Am not getting points for work completed...
RobbyB
Hardware configuration: Hardware configuration:Homebuilt Windows 10, 64-Bit Operating System
Main Board: GigaByte GA-B85M-D3H
Processor: Intel Core i7-4770 ~ 2014 or 2015
Memory: 32 GB RAM (up from 8 GB in 2018)
GPS: GigaByte GEFORCE GTX 1660 GPU ~ March 2020
Post by RobbyB »
Hello,
Got tired of trying to adjust and reconfigure my old installation of Windows 10, so "nuked" the drive and started over - with a much better running machine.
Trying to get back into folding, I installed 8.3.18_AMD64 as on Join The Fold from the main FAH site. This one appeared to be working as designed and was folding and making results, but I have not received any credit. Given that I have 1.5 days of work, I'll clip some of the code, and hopefully can help you in diagnosing what is wrong.
My user name is Robby on Team #1. I did not see that information in the below code like version #7 or an earlier #8 displaced (unless it was changed to another format). I have entered that information, along with a password and passkey in the FAH software, that I have been using the past few years.
I've booted the machine before collecting the below data. I could not get the 8.3.18 version to run, so I deleted it and am currently running an "alpha" version, 8.4.8. It seems to be doing okay so far. This version like the older 8.3.18 does not display my information (unless it was changed / encrypted following the "F@H ID" string.
Respectfully yours,
Robby
Start of the program...
07:10:55:I1:WU1:Project: 19228 (Run 965, Clone 5, Gen 0)
07:11:25:I1:WU2:Project: 18237 (Run 111, Clone 0, Gen 96)
*********************** Log Started 2024-11-22T07:10:31Z ***********************
07:10:31:I1:*********************** Folding@home Client ***********************
07:10:31:I1:    Version: 8.3.18
07:10:31:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:10:31:I1:        Org: foldingathome.org
07:10:31:I1:  Copyright: 2023-2024, foldingathome.org
07:10:31:I1:   Homepage: https://foldingathome.org/
07:10:31:I1:    License: GPL-3.0-or-later
07:10:31:I1:        URL: https://v8-3.foldingathome.org/
07:10:31:I1:       Date: Jul 12 2024
07:10:31:I1:       Time: 13:26:51
07:10:31:I1:   Revision: 99ae953ee7b1c0b3070161cfcf9150184f76bd96
07:10:31:I1:     Branch: master
07:10:31:I1:   Compiler: Visual C++
07:10:31:I1:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
07:10:31:I1:             /Zc:throwingNew /MT
07:10:31:I1:   Platform: win32 10
07:10:31:I1:       Bits: 64
07:10:31:I1:       Mode: Release
07:10:31:I1:       Args: --open-web-control
07:10:31:I1:****************************** CBang ******************************
07:10:31:I1:    Version: 1.7.2
07:10:31:I1:        Org: Cauldron Development
07:10:31:I1:  Copyright: Cauldron Development, 2003-2024
07:10:31:I1:   Homepage: https://cauldrondevelopment.com/
07:10:31:I1:    License: LGPL-2.1-or-later
07:10:31:I1:       Date: Jun 24 2024
07:10:31:I1:       Time: 13:29:54
07:10:31:I1:   Revision: 1b05ea96f0ed3043c32b78a66dbf50a9b2002289
07:10:31:I1:***************************** System ******************************
07:10:31:I1:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
07:10:31:I1:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:10:31:I1:       CPUs: 8
07:10:31:I1:     Memory: 15.87GiB
07:10:31:I1:Free Memory: 12.07GiB
07:10:31:I1: OS Version: 6.2
07:10:31:I1:Has Battery: true
07:10:31:I1: On Battery: false
07:10:31:I1:   Hostname: DESKTOP-JIR7UQA
07:10:31:I1: UTC Offset: -6
07:10:31:I1:        PID: 13292
07:10:31:I1:        CWD: C:\ProgramData\FAHClient
07:10:31:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
07:10:31:I1:*******************************************************************
07:10:31:I2:<config/>
07:10:31:I1:Opening Database
07:10:32:I1:Generating RSA key..................++++-................++++-
07:10:32:I1:F@H ID = 5rHNepiubhZm8sbEKddrbB-O7a5h2fApx_oe0_VAw_s
07:10:32:I3:Loading default group
07:10:32:I3:Loading default resource group
07:10:32:I1:Listening for HTTP on 127.0.0.1:7396
07:10:33:I3:Loaded 0 wus.
