Projet 2665 (Run 3, Clone 92, Gen 29)
Sunin
Post by Sunin »
c
[05:09:37] Project: 2665 (Run 3, Clone 92, Gen 29)
[05:09:37]
[05:09:38] Entering M.D.
[05:09:44] Rejecting checkpoint
[05:09:45]
[05:09:45] Writing local files
[05:09:46]
[05:09:46] Writing local files
[05:09:54] Extra SSE boost OK.
[05:09:54] Writing local files
[05:09:54] Completed 0 out of 250000 steps  (0 percent)
[05:23:49] Writing local files
[05:23:49] Completed 2500 out of 250000 steps  (1 percent)
[05:37:42] Writing local files
[05:37:42] Completed 5000 out of 250000 steps  (2 percent)
[05:51:36] Writing local files
[05:51:36] Completed 7500 out of 250000 steps  (3 percent)
[06:05:30] Writing local files
[06:05:30] Completed 10000 out of 250000 steps  (4 percent)
[06:19:24] Writing local files
[06:19:24] Completed 12500 out of 250000 steps  (5 percent)
[06:33:17] Writing local files
[06:33:18] Completed 15000 out of 250000 steps  (6 percent)
[06:47:11] Writing local files
[06:47:11] Completed 17500 out of 250000 steps  (7 percent)
[07:00:59] Writing local files
[07:00:59] Completed 20000 out of 250000 steps  (8 percent)
[07:14:52] Writing local files
[07:14:52] Completed 22500 out of 250000 steps  (9 percent)
[07:28:44] Writing local files
[07:28:44] Completed 25000 out of 250000 steps  (10 percent)
[07:42:37] Writing local files
[07:42:37] Completed 27500 out of 250000 steps  (11 percent)
[07:56:29] Writing local files
[07:56:29] Completed 30000 out of 250000 steps  (12 percent)
[08:10:22] Writing local files
[08:10:22] Completed 32500 out of 250000 steps  (13 percent)
[08:24:15] Writing local files
[08:24:15] Completed 35000 out of 250000 steps  (14 percent)
[08:38:09] Writing local files
[08:38:09] Completed 37500 out of 250000 steps  (15 percent)
[08:52:03] Writing local files
[08:52:03] Completed 40000 out of 250000 steps  (16 percent)
[09:05:56] Writing local files
[09:05:57] Completed 42500 out of 250000 steps  (17 percent)
[09:19:50] Writing local files
[09:19:50] Completed 45000 out of 250000 steps  (18 percent)
[09:33:40] Writing local files
[09:33:40] Completed 47500 out of 250000 steps  (19 percent)
[09:47:34] Writing local files
[09:47:34] Completed 50000 out of 250000 steps  (20 percent)
[10:01:27] Writing local files
[10:01:28] Completed 52500 out of 250000 steps  (21 percent)
[10:15:21] Writing local files
[10:15:21] Completed 55000 out of 250000 steps  (22 percent)
[10:29:14] Writing local files
[10:29:14] Completed 57500 out of 250000 steps  (23 percent)
[10:43:09] Writing local files
[10:43:09] Completed 60000 out of 250000 steps  (24 percent)
[10:57:04] Writing local files
[10:57:04] Completed 62500 out of 250000 steps  (25 percent)
[11:10:58] Writing local files
[11:10:58] Completed 65000 out of 250000 steps  (26 percent)
[11:24:54] Writing local files
[11:24:54] Completed 67500 out of 250000 steps  (27 percent)
[11:38:50] Writing local files
[11:38:50] Completed 70000 out of 250000 steps  (28 percent)
[11:52:45] Writing local files
[11:52:46] Completed 72500 out of 250000 steps  (29 percent)
[12:06:36] Writing local files
[12:06:36] Completed 75000 out of 250000 steps  (30 percent)
[12:20:31] Writing local files
[12:20:31] Completed 77500 out of 250000 steps  (31 percent)
[12:34:26] Writing local files
[12:34:26] Completed 80000 out of 250000 steps  (32 percent)
[12:48:20] Writing local files
[12:48:20] Completed 82500 out of 250000 steps  (33 percent)
[13:02:14] Writing local files
[13:02:15] Completed 85000 out of 250000 steps  (34 percent)
[13:16:09] Writing local files
[13:16:09] Completed 87500 out of 250000 steps  (35 percent)
[13:28:14] Warning:  long 1-4 interactions
[13:28:14] Quit 101 - NaN detected: (ener[20])
[13:28:14]
[13:28:14] Simulation instability has been encountered. The run has entered a
[13:28:14]   state from which no further progress can be made.
[13:28:14] This may be the correct result of the simulation, however if you
[13:28:14]   often see other project units terminating early like this
[13:28:14]   too, you may wish to check the stability of your computer (issues
[13:28:14]   such as high temperature, overclocking, etc.).
[13:28:14] Going to send back what have done.
[13:28:14] logfile size: 74828
[13:28:14] - Writing 75378 bytes of core data to disk...
[13:28:14]   ... Done.
[13:28:14] - Failed to delete work/wudata_01.arc
[13:28:14] - Failed to delete work/wudata_01.xtc
[13:28:14] No C.P. to delete.
[13:28:14] - Failed to delete work/wudata_01.chk
[13:28:14] Warning:  check for stray files
[13:30:14]
[13:30:14] Folding@home Core Shutdown: EARLY_UNIT_END
[13:30:14]
[13:30:17] CoreStatus = 7B (123)
[13:30:17] Client-core communications error: ERROR 0x7b
[13:30:17] Deleting current work unit & continuing...
[13:32:21] - Preparing to get new work unit...
[13:32:21] + Attempting to get work packet
[13:32:21] - Connecting to assignment server
[13:32:21] - Successful: assigned to (171.64.65.64).
[13:32:21] + News From Folding@Home: Welcome to Folding@Home
[13:32:21] Loaded queue successfully.
[13:32:35] + Closed connections
[13:32:40]
[13:32:40] + Processing work unit
[13:32:40] Core required: FahCore_a1.exe
[13:32:40] Core found.
[13:32:40] Working on Unit 02 [July 22 13:32:40]
[13:32:40] + Working ...
[13:32:40]
[13:32:40] *------------------------------*
[13:32:40] Folding@Home Gromacs SMP Core
[13:32:40] Version 1.74 (March 10, 2007)
[13:32:40]
[13:32:40] Preparing to commence simulation
[13:32:40] - Ensuring status. Please wait.
[13:32:44] - Starting from initial work packet
[13:32:45]
[13:32:45] Project: 2665 (Run 3, Clone 92, Gen 29)
[13:32:45]
[13:32:45] Assembly optimizations on if available.
[13:32:45] Entering M.D.
[13:33:08] ial work packet
[13:33:08]
[13:33:08] Project: 2665 (Run 3, Clone 92, Gen 29)
[13:33:08]
[13:33:08] 665 (Run 3, Clone 92, Gen 29)
[13:33:08]
[13:33:09] Entering M.D.
[13:33:15] Rejecting checkpoint
[13:33:17] Protein: HGG in water
[13:33:17] Writing local files
[13:33:25] Extra SSE boost OK.
[13:33:25] Writing local files
[13:33:25] Completed 0 out of 250000 steps  (0 percent)
[13:47:19] Writing local files
[13:47:19] Completed 2500 out of 250000 steps  (1 percent)
[14:01:11] Writing local files
[14:01:11] Completed 5000 out of 250000 steps  (2 percent)
[14:15:02] Writing local files
[14:15:03] Completed 7500 out of 250000 steps  (3 percent)
[14:28:55] Writing local files
[14:28:55] Completed 10000 out of 250000 steps  (4 percent)
[14:42:45] Writing local files
[14:42:45] Completed 12500 out of 250000 steps  (5 percent)
[14:56:38] Writing local files
[14:56:38] Completed 15000 out of 250000 steps  (6 percent)
[15:10:31] Writing local files
[15:10:31] Completed 17500 out of 250000 steps  (7 percent)
[15:24:24] Writing local files
[15:24:24] Completed 20000 out of 250000 steps  (8 percent)
[15:38:16] Writing local files
[15:38:16] Completed 22500 out of 250000 steps  (9 percent)
[15:52:06] Writing local files
[15:52:06] Completed 25000 out of 250000 steps  (10 percent)
[16:05:57] Writing local files
[16:05:57] Completed 27500 out of 250000 steps  (11 percent)
[16:19:49] Writing local files
[16:19:49] Completed 30000 out of 250000 steps  (12 percent)
[16:33:40] Writing local files
[16:33:41] Completed 32500 out of 250000 steps  (13 percent)
[16:47:33] Writing local files
[16:47:33] Completed 35000 out of 250000 steps  (14 percent)
[17:01:26] Writing local files
[17:01:26] Completed 37500 out of 250000 steps  (15 percent)
[17:15:12] Writing local files
[17:15:12] Completed 40000 out of 250000 steps  (16 percent)
[17:29:04] Writing local files
[17:29:04] Completed 42500 out of 250000 steps  (17 percent)
[17:42:57] Writing local files
[17:42:57] Completed 45000 out of 250000 steps  (18 percent)
[17:56:48] Writing local files
[17:56:48] Completed 47500 out of 250000 steps  (19 percent)
[18:10:40] Writing local files
[18:10:40] Completed 50000 out of 250000 steps  (20 percent)
[18:24:31] Writing local files
[18:24:31] Completed 52500 out of 250000 steps  (21 percent)
[18:38:22] Writing local files
[18:38:22] Completed 55000 out of 250000 steps  (22 percent)
[18:52:13] Writing local files
[18:52:13] Completed 57500 out of 250000 steps  (23 percent)
[19:06:06] Writing local files
[19:06:06] Completed 60000 out of 250000 steps  (24 percent)
[19:19:58] Writing local files
[19:19:58] Completed 62500 out of 250000 steps  (25 percent)
[19:33:51] Writing local files
[19:33:52] Completed 65000 out of 250000 steps  (26 percent)
[19:47:45] Writing local files
[19:47:45] Completed 67500 out of 250000 steps  (27 percent)
[20:01:34] Writing local files
[20:01:34] Completed 70000 out of 250000 steps  (28 percent)
[20:15:27] Writing local files
[20:15:28] Completed 72500 out of 250000 steps  (29 percent)
[20:29:20] Writing local files
[20:29:20] Completed 75000 out of 250000 steps  (30 percent)
[20:43:14] Writing local files
[20:43:14] Completed 77500 out of 250000 steps  (31 percent)
[20:57:07] Writing local files
[20:57:07] Completed 80000 out of 250000 steps  (32 percent)
[21:11:00] Writing local files
[21:11:00] Completed 82500 out of 250000 steps  (33 percent)
[21:24:54] Writing local files
[21:24:54] Completed 85000 out of 250000 steps  (34 percent)
[21:38:47] Writing local files
[21:38:47] Completed 87500 out of 250000 steps  (35 percent)
[21:50:50] Warning:  long 1-4 interactions
[21:50:50] Quit 101 - NaN detected: (ener[20])
[21:50:50]
[21:50:50] Simulation instability has been encountered. The run has entered a
[21:50:50]   state from which no further progress can be made.
[21:50:50] This may be the correct result of the simulation, however if you
[21:50:50]   often see other project units terminating early like this
[21:50:50]   too, you may wish to check the stability of your computer (issues
[21:50:50]   such as high temperature, overclocking, etc.).
[21:50:50] Going to send back what have done.
[21:50:50] logfile size: 74829
[21:50:50] - Writing 75379 bytes of core data to disk...
[21:50:50]   ... Done.
[21:52:50]
[21:52:50] Folding@home Core Shutdown: EARLY_UNIT_END
[21:52:50]
[21:52:54] CoreStatus = 7B (123)
[21:52:54] Client-core communications error: ERROR 0x7b
[21:52:54] Deleting current work unit & continuing...
[21:54:58] - Preparing to get new work unit...
[21:54:58] + Attempting to get work packet
[21:54:58] - Connecting to assignment server
[21:54:58] - Successful: assigned to (171.64.65.64).
[21:54:58] + News From Folding@Home: Welcome to Folding@Home
[21:54:59] Loaded queue successfully.
[21:55:12] + Closed connections
[21:55:17]
[21:55:17] + Processing work unit
[21:55:17] Core required: FahCore_a1.exe
[21:55:17] Core found.
[21:55:17] Working on Unit 03 [July 22 21:55:17]
[21:55:17] + Working ...
[21:55:17]
[21:55:17] *------------------------------*
[21:55:17] Folding@Home Gromacs SMP Core
[21:55:17] Version 1.74 (March 10, 2007)
[21:55:17]
[21:55:17] Preparing to commence simulation
[21:55:17] - Ensuring status. Please wait.
[21:55:22] - Starting from initial work packet
[21:55:22]
[21:55:22] Project: 2665 (Run 3, Clone 92, Gen 29)
[21:55:22]
[21:55:23] Assembly optimizations on if available.
[21:55:23] Entering M.D.
[21:55:45] ial work pa- Starting from initial work packet
[21:55:45]
[21:55:45] Project: 2665 (Run 3, Clone 92, Gen 29)
[21:55:45]
[21:55:47] Entering M.D.
[21:55:53] Rejecting checkpoint
[21:55:54] Protein: HGG in water
[21:55:54] Writing local files
[21:56:02] Extra SSE boost OK.
[21:56:03] Writing local files
[21:56:03] Completed 0 out of 250000 steps  (0 percent)
[22:09:57] Writing local files
[22:09:57] Completed 2500 out of 250000 steps  (1 percent)
[22:23:48] Writing local files
[22:23:49] Completed 5000 out of 250000 steps  (2 percent)
[22:37:38] Writing local files
[22:37:38] Completed 7500 out of 250000 steps  (3 percent)
[22:51:31] Writing local files
[22:51:31] Completed 10000 out of 250000 steps  (4 percent)
[23:05:25] Writing local files
[23:05:25] Completed 12500 out of 250000 steps  (5 percent)
[23:19:18] Writing local files
[23:19:18] Completed 15000 out of 250000 steps  (6 percent)
[23:33:11] Writing local files
[23:33:11] Completed 17500 out of 250000 steps  (7 percent)
[23:47:05] Writing local files
[23:47:05] Completed 20000 out of 250000 steps  (8 percent)
[00:00:57] Writing local files
[00:00:57] Completed 22500 out of 250000 steps  (9 percent)
[00:14:48] Writing local files
[00:14:48] Completed 25000 out of 250000 steps  (10 percent)
[00:28:40] Writing local files
[00:28:40] Completed 27500 out of 250000 steps  (11 percent)
[00:42:32] Writing local files
[00:42:32] Completed 30000 out of 250000 steps  (12 percent)
[00:56:25] Writing local files
[00:56:25] Completed 32500 out of 250000 steps  (13 percent)
[01:10:15] Writing local files
[01:10:15] Completed 35000 out of 250000 steps  (14 percent)
[01:24:09] Writing local files
[01:24:09] Completed 37500 out of 250000 steps  (15 percent)
[01:38:03] Writing local files
[01:38:03] Completed 40000 out of 250000 steps  (16 percent)
[01:51:57] Writing local files
[01:51:57] Completed 42500 out of 250000 steps  (17 percent)
[02:05:51] Writing local files
[02:05:51] Completed 45000 out of 250000 steps  (18 percent)
[02:19:44] Writing local files
[02:19:44] Completed 47500 out of 250000 steps  (19 percent)
[02:33:37] Writing local files
[02:33:37] Completed 50000 out of 250000 steps  (20 percent)
[02:47:30] Writing local files
[02:47:30] Completed 52500 out of 250000 steps  (21 percent)
[03:01:24] Writing local files
[03:01:24] Completed 55000 out of 250000 steps  (22 percent)
[03:15:17] Writing local files
[03:15:17] Completed 57500 out of 250000 steps  (23 percent)
[03:29:11] Writing local files
[03:29:11] Completed 60000 out of 250000 steps  (24 percent)
[03:43:00] Writing local files
[03:43:01] Completed 62500 out of 250000 steps  (25 percent)
[03:56:54] Writing local files
[03:56:54] Completed 65000 out of 250000 steps  (26 percent)
[04:10:48] Writing local files
[04:10:48] Completed 67500 out of 250000 steps  (27 percent)
[04:24:43] Writing local files
[04:24:43] Completed 70000 out of 250000 steps  (28 percent)
[04:38:38] Writing local files
[04:38:38] Completed 72500 out of 250000 steps  (29 percent)
[04:52:32] Writing local files
[04:52:32] Completed 75000 out of 250000 steps  (30 percent)
[05:06:26] Writing local files
[05:06:27] Completed 77500 out of 250000 steps  (31 percent)
[05:20:21] Writing local files
[05:20:21] Completed 80000 out of 250000 steps  (32 percent)
[05:34:15] Writing local files
[05:34:15] Completed 82500 out of 250000 steps  (33 percent)
[05:48:10] Writing local files
[05:48:10] Completed 85000 out of 250000 steps  (34 percent)
[06:02:04] Writing local files
[06:02:04] Completed 87500 out of 250000 steps  (35 percent)
[06:14:05] Warning:  long 1-4 interactions
[06:14:05] Quit 101 - NaN detected: (ener[20])
[06:14:05]
[06:14:05] Simulation instability has been encountered. The run has entered a
[06:14:05]   state from which no further progress can be made.
