Did Migration Assistant transfer from old Mac Pro 2 to new Mac Pro 3. Prior F@H client was brought over to new MP3 and is processing under old MP2 settings but log show new MP3 is recognized. Have Red colored log entry - "WU with client ID xxxxxx does not belong client (line cut off).
How do I add new MP3 to F@H Client Listing of 11 computers and delete old MP2 WU ?
MP2 is running WU Project 12421 and MP3 is running WU Project 18497 and is 5% complete.
How to add new Mac Pro to F@H 8.3.18
TomJohnson
- Hardware configuration: F@H Info – V8.4.9 – 12 Machines – 123 CPUs - 1,000K+ PPD; 1/5/2025
Mac Pro 14,8, 24 CPUs, 256K PPD;
Mac Pro 5,1, 24 CPUs, 496K PPD;
Mac Studio 13,1, 10 CPUs, 146K PPD;
iMac Pro 1,1, 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD;
iMac 14,1, 4 CPUs, 40K PPD;
Mac Book Pro 17,1, 8 CPUs, 166K PPD;
Mac Book Pro 13,3, 8 CPUs, 57K PPD;
Mac Book Air 5,2, 4 CPUs, 23K PPD;
Mac Mini 7,1, 4 CPUs, 9K PPD;
HP Pavilion, 12 CPUs, 105K PPD;
SONY VAIO, 8 CPUs, 44K PPD. - Location: Oak Harbor, WA
Mac Pro 14,8, 24 CPUs, 226K PPD;
iMac Pro 1,1. 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD; + 7 more CPUs
Re: How to add new Mac Pro to F@H 8.3.18
I'm not following the question.
Meanwhile, I recommend you upgrade to beta 8.4.9
https://foldingathome.org/beta/
and use https://v8-4.foldingathome.org/
If the same WU is running on two computers after migration, pause and dump the cloned WU.
Linking a machine happens when you login using web control on that machine.
The client detects a hardware id change and generates a new uuid "F@H ID".
TomJohnson
Each computer is running a separate WU but the web control Client log shows that both computers are identified as MP2. My solution is to uninstall F@H on MP3 then reinstall F@H on MP3 then restart and go to web control Client to re-enter my profile info.
I installed 8.4.9 on MP2 and it seems to be working properly.
Thanks for the reply.
The machine name ends up in client.db
You can change a name via machine settings when logged into web control. Look at info if it’s unclear which is which.
TomJohnson
When viewing Client Details it shows "MAC-PRO-SSD-2.local". All Machine data below is correct for MP3. I have MP3 Local hostname set to "Mac-Pro3.local"
F@H DETAILS 2024-12-16 at 2.43.16 PM.jpgMac Pro 14,8, 24 CPUs, 226K PPD;
TomJohnson
Finally figured out how to fix this problem - went to this URL for Client = https://v8-4.foldingathome.org/machines - then went to MP2 Machines Name line then clicked on Gear icon then went to Machine/Name line which then permit User to Edit the Name to "MAC-PRO-3.local".
Recommend that this info be added to FAQs.
Thanks for your help.
Case closed.
Case closed.
