Account not replicating - Disconnected
Demmers
Post by Demmers »
After a two year hiatus, I have returned to folding, and got the latest version installed on my Windows setup. All good on that machine, folding fine.
However, I have noticed that my account when logged into on my iphone no longer shows its current status. Yesterday during the first WU I could follow it just fine, but after it completed yesterday evening, the account when logged into on my phone doesn't recognise the new WU and instead shows as Disconnected - No Work Units.
Interestingly, I have noticed a user on Reddit saying the same thing https://www.reddit.com/r/Folding/commen ... g_my_mind/
Is this happening for anyone else, or anyone know what might be happening here?
Also of note, my stats haven't updated since the WU completed yesterday, even though i've used the same passkey as years before.
Demmers
Re: Account not replicating - Disconnected
Post by Demmers »
Things are getting even weirder. Just tried to start a new WU manually to see if I could start it from the phone. It would start on the phone but not sync on the machine itself (Disconnected). Then noticed I had multiple icons in the System Tray. One said Failed, the other was asleep?, the other running. So I quit the first two, and now the WU is showing on the machine. Go back to the phone... Disconnected?!
I just looked in the logs, which don't make much sense. The first half from the beginning of trying to start the console show the correct time. Then I get an error regarding a .txt file at midnight, then after more errors, the WU starts, but now the time is one hour behind?!
18:17:05:I1:*********************** Folding@home Client ***********************
18:17:05:I1: Version: 8.3.18
18:17:05:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:17:05:I1: Org: foldingathome.org
18:17:05:I1: Copyright: 2023-2024, foldingathome.org
18:17:05:I1: Homepage: https://foldingathome.org/
18:17:05:I1: License: GPL-3.0-or-later
18:17:05:I1: URL: https://v8-3.foldingathome.org/
18:17:05:I1: Date: Jul 12 2024
18:17:05:I1: Time: 13:26:51
18:17:05:I1: Revision: 99ae953ee7b1c0b3070161cfcf9150184f76bd96
18:17:05:I1: Branch: master
18:17:05:I1: Compiler: Visual C++
18:17:05:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
18:17:05:I1: /Zc:throwingNew /MT
18:17:05:I1: Platform: win32 10
18:17:05:I1: Bits: 64
18:17:05:I1: Mode: Release
18:17:05:I1: Args: --open-web-control
18:17:05:I1:****************************** CBang ******************************
18:17:05:I1: Version: 1.7.2
18:17:05:I1: Org: Cauldron Development
18:17:05:I1: Copyright: Cauldron Development, 2003-2024
18:17:05:I1: Homepage: https://cauldrondevelopment.com/
18:17:05:I1: License: LGPL-2.1-or-later
18:17:05:I1: Date: Jun 24 2024
18:17:05:I1: Time: 13:29:54
18:17:05:I1: Revision: 1b05ea96f0ed3043c32b78a66dbf50a9b2002289
18:17:05:I1:***************************** System ******************************
18:17:05:I1: CPU: AMD Ryzen 5 3400G with Radeon Vega Graphics
18:17:05:I1: CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
18:17:05:I1: CPUs: 8
18:17:05:I1: Memory: 13.92GiB
18:17:05:I1:Free Memory: 11.45GiB
18:17:05:I1: OS Version: 6.2
18:17:05:I1:Has Battery: false
18:17:05:I1: On Battery: false
18:17:05:I1: Hostname: PC
18:17:05:I1: UTC Offset: 1
18:17:05:I1: PID: 3700
18:17:05:I1: CWD: C:\ProgramData\FAHClient
18:17:05:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
18:17:05:I1:*******************************************************************
18:17:05:I2:<config/>
18:17:05:I1:Opening Database
18:17:05:I1:F@H ID = bmI9bFj5zbsJLJ7qJu77jbLFSXT_4zJscQZBjXsQJbQ
18:17:05:I3:Loading default group
18:17:05:I3:Loading default resource group
18:17:05:I1:Listening for HTTP on 127.0.0.1:7396
18:17:05:I3:Loaded 0 wus.
18:17:06:I1:Started Windows systray control
18:17:06:W :CUDA not supported: Failed to open dynamic library 'nvcuda.dll': The specified module could not be found.