[06:14:05] This may be the correct result of the simulation, however if you
[06:14:05]   often see other project units terminating early like this
[06:14:05]   too, you may wish to check the stability of your computer (issues
[06:14:05]   such as high temperature, overclocking, etc.).
[06:14:05] Going to send back what have done.
[06:14:05] logfile size: 74829
[06:14:05] - Writing 75379 bytes of core data to disk...
[06:14:05]   ... Done.
[06:14:05] - Failed to delete work/wudata_03.pdo
[06:14:05] - Failed to delete work/wudata_03.xvg
[06:14:05] Warning:  check for stray files
[06:16:05]
[06:16:05] Folding@home Core Shutdown: EARLY_UNIT_END
[06:16:05]
[06:16:08] CoreStatus = 7B (123)
[06:16:08] Client-core communications error: ERROR 0x7b
[06:16:08] - Attempting to download new core...
[06:16:08] + Downloading new core: FahCore_a1.exe
[06:16:08] + 10240 bytes downloaded
[06:16:08] + 20480 bytes downloaded
[06:16:08] + 30720 bytes downloaded
[06:16:08] + 40960 bytes downloaded
[06:16:08] + 51200 bytes downloaded
[06:16:08] + 61440 bytes downloaded
[06:16:08] + 71680 bytes downloaded
[06:16:08] + 81920 bytes downloaded
[06:16:08] + 92160 bytes downloaded
[06:16:08] + 102400 bytes downloaded
[06:16:08] + 112640 bytes downloaded
[06:16:08] + 122880 bytes downloaded
[06:16:08] + 133120 bytes downloaded
[06:16:08] + 143360 bytes downloaded
[06:16:08] + 153600 bytes downloaded
[06:16:08] + 163840 bytes downloaded
[06:16:08] + 174080 bytes downloaded
[06:16:08] + 184320 bytes downloaded
[06:16:08] + 194560 bytes downloaded
[06:16:08] + 204800 bytes downloaded
[06:16:08] + 215040 bytes downloaded
[06:16:08] + 225280 bytes downloaded
[06:16:08] + 235520 bytes downloaded
[06:16:08] + 245760 bytes downloaded
[06:16:08] + 256000 bytes downloaded
[06:16:08] + 266240 bytes downloaded
[06:16:08] + 276480 bytes downloaded
[06:16:09] + 286720 bytes downloaded
[06:16:09] + 296960 bytes downloaded
[06:16:09] + 307200 bytes downloaded
[06:16:09] + 317440 bytes downloaded
[06:16:09] + 327680 bytes downloaded
[06:16:09] + 337920 bytes downloaded
[06:16:09] + 348160 bytes downloaded
[06:16:09] + 358400 bytes downloaded
[06:16:09] + 368640 bytes downloaded
[06:16:09] + 378880 bytes downloaded
[06:16:09] + 389120 bytes downloaded
[06:16:09] + 399360 bytes downloaded
[06:16:09] + 409600 bytes downloaded
[06:16:09] + 419840 bytes downloaded
[06:16:09] + 430080 bytes downloaded
[06:16:09] + 440320 bytes downloaded
[06:16:09] + 450560 bytes downloaded
[06:16:09] + 460800 bytes downloaded
[06:16:09] + 471040 bytes downloaded
[06:16:09] + 481280 bytes downloaded
[06:16:09] + 491520 bytes downloaded
[06:16:09] + 501760 bytes downloaded
[06:16:09] + 512000 bytes downloaded
[06:16:09] + 522240 bytes downloaded
[06:16:09] + 532480 bytes downloaded
[06:16:09] + 542720 bytes downloaded
[06:16:09] + 552960 bytes downloaded
[06:16:09] + 563200 bytes downloaded
[06:16:09] + 573440 bytes downloaded
[06:16:09] + 583680 bytes downloaded
[06:16:09] + 593920 bytes downloaded
[06:16:09] + 604160 bytes downloaded
[06:16:09] + 614400 bytes downloaded
[06:16:09] + 624640 bytes downloaded
[06:16:09] + 634880 bytes downloaded
[06:16:09] + 645120 bytes downloaded
[06:16:09] + 655360 bytes downloaded
[06:16:09] + 665600 bytes downloaded
[06:16:09] + 675840 bytes downloaded
[06:16:09] + 686080 bytes downloaded
[06:16:09] + 696320 bytes downloaded
[06:16:09] + 706560 bytes downloaded
[06:16:09] + 716800 bytes downloaded
[06:16:09] + 727040 bytes downloaded
[06:16:09] + 737280 bytes downloaded
[06:16:09] + 747520 bytes downloaded
[06:16:09] + 757760 bytes downloaded
[06:16:09] + 768000 bytes downloaded
[06:16:09] + 778240 bytes downloaded
[06:16:09] + 788480 bytes downloaded
[06:16:09] + 789667 bytes downloaded
[06:16:09] Verifying core Core_a1.fah...
[06:16:09] Signature is VALID
[06:16:09]
[06:16:09] Trying to unzip core FahCore_a1.exe
[06:16:09] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[06:16:09] + Core successfully engaged
[06:16:09] Deleting current work unit & continuing...
[06:18:13] - Preparing to get new work unit...
[06:18:13] + Attempting to get work packet
[06:18:13] - Connecting to assignment server
[06:18:14] - Successful: assigned to (171.64.65.63).
[06:18:14] + News From Folding@Home: Welcome to Folding@Home
[06:18:14] Loaded queue successfully.
[06:18:17] + Closed connections
[06:18:22]
[06:18:22] + Processing work unit
[06:18:22] Core required: FahCore_a1.exe
[06:18:22] Core found.
[06:18:22] Working on Unit 04 [July 23 06:18:22]
[06:18:22] + Working ...
[06:18:22]
[06:18:22] *------------------------------*
[06:18:22] Folding@Home Gromacs SMP Core
[06:18:22] Version 1.74 (March 10, 2007)
[06:18:22]
[06:18:22] Preparing to commence simulation
[06:18:22] - Ensuring status. Please wait.
[06:18:23] - Starting from initial work packet
[06:18:23]
[06:18:23] Project: 3064 (Run 2, Clone 90, Gen 48)
[06:18:23]
[06:18:23] Assembly optimizations on if available.
[06:18:23] Entering M.D.
[06:18:40] 7 percent)
[06:18:40] - Starting from initial work packet
[06:18:40]
[06:18:40] Project: 3Entering M.D.
[06:18:40] one 90, Gen 48)
[06:18:40]
[06:18:40] Entering M.D.
[06:18:46] Rejecting checkpoint
[06:18:46] a SSE boost OK.
[06:18:46] ambda5_2003Extra SSE boost OK.
[06:18:46]
[06:18:46] Extra SSE boost OK.
[06:18:46] Writing local files
[06:18:46] Completed 0 out of 5000000 steps  (0 percent)
[06:28:43] Writing local files
[06:28:43] Completed 50000 out of 5000000 steps  (1 percent)
[06:38:40] Writing local files
[06:38:40] Completed 100000 out of 5000000 steps  (2 percent)
[06:48:37] Writing local files
[06:48:37] Completed 150000 out of 5000000 steps  (3 percent)
[06:58:32] Writing local files
[06:58:32] Completed 200000 out of 5000000 steps  (4 percent)
[07:08:28] Writing local files
[07:08:28] Completed 250000 out of 5000000 steps  (5 percent)
[07:18:23] Writing local files
[07:18:23] Completed 300000 out of 5000000 steps  (6 percent)
[07:28:17] Writing local files
[07:28:17] Completed 350000 out of 5000000 steps  (7 percent)
[07:38:14] Writing local files
[07:38:14] Completed 400000 out of 5000000 steps  (8 percent)
[07:48:11] Writing local files
[07:48:11] Completed 450000 out of 5000000 steps  (9 percent)
[07:58:07] Writing local files
[07:58:07] Completed 500000 out of 5000000 steps  (10 percent)
[08:08:04] Writing local files
[08:08:04] Completed 550000 out of 5000000 steps  (11 percent)
[08:18:00] Writing local files
[08:18:00] Completed 600000 out of 5000000 steps  (12 percent)
[08:27:55] Writing local files
[08:27:55] Completed 650000 out of 5000000 steps  (13 percent)
[08:37:36] Writing local files
[08:37:36] Completed 700000 out of 5000000 steps  (14 percent)
[08:47:31] Writing local files
[08:47:31] Completed 750000 out of 5000000 steps  (15 percent)
[08:57:26] Writing local files
[08:57:26] Completed 800000 out of 5000000 steps  (16 percent)
[09:07:22] Writing local files
[09:07:23] Completed 850000 out of 5000000 steps  (17 percent)
[09:17:17] Writing local files
[09:17:17] Completed 900000 out of 5000000 steps  (18 percent)
[09:27:13] Writing local files
[09:27:13] Completed 950000 out of 5000000 steps  (19 percent)
[09:37:07] Writing local files
[09:37:07] Completed 1000000 out of 5000000 steps  (20 percent)
[09:47:02] Writing local files
[09:47:02] Completed 1050000 out of 5000000 steps  (21 percent)
[09:56:58] Writing local files
[09:56:58] Completed 1100000 out of 5000000 steps  (22 percent)
[10:06:55] Writing local files
[10:06:56] Completed 1150000 out of 5000000 steps  (23 percent)
[10:16:52] Writing local files
[10:16:52] Completed 1200000 out of 5000000 steps  (24 percent)
[10:26:47] Writing local files
[10:26:47] Completed 1250000 out of 5000000 steps  (25 percent)
[10:36:43] Writing local files
[10:36:43] Completed 1300000 out of 5000000 steps  (26 percent)
[10:46:39] Writing local files
[10:46:39] Completed 1350000 out of 5000000 steps  (27 percent)
[10:56:36] Writing local files
[10:56:36] Completed 1400000 out of 5000000 steps  (28 percent)
[11:06:19] Writing local files
[11:06:19] Completed 1450000 out of 5000000 steps  (29 percent)
[11:16:17] Writing local files
[11:16:17] Completed 1500000 out of 5000000 steps  (30 percent)
[11:26:14] Writing local files
[11:26:14] Completed 1550000 out of 5000000 steps  (31 percent)
[11:36:11] Writing local files
[11:36:11] Completed 1600000 out of 5000000 steps  (32 percent)
[11:46:07] Writing local files
[11:46:07] Completed 1650000 out of 5000000 steps  (33 percent)
[11:56:04] Writing local files
[11:56:04] Completed 1700000 out of 5000000 steps  (34 percent)
[12:06:00] Writing local files
[12:06:00] Completed 1750000 out of 5000000 steps  (35 percent)
[12:15:56] Writing local files
[12:15:56] Completed 1800000 out of 5000000 steps  (36 percent)
[12:25:53] Writing local files
[12:25:53] Completed 1850000 out of 5000000 steps  (37 percent)
[12:35:51] Writing local files
[12:35:51] Completed 1900000 out of 5000000 steps  (38 percent)
[12:45:50] Writing local files
[12:45:50] Completed 1950000 out of 5000000 steps  (39 percent)
[12:55:49] Writing local files
[12:55:49] Completed 2000000 out of 5000000 steps  (40 percent)
[13:05:49] Writing local files
[13:05:49] Completed 2050000 out of 5000000 steps  (41 percent)
[13:15:47] Writing local files
[13:15:47] Completed 2100000 out of 5000000 steps  (42 percent)
[13:25:23] Writing local files
[13:25:23] Completed 2150000 out of 5000000 steps  (43 percent)
[13:35:20] Writing local files
[13:35:20] Completed 2200000 out of 5000000 steps  (44 percent)
[13:45:16] Writing local files
[13:45:16] Completed 2250000 out of 5000000 steps  (45 percent)
[13:55:11] Writing local files
[13:55:11] Completed 2300000 out of 5000000 steps  (46 percent)
[14:05:06] Writing local files
[14:05:06] Completed 2350000 out of 5000000 steps  (47 percent)
[14:15:01] Writing local files
[14:15:01] Completed 2400000 out of 5000000 steps  (48 percent)
[14:24:56] Writing local files
[14:24:56] Completed 2450000 out of 5000000 steps  (49 percent)
[14:34:54] Writing local files
[14:34:54] Completed 2500000 out of 5000000 steps  (50 percent)
[14:44:51] Writing local files
[14:44:51] Completed 2550000 out of 5000000 steps  (51 percent)
[14:54:47] Writing local files
[14:54:47] Completed 2600000 out of 5000000 steps  (52 percent)
[15:04:44] Writing local files
[15:04:44] Completed 2650000 out of 5000000 steps  (53 percent)
[15:14:41] Writing local files
[15:14:41] Completed 2700000 out of 5000000 steps  (54 percent)
[15:24:38] Writing local files
[15:24:38] Completed 2750000 out of 5000000 steps  (55 percent)
[15:34:36] Writing local files
[15:34:36] Completed 2800000 out of 5000000 steps  (56 percent)
[15:44:36] Writing local files
[15:44:36] Completed 2850000 out of 5000000 steps  (57 percent)
[15:54:21] Writing local files
[15:54:21] Completed 2900000 out of 5000000 steps  (58 percent)
[16:04:18] Writing local files
[16:04:18] Completed 2950000 out of 5000000 steps  (59 percent)
[16:14:14] Writing local files
[16:14:14] Completed 3000000 out of 5000000 steps  (60 percent)
[16:24:11] Writing local files
[16:24:11] Completed 3050000 out of 5000000 steps  (61 percent)
[16:34:07] Writing local files
[16:34:07] Completed 3100000 out of 5000000 steps  (62 percent)
[16:44:03] Writing local files
[16:44:03] Completed 3150000 out of 5000000 steps  (63 percent)
[16:53:59] Writing local files
[16:53:59] Completed 3200000 out of 5000000 steps  (64 percent)
[17:03:55] Writing local files
[17:03:55] Completed 3250000 out of 5000000 steps  (65 percent)
[17:13:50] Writing local files
[17:13:50] Completed 3300000 out of 5000000 steps  (66 percent)
[17:23:48] Writing local files
[17:23:48] Completed 3350000 out of 5000000 steps  (67 percent)
[17:33:46] Writing local files
[17:33:46] Completed 3400000 out of 5000000 steps  (68 percent)
[17:43:42] Writing local files
[17:43:42] Completed 3450000 out of 5000000 steps  (69 percent)
[17:53:38] Writing local files
[17:53:38] Completed 3500000 out of 5000000 steps  (70 percent)
[18:03:36] Writing local files
[18:03:36] Completed 3550000 out of 5000000 steps  (71 percent)
[18:13:03] Writing local files
[18:13:03] Completed 3600000 out of 5000000 steps  (72 percent)
[18:22:55] Writing local files
[18:22:55] Completed 3650000 out of 5000000 steps  (73 percent)
[18:32:52] Writing local files
[18:32:52] Completed 3700000 out of 5000000 steps  (74 percent)
[18:42:51] Writing local files
[18:42:51] Completed 3750000 out of 5000000 steps  (75 percent)
[18:52:48] Writing local files
[18:52:48] Completed 3800000 out of 5000000 steps  (76 percent)
[19:02:47] Writing local files
[19:02:47] Completed 3850000 out of 5000000 steps  (77 percent)
[19:12:45] Writing local files
[19:12:45] Completed 3900000 out of 5000000 steps  (78 percent)
[19:22:45] Writing local files
[19:22:45] Completed 3950000 out of 5000000 steps  (79 percent)
[19:32:44] Writing local files
[19:32:44] Completed 4000000 out of 5000000 steps  (80 percent)
[19:42:42] Writing local files
[19:42:42] Completed 4050000 out of 5000000 steps  (81 percent)
[19:52:41] Writing local files
[19:52:41] Completed 4100000 out of 5000000 steps  (82 percent)
[20:02:40] Writing local files
[20:02:40] Completed 4150000 out of 5000000 steps  (83 percent)
[20:12:39] Writing local files
[20:12:39] Completed 4200000 out of 5000000 steps  (84 percent)
[20:22:36] Writing local files
[20:22:36] Completed 4250000 out of 5000000 steps  (85 percent)
[20:32:31] Writing local files
[20:32:31] Completed 4300000 out of 5000000 steps  (86 percent)
[20:42:13] Writing local files
[20:42:13] Completed 4350000 out of 5000000 steps  (87 percent)
[20:52:09] Writing local files
[20:52:09] Completed 4400000 out of 5000000 steps  (88 percent)
[21:02:05] Writing local files
[21:02:05] Completed 4450000 out of 5000000 steps  (89 percent)
[21:12:02] Writing local files
[21:12:02] Completed 4500000 out of 5000000 steps  (90 percent)
[21:22:00] Writing local files
[21:22:00] Completed 4550000 out of 5000000 steps  (91 percent)
[21:31:57] Writing local files
[21:31:57] Completed 4600000 out of 5000000 steps  (92 percent)
[21:41:53] Writing local files
[21:41:53] Completed 4650000 out of 5000000 steps  (93 percent)
[21:51:49] Writing local files
[21:51:49] Completed 4700000 out of 5000000 steps  (94 percent)
[22:01:46] Writing local files
[22:01:46] Completed 4750000 out of 5000000 steps  (95 percent)
[22:11:42] Writing local files
[22:11:42] Completed 4800000 out of 5000000 steps  (96 percent)
[22:21:37] Writing local files
[22:21:37] Completed 4850000 out of 5000000 steps  (97 percent)
[22:31:32] Writing local files
[22:31:32] Completed 4900000 out of 5000000 steps  (98 percent)
[22:41:29] Writing local files
[22:41:29] Completed 4950000 out of 5000000 steps  (99 percent)
[22:51:26] Writing local files
[22:51:26] Completed 5000000 out of 5000000 steps  (100 percent)
[22:51:26] Writing final coordinates.