07:10:33:I1:Started Windows systray control
07:10:33:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
07:10:33:I1:OUT1:< HTTP/1.1 200 HTTP_OK
07:10:34:I3:gpus = {
07:10:34:I3:  "gpu:04:00:00": {
07:10:34:I3:    "vendor": 4318,
07:10:34:I3:    "type": "nvidia",
07:10:34:I3:    "description": "NVIDIA GeForce GTX 1660 SUPER",
07:10:34:I3:    "uuid": "474e7d04-a8c3-1102-ec14-7020410cfb7b",
07:10:34:I3:    "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "560.94"},
07:10:34:I3:    "cuda": {"platform": 0, "device": 0, "compute": "7.5", "driver": "12.6"},
07:10:34:I3:    "device": 8644,
07:10:34:I3:    "supported": true
07:10:34:I3:  }
07:10:34:I3:}
07:10:46:I1:Default:Added new work unit: cpus:7 gpus:
07:10:46:I1:WU1:Requesting WU assignment for user Anonymous team 0
07:10:46:I1:OUT3:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
07:10:47:I1:OUT3:< HTTP/1.1 200 HTTP_OK
07:10:47:I1:WU1:Received WU assignment 2cO6V_DejTp6iSD2tRyQ9beAkDzqxd1LTvbhkpS6d2U
07:10:47:I1:WU1:Downloading WU
07:10:47:I1:OUT4:> POST https://ds01.scs.illinois.edu/api/assign HTTP/1.1
07:10:48:I1:OUT4:< HTTP/1.1 200 HTTP_OK
07:10:48:I1:WU1:Received WU P19228 R965 C5 G0
07:10:49:I1:Downloading https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.crt
07:10:49:I1:OUT5:> GET https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.crt HTTP/1.1
07:10:49:I1:OUT5:< HTTP/1.1 200 OK
07:10:49:I1:Downloading https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.sig
07:10:49:I1:OUT6:> GET https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2.sig HTTP/1.1
07:10:49:I1:OUT6:< HTTP/1.1 200 OK
07:10:49:I1:OUT7:> GET https://cores2.foldingathome.org/fahcore-a8-win-64bit-avx2_256-0.0.12.tar.bz2 HTTP/1.1
07:10:50:I1:OUT7:< HTTP/1.1 200 OK
07:10:50:I1:Core signature valid
07:10:50:I1:Extracting cores/fahcore-a8-win-64bit-avx2_256-0.0.12/libfftw3f-3.dll
07:10:51:I1:Extracting cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8
07:10:51:I1:Extracting cores/fahcore-a8-win-64bit-avx2_256-0.0.12/vcomp140.dll
07:10:52:I3:WU1:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2cO6V_DejTp6iSD2tRyQ9beAkDzqxd1LTvbhkpS6d2U -suffix 01 -version 8.3.18 -lifeline 13292 -np 7
07:10:55:I3:WU1:Started FahCore on PID 12868
07:10:55:I1:WU1:*********************** Log Started 2024-11-22T07:10:55Z ***********************
07:10:55:I1:WU1:************************** Gromacs Folding@home Core ***************************
07:10:55:I1:WU1:       Core: Gromacs
07:10:55:I1:WU1:       Type: 0xa8
07:10:55:I1:WU1:    Version: 0.0.12
07:10:55:I1:WU1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:10:55:I1:WU1:  Copyright: 2020 foldingathome.org
07:10:55:I1:WU1:   Homepage: https://foldingathome.org/
07:10:55:I1:WU1:       Date: Jan 16 2021
07:10:55:I1:WU1:       Time: 12:29:40
07:10:55:I1:WU1:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
07:10:55:I1:WU1:     Branch: master
07:10:55:I1:WU1:   Compiler: Visual C++ 2019 16.7
07:10:55:I1:WU1:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:10:55:I1:WU1:   Platform: win32 10
07:10:55:I1:WU1:       Bits: 64
07:10:55:I1:WU1:       Mode: Release
07:10:55:I1:WU1:       SIMD: avx2_256
07:10:55:I1:WU1:     OpenMP: ON
07:10:55:I1:WU1:       CUDA: OFF
07:10:55:I1:WU1:       Args: -dir 2cO6V_DejTp6iSD2tRyQ9beAkDzqxd1LTvbhkpS6d2U -suffix 01
07:10:55:I1:WU1:             -version 8.3.18 -lifeline 13292 -np 7
07:10:55:I1:WU1:************************************ libFAH ************************************
07:10:55:I1:WU1:       Time: 11:24:13
07:10:55:I1:WU1:************************************ CBang *************************************
07:10:55:I1:WU1:       Time: 11:23:53
07:10:55:I1:WU1:************************************ System ************************************
07:10:55:I1:WU1:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
07:10:55:I1:WU1:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:10:55:I1:WU1:       CPUs: 8
07:10:55:I1:WU1:     Memory: 15.87GiB
07:10:55:I1:WU1:Free Memory: 11.96GiB
07:10:55:I1:WU1:    Threads: WINDOWS_THREADS
07:10:55:I1:WU1: OS Version: 6.2
07:10:55:I1:WU1:Has Battery: true
07:10:55:I1:WU1: On Battery: false
07:10:55:I1:WU1: UTC Offset: -6
07:10:55:I1:WU1:        PID: 12868
07:10:55:I1:WU1:        CWD: C:\ProgramData\FAHClient\work
07:10:55:I1:WU1:********************************************************************************
07:10:55:I1:WU1:Unit: 0x00000000000000000000000000000000
07:10:55:I1:WU1:Reading tar file core.xml
07:10:55:I1:WU1:Reading tar file md0.tpr
07:10:55:I1:WU1:Digital signatures verified
07:10:55:I1:WU1:Calling: mdrun -c md0.gro -s md0.tpr -x md0.xtc -cpt 5 -nt 7 -ntmpi 1
07:10:55:I1:WU1:Steps: first=0 total=500000
07:10:58:I1:Default:Added new work unit: cpus:0 gpus:gpu:04:00:00
07:10:58:I1:WU2:Requesting WU assignment for user Anonymous team 0
07:10:58:I1:WU1:WARNING:Console control signal 1 on PID 12868
07:10:58:I1:WU1:Exiting, please wait. . .
