It's another day I can't download a WU. The log says:
10:14:37:WU01:FS00:Connecting to assign1.foldingathome.org:80
10:14:38:WU01:FS00:Assigned to work server 144.121.86.56
10:14:38:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 144.121.86.56
10:14:38:WU01:FS00:Connecting to 144.121.86.56:8080
10:14:59:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
10:14:59:WU01:FS00:Connecting to 144.121.86.56:80
10:15:20:ERROR:WU01:FS00:Exception: Failed to connect to 144.121.86.56:80: >?KB:0 CAB0=>28BL A>548=5=85 1K;0 157CA?5H=>9, B.:. >B 4@C3>3> :><?LNB5@0 70 B@51C5<>5 2@5<O =5 ?>;CG5= =C6=K9 >B:;8:, 8;8 1K;> @07>@20=> C65 CAB0=>2;5==>5 A>548=5=85 87-70 =525@=>3> >B:;8:0 C65 ?>4:;NG5==>3> :><?LNB5@0.
What can be the reason?
Is there any way to fix this?
Can't download WU
m_vokhm
- Hardware configuration: CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz (4 kernels)
Memory: 16 GiB
No GPU - Location: Kurgan, Russia
Re: Can't download WU
The solution was to set up a VPN to connect to 144.121.86.56. Obviously, F@H servers reject attempts to connect to them from Russia.
Or the institutional firewall at the research institute where the F@h server is located is blocking a range of IPs that corresponds to your ISP.