[22:51:26] Past main M.D. loop
[22:51:26] Will end MPI now
[22:52:26]
[22:52:26] Finished Work Unit:
[22:52:26] - Reading up to 517920 from "work/wudata_04.arc": Read 517920
[22:52:26] - Reading up to 971780 from "work/wudata_04.xtc": Read 971780
[22:52:26] goefile size: 0
[22:52:26] logfile size: 140911
[22:52:26] Leaving Run
[22:52:30] - Writing 1831655 bytes of core data to disk...
[22:52:30]   ... Done.
[22:52:30] - Failed to delete work/wudata_04.sas
[22:52:30] - Failed to delete work/wudata_04.goe
[22:52:30] Warning:  check for stray files
[22:52:30] - Shutting down core
[22:54:30]
[22:54:30] Folding@home Core Shutdown: FINISHED_UNIT
[22:54:30]
[22:54:32] CoreStatus = 64 (100)
[22:54:32] Sending work to server
[22:54:32] + Attempting to send results
[22:54:55] + Results successfully sent
[22:54:55] Thank you for your contribution to Folding@Home.
[22:54:55] + Number of Units Completed: 88
[22:56:59] - Preparing to get new work unit...
[22:56:59] + Attempting to get work packet
[22:56:59] - Connecting to assignment server
[22:57:00] - Successful: assigned to (171.64.65.64).
[22:57:00] + News From Folding@Home: Welcome to Folding@Home
[22:57:00] Loaded queue successfully.
[22:57:13] + Closed connections
[22:57:13]
[22:57:13] + Processing work unit
[22:57:13] Core required: FahCore_a1.exe
[22:57:13] Core found.
[22:57:13] Working on Unit 05 [July 23 22:57:13]
[22:57:13] + Working ...
[22:57:13]
[22:57:13] *------------------------------*
[22:57:13] Folding@Home Gromacs SMP Core
[22:57:13] Version 1.74 (March 10, 2007)
[22:57:13]
[22:57:13] Preparing to commence simulation
[22:57:13] - Ensuring status. Please wait.
[22:57:18] - Starting from initial work packet
[22:57:18]
[22:57:18] Project: 2665 (Run 3, Clone 92, Gen 29)
[22:57:18]
[22:57:19] Assembly optimizations on if available.
[22:57:19] Entering M.D.
[22:57:41] ial work packet
[22:57:41]
[22:57:41] Project: 2665 (Run 3, Clone 92, Gen 29)
[22:57:41]
[22:57:41] 665 (Run 3, Clone 92, Gen 29)
[22:57:41]
[22:57:43] Entering M.D.
[22:57:49] Rejecting checkpoint
[22:57:50] Protein: HGG in water
[22:57:50] Writing local files
[22:57:58] Extra SSE boost OK.
[22:57:59] Writing local files
[22:57:59] Completed 0 out of 250000 steps  (0 percent)
[23:11:49] Writing local files
[23:11:49] Completed 2500 out of 250000 steps  (1 percent)
[23:25:41] Writing local files
[23:25:42] Completed 5000 out of 250000 steps  (2 percent)
[23:39:34] Writing local files
[23:39:34] Completed 7500 out of 250000 steps  (3 percent)
[23:53:27] Writing local files
[23:53:27] Completed 10000 out of 250000 steps  (4 percent)
[00:07:20] Writing local files
[00:07:20] Completed 12500 out of 250000 steps  (5 percent)
[00:21:13] Writing local files
[00:21:14] Completed 15000 out of 250000 steps  (6 percent)
[00:35:06] Writing local files
[00:35:07] Completed 17500 out of 250000 steps  (7 percent)
[00:49:00] Writing local files
[00:49:00] Completed 20000 out of 250000 steps  (8 percent)
[01:02:51] Writing local files
[01:02:52] Completed 22500 out of 250000 steps  (9 percent)
[01:16:43] Writing local files
[01:16:43] Completed 25000 out of 250000 steps  (10 percent)
[01:30:34] Writing local files
[01:30:34] Completed 27500 out of 250000 steps  (11 percent)
[01:44:22] Writing local files
[01:44:22] Completed 30000 out of 250000 steps  (12 percent)
[01:58:14] Writing local files
[01:58:14] Completed 32500 out of 250000 steps  (13 percent)
[02:12:06] Writing local files
[02:12:06] Completed 35000 out of 250000 steps  (14 percent)
[02:26:00] Writing local files
[02:26:00] Completed 37500 out of 250000 steps  (15 percent)
[02:39:53] Writing local files
[02:39:54] Completed 40000 out of 250000 steps  (16 percent)
[02:53:47] Writing local files
[02:53:47] Completed 42500 out of 250000 steps  (17 percent)
[03:07:40] Writing local files
[03:07:40] Completed 45000 out of 250000 steps  (18 percent)
[03:21:33] Writing local files
[03:21:33] Completed 47500 out of 250000 steps  (19 percent)
[03:35:26] Writing local files
[03:35:26] Completed 50000 out of 250000 steps  (20 percent)
[03:49:18] Writing local files
[03:49:18] Completed 52500 out of 250000 steps  (21 percent)
[04:03:11] Writing local files
[04:03:11] Completed 55000 out of 250000 steps  (22 percent)
[04:16:59] Writing local files
[04:16:59] Completed 57500 out of 250000 steps  (23 percent)
[04:30:53] Writing local files
[04:30:53] Completed 60000 out of 250000 steps  (24 percent)
[04:44:46] Writing local files
[04:44:46] Completed 62500 out of 250000 steps  (25 percent)
[04:58:40] Writing local files
[04:58:40] Completed 65000 out of 250000 steps  (26 percent)
[05:12:33] Writing local files
[05:12:34] Completed 67500 out of 250000 steps  (27 percent)
[05:26:27] Writing local files
[05:26:28] Completed 70000 out of 250000 steps  (28 percent)
[05:40:22] Writing local files
[05:40:22] Completed 72500 out of 250000 steps  (29 percent)
[05:54:15] Writing local files
[05:54:16] Completed 75000 out of 250000 steps  (30 percent)
[06:08:10] Writing local files
[06:08:10] Completed 77500 out of 250000 steps  (31 percent)
[06:22:04] Writing local files
[06:22:04] Completed 80000 out of 250000 steps  (32 percent)
[06:35:57] Writing local files
[06:35:58] Completed 82500 out of 250000 steps  (33 percent)
[06:49:48] Writing local files
[06:49:48] Completed 85000 out of 250000 steps  (34 percent)
[07:03:42] Writing local files
[07:03:42] Completed 87500 out of 250000 steps  (35 percent)
[07:15:46] Warning:  long 1-4 interactions
[07:15:46] Quit 101 - NaN detected: (ener[20])
[07:15:46]
[07:15:46] Simulation instability has been encountered. The run has entered a
[07:15:46]   state from which no further progress can be made.
[07:15:46] This may be the correct result of the simulation, however if you
[07:15:46]   often see other project units terminating early like this
[07:15:46]   too, you may wish to check the stability of your computer (issues
[07:15:46]   such as high temperature, overclocking, etc.).
[07:15:46] Going to send back what have done.
[07:15:46] logfile size: 74829
[07:15:46] - Writing 75379 bytes of core data to disk...
[07:15:46]   ... Done.
[07:15:46] - Failed to delete work/wudata_05.arc
[07:15:46] No C.P. to delete.
[07:15:46] - Failed to delete work/wudata_05.goe
[07:15:46] - Failed to delete work/wudata_05.xvg
[07:15:46] Warning:  check for stray files
[07:15:46]
[07:15:46] Folding@home Core Shutdown: EARLY_UNIT_END
[07:15:46]
[07:15:49] CoreStatus = 7B (123)
[07:15:49] Client-core communications error: ERROR 0x7b
[07:15:49] Deleting current work unit & continuing...
[07:17:53] - Preparing to get new work unit...
[07:17:53] + Attempting to get work packet
[07:17:53] - Connecting to assignment server
[07:17:54] - Successful: assigned to (171.64.65.64).
[07:17:54] + News From Folding@Home: Welcome to Folding@Home
[07:17:54] Loaded queue successfully.
[07:18:08] + Closed connections
[07:18:13]
[07:18:13] + Processing work unit
[07:18:13] Core required: FahCore_a1.exe
[07:18:13] Core found.
[07:18:13] Working on Unit 06 [July 24 07:18:13]
[07:18:13] + Working ...
[07:18:13]
[07:18:13] *------------------------------*
[07:18:13] Folding@Home Gromacs SMP Core
[07:18:13] Version 1.74 (March 10, 2007)
[07:18:13]
[07:18:13] Preparing to commence simulation
[07:18:13] - Ensuring status. Please wait.
[07:18:18] - Starting from initial work packet
[07:18:18]
[07:18:18] Project: 2665 (Run 3, Clone 92, Gen 29)
[07:18:18]
[07:18:18] Assembly optimizations on if available.
[07:18:18] Entering M.D.
[07:18:41] ial work pa- Starting from initial work packet
[07:18:41]
[07:18:41] Project: 2665 (Run 3, Clone 92, Gen 29)
[07:18:41]
[07:18:43] Entering M.D.
[07:18:49] Rejecting checkpoint
[07:18:50] Protein: HGG in water
[07:18:50] Writing local files
[07:18:58] Extra SSE boost OK.
[07:18:59] Writing local files
[07:18:59] Completed 0 out of 250000 steps  (0 percent)
[07:32:54] Writing local files
[07:32:54] Completed 2500 out of 250000 steps  (1 percent)
[07:46:48] Writing local files
[07:46:48] Completed 5000 out of 250000 steps  (2 percent)
[08:00:41] Writing local files
[08:00:41] Completed 7500 out of 250000 steps  (3 percent)
[08:14:34] Writing local files
[08:14:34] Completed 10000 out of 250000 steps  (4 percent)
[08:28:28] Writing local files
[08:28:29] Completed 12500 out of 250000 steps  (5 percent)
[08:42:23] Writing local files
[08:42:23] Completed 15000 out of 250000 steps  (6 percent)
[08:56:16] Writing local files
[08:56:16] Completed 17500 out of 250000 steps  (7 percent)
[09:10:10] Writing local files
[09:10:10] Completed 20000 out of 250000 steps  (8 percent)
[09:24:00] Writing local files
[09:24:00] Completed 22500 out of 250000 steps  (9 percent)
[09:37:52] Writing local files
[09:37:53] Completed 25000 out of 250000 steps  (10 percent)
[09:51:45] Writing local files
[09:51:46] Completed 27500 out of 250000 steps  (11 percent)
[10:05:39] Writing local files
[10:05:39] Completed 30000 out of 250000 steps  (12 percent)
[10:19:33] Writing local files
[10:19:33] Completed 32500 out of 250000 steps  (13 percent)
[10:33:27] Writing local files
[10:33:27] Completed 35000 out of 250000 steps  (14 percent)
[10:47:21] Writing local files
[10:47:21] Completed 37500 out of 250000 steps  (15 percent)
[11:01:16] Writing local files
[11:01:16] Completed 40000 out of 250000 steps  (16 percent)
[11:15:10] Writing local files
[11:15:10] Completed 42500 out of 250000 steps  (17 percent)
[11:29:04] Writing local files
[11:29:04] Completed 45000 out of 250000 steps  (18 percent)
[11:42:58] Writing local files
[11:42:58] Completed 47500 out of 250000 steps  (19 percent)
[11:56:51] Writing local files
[11:56:51] Completed 50000 out of 250000 steps  (20 percent)
[12:10:40] Writing local files
[12:10:40] Completed 52500 out of 250000 steps  (21 percent)
[12:24:33] Writing local files
[12:24:34] Completed 55000 out of 250000 steps  (22 percent)
[12:38:27] Writing local files
[12:38:27] Completed 57500 out of 250000 steps  (23 percent)
[12:52:21] Writing local files
[12:52:21] Completed 60000 out of 250000 steps  (24 percent)
[13:06:14] Writing local files
[13:06:14] Completed 62500 out of 250000 steps  (25 percent)
[13:20:08] Writing local files
[13:20:08] Completed 65000 out of 250000 steps  (26 percent)
[13:34:03] Writing local files
[13:34:03] Completed 67500 out of 250000 steps  (27 percent)
[13:47:58] Writing local files
[13:47:58] Completed 70000 out of 250000 steps  (28 percent)
[14:01:53] Writing local files
[14:01:53] Completed 72500 out of 250000 steps  (29 percent)
[14:15:47] Writing local files
[14:15:47] Completed 75000 out of 250000 steps  (30 percent)
[14:29:42] Writing local files
[14:29:42] Completed 77500 out of 250000 steps  (31 percent)
[14:43:33] Writing local files
[14:43:33] Completed 80000 out of 250000 steps  (32 percent)
[14:57:28] Writing local files
[14:57:28] Completed 82500 out of 250000 steps  (33 percent)
[15:11:23] Writing local files
[15:11:23] Completed 85000 out of 250000 steps  (34 percent)
[15:25:18] Writing local files
[15:25:18] Completed 87500 out of 250000 steps  (35 percent)
[15:37:22] Warning:  long 1-4 interactions
[15:37:22] Quit 101 - NaN detected: (ener[20])
[15:37:22]
[15:37:22] Simulation instability has been encountered. The run has entered a
[15:37:22]   state from which no further progress can be made.