07:10:58:I1:OUT8:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
07:10:59:I1:OUT8:< HTTP/1.1 200 HTTP_OK
07:10:59:I1:WU2:Received WU assignment DDkp8gum5mRdvCobIxR633mbP0g-FHJ6VWOZSQkN5XQ
07:10:59:I1:WU2:Downloading WU
07:10:59:I1:OUT9:> POST https://highland1.seas.upenn.edu/api/assign HTTP/1.1
07:11:00:I1:OUT9:< HTTP/1.1 200 HTTP_OK
07:11:00:I1:WU2:Received WU P18237 R111 C0 G96
07:11:00:I1:Downloading https://cores2.foldingathome.org/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4.tar.bz2.crt
07:11:00:I1:OUT10:> GET https://cores2.foldingathome.org/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4.tar.bz2.crt HTTP/1.1
07:11:01:I1:OUT10:< HTTP/1.1 200 OK
07:11:01:I1:Downloading https://cores2.foldingathome.org/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4.tar.bz2.sig
07:11:01:I1:OUT11:> GET https://cores2.foldingathome.org/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4.tar.bz2.sig HTTP/1.1
07:11:01:I1:OUT11:< HTTP/1.1 200 OK
07:11:01:I1:OUT12:> GET https://cores2.foldingathome.org/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4.tar.bz2 HTTP/1.1
07:11:05:I1:OUT12:< HTTP/1.1 200 OK
07:11:05:I1:Core signature valid
07:11:05:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe
07:11:05:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMM.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMAmoeba.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMAmoebaCUDA.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMAmoebaOpenCL.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMAmoebaReference.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMCPU.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMCUDA.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMDrude.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMDrudeCUDA.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMDrudeOpenCL.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMDrudeReference.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMOpenCL.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMPME.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMRPMD.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMRPMDCUDA.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMRPMDOpenCL.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/OpenMMRPMDReference.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/api-ms-win-crt-runtime-l1-1-0.dll
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/core-meta.json
07:11:06:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/cufft64_10.dll
07:11:21:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/libcrypto-1_1-x64.dll
07:11:21:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/libssl-1_1-x64.dll
07:11:22:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/msvcp140.dll
07:11:22:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/msvcp140_1.dll
07:11:22:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/msvcp140_2.dll
07:11:22:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/msvcp140_atomic_wait.dll
07:11:22:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/msvcp140_codecvt_ids.dll
07:11:22:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/nvrtc-builtins64_118.dll
07:11:22:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/nvrtc64_112_0.dll
07:11:24:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/vcruntime140.dll
07:11:24:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/vcruntime140_1.dll
07:11:24:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/vcruntime140_threads.dll
07:11:24:I1:Extracting cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/zlib.dll
07:11:25:I1:WU1:Completed 1 out of 500000 steps (0%)
07:11:25:I1:WU1:Folding@home Core Shutdown: INTERRUPTED
07:11:25:I1:WU1:Core returned INTERRUPTED (102)
07:11:25:I3:WU1:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2cO6V_DejTp6iSD2tRyQ9beAkDzqxd1LTvbhkpS6d2U -suffix 01 -version 8.3.18 -lifeline 13292 -np 5
07:11:25:I3:WU1:Started FahCore on PID 11260
07:11:25:I3:WU2:Running FahCore: C:\ProgramData\FAHClient\cores/openmm-core-24/windows-10-64bit/release/fahcore-24-windows-10-64bit-release-8.1.4/FahCore_24.exe -dir DDkp8gum5mRdvCobIxR633mbP0g-FHJ6VWOZSQkN5XQ -suffix 01 -version 8.3.18 -lifeline 13292 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
07:11:25:I3:WU2:Started FahCore on PID 12496
07:11:25:I1:WU1:*********************** Log Started 2024-11-22T07:11:25Z ***********************
07:11:25:I1:WU1:************************** Gromacs Folding@home Core ***************************
07:11:25:I1:WU1:       Core: Gromacs
07:11:25:I1:WU1:       Type: 0xa8
07:11:25:I1:WU1:    Version: 0.0.12
07:11:25:I1:WU1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:11:25:I1:WU1:  Copyright: 2020 foldingathome.org
07:11:25:I1:WU1:   Homepage: https://foldingathome.org/
07:11:25:I1:WU1:       Date: Jan 16 2021
07:11:25:I1:WU1:       Time: 12:29:40
07:11:25:I1:WU1:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
07:11:25:I1:WU1:     Branch: master
07:11:25:I1:WU1:   Compiler: Visual C++ 2019 16.7
07:11:25:I1:WU1:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:11:25:I1:WU1:   Platform: win32 10
07:11:25:I1:WU1:       Bits: 64
07:11:25:I1:WU1:       Mode: Release
