Log for a Failure of Core 24 and Project 18237
Badsinger
Post by Badsinger »
00:55:20:WU00:FS05:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18237 run:933 clone:1 gen:4 core:0x24 unit:0x00000001000000040000473d000003a5
00:55:20:WU00:FS05:Starting
00:55:20:WU00:FS05:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 1417 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:55:20:WU00:FS05:Started FahCore on PID 7643
00:55:20:WU00:FS05:Core PID:7647
00:55:20:WU00:FS05:FahCore 0x24 started
00:55:20:WARNING:WU00:FS05:FahCore returned: FAILED_2 (1 = 0x1)
00:55:20:WU00:FS05:Started FahCore on PID 7648
00:55:20:WU00:FS05:Core PID:7652
00:55:21:WARNING:WU00:FS05:FahCore returned: FAILED_2 (1 = 0x1)
00:56:20:WU00:FS05:Starting
00:56:20:WU00:FS05:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 1417 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:56:20:WU00:FS05:Started FahCore on PID 7653
00:56:20:WU00:FS05:Core PID:7657
00:56:20:WU00:FS05:FahCore 0x24 started
00:56:21:WARNING:WU00:FS05:FahCore returned: FAILED_2 (1 = 0x1)
00:57:20:WU00:FS05:Starting
00:57:20:WU00:FS05:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 1417 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:57:20:WU00:FS05:Started FahCore on PID 7659
00:57:20:WU00:FS05:Core PID:7663
00:57:20:WU00:FS05:FahCore 0x24 started
00:57:21:WARNING:WU00:FS05:FahCore returned: FAILED_2 (1 = 0x1)
00:58:20:WU00:FS05:Starting
00:58:20:WU00:FS05:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 1417 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:58:20:WU00:FS05:Started FahCore on PID 7665
00:58:20:WU00:FS05:Core PID:7669
00:58:20:WU00:FS05:FahCore 0x24 started
00:58:21:WARNING:WU00:FS05:FahCore returned: FAILED_2 (1 = 0x1)
00:58:21:WARNING:WU00:FS05:Too many errors, failing
00:58:21:WU00:FS05:Sending unit results: id:00 state:SEND error:FAILED project:18237 run:933 clone:1 gen:4 core:0x24 unit:0x00000001000000040000473d000003a5
00:58:21:WU00:FS05:Connecting to 158.130.118.23:8080
00:58:21:WU00:FS05:Server responded WORK_ACK (400)
00:58:21:WU00:FS05:Cleaning up
00:58:22:WU01:FS05:Connecting to assign1.foldingathome.org:80
00:58:22:WU01:FS05:Assigned to work server 158.130.118.26
00:58:22:WU01:FS05:Requesting new work unit for slot 05: gpu:1:0 AD103 [GeForce RTX 4080] from 158.130.118.26
00:58:22:WU01:FS05:Connecting to 158.130.118.26:8080
00:58:23:WU01:FS05:Downloading 23.42MiB
00:58:29:WU01:FS05:Download 31.76%
00:58:35:WU01:FS05:Download 43.77%
00:58:39:WU01:FS05:Download complete
00:58:39:WU01:FS05:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18223 run:9837 clone:1 gen:4 core:0x23 unit:0x00000001000000040000472f0000266d
00:58:39:WU01:FS05:Starting
00:58:39:WU01:FS05:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23 -dir 01 -suffix 01 -version 706 -lifeline 1417 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:58:39:WU01:FS05:Started FahCore on PID 7670
00:58:39:WU01:FS05:Core PID:7674
00:58:39:WU01:FS05:FahCore 0x23 started
00:58:40:WU01:FS05:0x23:*********************** Log Started
The O/S is Mint 19.3 The system info for the Core 23 that followed the Core 24 fail follows
00:58:40:WU01:FS05:0x23:*********************** Log Started 2024-10-07T00:58:39Z ***********************
00:58:40:WU01:FS05:0x23:*************************** Core23 Folding@home Core ***************************
00:58:40:WU01:FS05:0x23:       Core: Core23
00:58:40:WU01:FS05:0x23:       Type: 0x23
00:58:40:WU01:FS05:0x23:    Version: 8.0.3
00:58:40:WU01:FS05:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:58:40:WU01:FS05:0x23:  Copyright: 2022 foldingathome.org
00:58:40:WU01:FS05:0x23:   Homepage: https://foldingathome.org/
00:58:40:WU01:FS05:0x23:       Date: Aug 3 2023
00:58:40:WU01:FS05:0x23:       Time: 08:28:22
00:58:40:WU01:FS05:0x23:   Revision: 199cb870317d05441d0a301287d9ef61254fa32b
00:58:40:WU01:FS05:0x23:     Branch: HEAD
00:58:40:WU01:FS05:0x23:   Compiler: GNU 7.5.0
00:58:40:WU01:FS05:0x23:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
00:58:40:WU01:FS05:0x23:             -fdata-sections -O3 -funroll-loops -fno-pie
00:58:40:WU01:FS05:0x23:             -DOPENMM_VERSION="\"8.0.0\""
00:58:40:WU01:FS05:0x23:   Platform: linux 5.15.0-1041-azure
00:58:40:WU01:FS05:0x23:       Bits: 64
00:58:40:WU01:FS05:0x23:       Mode: Release
00:58:40:WU01:FS05:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:58:40:WU01:FS05:0x23:             <peastman@stanford.edu>
