched over to my cellular network and device is linked now. Waiting for work units
Thanks!
