Which fan settings for 5700XT
dominicgarcia
What fan settings do people recommend for a 5700XT? I wonder if the default fan settings aren't meant to keep it at a temperature that's safe for 24/7 operation, and maybe I should turn it up a bit?
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Which fan settings for 5700XT
That depends on case size, system fans, airflow, etc.... as well as how much heat your GPU makes at your power settings.
I often bump the stock fan curves a bit on my GPU, as I like to keep it running cooler since it folds 24/7. Since I usually run power limited I can easily keep temps down below about 60C without the fans running quick enough to make any noise that is noticed.
Fold them if you get them!