07:11:25:I1:WU1:       SIMD: avx2_256
07:11:25:I1:WU1:     OpenMP: ON
07:11:25:I1:WU1:       CUDA: OFF
07:11:25:I1:WU1:       Args: -dir 2cO6V_DejTp6iSD2tRyQ9beAkDzqxd1LTvbhkpS6d2U -suffix 01
07:11:25:I1:WU1:             -version 8.3.18 -lifeline 13292 -np 5
07:11:25:I1:WU1:************************************ libFAH ************************************
07:11:25:I1:WU1:       Time: 11:24:13
07:11:25:I1:WU1:************************************ CBang *************************************
07:11:25:I1:WU1:       Time: 11:23:53
07:11:25:I1:WU1:************************************ System ************************************
07:11:25:I1:WU1:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
07:11:25:I1:WU1:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:11:25:I1:WU1:       CPUs: 8
07:11:25:I1:WU1:     Memory: 15.87GiB
07:11:25:I1:WU1:Free Memory: 11.66GiB
07:11:25:I1:WU1:    Threads: WINDOWS_THREADS
07:11:25:I1:WU1: OS Version: 6.2
07:11:25:I1:WU1:Has Battery: true
07:11:25:I1:WU1: On Battery: false
07:11:25:I1:WU1: UTC Offset: -6
07:11:25:I1:WU1:        PID: 11260
07:11:25:I1:WU1:        CWD: C:\ProgramData\FAHClient\work
07:11:25:I1:WU1:********************************************************************************
07:11:25:I1:WU1:Project: 19228 (Run 965, Clone 5, Gen 0)
07:11:25:I1:WU1:Unit: 0x00000000000000000000000000000000
07:11:25:I1:WU1:Digital signatures verified
07:11:25:I1:WU1:Calling: mdrun -c md0.gro -s md0.tpr -x md0.xtc -cpi state.cpt -cpt 5 -nt 5 -ntmpi 1
07:11:25:I1:WU1:Steps: first=0 total=500000
07:11:25:I1:WU2:*********************** Log Started 2024-11-22T07:11:25Z ***********************
07:11:25:I1:WU2:*************************** Core24 Folding@home Core ***************************
07:11:25:I1:WU2:       Core: Core24
07:11:25:I1:WU2:       Type: 0x24
07:11:25:I1:WU2:    Version: 8.1.4
07:11:25:I1:WU2:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:11:25:I1:WU2:  Copyright: 2022 foldingathome.org
07:11:25:I1:WU2:   Homepage: https://foldingathome.org/
07:11:25:I1:WU2:       Date: Jul 25 2024
07:11:25:I1:WU2:       Time: 05:42:49
07:11:25:I1:WU2:   Revision: cf9f0139862b8945a2091772770e4631aac37792
07:11:25:I1:WU2:     Branch: HEAD
07:11:25:I1:WU2:   Compiler: Visual C++
07:11:25:I1:WU2:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
07:11:25:I1:WU2:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
07:11:25:I1:WU2:   Platform: win32 10
07:11:25:I1:WU2:       Bits: 64
07:11:25:I1:WU2:       Mode: Release
07:11:25:I1:WU2:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:11:25:I1:WU2:             <peastman@stanford.edu>
07:11:25:I1:WU2:       Args: -dir DDkp8gum5mRdvCobIxR633mbP0g-FHJ6VWOZSQkN5XQ -suffix 01
07:11:25:I1:WU2:             -version 8.3.18 -lifeline 13292 -gpu-vendor nvidia -opencl-platform
07:11:25:I1:WU2:             0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
07:11:25:I1:WU2:************************************ libFAH ************************************
07:11:25:I1:WU2:       Time: 05:23:50
07:11:25:I1:WU2:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
07:11:25:I1:WU2:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:11:25:I1:WU2:************************************ CBang *************************************
07:11:25:I1:WU2:    Version: 1.7.2
07:11:25:I1:WU2:        Org: Cauldron Development LLC
07:11:25:I1:WU2:  Copyright: Cauldron Development LLC, 2003-2024
07:11:25:I1:WU2:   Homepage: https://cauldrondevelopment.com/
07:11:25:I1:WU2:    License: LGPL-2.1-or-later
07:11:25:I1:WU2:       Time: 05:22:43
07:11:25:I1:WU2:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
07:11:25:I1:WU2:************************************ System ************************************
07:11:25:I1:WU2:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
07:11:25:I1:WU2:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:11:25:I1:WU2:       CPUs: 8
07:11:25:I1:WU2:     Memory: 15.87GiB
07:11:25:I1:WU2:Free Memory: 11.65GiB
07:11:25:I1:WU2: OS Version: 10.0
07:11:25:I1:WU2:Has Battery: true
07:11:25:I1:WU2: On Battery: false
07:11:25:I1:WU2:   Hostname: DESKTOP-JIR7UQA
07:11:25:I1:WU2: UTC Offset: -6
07:11:25:I1:WU2:        PID: 12496
07:11:25:I1:WU2:        CWD: C:\ProgramData\FAHClient\work
07:11:25:I1:WU2:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
07:11:25:I1:WU2:************************************ OpenMM ************************************
07:11:25:I1:WU2:    Version: 8.1.1
07:11:25:I1:WU2:********************************************************************************
07:11:25:I1:WU2:Reading tar file core.xml
07:11:25:I1:WU2:Reading tar file integrator.xml
07:11:25:I1:WU2:Reading tar file state.xml.bz2
07:11:25:I1:WU2:Reading tar file system.xml.bz2
07:11:25:I1:WU2:Digital signatures verified
07:11:25:I1:WU2:Folding@home GPU Core24 Folding@home Core
07:11:25:I1:WU2:Version 8.1.4
07:11:25:I1:WU2:  Checkpoint write interval: 50000 steps (2%) [50 total]
07:11:25:I1:WU2:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
07:11:25:I1:WU2:  XTC frame write interval: 10000 steps (0.4%) [250 total]
07:11:25:I1:WU2:  TRR frame write interval: disabled
07:11:25:I1:WU2:  Global context and integrator variables write interval: disabled
07:11:38:I1:WU2:There are 4 platforms available.