[15:37:22] This may be the correct result of the simulation, however if you
[15:37:22]   often see other project units terminating early like this
[15:37:22]   too, you may wish to check the stability of your computer (issues
[15:37:22]   such as high temperature, overclocking, etc.).
[15:37:22] Going to send back what have done.
[15:37:22] logfile size: 74829
[15:37:22] - Writing 75379 bytes of core data to disk...
[15:37:22]   ... Done.
[15:37:22] - Failed to delete work/wudata_06.arc
[15:37:22] - Failed to delete work/wudata_06.xtc
[15:37:22] No C.P. to delete.
[15:37:22] - Failed to delete work/wudata_06.dyn
[15:37:22] - Failed to delete work/wudata_06.chk
[15:37:22] - Failed to delete work/wudata_06.sas
[15:37:22] - Failed to delete work/wudata_06.goe
[15:37:22] - Failed to delete work/wudata_06.pdo
[15:37:22] - Failed to delete work/wudata_06.xvg
[15:37:22] Warning:  check for stray files
[15:39:22]
[15:39:22] Folding@home Core Shutdown: EARLY_UNIT_END
[15:39:22]
[15:39:25] CoreStatus = 7B (123)
[15:39:25] Client-core communications error: ERROR 0x7b
[15:39:25] Deleting current work unit & continuing...
[15:41:29] - Preparing to get new work unit...
[15:41:29] + Attempting to get work packet
[15:41:29] - Connecting to assignment server
[15:41:30] - Successful: assigned to (171.64.65.64).
[15:41:30] + News From Folding@Home: Welcome to Folding@Home
[15:41:30] Loaded queue successfully.
[15:41:43] + Closed connections
[15:41:48]
[15:41:48] + Processing work unit
[15:41:48] Core required: FahCore_a1.exe
[15:41:48] Core found.
[15:41:48] Working on Unit 07 [July 24 15:41:48]
[15:41:48] + Working ...
[15:41:48]
[15:41:48] *------------------------------*
[15:41:48] Folding@Home Gromacs SMP Core
[15:41:48] Version 1.74 (March 10, 2007)
[15:41:48]
[15:41:48] Preparing to commence simulation
[15:41:48] - Ensuring status. Please wait.
[15:41:53] - Starting from initial work packet
[15:41:53]
[15:41:53] Project: 2665 (Run 3, Clone 92, Gen 29)
[15:41:53]
[15:41:53] Assembly optimizations on if available.
[15:41:53] Entering M.D.
[15:42:16] 1 percent)
[15:42:16] - Starting from initial work packet
[15:42:16]
[15:42:16] Project: 2665 (Run 3, Clone 92, Gen 29)
[15:42:16]
[15:42:18] Entering M.D.
[15:42:24] Rejecting checkpoint
[15:42:25] Protein: HGG in water
[15:42:25] Writing local files
[15:42:33] Extra SSE boost OK.
[15:42:34] Writing local files
[15:42:34] Completed 0 out of 250000 steps  (0 percent)
[15:56:28] Writing local files
[15:56:28] Completed 2500 out of 250000 steps  (1 percent)
[16:10:22] Writing local files
[16:10:22] Completed 5000 out of 250000 steps  (2 percent)
[16:24:15] Writing local files
[16:24:15] Completed 7500 out of 250000 steps  (3 percent)
[16:38:09] Writing local files
[16:38:09] Completed 10000 out of 250000 steps  (4 percent)
[16:52:03] Writing local files
[16:52:03] Completed 12500 out of 250000 steps  (5 percent)
[17:05:57] Writing local files
[17:05:57] Completed 15000 out of 250000 steps  (6 percent)
[17:19:42] Writing local files
[17:19:43] Completed 17500 out of 250000 steps  (7 percent)
[17:33:36] Writing local files
[17:33:36] Completed 20000 out of 250000 steps  (8 percent)
[17:47:29] Writing local files
[17:47:30] Completed 22500 out of 250000 steps  (9 percent)
[18:01:21] Writing local files
[18:01:22] Completed 25000 out of 250000 steps  (10 percent)
[18:15:14] Writing local files
[18:15:14] Completed 27500 out of 250000 steps  (11 percent)
[18:29:07] Writing local files
[18:29:07] Completed 30000 out of 250000 steps  (12 percent)
[18:43:00] Writing local files
[18:43:00] Completed 32500 out of 250000 steps  (13 percent)
[18:56:54] Writing local files
[18:56:54] Completed 35000 out of 250000 steps  (14 percent)
[19:10:47] Writing local files
[19:10:47] Completed 37500 out of 250000 steps  (15 percent)
[19:24:41] Writing local files
[19:24:42] Completed 40000 out of 250000 steps  (16 percent)
[19:38:36] Writing local files
[19:38:36] Completed 42500 out of 250000 steps  (17 percent)
[19:52:26] Writing local files
[19:52:26] Completed 45000 out of 250000 steps  (18 percent)
[20:06:19] Writing local files
[20:06:19] Completed 47500 out of 250000 steps  (19 percent)
[20:20:13] Writing local files
[20:20:13] Completed 50000 out of 250000 steps  (20 percent)
[20:34:05] Writing local files
[20:34:05] Completed 52500 out of 250000 steps  (21 percent)
[20:47:58] Writing local files
[20:47:58] Completed 55000 out of 250000 steps  (22 percent)
[21:01:51] Writing local files
[21:01:51] Completed 57500 out of 250000 steps  (23 percent)
[21:15:44] Writing local files
[21:15:44] Completed 60000 out of 250000 steps  (24 percent)
[21:29:38] Writing local files
[21:29:38] Completed 62500 out of 250000 steps  (25 percent)
[21:43:32] Writing local files
[21:43:32] Completed 65000 out of 250000 steps  (26 percent)
[21:57:27] Writing local files
[21:57:27] Completed 67500 out of 250000 steps  (27 percent)
[22:11:21] Writing local files
[22:11:22] Completed 70000 out of 250000 steps  (28 percent)
[22:25:13] Writing local files
[22:25:13] Completed 72500 out of 250000 steps  (29 percent)
[22:39:07] Writing local files
[22:39:07] Completed 75000 out of 250000 steps  (30 percent)
[22:53:01] Writing local files
[22:53:01] Completed 77500 out of 250000 steps  (31 percent)
[23:06:56] Writing local files
[23:06:56] Completed 80000 out of 250000 steps  (32 percent)
[23:20:51] Writing local files
[23:20:51] Completed 82500 out of 250000 steps  (33 percent)
[23:34:46] Writing local files
[23:34:46] Completed 85000 out of 250000 steps  (34 percent)
[23:48:41] Writing local files
[23:48:41] Completed 87500 out of 250000 steps  (35 percent)
[00:00:45] Warning:  long 1-4 interactions
[00:00:45] Quit 101 - NaN detected: (ener[20])
[00:00:45]
[00:00:45] Simulation instability has been encountered. The run has entered a
[00:00:45]   state from which no further progress can be made.
[00:00:45] This may be the correct result of the simulation, however if you
[00:00:45]   often see other project units terminating early like this
[00:00:45]   too, you may wish to check the stability of your computer (issues
[00:00:45]   such as high temperature, overclocking, etc.).
[00:00:45] Going to send back what have done.
[00:00:45] logfile size: 74829
[00:00:45] - Writing 75379 bytes of core data to disk...
[00:00:45]   ... Done.
[00:02:45]
[00:02:45] Folding@home Core Shutdown: EARLY_UNIT_END
[00:02:45]
[00:02:49] CoreStatus = 7B (123)
[00:02:49] Client-core communications error: ERROR 0x7b
[00:02:49] - Attempting to download new core...
[00:02:49] + Downloading new core: FahCore_a1.exe
[00:02:49] + 10240 bytes downloaded
[00:02:49] + 20480 bytes downloaded
[00:02:49] + 30720 bytes downloaded
[00:02:49] + 40960 bytes downloaded
[00:02:49] + 51200 bytes downloaded
[00:02:49] + 61440 bytes downloaded
[00:02:49] + 71680 bytes downloaded
[00:02:49] + 81920 bytes downloaded
[00:02:49] + 92160 bytes downloaded
[00:02:49] + 102400 bytes downloaded
[00:02:49] + 112640 bytes downloaded
[00:02:49] + 122880 bytes downloaded
[00:02:49] + 133120 bytes downloaded
[00:02:49] + 143360 bytes downloaded
[00:02:49] + 153600 bytes downloaded
[00:02:49] + 163840 bytes downloaded
[00:02:49] + 174080 bytes downloaded
[00:02:49] + 184320 bytes downloaded
[00:02:49] + 194560 bytes downloaded
[00:02:49] + 204800 bytes downloaded
[00:02:49] + 215040 bytes downloaded
[00:02:49] + 225280 bytes downloaded
[00:02:49] + 235520 bytes downloaded
[00:02:50] + 245760 bytes downloaded
[00:02:50] + 256000 bytes downloaded
[00:02:50] + 266240 bytes downloaded
[00:02:50] + 276480 bytes downloaded
[00:02:50] + 286720 bytes downloaded
[00:02:50] + 296960 bytes downloaded
[00:02:50] + 307200 bytes downloaded
[00:02:50] + 317440 bytes downloaded
[00:02:50] + 327680 bytes downloaded
[00:02:50] + 337920 bytes downloaded
[00:02:50] + 348160 bytes downloaded
[00:02:50] + 358400 bytes downloaded
[00:02:50] + 368640 bytes downloaded
[00:02:50] + 378880 bytes downloaded
[00:02:50] + 389120 bytes downloaded
[00:02:50] + 399360 bytes downloaded
[00:02:50] + 409600 bytes downloaded
[00:02:50] + 419840 bytes downloaded
[00:02:50] + 430080 bytes downloaded
[00:02:50] + 440320 bytes downloaded
[00:02:50] + 450560 bytes downloaded
[00:02:50] + 460800 bytes downloaded
[00:02:50] + 471040 bytes downloaded
[00:02:50] + 481280 bytes downloaded
[00:02:50] + 491520 bytes downloaded
[00:02:50] + 501760 bytes downloaded
[00:02:50] + 512000 bytes downloaded
[00:02:50] + 522240 bytes downloaded
[00:02:50] + 532480 bytes downloaded
[00:02:50] + 542720 bytes downloaded
[00:02:50] + 552960 bytes downloaded
[00:02:50] + 563200 bytes downloaded
[00:02:50] + 573440 bytes downloaded
[00:02:50] + 583680 bytes downloaded
[00:02:50] + 593920 bytes downloaded
[00:02:50] + 604160 bytes downloaded
[00:02:50] + 614400 bytes downloaded
[00:02:50] + 624640 bytes downloaded
[00:02:50] + 634880 bytes downloaded
[00:02:50] + 645120 bytes downloaded
[00:02:50] + 655360 bytes downloaded
[00:02:50] + 665600 bytes downloaded
[00:02:50] + 675840 bytes downloaded
[00:02:50] + 686080 bytes downloaded
[00:02:50] + 696320 bytes downloaded
[00:02:50] + 706560 bytes downloaded
[00:02:50] + 716800 bytes downloaded
[00:02:50] + 727040 bytes downloaded
[00:02:50] + 737280 bytes downloaded
[00:02:50] + 747520 bytes downloaded
[00:02:50] + 757760 bytes downloaded
[00:02:50] + 768000 bytes downloaded
[00:02:50] + 778240 bytes downloaded
[00:02:50] + 788480 bytes downloaded
[00:02:50] + 789667 bytes downloaded
[00:02:50] Verifying core Core_a1.fah...
[00:02:50] Signature is VALID
[00:02:50]
[00:02:50] Trying to unzip core FahCore_a1.exe
[00:02:50] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[00:02:50] + Core successfully engaged
[00:02:50] Deleting current work unit & continuing...
[00:04:54] - Preparing to get new work unit...
[00:04:54] + Attempting to get work packet
[00:04:54] - Connecting to assignment server
[00:04:55] - Successful: assigned to (171.64.65.64).
[00:04:55] + News From Folding@Home: Welcome to Folding@Home
[00:04:55] Loaded queue successfully.
[00:05:09] + Closed connections
[00:05:14]
[00:05:14] + Processing work unit
[00:05:14] Core required: FahCore_a1.exe
[00:05:14] Core found.
[00:05:14] Working on Unit 08 [July 25 00:05:14]
[00:05:14] + Working ...
[00:05:14]
[00:05:14] *------------------------------*
[00:05:14] Folding@Home Gromacs SMP Core
[00:05:14] Version 1.74 (March 10, 2007)
[00:05:14]
[00:05:14] Preparing to commence simulation
[00:05:14] - Ensuring status. Please wait.
[00:05:18] - Starting from initial work packet
[00:05:18]
[00:05:18] Project: 2665 (Run 3, Clone 92, Gen 29)
[00:05:18]
[00:05:19] Assembly optimizations on if available.
[00:05:19] Entering M.D.
[00:05:42] ial work pa- Starting from initial work packet
[00:05:42]
[00:05:42] Project: 2665 (Run 3, Clone 92, Gen 29)
[00:05:42]
[00:05:43] Entering M.D.
[00:05:51] GG in water
[00:05:51] Writing local files
[00:05:51] cal files
[00:05:52] Extra SSE boost OK.
