Please add Nvidia CMP 70HX (GA104 A1)
80-wattHamster
Post by 80-wattHamster »
Name: NVIDIA CMP 70HX
Device ID: 10DE 248A - 10DE 248A
*********************** Log Started 2024-10-11T04:13:51Z ***********************
04:13:51:******************************* libFAH ********************************
04:13:51:           Date: Oct 20 2020
04:13:51:           Time: 13:36:55
04:13:51:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
04:13:51:         Branch: master
04:13:51:       Compiler: Visual C++ 2015
04:13:51:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:13:51:       Platform: win32 10
04:13:51:           Bits: 32
04:13:51:           Mode: Release
04:13:51:****************************** FAHClient ******************************
04:13:51:        Version: 7.6.21
04:13:51:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:13:51:      Copyright: 2020 foldingathome.org
04:13:51:       Homepage: https://foldingathome.org/
04:13:51:           Time: 13:41:04
04:13:51:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
04:13:51:           Bits: 32
04:13:51:           Args: --open-web-control
04:13:51:         Config: C:\ProgramData\FAHClient\config.xml
04:13:51:******************************** CBang ********************************
04:13:51:           Time: 11:36:18
04:13:51:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
04:13:51:           Bits: 32
04:13:51:******************************* System ********************************
04:13:51:            CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
04:13:51:         CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
04:13:51:           CPUs: 16
04:13:51:         Memory: 15.83GiB
04:13:51:    Free Memory: 13.41GiB
04:13:51:        Threads: WINDOWS_THREADS
04:13:51:     OS Version: 6.2
04:13:51:    Has Battery: false
04:13:51:     On Battery: false
04:13:51:     UTC Offset: -5
04:13:51:            PID: 9888
04:13:51:            CWD: C:\ProgramData\FAHClient
04:13:51:  Win32 Service: false
04:13:51:             OS: Windows 10 Enterprise
04:13:51:        OS Arch: AMD64
04:13:51:           GPUs: 2
04:13:51:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
04:13:51:          GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 CML GT2 [UHD Graphics 630]
04:13:51:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:12.2
04:13:51:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:31.0
04:13:51:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:536.23
04:13:51:***********************************************************************
04:13:51:<config>
04:13:51:  <!-- Network -->
04:13:51:  <proxy v=':8080'/>
04:13:51:
04:13:51:  <!-- Slot Control -->
04:13:51:  <power v='full'/>
04:13:51:
04:13:51:  <!-- User Information -->
04:13:51:  <passkey v='*****'/>
04:13:51:  <team v='50711'/>
04:13:51:  <user v='80wattHamster'/>
04:13:51:
04:13:51:  <!-- Folding Slots -->
04:13:51:  <slot id='0' type='GPU'>
04:13:51:    <pci-bus v='0'/>
04:13:51:    <pci-slot v='2'/>
04:13:51:  </slot>
04:13:51:  <slot id='3' type='GPU'>
04:13:51:    <pci-bus v='1'/>
04:13:51:    <pci-slot v='0'/>
04:13:51:  </slot>
04:13:51:</config>
04:13:51:Trying to access database...
04:13:51:Successfully acquired database lock
04:13:51:WARNING:FS00:Guessing ambiguous GPU to OpenCL device mapping for 00: gpu:0:2 CML GT2 [UHD Graphics 630].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
04:13:51:WARNING:FS00:Disabling beta GPU slot 00: gpu:0:2 CML GT2 [UHD Graphics 630].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
04:13:51:WARNING:FS03:Disabling beta GPU slot 03: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
04:13:51:ERROR:No valid folding configuration
04:13:57:4:127.0.0.1:New Web session
Re: Please add Nvidia CMP 70HX (GA104 A1)
Added the following GPUs that were missing :
0x248a / GA104 [CMP 70HX]
0x248c / GA104 [GeForce RTX 3070 Ti]
0x248d / GA104 [GeForce RTX 3070]
0x248e / GA104 [GeForce RTX 3060 Ti]
80-wattHamster
toTOW wrote: Fri Oct 11, 2024 6:33 pm Added the following GPUs that were missing :
Thank you very much!