07:11:38:I1:WU2:Platform 0: Reference
07:11:38:I1:WU2:Platform 1: CPU
07:11:38:I1:WU2:Platform 2: OpenCL
07:11:38:I1:WU2:  opencl-device 0 specified
07:11:38:I1:WU2:Platform 3: CUDA
07:11:38:I1:WU2:  cuda-device 0 specified
07:11:41:I1:WU1:Completed 12 out of 500000 steps (0%)
07:12:01:I1:WU2:Attempting to create CUDA context:
07:12:01:I1:WU2:  Configuring platform CUDA
07:12:10:I1:WU2:  Using CUDA on CUDA Platform and gpu 0
07:12:10:I1:WU2:  GPU info: Platform: CUDA
07:12:10:I1:WU2:  GPU info: PlatformIndex: 0
07:12:10:I1:WU2:  GPU info: Device: NVIDIA GeForce GTX 1660 SUPER
07:12:10:I1:WU2:  GPU info: DeviceIndex: 0
07:12:10:I1:WU2:  GPU info: Vendor: 0x10de
07:12:10:I1:WU2:  GPU info: PCI: 04:00:00
07:12:10:I1:WU2:  GPU info: Compute: 7.5
07:12:10:I1:WU2:  GPU info: Driver: 12.6
07:12:10:I1:WU2:  GPU info: GPU: true
07:12:10:I1:WU2:Completed 0 out of 2500000 steps (0%)
07:12:11:I1:WU2:Checkpoint completed at step 0
07:15:27:I1:WU2:Completed 25000 out of 2500000 steps (1%)
07:18:41:I1:WU2:Completed 50000 out of 2500000 steps (2%)
07:18:43:I1:WU2:Checkpoint completed at step 50000
07:21:58:I1:WU2:Completed 75000 out of 2500000 steps (3%)
07:25:14:I1:WU2:Completed 100000 out of 2500000 steps (4%)
07:25:15:I1:WU2:Checkpoint completed at step 100000
07:25:42:I1:WU1:Completed 5000 out of 500000 steps (1%)
07:28:31:I1:WU2:Completed 125000 out of 2500000 steps (5%)
07:31:51:I1:WU2:Completed 150000 out of 2500000 steps (6%)
07:31:52:I1:WU2:Checkpoint completed at step 150000
07:35:12:I1:WU2:Completed 175000 out of 2500000 steps (7%)
07:38:32:I1:WU2:Completed 200000 out of 2500000 steps (8%)
07:38:33:I1:WU2:Checkpoint completed at step 200000
07:39:30:I1:WU1:Completed 10000 out of 500000 steps (2%)
07:41:57:I1:WU2:Completed 225000 out of 2500000 steps (9%)
Finishing WU2 Project: 18237 (Run 111, Clone 0, Gen 96) and "credit" for it.
Also think WU1 failed in the below...
11:32:07:I1:WU2:Checkpoint completed at step 1950000
11:35:44:I1:WU2:Completed 1975000 out of 2500000 steps (79%)
11:37:05:W :WU2:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
11:39:23:I1:WU2:Completed 2000000 out of 2500000 steps (80%)
11:39:44:I1:WU2:Checkpoint completed at step 2000000
11:43:02:I1:WU2:Completed 2025000 out of 2500000 steps (81%)
11:43:26:I1:WU1:Completed 95000 out of 500000 steps (19%)
11:46:21:I1:WU2:Completed 2050000 out of 2500000 steps (82%)
11:46:23:I1:WU2:Checkpoint completed at step 2050000
11:49:43:I1:WU2:Completed 2075000 out of 2500000 steps (83%)
11:53:12:I1:WU2:Completed 2100000 out of 2500000 steps (84%)
11:53:34:I1:WU2:Checkpoint completed at step 2100000
11:56:58:I1:WU2:Completed 2125000 out of 2500000 steps (85%)
12:00:16:I1:WU1:Completed 100000 out of 500000 steps (20%)
12:00:29:I1:WU2:Completed 2150000 out of 2500000 steps (86%)
12:00:57:I1:WU2:Checkpoint completed at step 2150000
12:04:25:I1:WU2:Completed 2175000 out of 2500000 steps (87%)
12:07:39:W :WU2:Detected clock skew (21 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:07:48:W :WU1:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:08:00:I1:WU2:Completed 2200000 out of 2500000 steps (88%)
12:08:32:I1:WU2:Checkpoint completed at step 2200000
12:09:03:W :WU1:Detected clock skew (21 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:10:00:W :WU1:Detected clock skew (23 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:10:04:W :WU2:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:10:43:W :WU2:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:12:25:I1:WU2:Completed 2225000 out of 2500000 steps (89%)
12:12:52:W :WU1:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:13:04:W :WU2:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:13:15:W :WU1:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:14:39:W :WU1:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:16:08:I1:WU2:Completed 2250000 out of 2500000 steps (90%)
12:17:03:I1:WU2:Checkpoint completed at step 2250000
12:17:18:W :WU1:Detected clock skew (19 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:17:37:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:17:46:W :WU2:Detected clock skew (22 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:21:07:W :WU1:Detected clock skew (24 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:21:11:I1:WU1:Completed 105000 out of 500000 steps (21%)
12:21:11:I1:WU2:Completed 2275000 out of 2500000 steps (91%)
12:21:32:W :WU2:Detected clock skew (37 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:21:32:W :WU1:Detected clock skew (21 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:22:37:W :WU1:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:24:33:I1:WU2:Completed 2300000 out of 2500000 steps (92%)