[00:05:59] cal files
[00:05:59] Completed 0 out of 250000 steps  (0 percent)
[00:19:53] Writing local files
[00:19:53] Completed 2500 out of 250000 steps  (1 percent)
[00:33:46] Writing local files
[00:33:47] Completed 5000 out of 250000 steps  (2 percent)
[00:47:40] Writing local files
[00:47:40] Completed 7500 out of 250000 steps  (3 percent)
[01:01:30] Writing local files
[01:01:30] Completed 10000 out of 250000 steps  (4 percent)
[01:15:23] Writing local files
[01:15:24] Completed 12500 out of 250000 steps  (5 percent)
[01:29:17] Writing local files
[01:29:17] Completed 15000 out of 250000 steps  (6 percent)
[01:43:10] Writing local files
[01:43:11] Completed 17500 out of 250000 steps  (7 percent)
[01:57:04] Writing local files
[01:57:04] Completed 20000 out of 250000 steps  (8 percent)
[02:10:56] Writing local files
[02:10:57] Completed 22500 out of 250000 steps  (9 percent)
[02:24:48] Writing local files
[02:24:48] Completed 25000 out of 250000 steps  (10 percent)
[02:38:41] Writing local files
[02:38:41] Completed 27500 out of 250000 steps  (11 percent)
[02:52:33] Writing local files
[02:52:33] Completed 30000 out of 250000 steps  (12 percent)
[03:06:26] Writing local files
[03:06:26] Completed 32500 out of 250000 steps  (13 percent)
[03:20:19] Writing local files
[03:20:19] Completed 35000 out of 250000 steps  (14 percent)
[03:34:12] Writing local files
[03:34:12] Completed 37500 out of 250000 steps  (15 percent)
[03:48:02] Writing local files
[03:48:02] Completed 40000 out of 250000 steps  (16 percent)
[04:01:56] Writing local files
[04:01:56] Completed 42500 out of 250000 steps  (17 percent)
[04:15:50] Writing local files
[04:15:50] Completed 45000 out of 250000 steps  (18 percent)
[04:29:43] Writing local files
[04:29:43] Completed 47500 out of 250000 steps  (19 percent)
[04:43:36] Writing local files
[04:43:36] Completed 50000 out of 250000 steps  (20 percent)
[04:57:29] Writing local files
[04:57:29] Completed 52500 out of 250000 steps  (21 percent)
[05:11:22] Writing local files
[05:11:22] Completed 55000 out of 250000 steps  (22 percent)
[05:25:15] Writing local files
[05:25:15] Completed 57500 out of 250000 steps  (23 percent)
[05:39:08] Writing local files
[05:39:09] Completed 60000 out of 250000 steps  (24 percent)
[05:53:02] Writing local files
[05:53:02] Completed 62500 out of 250000 steps  (25 percent)
[06:06:56] Writing local files
[06:06:56] Completed 65000 out of 250000 steps  (26 percent)
[06:20:46] Writing local files
[06:20:46] Completed 67500 out of 250000 steps  (27 percent)
[06:34:41] Writing local files
[06:34:41] Completed 70000 out of 250000 steps  (28 percent)
[06:48:34] Writing local files
[06:48:34] Completed 72500 out of 250000 steps  (29 percent)
[07:02:27] Writing local files
[07:02:28] Completed 75000 out of 250000 steps  (30 percent)
[07:16:21] Writing local files
[07:16:21] Completed 77500 out of 250000 steps  (31 percent)
[07:30:14] Writing local files
[07:30:14] Completed 80000 out of 250000 steps  (32 percent)
[07:44:07] Writing local files
[07:44:08] Completed 82500 out of 250000 steps  (33 percent)
[07:58:01] Writing local files
[07:58:02] Completed 85000 out of 250000 steps  (34 percent)
[08:11:56] Writing local files
[08:11:56] Completed 87500 out of 250000 steps  (35 percent)
[08:24:00] Warning:  long 1-4 interactions
[08:24:00] Quit 101 - NaN detected: (ener[20])
[08:24:00]
[08:24:00] Simulation instability has been encountered. The run has entered a
[08:24:00]   state from which no further progress can be made.
[08:24:00] This may be the correct result of the simulation, however if you
[08:24:00]   often see other project units terminating early like this
[08:24:00]   too, you may wish to check the stability of your computer (issues
[08:24:00]   such as high temperature, overclocking, etc.).
[08:24:00] Going to send back what have done.
[08:24:00] logfile size: 74829
[08:24:00] - Writing 75379 bytes of core data to disk...
[08:24:00]   ... Done.
[08:24:00] - Failed to delete work/wudata_08.arc
[08:24:00] - Failed to delete work/wudata_08.xtc
[08:24:00] - Failed to delete work/wudata_08.dyn
[08:24:00] - Failed to delete work/wudata_08.chk
[08:24:00] - Failed to delete work/wudata_08.xvg
[08:24:00] Warning:  check for stray files
[08:26:00]
[08:26:00] Folding@home Core Shutdown: EARLY_UNIT_END
[08:26:00]
[08:26:04] CoreStatus = 7B (123)
[08:26:04] Client-core communications error: ERROR 0x7b
[08:26:04] Deleting current work unit & continuing...
[08:28:08] - Preparing to get new work unit...
[08:28:08] + Attempting to get work packet
[08:28:08] - Connecting to assignment server
[08:28:08] - Successful: assigned to (171.64.65.64).
[08:28:08] + News From Folding@Home: Welcome to Folding@Home
[08:28:08] Loaded queue successfully.
[08:28:23] + Closed connections
[08:28:28]
[08:28:28] + Processing work unit
[08:28:28] Core required: FahCore_a1.exe
[08:28:28] Core found.
[08:28:28] Working on Unit 09 [July 25 08:28:28]
[08:28:28] + Working ...
[08:28:28]
[08:28:28] *------------------------------*
[08:28:28] Folding@Home Gromacs SMP Core
[08:28:28] Version 1.74 (March 10, 2007)
[08:28:28]
[08:28:28] Preparing to commence simulation
[08:28:28] - Ensuring status. Please wait.
[08:28:32] - Starting from initial work packet
[08:28:33]
[08:28:33] Project: 2665 (Run 3, Clone 92, Gen 29)
[08:28:33]
[08:28:34] Assembly optimizations on if available.
[08:28:34] Entering M.D.
[08:28:56] ial work pa- Starting from initial work packet
[08:28:56]
[08:28:56] Project: 2665 (Run 3, Clone 92, Gen 29)
[08:28:56]
[08:28:57] Entering M.D.
[08:29:03] Rejecting checkpoint
[08:29:04]
[08:29:04] Writing local files
[08:29:05]
[08:29:05] Writing local files
[08:29:13] Extra SSE boost OK.
[08:29:13] Writing local files
[08:29:13] Completed 0 out of 250000 steps  (0 percent)
[08:43:07] Writing local files
[08:43:07] Completed 2500 out of 250000 steps  (1 percent)
[08:56:56] Writing local files
[08:56:56] Completed 5000 out of 250000 steps  (2 percent)
[09:10:48] Writing local files
[09:10:48] Completed 7500 out of 250000 steps  (3 percent)
[09:24:42] Writing local files
[09:24:42] Completed 10000 out of 250000 steps  (4 percent)
[09:38:35] Writing local files
[09:38:36] Completed 12500 out of 250000 steps  (5 percent)
[09:52:29] Writing local files
[09:52:29] Completed 15000 out of 250000 steps  (6 percent)
I've been blessed with getting this puppy not just once. I included a large portion of my log showing how numerous other WU's in between me getting this project several times ran to 100% flawlessly.
Sunin
Re: Projet 2665 (Run 3, Clone 92, Gen 29)
Post by Sunin »
[23:27:39] Version 1.74 (March 10, 2007)
[23:27:39]
[23:27:39] Preparing to commence simulation
[23:27:39] - Ensuring status. Please wait.
[23:27:44] - Starting from initial work packet
[23:27:44]
[23:27:44] Project: 2665 (Run 3, Clone 317, Gen 32)
[23:27:44]
[23:27:45] Assembly optimizations on if available.
[23:27:45] Entering M.D.
[23:28:07] al work packet
[23:28:07]
[23:28:07] Project: 2665 (Run 3, Clone 317, Gen 32)
[23:28:07]
[23:28:07] 65 (Run 3, Clone 317, Gen 32)
[23:28:07]
[23:28:09] Entering M.D.
[23:28:15] Rejecting checkpoint
[23:28:16] Protein: HGG in water
[23:28:16] Writing local files
[23:28:24] Extra SSE boost OK.
[23:28:25] Writing local files
[23:28:25] Completed 0 out of 250000 steps  (0 percent)
[23:42:21] Writing local files
[23:42:21] Completed 2500 out of 250000 steps  (1 percent)
[23:56:22] Writing local files
[23:56:22] Completed 5000 out of 250000 steps  (2 percent)
[00:10:23] Writing local files
[00:10:23] Completed 7500 out of 250000 steps  (3 percent)
[00:24:25] Writing local files
[00:24:25] Completed 10000 out of 250000 steps  (4 percent)
[00:38:26] Writing local files
[00:38:26] Completed 12500 out of 250000 steps  (5 percent)
[00:52:27] Writing local files
[00:52:27] Completed 15000 out of 250000 steps  (6 percent)
[01:06:27] Writing local files
[01:06:28] Completed 17500 out of 250000 steps  (7 percent)
[01:20:29] Writing local files
[01:20:29] Completed 20000 out of 250000 steps  (8 percent)
[01:34:29] Writing local files
[01:34:29] Completed 22500 out of 250000 steps  (9 percent)
[01:48:28] Writing local files
[01:48:29] Completed 25000 out of 250000 steps  (10 percent)
[02:02:28] Writing local files
[02:02:28] Completed 27500 out of 250000 steps  (11 percent)
[02:16:22] Writing local files
[02:16:22] Completed 30000 out of 250000 steps  (12 percent)
[02:30:22] Writing local files
[02:30:22] Completed 32500 out of 250000 steps  (13 percent)
[02:44:21] Writing local files
[02:44:21] Completed 35000 out of 250000 steps  (14 percent)
[02:58:20] Writing local files
[02:58:21] Completed 37500 out of 250000 steps  (15 percent)
[03:12:20] Writing local files
[03:12:20] Completed 40000 out of 250000 steps  (16 percent)
[03:26:19] Writing local files
[03:26:19] Completed 42500 out of 250000 steps  (17 percent)
[03:40:20] Writing local files
[03:40:20] Completed 45000 out of 250000 steps  (18 percent)
[03:54:20] Writing local files
[03:54:21] Completed 47500 out of 250000 steps  (19 percent)
[04:08:21] Writing local files
[04:08:21] Completed 50000 out of 250000 steps  (20 percent)
[04:22:20] Writing local files
[04:22:20] Completed 52500 out of 250000 steps  (21 percent)
[04:36:20] Writing local files
[04:36:20] Completed 55000 out of 250000 steps  (22 percent)
[04:50:18] Writing local files
[04:50:18] Completed 57500 out of 250000 steps  (23 percent)
[05:04:17] Writing local files
[05:04:17] Completed 60000 out of 250000 steps  (24 percent)
[05:18:18] Writing local files
[05:18:18] Completed 62500 out of 250000 steps  (25 percent)
[05:32:18] Writing local files
[05:32:18] Completed 65000 out of 250000 steps  (26 percent)
[05:46:19] Writing local files
[05:46:19] Completed 67500 out of 250000 steps  (27 percent)
[06:00:19] Writing local files
[06:00:20] Completed 70000 out of 250000 steps  (28 percent)
[06:14:20] Writing local files
[06:14:20] Completed 72500 out of 250000 steps  (29 percent)
[06:28:20] Writing local files
[06:28:20] Completed 75000 out of 250000 steps  (30 percent)
[06:42:21] Writing local files
[06:42:21] Completed 77500 out of 250000 steps  (31 percent)
[06:56:22] Writing local files
[06:56:22] Completed 80000 out of 250000 steps  (32 percent)
[07:10:22] Writing local files
[07:10:22] Completed 82500 out of 250000 steps  (33 percent)
[07:24:22] Writing local files
[07:24:22] Completed 85000 out of 250000 steps  (34 percent)
[07:38:18] Writing local files
[07:38:18] Completed 87500 out of 250000 steps  (35 percent)
[07:52:17] Writing local files
[07:52:17] Completed 90000 out of 250000 steps  (36 percent)
[08:06:16] Writing local files
[08:06:17] Completed 92500 out of 250000 steps  (37 percent)
[08:20:16] Writing local files
[08:20:16] Completed 95000 out of 250000 steps  (38 percent)
[08:34:16] Writing local files
[08:34:16] Completed 97500 out of 250000 steps  (39 percent)
[08:48:16] Writing local files
[08:48:17] Completed 100000 out of 250000 steps  (40 percent)
[09:02:17] Writing local files
[09:02:17] Completed 102500 out of 250000 steps  (41 percent)
[09:16:17] Writing local files
[09:16:17] Completed 105000 out of 250000 steps  (42 percent)
[09:30:17] Writing local files
[09:30:17] Completed 107500 out of 250000 steps  (43 percent)
[09:44:15] Writing local files
[09:44:16] Completed 110000 out of 250000 steps  (44 percent)
[09:58:14] Writing local files
[09:58:14] Completed 112500 out of 250000 steps  (45 percent)
[10:12:08] Writing local files
[10:12:08] Completed 115000 out of 250000 steps  (46 percent)
[10:26:08] Writing local files
[10:26:08] Completed 117500 out of 250000 steps  (47 percent)
[10:40:09] Writing local files
[10:40:09] Completed 120000 out of 250000 steps  (48 percent)
[10:54:10] Writing local files
[10:54:10] Completed 122500 out of 250000 steps  (49 percent)
[11:08:11] Writing local files
[11:08:11] Completed 125000 out of 250000 steps  (50 percent)
[11:22:11] Writing local files
[11:22:11] Completed 127500 out of 250000 steps  (51 percent)
[11:36:12] Writing local files
[11:36:12] Completed 130000 out of 250000 steps  (52 percent)
[11:50:12] Writing local files
[11:50:12] Completed 132500 out of 250000 steps  (53 percent)
[12:04:13] Writing local files
[12:04:13] Completed 135000 out of 250000 steps  (54 percent)
[12:18:14] Writing local files
[12:18:14] Completed 137500 out of 250000 steps  (55 percent)
[12:32:15] Writing local files
[12:32:15] Completed 140000 out of 250000 steps  (56 percent)
[12:46:11] Writing local files
[12:46:11] Completed 142500 out of 250000 steps  (57 percent)
[13:00:12] Writing local files
[13:00:12] Completed 145000 out of 250000 steps  (58 percent)
[13:14:12] Writing local files
[13:14:12] Completed 147500 out of 250000 steps  (59 percent)
[13:28:12] Writing local files
[13:28:12] Completed 150000 out of 250000 steps  (60 percent)
[13:42:11] Writing local files
[13:42:11] Completed 152500 out of 250000 steps  (61 percent)
[13:56:11] Writing local files
[13:56:11] Completed 155000 out of 250000 steps  (62 percent)
[14:10:10] Writing local files
[14:10:10] Completed 157500 out of 250000 steps  (63 percent)
[14:24:09] Writing local files
[14:24:09] Completed 160000 out of 250000 steps  (64 percent)
[14:38:09] Writing local files
[14:38:09] Completed 162500 out of 250000 steps  (65 percent)
[14:52:10] Writing local files
[14:52:10] Completed 165000 out of 250000 steps  (66 percent)
[15:06:10] Writing local files
[15:06:10] Completed 167500 out of 250000 steps  (67 percent)
[15:20:04] Writing local files
[15:20:05] Completed 170000 out of 250000 steps  (68 percent)
[15:34:05] Writing local files
[15:34:05] Completed 172500 out of 250000 steps  (69 percent)
[15:48:05] Writing local files
[15:48:05] Completed 175000 out of 250000 steps  (70 percent)
[16:02:04] Writing local files
[16:02:04] Completed 177500 out of 250000 steps  (71 percent)
[16:16:04] Writing local files
[16:16:04] Completed 180000 out of 250000 steps  (72 percent)
[16:30:04] Writing local files
[16:30:04] Completed 182500 out of 250000 steps  (73 percent)
[16:44:05] Writing local files
[16:44:05] Completed 185000 out of 250000 steps  (74 percent)
[16:58:05] Writing local files
[16:58:05] Completed 187500 out of 250000 steps  (75 percent)
[17:12:04] Writing local files
[17:12:04] Completed 190000 out of 250000 steps  (76 percent)
[17:26:04] Writing local files
[17:26:04] Completed 192500 out of 250000 steps  (77 percent)
[17:40:03] Writing local files
[17:40:03] Completed 195000 out of 250000 steps  (78 percent)
[17:53:57] Writing local files
[17:53:57] Completed 197500 out of 250000 steps  (79 percent)
[18:07:56] Writing local files
[18:07:56] Completed 200000 out of 250000 steps  (80 percent)
[18:21:55] Writing local files
[18:21:55] Completed 202500 out of 250000 steps  (81 percent)
[18:35:53] Writing local files
[18:35:53] Completed 205000 out of 250000 steps  (82 percent)
[18:49:51] Writing local files
[18:49:51] Completed 207500 out of 250000 steps  (83 percent)
[19:03:49] Writing local files
[19:03:49] Completed 210000 out of 250000 steps  (84 percent)
[19:17:47] Writing local files
[19:17:47] Completed 212500 out of 250000 steps  (85 percent)
[19:31:46] Writing local files
[19:31:46] Completed 215000 out of 250000 steps  (86 percent)
[19:45:46] Writing local files
[19:45:46] Completed 217500 out of 250000 steps  (87 percent)
[19:59:47] Writing local files
[19:59:47] Completed 220000 out of 250000 steps  (88 percent)
[20:13:48] Writing local files
[20:13:48] Completed 222500 out of 250000 steps  (89 percent)
[20:27:45] Writing local files
[20:27:45] Completed 225000 out of 250000 steps  (90 percent)
[20:41:46] Writing local files
[20:41:46] Completed 227500 out of 250000 steps  (91 percent)
[20:55:45] Writing local files
[20:55:45] Completed 230000 out of 250000 steps  (92 percent)
[21:09:44] Writing local files
[21:09:44] Completed 232500 out of 250000 steps  (93 percent)
[21:23:43] Writing local files
[21:23:44] Completed 235000 out of 250000 steps  (94 percent)
[21:37:42] Writing local files
[21:37:42] Completed 237500 out of 250000 steps  (95 percent)
[21:51:42] Writing local files
[21:51:42] Completed 240000 out of 250000 steps  (96 percent)
[22:05:40] Writing local files
[22:05:40] Completed 242500 out of 250000 steps  (97 percent)
[22:19:39] Writing local files
[22:19:39] Completed 245000 out of 250000 steps  (98 percent)
[22:33:38] Writing local files
[22:33:38] Completed 247500 out of 250000 steps  (99 percent)
[22:47:38] Writing local files
[22:47:39] Completed 250000 out of 250000 steps  (100 percent)
[22:47:39] Writing final coordinates.
