Start folding.
adrianxw
Hardware configuration: Intel 6700 CPU on ASUS Sabertooth Z170 motherboard with 16 GB RAM
Start folding.
Post by adrianxw »
If I click "Stop folding", it completes the work unit, and stops. Fine, that is what I wanted it to do. What then happens when I am ready for it to start again, I do..... well.... what do I do? The stop folding poke point is still there, okay, but that is not what I want now. I can refresh the page, great, it refreshes, but does not alter the poke point.
Re: Start folding.
Post by calxalot »
What OS and version?
What fah version?
bollix47
Re: Start folding.
Post by bollix47 »
adrianxw
Re: Start folding.
Post by adrianxw »
Okay, when I click stop folding, it finishes the work unit then stops. This morning, and this is not the first time I have had this happen, I started my machine, and, ignoring the fact I have told it to stop, it downloaded a new work unit, which is still running now. The stop function does not appear to be saved across invocations.
Re: Start folding.
Post by calxalot »
You mean Finish?
Finish is not sticky in fah v7.
Manually pause after it finishes and uploads.
Or add client option pause-on-start true
adrianxw
Re: Start folding.
Post by adrianxw »
Stop Folding is the text on the poke point. Where do I add client options, sounds more like what I want.
Re: Start folding.
Post by calxalot »
Are you using v7 FAHControl?
adrianxw
Re: Start folding.
Post by adrianxw »
I don't know, where do I find that information?
Re: Start folding.
Post by calxalot »
In Windows sys tray, find fah icon and select about from the popup menu
adrianxw
Re: Start folding.
Post by adrianxw »
7.6.21
Re: Start folding.
Post by calxalot »
Sys tray fah > Advanced Control is FAHControl
The configure window will have a client options tab
Add option
value: true
Use lower case.
adrianxw
Re: Start folding.
Post by adrianxw »
Good. I'll look for that in the morning, my girl has gone to bed now and making "lights out time" noises...
adrianxw
Re: Start folding.
Post by adrianxw »
Good, a bit of hunting around, but I found a place to enter the item and its value. Hopefully that will be working.