12:24:42:W :WU1:Detected clock skew (22 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:25:21:I1:WU2:Checkpoint completed at step 2300000
12:26:30:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:26:43:W :WU2:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:27:27:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:27:58:W :WU1:Detected clock skew (20 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:28:31:W :WU1:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:29:08:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:29:21:I1:WU2:Completed 2325000 out of 2500000 steps (93%)
12:33:03:I1:WU2:Completed 2350000 out of 2500000 steps (94%)
12:33:06:W :WU1:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:33:06:W :WU2:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:33:17:I1:WU2:Checkpoint completed at step 2350000
12:36:39:I1:WU2:Completed 2375000 out of 2500000 steps (95%)
12:39:40:I1:WU1:Completed 110000 out of 500000 steps (22%)
12:40:15:I1:WU2:Completed 2400000 out of 2500000 steps (96%)
12:40:39:I1:WU2:Checkpoint completed at step 2400000
12:42:46:W :WU2:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:44:10:I1:WU2:Completed 2425000 out of 2500000 steps (97%)
12:44:39:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:47:59:I1:WU2:Completed 2450000 out of 2500000 steps (98%)
12:48:16:I1:WU2:Checkpoint completed at step 2450000
12:51:49:I1:WU2:Completed 2475000 out of 2500000 steps (99%)
12:52:59:W :WU1:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:55:08:W :WU1:Detected clock skew (19 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:55:45:W :WU2:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:55:48:I1:WU2:Completed 2500000 out of 2500000 steps (100%)
12:55:51:I1:WU2:Average performance: 39.3622 ns/day
12:55:51:W :WU1:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:56:04:I1:WU2:Checkpoint completed at step 2500000
12:57:16:W :WU1:Detected clock skew (19 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:57:20:W :WU2:Detected clock skew (22 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:57:55:W :WU2:Detected clock skew (20 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:58:25:I1:WU1:Completed 115000 out of 500000 steps (23%)
12:58:28:I1:WU2:Saving result file ..\logfile_01.txt
12:58:28:I1:WU2:Saving result file checkpointIntegrator.xml
12:58:31:I1:WU2:Saving result file checkpointState.xml.bz2
12:58:54:I1:WU2:Saving result file positions.xtc
12:59:00:W :WU2:Detected clock skew (20 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:59:00:W :WU1:Detected clock skew (23 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
12:59:03:I1:WU2:Saving result file science.log
12:59:05:I1:WU2:Saving result file xtcAtoms.csv.bz2
12:59:17:I1:WU2:Folding@home Core Shutdown: FINISHED_UNIT
13:00:29:W :WU2:Detected clock skew (20 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:00:52:W :WU2:Detected clock skew (23 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:01:02:W :WU1:Detected clock skew (21 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:01:11:W :WU2:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:01:22:W :WU1:Detected clock skew (19 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:01:39:I1:WU2:Core returned FINISHED_UNIT (100)
13:02:11:I1:Default:Added new work unit: cpus:0 gpus:gpu:04:00:00
13:02:16:I1:WU2:Uploading WU results
13:02:17:I1:WU3:Requesting WU assignment for user Anonymous team 0
13:02:21:I1:WU1:WARNING:Console control signal 1 on PID 11260
13:02:21:I1:WU1:Exiting, please wait. . .
13:02:21:I1:OUT13:> POST https://highland1.seas.upenn.edu/api/results HTTP/1.1
13:02:21:I1:OUT14:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
13:02:25:I1:OUT14:< HTTP/1.1 200 HTTP_OK
13:02:30:I1:WU3:Received WU assignment uEIvormQj_amXyr5fjK3WRHl_--TE-xu8hFKbSV-DQs
13:02:30:I1:WU3:Downloading WU
13:02:30:I1:OUT13:< HTTP/1.1 200 HTTP_OK
13:02:30:I1:WU2:Credited
13:05:45:I1:WU1:Folding@home Core Shutdown: INTERRUPTED
13:05:45:W :CON15:DNS lookup failed for highland2.seas.upenn.edu
13:05:45:E :OUT15:Failed response: CONNECT
13:05:45:I1:WU3:Retry #1 in 2 secs
13:05:45:W :WU1:Detected clock skew (4 mins 12 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:05:54:I1:WU3:Downloading WU
13:05:59:I1:OUT16:> POST https://highland2.seas.upenn.edu/api/assign HTTP/1.1
13:06:04:I1:WU1:Core returned INTERRUPTED (102)
13:06:04:I3:WU1:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir 2cO6V_DejTp6iSD2tRyQ9beAkDzqxd1LTvbhkpS6d2U -suffix 01 -version 8.3.18 -lifeline 13292 -np 5