[22:47:40] Past main M.D. loop
[22:47:40] Will end MPI now
[22:48:40]
[22:48:40] Finished Work Unit:
[22:48:40] - Reading up to 21310704 from "work/wudata_04.arc": Read 21310704
[22:48:40] - Reading up to 555360 from "work/wudata_04.xtc": Read 555360
[22:48:40] goefile size: 0
[22:48:40] logfile size: 203313
[22:48:40] Leaving Run
[22:48:41] - Writing 22075749 bytes of core data to disk...
[22:48:41]   ... Done.
[22:48:41] - Failed to delete work/wudata_04.sas
[22:48:41] - Failed to delete work/wudata_04.goe
[22:48:41] Warning:  check for stray files
[22:48:41] - Shutting down core
[22:48:41]
[22:48:41] Folding@home Core Shutdown: FINISHED_UNIT
[22:48:41]
[22:50:47] CoreStatus = 64 (100)
[22:50:47] Sending work to server
[22:50:47] + Attempting to send results
[22:55:37] + Results successfully sent
[22:55:37] Thank you for your contribution to Folding@Home.
[22:55:37] + Number of Units Completed: 84
[22:57:41] - Preparing to get new work unit...
[22:57:41] + Attempting to get work packet
[22:57:41] - Connecting to assignment server
[22:57:42] - Successful: assigned to (171.64.65.64).
[22:57:42] + News From Folding@Home: Welcome to Folding@Home
[22:57:42] Loaded queue successfully.
[22:57:54] + Closed connections
[22:57:54]
[22:57:54] + Processing work unit
[22:57:54] Core required: FahCore_a1.exe
[22:57:54] Core found.
[22:57:54] Working on Unit 05 [July 19 22:57:54]
[22:57:54] + Working ...
[22:57:54]
[22:57:54] *------------------------------*
[22:57:54] Folding@Home Gromacs SMP Core
[22:57:54] Version 1.74 (March 10, 2007)
[22:57:54]
[22:57:54] Preparing to commence simulation
[22:57:54] - Ensuring status. Please wait.
[22:57:56] - Starting from initial work packet
[22:57:56]
[22:57:56] Project: 2653 (Run 26, Clone 52, Gen 79)
[22:57:56]
[22:57:56] Assembly optimizations on if available.
[22:57:56] Entering M.D.
[22:58:14] al work pa- Starting from initial work packet
[22:58:14]
[22:58:14] Project: 2653 (Run 26, Clone 52, Gen 79)
[22:58:14]
[22:58:15] Entering M.D.
[22:58:21] Rejecting checkpoint
[22:58:22] Protein: Protein in POPC
[22:58:22] Writing local files
[22:58:23] Extra SSE boost OK.
[22:58:23] Writing local files
[22:58:23] Completed 0 out of 500000 steps  (0 percent)
[23:07:25] Writing local files
[23:07:25] Completed 5000 out of 500000 steps  (1 percent)
[23:16:30] Writing local files
[23:16:30] Completed 10000 out of 500000 steps  (2 percent)
[23:25:35] Writing local files
[23:25:35] Completed 15000 out of 500000 steps  (3 percent)
[23:34:41] Writing local files
[23:34:41] Completed 20000 out of 500000 steps  (4 percent)
[23:43:46] Writing local files
[23:43:46] Completed 25000 out of 500000 steps  (5 percent)
[23:52:52] Writing local files
[23:52:52] Completed 30000 out of 500000 steps  (6 percent)
[00:01:58] Writing local files
[00:01:58] Completed 35000 out of 500000 steps  (7 percent)
[00:11:04] Writing local files
[00:11:04] Completed 40000 out of 500000 steps  (8 percent)
[00:20:10] Writing local files
[00:20:10] Completed 45000 out of 500000 steps  (9 percent)
[00:29:16] Writing local files
[00:29:16] Completed 50000 out of 500000 steps  (10 percent)
[00:38:22] Writing local files
[00:38:22] Completed 55000 out of 500000 steps  (11 percent)
[00:47:27] Writing local files
[00:47:27] Completed 60000 out of 500000 steps  (12 percent)
[00:56:33] Writing local files
[00:56:33] Completed 65000 out of 500000 steps  (13 percent)
[01:05:38] Writing local files
[01:05:38] Completed 70000 out of 500000 steps  (14 percent)
[01:14:43] Writing local files
[01:14:43] Completed 75000 out of 500000 steps  (15 percent)
[01:23:48] Writing local files
[01:23:48] Completed 80000 out of 500000 steps  (16 percent)
[01:32:53] Writing local files
[01:32:53] Completed 85000 out of 500000 steps  (17 percent)
[01:41:56] Writing local files
[01:41:56] Completed 90000 out of 500000 steps  (18 percent)
[01:50:59] Writing local files
[01:50:59] Completed 95000 out of 500000 steps  (19 percent)
[02:00:05] Writing local files
[02:00:05] Completed 100000 out of 500000 steps  (20 percent)
[02:09:10] Writing local files
[02:09:10] Completed 105000 out of 500000 steps  (21 percent)
[02:18:14] Writing local files
[02:18:14] Completed 110000 out of 500000 steps  (22 percent)
[02:27:18] Writing local files
[02:27:18] Completed 115000 out of 500000 steps  (23 percent)
[02:36:22] Writing local files
[02:36:23] Completed 120000 out of 500000 steps  (24 percent)
[02:45:26] Writing local files
[02:45:26] Completed 125000 out of 500000 steps  (25 percent)
[02:54:31] Writing local files
[02:54:31] Completed 130000 out of 500000 steps  (26 percent)
[03:03:36] Writing local files
[03:03:36] Completed 135000 out of 500000 steps  (27 percent)
[03:12:41] Writing local files
[03:12:41] Completed 140000 out of 500000 steps  (28 percent)
[03:21:45] Writing local files
[03:21:45] Completed 145000 out of 500000 steps  (29 percent)
[03:30:49] Writing local files
[03:30:49] Completed 150000 out of 500000 steps  (30 percent)
[03:39:52] Writing local files
[03:39:53] Completed 155000 out of 500000 steps  (31 percent)
[03:48:57] Writing local files
[03:48:57] Completed 160000 out of 500000 steps  (32 percent)
[03:58:01] Writing local files
[03:58:01] Completed 165000 out of 500000 steps  (33 percent)
[04:07:06] Writing local files
[04:07:06] Completed 170000 out of 500000 steps  (34 percent)
[04:16:10] Writing local files
[04:16:10] Completed 175000 out of 500000 steps  (35 percent)
[04:25:12] Writing local files
[04:25:12] Completed 180000 out of 500000 steps  (36 percent)
[04:34:14] Writing local files
[04:34:14] Completed 185000 out of 500000 steps  (37 percent)
[04:43:18] Writing local files
[04:43:18] Completed 190000 out of 500000 steps  (38 percent)
[04:52:22] Writing local files
[04:52:22] Completed 195000 out of 500000 steps  (39 percent)
[05:01:26] Writing local files
[05:01:27] Completed 200000 out of 500000 steps  (40 percent)
[05:10:30] Writing local files
[05:10:30] Completed 205000 out of 500000 steps  (41 percent)
[05:19:34] Writing local files
[05:19:34] Completed 210000 out of 500000 steps  (42 percent)
[05:28:39] Writing local files
[05:28:39] Completed 215000 out of 500000 steps  (43 percent)
[05:37:43] Writing local files
[05:37:43] Completed 220000 out of 500000 steps  (44 percent)
[05:46:48] Writing local files
[05:46:48] Completed 225000 out of 500000 steps  (45 percent)
[05:55:53] Writing local files
[05:55:53] Completed 230000 out of 500000 steps  (46 percent)
[06:04:56] Writing local files
[06:04:56] Completed 235000 out of 500000 steps  (47 percent)
[06:14:00] Writing local files
[06:14:00] Completed 240000 out of 500000 steps  (48 percent)
[06:23:04] Writing local files
[06:23:04] Completed 245000 out of 500000 steps  (49 percent)
[06:32:09] Writing local files
[06:32:09] Completed 250000 out of 500000 steps  (50 percent)
[06:41:14] Writing local files
[06:41:14] Completed 255000 out of 500000 steps  (51 percent)
[06:50:18] Writing local files
[06:50:18] Completed 260000 out of 500000 steps  (52 percent)
[06:59:22] Writing local files
[06:59:22] Completed 265000 out of 500000 steps  (53 percent)
[07:08:23] Writing local files
[07:08:23] Completed 270000 out of 500000 steps  (54 percent)
[07:17:26] Writing local files
[07:17:26] Completed 275000 out of 500000 steps  (55 percent)
[07:26:29] Writing local files
[07:26:29] Completed 280000 out of 500000 steps  (56 percent)
[07:35:32] Writing local files
[07:35:33] Completed 285000 out of 500000 steps  (57 percent)
[07:44:36] Writing local files
[07:44:36] Completed 290000 out of 500000 steps  (58 percent)
[07:53:40] Writing local files
[07:53:40] Completed 295000 out of 500000 steps  (59 percent)
[08:02:43] Writing local files
[08:02:43] Completed 300000 out of 500000 steps  (60 percent)
[08:11:47] Writing local files
[08:11:47] Completed 305000 out of 500000 steps  (61 percent)
[08:20:50] Writing local files
[08:20:50] Completed 310000 out of 500000 steps  (62 percent)
[08:29:53] Writing local files
[08:29:53] Completed 315000 out of 500000 steps  (63 percent)
[08:38:56] Writing local files
[08:38:56] Completed 320000 out of 500000 steps  (64 percent)
[08:48:00] Writing local files
[08:48:00] Completed 325000 out of 500000 steps  (65 percent)
[08:57:04] Writing local files
[08:57:04] Completed 330000 out of 500000 steps  (66 percent)
[09:06:08] Writing local files
[09:06:08] Completed 335000 out of 500000 steps  (67 percent)
[09:15:12] Writing local files
[09:15:12] Completed 340000 out of 500000 steps  (68 percent)
[09:24:15] Writing local files
[09:24:15] Completed 345000 out of 500000 steps  (69 percent)
[09:33:19] Writing local files
[09:33:19] Completed 350000 out of 500000 steps  (70 percent)
[09:42:22] Writing local files
[09:42:22] Completed 355000 out of 500000 steps  (71 percent)
[09:51:23] Writing local files
[09:51:23] Completed 360000 out of 500000 steps  (72 percent)
[10:00:24] Writing local files
[10:00:24] Completed 365000 out of 500000 steps  (73 percent)
[10:09:27] Writing local files
[10:09:28] Completed 370000 out of 500000 steps  (74 percent)
[10:18:31] Writing local files
[10:18:31] Completed 375000 out of 500000 steps  (75 percent)
[10:27:34] Writing local files
[10:27:34] Completed 380000 out of 500000 steps  (76 percent)
[10:36:37] Writing local files
[10:36:37] Completed 385000 out of 500000 steps  (77 percent)
[10:45:41] Writing local files
[10:45:41] Completed 390000 out of 500000 steps  (78 percent)
[10:54:44] Writing local files
[10:54:44] Completed 395000 out of 500000 steps  (79 percent)
[11:03:47] Writing local files
[11:03:47] Completed 400000 out of 500000 steps  (80 percent)
[11:12:51] Writing local files
[11:12:51] Completed 405000 out of 500000 steps  (81 percent)
[11:21:55] Writing local files
[11:21:55] Completed 410000 out of 500000 steps  (82 percent)
[11:31:00] Writing local files
[11:31:00] Completed 415000 out of 500000 steps  (83 percent)
[11:40:04] Writing local files
[11:40:04] Completed 420000 out of 500000 steps  (84 percent)
[11:49:08] Writing local files
[11:49:08] Completed 425000 out of 500000 steps  (85 percent)
[11:58:12] Writing local files
[11:58:12] Completed 430000 out of 500000 steps  (86 percent)
[12:07:15] Writing local files
[12:07:15] Completed 435000 out of 500000 steps  (87 percent)
[12:16:18] Writing local files
[12:16:18] Completed 440000 out of 500000 steps  (88 percent)
[12:25:21] Writing local files
[12:25:21] Completed 445000 out of 500000 steps  (89 percent)
[12:34:24] Writing local files
[12:34:24] Completed 450000 out of 500000 steps  (90 percent)
[12:43:25] Writing local files
[12:43:25] Completed 455000 out of 500000 steps  (91 percent)
[12:52:28] Writing local files
[12:52:28] Completed 460000 out of 500000 steps  (92 percent)
[13:01:32] Writing local files
[13:01:32] Completed 465000 out of 500000 steps  (93 percent)
[13:10:35] Writing local files
[13:10:35] Completed 470000 out of 500000 steps  (94 percent)
[13:19:39] Writing local files
[13:19:39] Completed 475000 out of 500000 steps  (95 percent)
[13:28:43] Writing local files
[13:28:43] Completed 480000 out of 500000 steps  (96 percent)
[13:37:47] Writing local files
[13:37:47] Completed 485000 out of 500000 steps  (97 percent)
[13:46:51] Writing local files
[13:46:51] Completed 490000 out of 500000 steps  (98 percent)
[13:55:55] Writing local files
[13:55:55] Completed 495000 out of 500000 steps  (99 percent)
[14:04:59] Writing local files
[14:04:59] Completed 500000 out of 500000 steps  (100 percent)
[14:04:59] Writing final coordinates.
[14:05:00] Past main M.D. loop
[14:05:00] Will end MPI now
[14:06:00]
[14:06:00] Finished Work Unit:
[14:06:00] - Reading up to 3724992 from "work/wudata_05.arc": Read 3724992
[14:06:00] - Reading up to 1779912 from "work/wudata_05.xtc": Read 1779912
[14:06:00] goefile size: 0
[14:06:00] logfile size: 17309
[14:06:00] Leaving Run
[14:06:04] - Writing 5526613 bytes of core data to disk...
[14:06:04]   ... Done.
