18237 crashes on E5-2640 V3 and rtx 3080
Bsb5068
Post by Bsb5068 »
hi!
i've got this configuration:
# free
              total        used        free      shared  buff/cache   available
Mem:       16239932     4990348     9094824      597800     2154760    10176476
Swap:      16777212           0    16777212
> info
PyON 1 info
    "FAHClient",
    ["Version", "7.6.13"],
    ["Author", "Joseph Coffland <joseph@cauldrondevelopment.com>"],
    ["Copyright", "2020 foldingathome.org"],
    ["Homepage", "https://foldingathome.org/"],
    ["Date", "Apr 28 2020"],
    ["Time", "04:20:16"],
    ["Revision", "5a652817f46116b6e135503af97f18e094414e3b"],
    ["Branch", "master"],
    ["Compiler", "GNU 8.3.0"],
    ["Options", "-std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie"],
    ["Platform", "linux2 4.19.0-5-amd64"],
    ["Bits", "64"],
    ["Mode", "Release"],
    ["Config", "/var/lib/fahclient/config.xml"]
    "CBang",
    ["Date", "Apr 25 2020"],
    ["Time", "00:07:53"],
    ["Revision", "ea081a3b3b0f4a37c4d0440b4f1bc184197c7797"],
    ["Options", "-std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie -fPIC"],
    ["Bits", "64"],
    ["Mode", "Release"]
    "System",
    ["CPU", "Intel(R) Xeon(R) CPU E5-2640 v3 @ 2.60GHz"],
    ["CPU ID", "GenuineIntel Family 6 Model 63 Stepping 2"],
    ["CPUs", "16"],
    ["Memory", "15.49GiB"],
    ["Free Memory", "10.11GiB"],
    ["Threads", "POSIX_THREADS"],
    ["OS Version", "5.4"],
    ["Has Battery", "false"],
    ["On Battery", "false"],
    ["UTC Offset", "3"],
    ["PID", "27247"],
    ["CWD", "/var/lib/fahclient"],
    ["OS", "Linux 5.4.53 x86_64"],
    ["OS Arch", "AMD64"],
    ["GPUs", "3"],
    ["GPU 0", "Bus:1 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080]"],
    ["GPU 1", "Bus:3 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080]"],
    ["GPU 2", "Bus:5 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080]"],
    ["CUDA Device 0", "Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:12.0"],
    ["CUDA Device 1", "Platform:0 Device:1 Bus:3 Slot:0 Compute:8.6 Driver:12.0"],
    ["CUDA Device 2", "Platform:0 Device:2 Bus:5 Slot:0 Compute:8.6 Driver:12.0"],
    ["OpenCL Device 0", "Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:525.60"],
    ["OpenCL Device 1", "Platform:0 Device:1 Bus:3 Slot:0 Compute:3.0 Driver:525.60"],
    ["OpenCL Device 2", "Platform:0 Device:2 Bus:5 Slot:0 Compute:3.0 Driver:525.60"]
    "libFAH",
    ["Date", "Apr 15 2020"],
    ["Time", "21:43:24"],
    ["Revision", "216968bc7025029c841ed6e36e81a03a316890d3"],
    ["Bits", "64"],
    ["Mode", "Release"]
core 0x24 has failed to work:
12:20:11:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:20:12:WU00:FS01:Assigned to work server 158.130.118.23
12:20:12:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GA102 [GeForce RTX 3080] from 158.130.118.23
12:20:12:WU00:FS01:Connecting to 158.130.118.23:8080
12:20:13:FS01:Finishing
12:20:13:WU00:FS01:Downloading 10.83MiB
12:20:19:WU00:FS01:Download 15.58%
12:20:25:WU00:FS01:Download 82.51%
12:20:25:WU00:FS01:Download complete
12:20:25:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18237 run:246 clone:0 gen:4 core:0x24 unit:0x00000000000000040000473d000000f6
12:20:25:WU00:FS01:Starting
12:20:25:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:20:25:WU00:FS01:Started FahCore on PID 28625
12:20:25:WU00:FS01:Core PID:28629
12:20:25:WU00:FS01:FahCore 0x24 started
12:20:26:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:20:26:WU00:FS01:Starting
12:20:26:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:20:26:WU00:FS01:Started FahCore on PID 28658
12:20:26:WU00:FS01:Core PID:28662
12:20:26:WU00:FS01:FahCore 0x24 started
12:20:27:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:21:28:WU00:FS01:Starting
12:21:28:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:21:28:WU00:FS01:Started FahCore on PID 29786
12:21:28:WU00:FS01:Core PID:29790
12:21:28:WU00:FS01:FahCore 0x24 started
12:21:28:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:22:28:WU00:FS01:Starting
12:22:28:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:22:28:WU00:FS01:Started FahCore on PID 30903
12:22:28:WU00:FS01:Core PID:30907
12:22:28:WU00:FS01:FahCore 0x24 started
12:22:28:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:23:28:WU00:FS01:Starting
12:23:28:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:23:28:WU00:FS01:Started FahCore on PID 32001
