Alright Pande Group, I'm ready to do some folding work with my brain, so lets get that cerebral client working.Think your computer is fast? Check out your brain.
The human brain is faster than any computer in the world, including the new RoadRunner supercomputer at Los Alamos National Laboratory that clocked in last month at a staggering 1.144 petaflop/s, just one part of the cerebral network can perform an as yet immeasurable number of calculations per second. The visual cortex alone, which scientists tried to mimic only a small part of while setting the supercomputer speed record, defies nature with its incredibly ability to process information.
Why not put that power to use to perform artificial calculations? Mark Changizi, Assistant Professor of Cognitive Science at Rensselaer Polytechnic Institute thinks that harnessing human cognizance could produce a powerful system for doing just that.
Changizi has been developing a system of visual cues designed to represent simple circuit logic, much like the basis of all computer programming. His visual circuits so far contain a “wire” and NOT, OR and AND functions, which are important for logic operations.
To get to the heart of the Changizi's visual circuit system, it's all based on perception. The wires and constructs as represented can easily be seen in different ways, like an optical illusion. However, just like binary, the system has 0 and 1 settings, which serve to force a perceived angle onto the drawing. This angle forces the brain to see a particular wire as either a 0 or 1 wire, and can be switched by the different operators and their visual representations.
“A digital circuit needs wire in order to transmit signals to different parts of the circuit. The ‘wire’ in a visual representation of a digital circuit is part of the drawing itself, which can be perceived only in two ways. An input to a digital circuit is a zero or one. Similarly, an input to a visual version of the circuit is an unambiguous cue to the tilt at that part of the circuit,” explains Changizi.
He goes on to explain how the various operators influence the information processing being done by the visual cortex. “Visually represented NOT gates flip a box’s perceived tilt as you work through a circuit, and OR gates are designed with transparency cues so that the elicited perception is always that the box is tilted toward you, unless overridden. The AND gate is similarly designed with transparency cues, but contrary to the OR gate, it will always favor the perception that it is tilted away from you.”
To help make some sense of this, the NOT, OR and AND operators perform specific tasks in logic processing. The NOT operator simply changes a 0 to 1 or 1 to 0. In respect to the Changizi's visual system, this is the same as flipping the perceived tilt of the circuit towards or away from the viewer. The OR operator always outputs a 1 (tilted toward viewer) if either or any of the circuit's inputs are in the 1 state. Finally, the AND operator tilts the wire towards the viewer only if both or all inputs are in the 1 state.
While the system is powerful in scope, at the base of it still lays human perception, which can sometimes be flawed. Not everyone can follow the circuits correctly but Changizi feels this is something that could be learned by viewers, similarly to how humans learn to read. There are also more components a complex virtual circuit would require, which he hopes that other perception experts will help realize.
While new supercomputers continue to the push the limits of processing power, creeping closer to matching the abilities of human cognizance, the idea of using cognizance itself, particularly perception, an easily influenced area of the brain, is a novel approach that may hold promise not only for designing powerful means of calculating, but for unlocking the inner workings of the brain.
FAH on your brain?
DarkElfa
- Hardware configuration: Gaming Bomb 2 case
Asus P5KC
Sigma Shark SP-635
Intel Q6600 @ 3Ghz
8 GB OCZ Reaper HPC DDR2-800
ATI Radeon HD 4870 Cat 8.7
SB XFi-Pro
3x Hitachi 1TB Deskstars
Logitech MX Revolution laser mouse
Logitech G15 Keyboard
Onkyo Reciever w/Polk 6.1 Speakers
Dell 3007WFP 30" WS @ 2560x1600 - Location: Cincinnati, Ohio, United States 45230
FAH on your brain?
Foxery
- Hardware configuration: Intel Core2 Quad Q9300 (Intel P35 chipset)
Radeon 3850, 512MB model (Catalyst 8.10)
Windows XP, SP2 - Location: Syracuse, NY
Re: FAH on your brain?
http://www.imdb.com/title/tt0113481/ Careful, Johnny, doubling your RAM causes brain damage!
Core2 Quad/Q9300, Radeon 3850/512MB (WinXP SP2)
Generally, human brains suck with any calculation. If anything then N-body simulation and force field calculations by heart is way too complex for being computed on human brain. Plainly put, the end results will not be correct and can not be trusted
Maybe there is a clever method to eliminate calculations from the folding process and describe the process as a puzzle. Only then the general public can tackle the protein folding.
Note: Human brain is quite good for analysis and Pande Group already have staff set for that purpose.
yeah i believe that human brain is smarter than computer...why?obviously, because human made the computers haha
new08
- Hardware configuration: Hewlett-Packard 1494 Win10 Build 1836
GeForce [MSI] GTX 950
Runs F@H Ver7.6.21
[As of Jan 2021] - Location: England
Yeah..smart comment
But...how smart is quick if the input is wrong and conversely how quick is smart if you're chasing moonbeams? Eh ??
damien_moore
Amazingly, I had the same idea, but I thought it was too stupid to put up lmao xD
Member of Nyx Online (160109)
ferrari12508
- Hardware configuration: Intel E6550 OC'ed
Geforce 9800GT OC'ed
Radeon 2600Pro OC'ed
WD 160GB SATA HD
500W Rosewill PSU
2GB OCZ Gold Edition RAM - Location: Central New Jersey