[14:06:04] - Failed to delete work/wudata_05.sas
[14:06:04] - Failed to delete work/wudata_05.goe
[14:06:04] Warning:  check for stray files
[14:06:04] - Shutting down core
[14:08:04]
[14:08:04] Folding@home Core Shutdown: FINISHED_UNIT
[14:08:04]
[14:08:09] CoreStatus = 64 (100)
[14:08:09] Sending work to server
[14:08:09] + Attempting to send results
[14:09:18] + Results successfully sent
[14:09:18] Thank you for your contribution to Folding@Home.
[14:09:18] + Number of Units Completed: 85
[14:11:22] - Preparing to get new work unit...
[14:11:22] + Attempting to get work packet
[14:11:22] - Connecting to assignment server
[14:11:22] - Successful: assigned to (171.64.65.64).
[14:11:22] + News From Folding@Home: Welcome to Folding@Home
[14:11:22] Loaded queue successfully.
[14:11:36] + Closed connections
[14:11:36]
[14:11:36] + Processing work unit
[14:11:36] Core required: FahCore_a1.exe
[14:11:36] Core found.
[14:11:36] Working on Unit 06 [July 20 14:11:36]
[14:11:36] + Working ...
[14:11:36]
[14:11:36] *------------------------------*
[14:11:36] Folding@Home Gromacs SMP Core
[14:11:36] Version 1.74 (March 10, 2007)
[14:11:36]
[14:11:36] Preparing to commence simulation
[14:11:36] - Ensuring status. Please wait.
[14:11:40] - Starting from initial work packet
[14:11:40]
[14:11:40] Project: 2665 (Run 0, Clone 50, Gen 6)
[14:11:40]
[14:11:41] Assembly optimizations on if available.
[14:11:41] Entering M.D.
[14:12:04] tial work packet
[14:12:04]
[14:12:04] Project: 2665 (Run 0, Clone 50, Gen 6)
[14:12:04]
[14:12:04] 2665 (Run 0, Clone 50, Gen 6)
[14:12:04]
[14:12:05] Entering M.D.
[14:12:11] Rejecting checkpoint
[14:12:13] NaN detected: x[11415][0]=5.19565 v[11415][0]=NaN
[14:12:13] utdown: BAD_CORE_FILES
[14:12:13] Finalizing output
[14:14:13] 74 v[12716][2]=NaN
[14:14:13] 16][2]=8.56374 v[12716][2]=NaN
[14:14:13]
[14:14:13] Folding@home Core Shutdown: BAD_CORE_FILES
[14:14:13] Finalizing output
[14:16:16] CoreStatus = 1 (1)
[14:16:16] Client-core communications error: ERROR 0x1
[14:16:16] Deleting current work unit & continuing...
[14:18:20] - Preparing to get new work unit...
[14:18:20] + Attempting to get work packet
[14:18:20] - Connecting to assignment server
[14:18:20] - Successful: assigned to (171.64.65.64).
[14:18:20] + News From Folding@Home: Welcome to Folding@Home
[14:18:21] Loaded queue successfully.
[14:18:34] + Closed connections
[14:18:39]
[14:18:39] + Processing work unit
[14:18:39] Core required: FahCore_a1.exe
[14:18:39] Core found.
[14:18:39] Working on Unit 07 [July 20 14:18:39]
[14:18:39] + Working ...
[14:18:39]
[14:18:39] *------------------------------*
[14:18:39] Folding@Home Gromacs SMP Core
[14:18:39] Version 1.74 (March 10, 2007)
[14:18:39]
[14:18:39] Preparing to commence simulation
[14:18:39] - Ensuring status. Please wait.
[14:18:44] - Starting from initial work packet
[14:18:44]
[14:18:44] Project: 2665 (Run 0, Clone 50, Gen 6)
[14:18:44]
[14:18:44] Assembly optimizations on if available.
[14:18:44] Entering M.D.
[14:19:07] tial work pa- Starting from initial work packet
[14:19:07]
[14:19:07] Project: 2665 (Run 0, Clone 50, Gen 6)
[14:19:07]
[14:19:09] Entering M.D.
[14:19:15] Rejecting checkpoint
[14:19:16] NaN detected: x[11415][0]=5.19565 v[11415][0]=NaN
[14:19:16] utdown: BAD_CORE_FILES
[14:19:16] Finalizing output
[14:21:16] 74 v[12716][2]=NaN
[14:21:16] 16][2]=8.56374 v[12716][2]=NaN
[14:21:16]
[14:21:16] Folding@home Core Shutdown: BAD_CORE_FILES
[14:21:16] Finalizing output
[14:23:20] CoreStatus = 1 (1)
[14:23:20] Client-core communications error: ERROR 0x1
[14:23:20] Deleting current work unit & continuing...
[14:25:24] - Preparing to get new work unit...
[14:25:24] + Attempting to get work packet
[14:25:24] - Connecting to assignment server
[14:25:24] - Successful: assigned to (171.64.65.64).
[14:25:24] + News From Folding@Home: Welcome to Folding@Home
[14:25:24] Loaded queue successfully.
[14:25:37] + Closed connections
[14:25:42]
[14:25:42] + Processing work unit
[14:25:42] Core required: FahCore_a1.exe
[14:25:42] Core found.
[14:25:42] Working on Unit 08 [July 20 14:25:42]
[14:25:42] + Working ...
[14:25:43]
[14:25:43] *------------------------------*
[14:25:43] Folding@Home Gromacs SMP Core
[14:25:43] Version 1.74 (March 10, 2007)
[14:25:43]
[14:25:43] Preparing to commence simulation
[14:25:43] - Ensuring status. Please wait.
[14:25:47] - Starting from initial work packet
[14:25:47]
[14:25:47] Project: 2665 (Run 0, Clone 50, Gen 6)
[14:25:47]
[14:25:48] Assembly optimizations on if available.
[14:25:48] Entering M.D.
[14:26:11] tial work packet
[14:26:11]
[14:26:11] Project: 2665 (Run 0, Clone 50, Gen 6)
[14:26:11]
[14:26:11] 2665 (Run 0, Clone 50, Gen 6)
[14:26:11]
[14:26:12] Entering M.D.
[14:26:18] Rejecting checkpoint
[14:26:20] NaN detected: x[11415][0]=5.19565 v[11415][0]=NaN
[14:26:20] utdown: BAD_CORE_FILES
[14:26:20] Finalizing output
[14:28:20] 74 v[12716][2]=NaN
[14:28:20] 16][2]=8.56374 v[12716][2]=NaN
[14:28:20]
[14:28:20] Folding@home Core Shutdown: BAD_CORE_FILES
[14:28:20] Finalizing output
[14:30:23] CoreStatus = 1 (1)
[14:30:23] Client-core communications error: ERROR 0x1
[14:30:23] - Attempting to download new core...
[14:30:23] + Downloading new core: FahCore_a1.exe
[14:30:23] + 10240 bytes downloaded
[14:30:23] + 20480 bytes downloaded
[14:30:23] + 30720 bytes downloaded
[14:30:23] + 40960 bytes downloaded
[14:30:23] + 51200 bytes downloaded
[14:30:23] + 61440 bytes downloaded
[14:30:23] + 71680 bytes downloaded
[14:30:23] + 81920 bytes downloaded
[14:30:23] + 92160 bytes downloaded
[14:30:23] + 102400 bytes downloaded
[14:30:23] + 112640 bytes downloaded
[14:30:23] + 122880 bytes downloaded
[14:30:23] + 133120 bytes downloaded
[14:30:23] + 143360 bytes downloaded
[14:30:23] + 153600 bytes downloaded
[14:30:23] + 163840 bytes downloaded
[14:30:23] + 174080 bytes downloaded
[14:30:23] + 184320 bytes downloaded
[14:30:23] + 194560 bytes downloaded
[14:30:23] + 204800 bytes downloaded
[14:30:23] + 215040 bytes downloaded
[14:30:24] + 225280 bytes downloaded
[14:30:24] + 235520 bytes downloaded
[14:30:24] + 245760 bytes downloaded
[14:30:24] + 256000 bytes downloaded
[14:30:24] + 266240 bytes downloaded
[14:30:24] + 276480 bytes downloaded
[14:30:24] + 286720 bytes downloaded
[14:30:24] + 296960 bytes downloaded
[14:30:24] + 307200 bytes downloaded
[14:30:24] + 317440 bytes downloaded
[14:30:24] + 327680 bytes downloaded
[14:30:24] + 337920 bytes downloaded
[14:30:24] + 348160 bytes downloaded
[14:30:24] + 358400 bytes downloaded
[14:30:24] + 368640 bytes downloaded
[14:30:24] + 378880 bytes downloaded
[14:30:24] + 389120 bytes downloaded
[14:30:24] + 399360 bytes downloaded
[14:30:24] + 409600 bytes downloaded
[14:30:24] + 419840 bytes downloaded
[14:30:24] + 430080 bytes downloaded
[14:30:24] + 440320 bytes downloaded
[14:30:24] + 450560 bytes downloaded
[14:30:24] + 460800 bytes downloaded
[14:30:24] + 471040 bytes downloaded
[14:30:24] + 481280 bytes downloaded
[14:30:24] + 491520 bytes downloaded
[14:30:24] + 501760 bytes downloaded
[14:30:24] + 512000 bytes downloaded
[14:30:24] + 522240 bytes downloaded
[14:30:24] + 532480 bytes downloaded
[14:30:24] + 542720 bytes downloaded
[14:30:24] + 552960 bytes downloaded
[14:30:24] + 563200 bytes downloaded
[14:30:24] + 573440 bytes downloaded
[14:30:24] + 583680 bytes downloaded
[14:30:24] + 593920 bytes downloaded
[14:30:24] + 604160 bytes downloaded
[14:30:24] + 614400 bytes downloaded
[14:30:24] + 624640 bytes downloaded
[14:30:24] + 634880 bytes downloaded
[14:30:24] + 645120 bytes downloaded
[14:30:24] + 655360 bytes downloaded
[14:30:24] + 665600 bytes downloaded
[14:30:24] + 675840 bytes downloaded
[14:30:24] + 686080 bytes downloaded
[14:30:24] + 696320 bytes downloaded
[14:30:24] + 706560 bytes downloaded
[14:30:24] + 716800 bytes downloaded
[14:30:24] + 727040 bytes downloaded
[14:30:24] + 737280 bytes downloaded
[14:30:24] + 747520 bytes downloaded
[14:30:24] + 757760 bytes downloaded
[14:30:24] + 768000 bytes downloaded
[14:30:24] + 778240 bytes downloaded
[14:30:24] + 788480 bytes downloaded
[14:30:24] + 789667 bytes downloaded
[14:30:24] Verifying core Core_a1.fah...
[14:30:24] Signature is VALID
[14:30:24]
[14:30:24] Trying to unzip core FahCore_a1.exe
[14:30:25] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[14:30:25] + Core successfully engaged
[14:30:25] Deleting current work unit & continuing...
[14:32:29] - Preparing to get new work unit...
[14:32:29] + Attempting to get work packet
[14:32:29] - Connecting to assignment server
[14:32:29] - Successful: assigned to (171.64.65.64).
[14:32:29] + News From Folding@Home: Welcome to Folding@Home
[14:32:29] Loaded queue successfully.
[14:32:30] - Error: Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[14:32:40] + Attempting to get work packet
[14:32:40] - Connecting to assignment server
[14:32:41] - Successful: assigned to (171.64.65.64).
[14:32:41] + News From Folding@Home: Welcome to Folding@Home
[14:32:41] Loaded queue successfully.
[14:32:48] + Closed connections
[14:32:53]
[14:32:53] + Processing work unit
[14:32:53] Core required: FahCore_a1.exe
[14:32:53] Core found.
[14:32:53] Working on Unit 09 [July 20 14:32:53]
[14:32:53] + Working ...
[14:32:53]
[14:32:53] *------------------------------*
[14:32:53] Folding@Home Gromacs SMP Core
[14:32:53] Version 1.74 (March 10, 2007)
[14:32:53]
[14:32:53] Preparing to commence simulation
[14:32:53] - Ensuring status. Please wait.
[14:32:55] - Starting from initial work packet
[14:32:55]
[14:32:55] Project: 2653 (Run 23, Clone 10, Gen 79)
[14:32:55]
[14:32:55] Assembly optimizations on if available.
[14:32:55] Entering M.D.
[14:33:13] al work pa- Starting from initial work packet
[14:33:13]
[14:33:13] Project: 2653 (Run 23, Clone 10, Gen 79)
[14:33:13]
[14:33:14] Entering M.D.
[14:33:20] Rejecting checkpoint
[14:33:21] Protein: Protein in POPC
[14:33:21] Writing local files
[14:33:22] Extra SSE boost OK.