18:17:06:I3:gpus = {
18:17:06:I3: "gpu:10:00:00": {
18:17:06:I3: "vendor": 4098,
18:17:06:I3: "type": "amd",
18:17:06:I3: "description": "gfx902",
18:17:06:I3: "opencl": {"platform": 0, "device": 0, "compute": "2.0", "driver": "3584.0"},
18:17:06:I3: "device": 5592,
18:17:06:I3: "supported": true
18:17:06:I3: }
18:17:06:I3:}
18:17:06:I1:OUT1:> GET https://api.foldingathome.org/machine/bmI9bFj5zbsJLJ7qJu77jbLFSXT_4zJscQZBjXsQJbQ HTTP/1.1
18:17:06:I1:OUT1:< HTTP/1.1 200 HTTP_OK
18:17:06:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
18:17:07:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
18:17:07:I1:Logging into node account
23:59:59:E :Exception: Failed to rename 'log.txt' to 'logs\log-20241021-235959.txt': The process cannot access the file because it is being used by another process.
17:22:51:I1:Default:Added new work unit: cpus:6 gpus:
17:22:51:I1:WU5:Requesting WU assignment for user Demmers team 76140
17:22:51:I1:OUT3:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
17:22:52:I1:OUT3:< HTTP/1.1 200 HTTP_OK
17:22:52:I1:WU5:Received WU assignment q7_WMUjU7PeExFTrBm00igv34e5N3me7ahhXxIb7vng
17:22:52:I1:WU5:Downloading WU
17:22:52:I1:OUT4:> POST https://vav21.fah.temple.edu/api/assign HTTP/1.1
17:22:52:I1:OUT4:< HTTP/1.1 200 HTTP_OK
17:22:52:I1:WU5:Received WU P18494 R1 C13 G59
17:22:52:I1:Loaded cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe
17:22:52:I3:WU5:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir q7_WMUjU7PeExFTrBm00igv34e5N3me7ahhXxIb7vng -suffix 01 -version 8.3.18 -lifeline 3700 -np 6
17:22:52:I3:WU5:Started FahCore on PID 4536
17:22:53:I1:WU5:*********************** Log Started 2024-10-22T17:22:53Z ***********************
17:22:53:I1:WU5:************************** Gromacs Folding@home Core ***************************
17:22:53:I1:WU5: Core: Gromacs
17:22:53:I1:WU5: Type: 0xa8
17:22:53:I1:WU5: Version: 0.0.12
17:22:53:I1:WU5: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:22:53:I1:WU5: Copyright: 2020 foldingathome.org
17:22:53:I1:WU5: Homepage: https://foldingathome.org/
17:22:53:I1:WU5: Date: Jan 16 2021
17:22:53:I1:WU5: Time: 12:29:40
17:22:53:I1:WU5: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:22:53:I1:WU5: Branch: master
17:22:53:I1:WU5: Compiler: Visual C++ 2019 16.7
17:22:53:I1:WU5: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:22:53:I1:WU5: Platform: win32 10
17:22:53:I1:WU5: Bits: 64
17:22:53:I1:WU5: Mode: Release
17:22:53:I1:WU5: SIMD: avx2_256
17:22:53:I1:WU5: OpenMP: ON
17:22:53:I1:WU5: CUDA: OFF
17:22:53:I1:WU5: Args: -dir q7_WMUjU7PeExFTrBm00igv34e5N3me7ahhXxIb7vng -suffix 01
17:22:53:I1:WU5: -version 8.3.18 -lifeline 3700 -np 6
17:22:53:I1:WU5:************************************ libFAH ************************************
17:22:53:I1:WU5: Time: 11:24:13
17:22:53:I1:WU5:************************************ CBang *************************************
17:22:53:I1:WU5: Time: 11:23:53
17:22:53:I1:WU5:************************************ System ************************************
17:22:53:I1:WU5: CPU: AMD Ryzen 5 3400G with Radeon Vega Graphics
17:22:53:I1:WU5: CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
17:22:53:I1:WU5: CPUs: 8
17:22:53:I1:WU5: Memory: 13.92GiB
