How can I control the slot that a command line unpause command affects?
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
I want to send a command line instruction to slot 2, using
--send-unpause [string]
What should [string] be to achieve this?
Re: How can I control the slot that a command line unpause command affects?
Post by calxalot »
Probably the slot number.
Besides “FAHClient —help”
try “FAHClint —send-command help”
That should be double dash before first argument. Some commands require a quoted command string sent to the remote script server.
Schrödinger's cat
calxalot wrote: Thu Dec 12, 2024 9:18 pm Probably the slot number.
Thanks calxalot, it was the format/syntax that was the problem.
The correct command (for my purposes) is
--send-unpause 02
where 02 is the slot number.