00:58:40:WU01:FS05:0x23:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7670 -checkpoint 15
00:58:40:WU01:FS05:0x23:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:58:40:WU01:FS05:0x23:             nvidia -gpu 0 -gpu-usage 100
00:58:40:WU01:FS05:0x23:************************************ libFAH ************************************
00:58:40:WU01:FS05:0x23:       Time: 08:27:48
00:58:40:WU01:FS05:0x23:   Revision: 112c2234abe20611a05652defc3c7f854cbf927f
00:58:40:WU01:FS05:0x23:************************************ CBang *************************************
00:58:40:WU01:FS05:0x23:    Version: 1.7.2
00:58:40:WU01:FS05:0x23:        Org: Cauldron Development LLC
00:58:40:WU01:FS05:0x23:  Copyright: Cauldron Development LLC, 2003-2023
00:58:40:WU01:FS05:0x23:   Homepage: https://cauldrondevelopment.com/
00:58:40:WU01:FS05:0x23:    License: GPL 2+
00:58:40:WU01:FS05:0x23:       Time: 08:27:30
00:58:40:WU01:FS05:0x23:   Revision: eae4b58965bdd4d54ea9eb77972674352b37a547
00:58:40:WU01:FS05:0x23:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
00:58:40:WU01:FS05:0x23:************************************ System ************************************
00:58:40:WU01:FS05:0x23:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
00:58:40:WU01:FS05:0x23:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
00:58:40:WU01:FS05:0x23:       CPUs: 8
00:58:40:WU01:FS05:0x23:     Memory: 15.58GiB
00:58:40:WU01:FS05:0x23:Free Memory: 11.43GiB
00:58:40:WU01:FS05:0x23:    Threads: POSIX_THREADS
00:58:40:WU01:FS05:0x23: OS Version: 5.4
00:58:40:WU01:FS05:0x23:Has Battery: false
00:58:40:WU01:FS05:0x23: On Battery: false
00:58:40:WU01:FS05:0x23: UTC Offset: -5
00:58:40:WU01:FS05:0x23:        PID: 7674
00:58:40:WU01:FS05:0x23:        CWD: /var/lib/fahclient/work
00:58:40:WU01:FS05:0x23:       Exec: /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-23/centos-7.9.2009-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23
00:58:40:WU01:FS05:0x23:************************************ OpenMM ************************************
00:58:40:WU01:FS05:0x23:    Version: 8.0.0
00:58:40:WU01:FS05:0x23:********************************************************************************
00:58:40:WU01:FS05:0x23:Project: 18223 (Run 9837, Clone 1, Gen 4)
00:58:40:WU01:FS05:0x23:Reading tar file core.xml
00:58:40:WU01:FS05:0x23:Reading tar file integrator.xml
00:58:40:WU01:FS05:0x23:Reading tar file state.xml.bz2
00:58:40:WU01:FS05:0x23:Reading tar file system.xml.bz2
00:58:40:WU01:FS05:0x23:Digital signatures verified
00:58:40:WU01:FS05:0x23:Folding@home GPU Core23 Folding@home Core
00:58:40:WU01:FS05:0x23:Version 8.0.3
00:58:40:WU01:FS05:0x23:  Checkpoint write interval: 25000 steps (2%) [50 total]
00:58:40:WU01:FS05:0x23:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
00:58:40:WU01:FS05:0x23:  XTC frame write interval: 10000 steps (0.8%) [125 total]
00:58:40:WU01:FS05:0x23:  Global context and integrator variables write interval: disabled
00:58:40:WU01:FS05:0x23:There are 4 platforms available.
00:58:40:WU01:FS05:0x23:Platform 0: Reference
00:58:40:WU01:FS05:0x23:Platform 1: CPU
00:58:40:WU01:FS05:0x23:Platform 2: OpenCL
00:58:40:WU01:FS05:0x23:  opencl-device 0 specified
00:58:40:WU01:FS05:0x23:Platform 3: CUDA
00:58:40:WU01:FS05:0x23:  cuda-device 0 specified
00:58:47:WU01:FS05:0x23:Attempting to create CUDA context:
00:58:47:WU01:FS05:0x23:  Configuring platform CUDA
00:58:51:WU01:FS05:0x23:  Using CUDA on CUDA Platform and gpu 0
00:58:51:WU01:FS05:0x23:  GPU info: Platform: CUDA
00:58:51:WU01:FS05:0x23:  GPU info: PlatformIndex: 0
00:58:51:WU01:FS05:0x23:  GPU info: Device: NVIDIA GeForce RTX 4080
00:58:51:WU01:FS05:0x23:  GPU info: DeviceIndex: 0
00:58:51:WU01:FS05:0x23:  GPU info: Vendor: 0x10de
00:58:51:WU01:FS05:0x23:  GPU info: PCI: 01:00:00
00:58:51:WU01:FS05:0x23:  GPU info: Compute: 8.9
00:58:51:WU01:FS05:0x23:  GPU info: Driver: 12.0
00:58:51:WU01:FS05:0x23:  GPU info: GPU: true
Core 24 is only failing on my Linux Machine. The Windows 10 boxes run core 24 fine. Let me know if I missed info you need.
Re: Log for a Failure of Core 24 and Project 18237
One of the moderators, toTOW, has posted - viewtopic.php?p=365762#p365762 - that Core 24 may require a newer version of glibc than available in Ubuntu before version 20. Mint 19.3 is based on Ubuntu 18.04 LTS, so may bee too old for that core.