17:22:53:I1:WU5:Free Memory: 9.95GiB
17:22:53:I1:WU5: Threads: WINDOWS_THREADS
17:22:53:I1:WU5: OS Version: 6.2
17:22:53:I1:WU5:Has Battery: false
17:22:53:I1:WU5: On Battery: false
17:22:53:I1:WU5: UTC Offset: 1
17:22:53:I1:WU5: PID: 4536
17:22:53:I1:WU5: CWD: C:\ProgramData\FAHClient\work
17:22:53:I1:WU5:********************************************************************************
17:22:53:I1:WU5:Project: 18494 (Run 1, Clone 13, Gen 59)
17:22:53:I1:WU5:Unit: 0x00000000000000000000000000000000
17:22:53:I1:WU5:Reading tar file core.xml
17:22:53:I1:WU5:Reading tar file frame59.tpr
17:22:53:I1:WU5:Digital signatures verified
17:22:53:I1:WU5:Calling: mdrun -c frame59.gro -s frame59.tpr -x frame59.xtc -cpt 5 -nt 6 -ntmpi 1
17:22:53:I1:WU5:Steps: first=295000000 total=300000000
17:22:53:I1:WU5:Completed 1 out of 5000000 steps (0%)
17:24:20:I1:Account websocket closed: UNACCEPTABLE msg=
17:24:20:I1:OUT5:> GET https://api.foldingathome.org/machine/bmI9bFj5zbsJLJ7qJu77jbLFSXT_4zJscQZBjXsQJbQ HTTP/1.1
17:24:21:I1:OUT5:< HTTP/1.1 200 HTTP_OK
17:24:21:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
17:24:21:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
17:24:21:I1:Logging into node account
17:24:54:I1:Account websocket closed: UNACCEPTABLE msg=
17:24:54:I1:OUT6:> GET https://api.foldingathome.org/machine/bmI9bFj5zbsJLJ7qJu77jbLFSXT_4zJscQZBjXsQJbQ HTTP/1.1
17:24:55:I1:OUT6:< HTTP/1.1 200 HTTP_OK
17:24:55:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
17:24:55:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
17:24:55:I1:Logging into node account
17:25:29:I1:Account websocket closed: UNACCEPTABLE msg=
17:25:29:I1:OUT7:> GET https://api.foldingathome.org/machine/bmI9bFj5zbsJLJ7qJu77jbLFSXT_4zJscQZBjXsQJbQ HTTP/1.1
17:25:30:I1:OUT7:< HTTP/1.1 200 HTTP_OK
17:25:30:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
17:25:31:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
17:25:31:I1:Logging into node account
17:25:54:I1:Account websocket closed: UNACCEPTABLE msg=
17:25:54:I1:OUT8:> GET https://api.foldingathome.org/machine/bmI9bFj5zbsJLJ7qJu77jbLFSXT_4zJscQZBjXsQJbQ HTTP/1.1
17:25:55:I1:OUT8:< HTTP/1.1 200 HTTP_OK
17:25:55:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
17:25:56:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
17:25:56:I1:Logging into node account
17:26:39:I1:Account websocket closed: UNACCEPTABLE msg=
17:26:39:I1:OUT9:> GET https://api.foldingathome.org/machine/bmI9bFj5zbsJLJ7qJu77jbLFSXT_4zJscQZBjXsQJbQ HTTP/1.1
17:26:39:I1:OUT9:< HTTP/1.1 200 HTTP_OK
17:26:39:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
17:26:40:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
17:26:40:I1:Logging into node account
17:30:11:I1:WU5:Completed 50000 out of 5000000 steps (1%)
17:35:07:I1:WU5:Completed 100000 out of 5000000 steps (2%)
17:40:06:I1:WU5:Completed 150000 out of 5000000 steps (3%)
17:44:55:I1:WU5:Completed 200000 out of 5000000 steps (4%)
Demmers
Post by Demmers »
Mystery solved I think! I disabled the Intrusion Detection system of part of my home firewall network, and once I refreshed the phone, it immediately synced! Now just a case of me figuring out what the false positive was that was causing the block.