12:23:28:WU00:FS01:Core PID:32005
12:23:28:WU00:FS01:FahCore 0x24 started
12:23:28:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:23:28:WARNING:WU00:FS01:Too many errors, failing
12:23:28:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:18237 run:246 clone:0 gen:4 core:0x24 unit:0x00000000000000040000473d000000f6
12:23:28:WU00:FS01:Connecting to 158.130.118.23:8080
12:23:30:WU00:FS01:Server responded WORK_ACK (400)
12:23:30:WU00:FS01:Cleaning up
12:24:26:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:24:27:WU00:FS01:Assigned to work server 158.130.118.26
12:24:27:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GA102 [GeForce RTX 3080] from 158.130.118.26
12:24:27:WU00:FS01:Connecting to 158.130.118.26:8080
12:24:28:WU00:FS01:Downloading 9.20MiB
12:24:30:FS01:Finishing
12:24:34:WU00:FS01:Download 25.83%
12:24:40:WU00:FS01:Download 73.40%
12:24:42:WU00:FS01:Download complete
12:24:42:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18235 run:458 clone:0 gen:2 core:0x24 unit:0x00000000000000020000473b000001ca
12:24:42:WU00:FS01:Starting
12:24:42:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:24:42:WU00:FS01:Started FahCore on PID 929
12:24:42:WU00:FS01:Core PID:933
12:24:42:WU00:FS01:FahCore 0x24 started
12:24:42:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:24:43:WU00:FS01:Starting
12:24:43:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:24:43:WU00:FS01:Started FahCore on PID 962
12:24:43:WU00:FS01:Core PID:966
12:24:43:WU00:FS01:FahCore 0x24 started
12:24:43:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:25:43:WU00:FS01:Starting
12:25:43:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:25:43:WU00:FS01:Started FahCore on PID 2082
12:25:43:WU00:FS01:Core PID:2086
12:25:43:WU00:FS01:FahCore 0x24 started
12:25:44:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:26:43:WU00:FS01:Starting
12:26:43:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:26:43:WU00:FS01:Started FahCore on PID 3212
12:26:43:WU00:FS01:Core PID:3216
12:26:43:WU00:FS01:FahCore 0x24 started
12:26:44:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:27:44:WU00:FS01:Starting
12:27:44:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/openmm-core-24/centos-7.9.2009-64bit/release/0x24-8.1.4/Core_24.fah/FahCore_24 -dir 00 -suffix 01 -version 706 -lifeline 24014 -checkpoint 6 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:27:44:WU00:FS01:Started FahCore on PID 4312
12:27:44:WU00:FS01:Core PID:4316
12:27:44:WU00:FS01:FahCore 0x24 started
12:27:44:WARNING:WU00:FS01:FahCore returned: FAILED_2 (1 = 0x1)
12:27:44:WARNING:WU00:FS01:Too many errors, failing
12:27:44:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:18235 run:458 clone:0 gen:2 core:0x24 unit:0x00000000000000020000473b000001ca
12:27:44:WU00:FS01:Connecting to 158.130.118.26:8080
12:27:46:WU00:FS01:Server responded WORK_ACK (400)
12:27:46:WU00:FS01:Cleaning up
0x23 works stable.
may be someone know where could be a problem ?
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: 18237 crashes on E5-2640 V3 and rtx 3080
Post by BobWilliams757 »
Are you failing or getting errors on all Ox24 projects? If so, have you tried any type of troubleshooting such as shutting down the client and core and rebooting the system?
Occasionally a specific work unit will fail even on a stable system. If you aren't seeing any kind of trend or multiple failed work units I wouldn't be too concerned. Even with the internal testing and beta testing some work units simply fail.
I have seen where numerous people have had problems with core downloads, but once downloaded it seems the new core is stable for most.
ETA: Both work units shown in your logs have failed multiple users. When this is the case it is more likely that there is an issue with the work unit. If work units fail on your system and complete on the next run it might be more an indication of a system problem.
You can check work unit status using the below link...
https://apps.foldingathome.org/wu#p ... &gen=4
Fold them if you get them!
Bsb5068
Post by Bsb5068 »
Thanks for helps to know the way to check WU. Someone's PC has done one of fault unit, seems like problem has lixus users, not windows folders
What distribution are you using ?
I think core 24 requires a newer glibc library that it only available with Ubuntu 20.04 or newer ...
Bsb5068
Post by Bsb5068 »
