I am getting errors downloading work units. Following errors are in the log file.
2:15:59:I1:WU3116:Received WU assignment xGPZM5EWSJ8YafjVumsHyLamXdaJfRTGj33BNdMto98
22:15:59:I1:WU3116:Downloading WU
22:15:59:I1:OUT1974:> POST https://highland3.seas.upenn.edu/api/assign HTTP/1.1
22:16:59:E :OUT1974:Failed response: EOF
22:16:59:I1:WU3116:Retry #1 in 2 secs
22:17:01:I1:WU3116:Downloading WU
22:17:01:I1:OUT1988:> POST https://highland3.seas.upenn.edu/api/assign HTTP/1.1
22:18:01:E :OUT1988:Failed response: EOF
22:18:01:I1:WU3116:Retry #2 in 4 secs
22:18:05:I1:WU3116:Downloading WU...
When I goto the url it does not show the work server web page and the browser hangs..
Cannot download workunit.
Re: Cannot download workunit.
Had to restart FAH app to get the download to work. Its happened a couple of times now.
ecretcarve
I noticed that retry delays increase with each failed attempt. That could be why restarting helps – it resets the retry count. Maybe setting a longer default retry delay could reduce load on the connection?
Please post the first 100 lines of FAH client log so that we could see your hardware setup ...
I'm getting the same on my Windows and Ubuntu 24.04 machine for GPU work units along with another error
14:16:19:W :Received unsupported remote command 'wus'
*********************** Log Started 2024-12-09T14:22:20Z ***********************
14:22:20:I1:*********************** Folding@home Client ***********************
14:22:20:I1: Version: 8.3.18
14:22:20:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:22:20:I1: Org: foldingathome.org
14:22:20:I1: Copyright: 2023-2024, foldingathome.org
14:22:20:I1: Homepage: https://foldingathome.org/
14:22:20:I1: License: GPL-3.0-or-later
14:22:20:I1: URL: https://v8-3.foldingathome.org/
14:22:20:I1: Date: Jul 12 2024
14:22:20:I1: Time: 13:26:31
14:22:20:I1: Revision: 99ae953ee7b1c0b3070161cfcf9150184f76bd96
14:22:20:I1: Branch: master
14:22:20:I1: Compiler: GNU 8.3.0
14:22:20:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
14:22:20:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
14:22:20:I1: Platform: linux 4.19.0-26-cloud-amd64
14:22:20:I1: Bits: 64
14:22:20:I1: Mode: Release
14:22:20:I1: Args: --config=/etc/fah-client/config.xml
14:22:20:I1: --log=/var/log/fah-client/log.txt
14:22:20:I1: --log-rotate-dir=/var/log/fah-client/
14:22:20:I1: Config: /etc/fah-client/config.xml
14:22:20:I1:****************************** CBang ******************************
14:22:20:I1: Version: 1.7.2
14:22:20:I1: Org: Cauldron Development
14:22:20:I1: Copyright: Cauldron Development, 2003-2024
14:22:20:I1: Homepage: https://cauldrondevelopment.com/
14:22:20:I1: License: LGPL-2.1-or-later
14:22:20:I1: Date: Jun 24 2024
14:22:20:I1: Time: 13:29:44
14:22:20:I1: Revision: 1b05ea96f0ed3043c32b78a66dbf50a9b2002289
14:22:20:I1: -fPIC
14:22:20:I1:***************************** System ******************************
14:22:20:I1: CPU: Common KVM processor
14:22:20:I1: CPU ID: GenuineIntel Family 15 Model 6 Stepping 1
14:22:20:I1: CPUs: 6
14:22:20:I1: Memory: 15.58GiB
14:22:20:I1:Free Memory: 11.97GiB
14:22:20:I1: OS Version: 6.8
14:22:20:I1:Has Battery: false
14:22:20:I1: On Battery: false
14:22:20:I1: Hostname: orion-server
14:22:20:I1: UTC Offset: -5
14:22:20:I1: PID: 7364
14:22:20:I1: CWD: /var/lib/fah-client
14:22:20:I1: Exec: /usr/bin/fah-client
14:22:20:I1:*******************************************************************-
Nothing to worry about. The wus command is for v8.4 client.