13:06:23:I3:WU1:Started FahCore on PID 13004
13:06:51:I1:OUT16:< HTTP/1.1 200 HTTP_OK
13:06:55:I1:WU3:Received WU P18236 R615 C0 G58
Start of WU3
13:09:55:I1:WU3:Project: 18236 (Run 615, Clone 0, Gen 58)
13:09:55:I1:WU3:*********************** Log Started 2024-11-22T13:09:50Z ***********************
13:09:55:I1:WU3:*************************** Core24 Folding@home Core ***************************
13:09:55:I1:WU3:       Core: Core24
13:09:55:I1:WU3:       Type: 0x24
13:09:55:I1:WU3:    Version: 8.1.4
13:09:55:I1:WU3:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:09:55:I1:WU3:  Copyright: 2022 foldingathome.org
13:09:55:I1:WU3:   Homepage: https://foldingathome.org/
13:09:55:I1:WU3:       Date: Jul 25 2024
13:09:55:I1:WU3:       Time: 05:42:49
13:09:55:I1:WU3:   Revision: cf9f0139862b8945a2091772770e4631aac37792
13:09:55:I1:WU3:     Branch: HEAD
13:09:55:I1:WU3:   Compiler: Visual C++
13:09:55:I1:WU3:    Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
13:09:55:I1:WU3:             /Zc:throwingNew /MT -DOPENMM_VERSION="\"8.1.1\"" /Ox /std:c++14
13:09:55:I1:WU3:   Platform: win32 10
13:09:55:I1:WU3:       Bits: 64
13:09:55:I1:WU3:       Mode: Release
13:09:55:I1:WU3:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:09:55:I1:WU3:             <peastman@stanford.edu>
13:09:55:I1:WU3:       Args: -dir uEIvormQj_amXyr5fjK3WRHl_--TE-xu8hFKbSV-DQs -suffix 01
13:09:55:I1:WU3:             -version 8.3.18 -lifeline 13292 -gpu-vendor nvidia -opencl-platform
13:09:55:I1:WU3:             0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
13:09:55:I1:WU3:************************************ libFAH ************************************
13:09:55:I1:WU3:       Time: 05:23:50
13:09:55:I1:WU3:   Revision: c7d2824a47eb025fa8cda8968c7a5e971585d90c
13:09:55:I1:WU3:    Options: $( /TP $) /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:09:55:I1:WU3:************************************ CBang *************************************
13:09:55:I1:WU3:    Version: 1.7.2
13:09:55:I1:WU3:        Org: Cauldron Development LLC
13:09:55:I1:WU3:  Copyright: Cauldron Development LLC, 2003-2024
13:09:55:I1:WU3:   Homepage: https://cauldrondevelopment.com/
13:09:55:I1:WU3:    License: LGPL-2.1-or-later
13:09:55:I1:WU3:       Time: 05:22:43
13:09:55:I1:WU3:   Revision: f1cd4c791e8c40a35dcfeab3ab85d910949cc0cb
13:09:55:I1:WU3:************************************ System ************************************
13:09:55:I1:WU3:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
13:09:55:I1:WU3:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:09:55:I1:WU3:       CPUs: 8
13:09:55:I1:WU3:     Memory: 15.87GiB
13:09:55:I1:WU3:Free Memory: 11.58GiB
13:09:55:I1:WU3: OS Version: 10.0
13:09:55:I1:WU3:Has Battery: true
13:09:55:I1:WU3: On Battery: false
13:09:55:I1:WU3:   Hostname: DESKTOP-JIR7UQA
13:09:55:I1:WU3: UTC Offset: -6
13:09:55:I1:WU3:        PID: 3284
13:09:55:I1:WU3:        CWD: C:\ProgramData\FAHClient\work
13:09:55:I1:WU3:       Exec: C:\ProgramData\FAHClient\cores\openmm-core-24\windows-10-64bit\release\fahcore-24-windows-10-64bit-release-8.1.4\FahCore_24.exe
13:09:55:I1:WU3:************************************ OpenMM ************************************
13:09:55:I1:WU3:    Version: 8.1.1
13:09:55:I1:WU3:********************************************************************************
13:09:55:I1:WU3:Reading tar file core.xml
13:09:55:I1:WU3:Reading tar file integrator.xml
13:09:55:I1:WU3:Reading tar file state.xml.bz2
13:10:11:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:10:19:I1:WU1:Completed 116012 out of 500000 steps (23%)
13:10:22:I1:WU3:Reading tar file system.xml.bz2
13:10:22:W :WU3:Detected clock skew (26 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:10:22:I1:WU3:Digital signatures verified
13:10:38:W :WU3:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:10:39:I1:WU3:Folding@home GPU Core24 Folding@home Core
13:10:39:I1:WU3:Version 8.1.4
13:11:27:W :WU1:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:11:52:W :WU1:Detected clock skew (19 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:12:21:W :WU3:Detected clock skew (18 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:12:28:I1:WU3:  Checkpoint write interval: 50000 steps (2%) [50 total]
13:12:33:I1:WU3:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
13:12:33:I1:WU3:  XTC frame write interval: 10000 steps (0.4%) [250 total]
13:12:33:I1:WU3:  TRR frame write interval: disabled
13:12:33:I1:WU3:  Global context and integrator variables write interval: disabled
13:12:56:I1:WU3:There are 4 platforms available.
