F@H Client V7.6 GPU Frying
Never happened before in years of folding, however after reinstalling the kernel and installing a downgraded nvidia driver having though 550.120 was a bad Linux driver, I'm still experiencing insane GPU temps almost instantly after starting the client. When F@H isn't running the GPU stays stable with low, normal temps in the 28-32C range. This is happening with any video card I install. Ideas??
Re: F@H Client V7.6 GPU Frying
Might this help? https://ubuntuforums.org/showthread.php?t=2502436
Ryzen 9800X3D / RTX 4090
Ryzen 5800X / RTX 5070 Ti
Ryzen 5600 / RTX 3070 Ti
All running Fedora 43 with folding client v8.5.6
Unfortunately no, that's a link to my post in the Ubuntu Forums, but thanks for the response.
Is it the same topic as this one : viewtopic.php?t=42190 ?
Why do you post the same question at multiple sub forums ? It won't help you get more answers ...
Because the forum is dead and I'm trying to get any info possible,,, Pretty sure, after almost 20 years folding , that F@H and all distributed computing projects are their last legs. $$$$
Take a look at the posting frequency,,,at least I got some response.
A discord was created during COVID, many people go there now instead of here on the forum.
Best I can say about your problem using the info you have split up over multiple topics, is that a number of people have reported various problems using the most recent Nvidia drivers on older Ubuntu versions such as 18.04. There are also issues with available libraries, newer versions exist that may have been used for creating the drivers and folding cores. Not sure where this becomes less of an issue, it is a few years since I ran an Ubuntu system for folding.
I usually ignore people who are double posting.
Thank you for a useful answer, it is most appreciated.Joe_H wrote: ↑Mon Nov 18, 2024 5:11 pm A discord was created during COVID, many people go there now instead of here on the forum.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Fold them if you get them!