13:13:02:I1:WU3:Platform 0: Reference
13:13:02:I1:WU3:Platform 1: CPU
13:13:02:I1:WU3:Platform 2: OpenCL
13:13:02:I1:WU3:  opencl-device 0 specified
13:13:02:I1:WU3:Platform 3: CUDA
13:13:02:I1:WU3:  cuda-device 0 specified
13:13:35:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:13:44:I1:WU3:Attempting to create CUDA context:
13:13:44:I1:WU3:  Configuring platform CUDA
13:14:52:W :WU3:Detected clock skew (17 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:15:33:W :WU3:Detected clock skew (24 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:15:39:W :WU1:Detected clock skew (23 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:15:57:W :WU3:Detected clock skew (21 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:16:01:W :WU1:Detected clock skew (16 secs), I/O delay, laptop hibernation, other slowdown or clock change noted, adjusting time estimates
13:17:51:I1:WU3:  Using CUDA on CUDA Platform and gpu 0
13:17:51:I1:WU3:  GPU info: Platform: CUDA
13:17:51:I1:WU3:  GPU info: PlatformIndex: 0
13:17:51:I1:WU3:  GPU info: Device: NVIDIA GeForce GTX 1660 SUPER
13:17:51:I1:WU3:  GPU info: DeviceIndex: 0
13:17:51:I1:WU3:  GPU info: Vendor: 0x10de
13:17:51:I1:WU3:  GPU info: PCI: 04:00:00
13:17:51:I1:WU3:  GPU info: Compute: 7.5
13:17:51:I1:WU3:  GPU info: Driver: 12.6
13:17:51:I1:WU3:  GPU info: GPU: true
13:18:05:I1:WU3:Completed 0 out of 2500000 steps (0%)
13:18:11:I1:WU3:Checkpoint completed at step 0
13:21:06:I1:WU3:Completed 25000 out of 2500000 steps (1%)
13:23:42:I1:WU3:Completed 50000 out of 2500000 steps (2%)
13:23:54:I1:WU3:Checkpoint completed at step 50000
13:26:31:I1:WU3:Completed 75000 out of 2500000 steps (3%)
Conclusion of WU3 or Project: 18236 (Run 615, Clone 0, Gen 58)
17:18:33:I1:WU3:Completed 2350000 out of 2500000 steps (94%)
17:18:34:I1:WU3:Checkpoint completed at step 2350000
17:20:54:I1:WU3:Completed 2375000 out of 2500000 steps (95%)
17:23:15:I1:WU3:Completed 2400000 out of 2500000 steps (96%)
17:23:16:I1:WU3:Checkpoint completed at step 2400000
17:25:36:I1:WU3:Completed 2425000 out of 2500000 steps (97%)
17:27:56:I1:WU3:Completed 2450000 out of 2500000 steps (98%)
17:27:57:I1:WU3:Checkpoint completed at step 2450000
17:30:17:I1:WU3:Completed 2475000 out of 2500000 steps (99%)
17:30:24:I1:WU1:Completed 190000 out of 500000 steps (38%)
17:32:38:I1:WU3:Completed 2500000 out of 2500000 steps (100%)
17:32:38:I1:WU3:Average performance: 61.4947 ns/day
17:32:39:I1:WU3:Checkpoint completed at step 2500000
17:32:47:I1:WU3:Saving result file ..\logfile_01.txt
17:32:47:I1:WU3:Saving result file checkpointIntegrator.xml
17:32:47:I1:WU3:Saving result file checkpointState.xml.bz2
17:32:47:I1:WU3:Saving result file positions.xtc
17:32:47:I1:WU3:Saving result file science.log
17:32:47:I1:WU3:Saving result file xtcAtoms.csv.bz2
17:32:47:I1:WU3:Folding@home Core Shutdown: FINISHED_UNIT
17:32:48:I1:WU3:Core returned FINISHED_UNIT (100)
17:32:48:I1:Default:Added new work unit: cpus:0 gpus:gpu:04:00:00
17:32:48:I1:WU3:Uploading WU results
17:32:49:I1:WU4:Requesting WU assignment for user Anonymous team 0
17:32:49:I1:WU1:WARNING:Console control signal 1 on PID 13004
17:32:49:I1:WU1:Exiting, please wait. . .
17:32:49:I1:OUT17:> POST https://highland2.seas.upenn.edu/api/results HTTP/1.1
17:32:49:I1:OUT18:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
17:32:49:I1:OUT18:< HTTP/1.1 200 HTTP_OK
17:32:49:I1:WU4:Received WU assignment J0Y2lB0H_E4AC_0XQLbs_3NCD-MelfTI-Iba4n9ObC8
17:32:49:I1:WU4:Downloading WU
17:32:49:I1:OUT19:> POST https://vav23.fah.temple.edu/api/assign HTTP/1.1
17:32:51:I1:WU1:Folding@home Core Shutdown: INTERRUPTED
17:32:51:I1:OUT17:< HTTP/1.1 200 HTTP_OK
17:32:51:I1:WU3:Credited
17:32:51:I1:OUT19:< HTTP/1.1 200 HTTP_OK
17:32:52:I1:WU4:Received WU P12431 R6 C223 G55
17:32:52:I1:Downloading https://cores2.foldingathome.org/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20.tar.bz2.crt
17:32:52:I1:WU1:Core returned INTERRUPTED (102)
Main Board: GigaByte GA-B85M-D3H, Processor: I7-4770
Memory: 32Gig RAM, GPU: GeForce GTX 1660 MB
PaulTV
Re: Am not getting points for work completed...
Post by PaulTV »
Hi,
When looking at the WU results:
https://apps.foldingathome.org/wu#proje ... ne=5&gen=0
https://apps.foldingathome.org/wu#proje ... e=0&gen=96
https://apps.foldingathome.org/wu#proje ... e=0&gen=58
... it looks like you may have a challenge with your user name, team and possibly pass key settings. For the jobs for which you posted the logging the times seem to match, so it's not that those jobs are returned by someone else.
I am still running v7 clients, so can't help you with the settings themselves though, but that seems what you need to be looking at.
Ryzen 9800X3D / RTX 4090
Ryzen 5800X / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti
All running Fedora 43 with folding client v8.5.6
bollix47
Post by bollix47 »
It appears you have not entered your username or team:
Open web-control and click on login/account
https://foldingathome.org/v8-3-client-guide/