[14:33:22] Writing local files
[14:33:22] Completed 0 out of 500000 steps  (0 percent)
[14:42:24] Writing local files
[14:42:24] Completed 5000 out of 500000 steps  (1 percent)
[14:51:25] Writing local files
[14:51:25] Completed 10000 out of 500000 steps  (2 percent)
[15:00:27] Writing local files
[15:00:27] Completed 15000 out of 500000 steps  (3 percent)
[15:09:28] Writing local files
[15:09:28] Completed 20000 out of 500000 steps  (4 percent)
[15:18:26] Writing local files
[15:18:26] Completed 25000 out of 500000 steps  (5 percent)
[15:27:28] Writing local files
[15:27:28] Completed 30000 out of 500000 steps  (6 percent)
[15:36:30] Writing local files
[15:36:30] Completed 35000 out of 500000 steps  (7 percent)
[15:45:31] Writing local files
[15:45:31] Completed 40000 out of 500000 steps  (8 percent)
[15:54:34] Writing local files
[15:54:34] Completed 45000 out of 500000 steps  (9 percent)
[16:03:36] Writing local files
[16:03:37] Completed 50000 out of 500000 steps  (10 percent)
[16:12:39] Writing local files
[16:12:39] Completed 55000 out of 500000 steps  (11 percent)
[16:21:42] Writing local files
[16:21:42] Completed 60000 out of 500000 steps  (12 percent)
[16:30:44] Writing local files
[16:30:44] Completed 65000 out of 500000 steps  (13 percent)
[16:39:47] Writing local files
[16:39:47] Completed 70000 out of 500000 steps  (14 percent)
[16:48:50] Writing local files
[16:48:50] Completed 75000 out of 500000 steps  (15 percent)
[16:57:52] Writing local files
[16:57:52] Completed 80000 out of 500000 steps  (16 percent)
[17:06:55] Writing local files
[17:06:55] Completed 85000 out of 500000 steps  (17 percent)
[17:15:57] Writing local files
[17:15:57] Completed 90000 out of 500000 steps  (18 percent)
[17:24:59] Writing local files
[17:24:59] Completed 95000 out of 500000 steps  (19 percent)
[17:34:02] Writing local files
[17:34:02] Completed 100000 out of 500000 steps  (20 percent)
[17:43:03] Writing local files
[17:43:03] Completed 105000 out of 500000 steps  (21 percent)
[17:52:06] Writing local files
[17:52:06] Completed 110000 out of 500000 steps  (22 percent)
[18:01:03] Writing local files
[18:01:04] Completed 115000 out of 500000 steps  (23 percent)
[18:10:06] Writing local files
[18:10:06] Completed 120000 out of 500000 steps  (24 percent)
[18:19:09] Writing local files
[18:19:09] Completed 125000 out of 500000 steps  (25 percent)
[18:28:12] Writing local files
[18:28:12] Completed 130000 out of 500000 steps  (26 percent)
[18:37:15] Writing local files
[18:37:15] Completed 135000 out of 500000 steps  (27 percent)
[18:46:18] Writing local files
[18:46:18] Completed 140000 out of 500000 steps  (28 percent)
[18:55:22] Writing local files
[18:55:22] Completed 145000 out of 500000 steps  (29 percent)
[19:04:26] Writing local files
[19:04:27] Completed 150000 out of 500000 steps  (30 percent)
[19:13:30] Writing local files
[19:13:30] Completed 155000 out of 500000 steps  (31 percent)
[19:22:33] Writing local files
[19:22:33] Completed 160000 out of 500000 steps  (32 percent)
[19:31:35] Writing local files
[19:31:36] Completed 165000 out of 500000 steps  (33 percent)
[19:40:39] Writing local files
[19:40:39] Completed 170000 out of 500000 steps  (34 percent)
[19:49:42] Writing local files
[19:49:42] Completed 175000 out of 500000 steps  (35 percent)
[19:58:46] Writing local files
[19:58:46] Completed 180000 out of 500000 steps  (36 percent)
[20:07:50] Writing local files
[20:07:50] Completed 185000 out of 500000 steps  (37 percent)
[20:16:54] Writing local files
[20:16:54] Completed 190000 out of 500000 steps  (38 percent)
[20:25:57] Writing local files
[20:25:57] Completed 195000 out of 500000 steps  (39 percent)
[20:35:01] Writing local files
[20:35:01] Completed 200000 out of 500000 steps  (40 percent)
[20:44:00] Writing local files
[20:44:00] Completed 205000 out of 500000 steps  (41 percent)
[20:53:02] Writing local files
[20:53:02] Completed 210000 out of 500000 steps  (42 percent)
[21:02:05] Writing local files
[21:02:05] Completed 215000 out of 500000 steps  (43 percent)
[21:11:07] Writing local files
[21:11:07] Completed 220000 out of 500000 steps  (44 percent)
[21:20:11] Writing local files
[21:20:11] Completed 225000 out of 500000 steps  (45 percent)
[21:29:13] Writing local files
[21:29:13] Completed 230000 out of 500000 steps  (46 percent)
[21:38:16] Writing local files
[21:38:16] Completed 235000 out of 500000 steps  (47 percent)
[21:47:18] Writing local files
[21:47:19] Completed 240000 out of 500000 steps  (48 percent)
[21:56:22] Writing local files
[21:56:22] Completed 245000 out of 500000 steps  (49 percent)
[22:05:25] Writing local files
[22:05:25] Completed 250000 out of 500000 steps  (50 percent)
[22:14:28] Writing local files
[22:14:29] Completed 255000 out of 500000 steps  (51 percent)
[22:23:32] Writing local files
[22:23:32] Completed 260000 out of 500000 steps  (52 percent)
[22:32:35] Writing local files
[22:32:35] Completed 265000 out of 500000 steps  (53 percent)
[22:41:38] Writing local files
[22:41:38] Completed 270000 out of 500000 steps  (54 percent)
[22:50:42] Writing local files
[22:50:42] Completed 275000 out of 500000 steps  (55 percent)
[22:59:46] Writing local files
[22:59:46] Completed 280000 out of 500000 steps  (56 percent)
[23:08:50] Writing local files
[23:08:50] Completed 285000 out of 500000 steps  (57 percent)
[23:17:53] Writing local files
[23:17:53] Completed 290000 out of 500000 steps  (58 percent)
[23:26:52] Writing local files
[23:26:52] Completed 295000 out of 500000 steps  (59 percent)
[23:35:56] Writing local files
[23:35:56] Completed 300000 out of 500000 steps  (60 percent)
[23:45:00] Writing local files
[23:45:00] Completed 305000 out of 500000 steps  (61 percent)
[23:54:03] Writing local files
[23:54:04] Completed 310000 out of 500000 steps  (62 percent)
[00:03:07] Writing local files
[00:03:07] Completed 315000 out of 500000 steps  (63 percent)
[00:12:10] Writing local files
[00:12:10] Completed 320000 out of 500000 steps  (64 percent)
[00:21:13] Writing local files
[00:21:13] Completed 325000 out of 500000 steps  (65 percent)
[00:30:16] Writing local files
[00:30:17] Completed 330000 out of 500000 steps  (66 percent)
[00:39:20] Writing local files
[00:39:20] Completed 335000 out of 500000 steps  (67 percent)
[00:48:24] Writing local files
[00:48:24] Completed 340000 out of 500000 steps  (68 percent)
[00:57:27] Writing local files
[00:57:27] Completed 345000 out of 500000 steps  (69 percent)
[01:06:29] Writing local files
[01:06:29] Completed 350000 out of 500000 steps  (70 percent)
[01:15:32] Writing local files
[01:15:32] Completed 355000 out of 500000 steps  (71 percent)
[01:24:35] Writing local files
[01:24:35] Completed 360000 out of 500000 steps  (72 percent)
[01:33:39] Writing local files
[01:33:39] Completed 365000 out of 500000 steps  (73 percent)
[01:42:42] Writing local files
[01:42:43] Completed 370000 out of 500000 steps  (74 percent)
[01:51:45] Writing local files
[01:51:45] Completed 375000 out of 500000 steps  (75 percent)
[02:00:49] Writing local files
[02:00:49] Completed 380000 out of 500000 steps  (76 percent)
[02:09:50] Writing local files
[02:09:50] Completed 385000 out of 500000 steps  (77 percent)
[02:18:53] Writing local files
[02:18:54] Completed 390000 out of 500000 steps  (78 percent)
[02:27:57] Writing local files
[02:27:57] Completed 395000 out of 500000 steps  (79 percent)
[02:37:01] Writing local files
[02:37:01] Completed 400000 out of 500000 steps  (80 percent)
[02:46:04] Writing local files
[02:46:04] Completed 405000 out of 500000 steps  (81 percent)
[02:55:08] Writing local files
[02:55:08] Completed 410000 out of 500000 steps  (82 percent)
[03:04:12] Writing local files
[03:04:13] Completed 415000 out of 500000 steps  (83 percent)
[03:13:16] Writing local files
[03:13:16] Completed 420000 out of 500000 steps  (84 percent)
[03:22:19] Writing local files
[03:22:19] Completed 425000 out of 500000 steps  (85 percent)
[03:31:23] Writing local files
[03:31:23] Completed 430000 out of 500000 steps  (86 percent)
[03:40:27] Writing local files
[03:40:27] Completed 435000 out of 500000 steps  (87 percent)
[03:49:31] Writing local files
[03:49:31] Completed 440000 out of 500000 steps  (88 percent)
[03:58:35] Writing local files
[03:58:35] Completed 445000 out of 500000 steps  (89 percent)
[04:07:38] Writing local files
[04:07:38] Completed 450000 out of 500000 steps  (90 percent)
[04:16:42] Writing local files
[04:16:42] Completed 455000 out of 500000 steps  (91 percent)
[04:25:46] Writing local files
[04:25:46] Completed 460000 out of 500000 steps  (92 percent)
[04:34:51] Writing local files
[04:34:51] Completed 465000 out of 500000 steps  (93 percent)
[04:43:55] Writing local files
[04:43:55] Completed 470000 out of 500000 steps  (94 percent)
[04:52:55] Writing local files
[04:52:56] Completed 475000 out of 500000 steps  (95 percent)
[05:01:59] Writing local files
[05:01:59] Completed 480000 out of 500000 steps  (96 percent)
[05:11:02] Writing local files
[05:11:02] Completed 485000 out of 500000 steps  (97 percent)
[05:20:06] Writing local files
[05:20:06] Completed 490000 out of 500000 steps  (98 percent)
[05:29:09] Writing local files
[05:29:09] Completed 495000 out of 500000 steps  (99 percent)
[05:38:13] Writing local files
[05:38:13] Completed 500000 out of 500000 steps  (100 percent)
[05:38:13] Writing final coordinates.
[05:38:13] Past main M.D. loop
[05:38:13] Will end MPI now
[05:39:13]
[05:39:13] Finished Work Unit:
[05:39:13] - Reading up to 3722928 from "work/wudata_09.arc": Read 3722928
[05:39:13] - Reading up to 1775984 from "work/wudata_09.xtc": Read 1775984
[05:39:13] goefile size: 0
[05:39:13] logfile size: 17311
[05:39:13] Leaving Run
[05:39:17] - Writing 5520623 bytes of core data to disk...
[05:39:17]   ... Done.
[05:39:17] - Failed to delete work/wudata_09.sas
[05:39:17] - Failed to delete work/wudata_09.goe
[05:39:17] Warning:  check for stray files
[05:39:17] - Shutting down core
[05:41:17]
[05:41:17] Folding@home Core Shutdown: FINISHED_UNIT
[05:41:17]
[05:41:21] CoreStatus = 64 (100)
[05:41:21] Sending work to server
[05:41:21] + Attempting to send results
[05:42:31] + Results successfully sent
[05:42:31] Thank you for your contribution to Folding@Home.
[05:42:31] + Number of Units Completed: 86
[05:44:35] - Preparing to get new work unit...
[05:44:35] + Attempting to get work packet
[05:44:35] - Connecting to assignment server
[05:44:38] - Successful: assigned to (171.64.65.64).
[05:44:38] + News From Folding@Home: Welcome to Folding@Home
[05:44:38] Loaded queue successfully.
[05:45:03] + Closed connections
[05:45:03]
[05:45:03] + Processing work unit
[05:45:03] Core required: FahCore_a1.exe
[05:45:03] Core found.
[05:45:03] Working on Unit 00 [July 21 05:45:03]
[05:45:03] + Working ...
[05:45:03]
[05:45:03] *------------------------------*
[05:45:03] Folding@Home Gromacs SMP Core
[05:45:03] Version 1.74 (March 10, 2007)
[05:45:03]
[05:45:03] Preparing to commence simulation
[05:45:03] - Ensuring status. Please wait.
[05:45:07] - Starting from initial work packet
[05:45:07]
[05:45:07] Project: 2665 (Run 3, Clone 19, Gen 27)
[05:45:07]
[05:45:08] Assembly optimizations on if available.
[05:45:08] Entering M.D.
[05:45:31] ial work packet
[05:45:31]
[05:45:31] Project: 2665 (Run 3, Clone 19, Gen 27)
[05:45:31]
[05:45:31] 665 (Run 3, Clone 19, Gen 27)
[05:45:31]
[05:45:32] Entering M.D.
[05:45:38] Rejecting checkpoint
[05:45:40] Protein: HGG in water
[05:45:40] Writing local files
[05:45:48] Extra SSE boost OK.
[05:45:48] Writing local files
[05:45:48] Completed 0 out of 250000 steps  (0 percent)
[05:59:42] Writing local files
[05:59:42] Completed 2500 out of 250000 steps  (1 percent)
[06:13:36] Writing local files
[06:13:36] Completed 5000 out of 250000 steps  (2 percent)
[06:27:29] Writing local files
[06:27:29] Completed 7500 out of 250000 steps  (3 percent)
[06:41:23] Writing local files
[06:41:24] Completed 10000 out of 250000 steps  (4 percent)
[06:55:17] Writing local files
[06:55:18] Completed 12500 out of 250000 steps  (5 percent)
[07:09:12] Writing local files
[07:09:13] Completed 15000 out of 250000 steps  (6 percent)
[07:23:07] Writing local files
[07:23:07] Completed 17500 out of 250000 steps  (7 percent)
[07:36:56] Writing local files
[07:36:57] Completed 20000 out of 250000 steps  (8 percent)
[07:50:51] Writing local files
[07:50:51] Completed 22500 out of 250000 steps  (9 percent)
[08:04:46] Writing local files
[08:04:46] Completed 25000 out of 250000 steps  (10 percent)
[08:18:41] Writing local files
[08:18:41] Completed 27500 out of 250000 steps  (11 percent)
[08:32:34] Writing local files
[08:32:34] Completed 30000 out of 250000 steps  (12 percent)
[08:46:29] Writing local files
[08:46:30] Completed 32500 out of 250000 steps  (13 percent)
[09:00:25] Writing local files
[09:00:25] Completed 35000 out of 250000 steps  (14 percent)
[09:14:21] Writing local files
[09:14:22] Completed 37500 out of 250000 steps  (15 percent)
[09:28:18] Writing local files
[09:28:18] Completed 40000 out of 250000 steps  (16 percent)
[09:42:14] Writing local files
[09:42:14] Completed 42500 out of 250000 steps  (17 percent)
[09:56:10] Writing local files
[09:56:11] Completed 45000 out of 250000 steps  (18 percent)
[10:10:03] Writing local files
[10:10:03] Completed 47500 out of 250000 steps  (19 percent)
[10:24:02] Writing local files
[10:24:02] Completed 50000 out of 250000 steps  (20 percent)
[10:37:58] Writing local files
[10:37:58] Completed 52500 out of 250000 steps  (21 percent)
[10:51:55] Writing local files
[10:51:55] Completed 55000 out of 250000 steps  (22 percent)
[11:05:50] Writing local files
[11:05:51] Completed 57500 out of 250000 steps  (23 percent)
[11:19:46] Writing local files
[11:19:47] Completed 60000 out of 250000 steps  (24 percent)
[11:33:41] Writing local files
[11:33:41] Completed 62500 out of 250000 steps  (25 percent)
[11:47:37] Writing local files
[11:47:37] Completed 65000 out of 250000 steps  (26 percent)
[12:01:33] Writing local files
[12:01:33] Completed 67500 out of 250000 steps  (27 percent)
[12:15:28] Writing local files
[12:15:28] Completed 70000 out of 250000 steps  (28 percent)
[12:29:24] Writing local files
[12:29:24] Completed 72500 out of 250000 steps  (29 percent)
[12:43:16] Writing local files
[12:43:17] Completed 75000 out of 250000 steps  (30 percent)
[12:57:13] Writing local files
[12:57:13] Completed 77500 out of 250000 steps  (31 percent)
[13:11:08] Writing local files
[13:11:08] Completed 80000 out of 250000 steps  (32 percent)
[13:25:03] Writing local files
[13:25:04] Completed 82500 out of 250000 steps  (33 percent)
[13:38:57] Writing local files
[13:38:58] Completed 85000 out of 250000 steps  (34 percent)
[13:52:51] Writing local files
[13:52:51] Completed 87500 out of 250000 steps  (35 percent)
[14:06:44] Writing local files
[14:06:44] Completed 90000 out of 250000 steps  (36 percent)
[14:20:37] Writing local files
[14:20:37] Completed 92500 out of 250000 steps  (37 percent)
[14:34:31] Writing local files
[14:34:31] Completed 95000 out of 250000 steps  (38 percent)
[14:48:24] Writing local files
[14:48:24] Completed 97500 out of 250000 steps  (39 percent)
[15:02:17] Writing local files
[15:02:18] Completed 100000 out of 250000 steps  (40 percent)
[15:16:07] Writing local files
[15:16:07] Completed 102500 out of 250000 steps  (41 percent)
[15:30:01] Writing local files
[15:30:01] Completed 105000 out of 250000 steps  (42 percent)
[15:43:55] Writing local files
[15:43:55] Completed 107500 out of 250000 steps  (43 percent)
[15:57:51] Writing local files
[15:57:51] Completed 110000 out of 250000 steps  (44 percent)
[16:11:46] Writing local files
[16:11:47] Completed 112500 out of 250000 steps  (45 percent)
[16:25:41] Writing local files
[16:25:42] Completed 115000 out of 250000 steps  (46 percent)
[16:39:38] Writing local files
[16:39:38] Completed 117500 out of 250000 steps  (47 percent)
[16:53:34] Writing local files
[16:53:34] Completed 120000 out of 250000 steps  (48 percent)
[17:07:30] Writing local files
[17:07:30] Completed 122500 out of 250000 steps  (49 percent)
[17:21:25] Writing local files
[17:21:25] Completed 125000 out of 250000 steps  (50 percent)
[17:35:19] Writing local files
[17:35:20] Completed 127500 out of 250000 steps  (51 percent)
[17:49:15] Writing local files
[17:49:15] Completed 130000 out of 250000 steps  (52 percent)
[18:03:08] Writing local files
[18:03:08] Completed 132500 out of 250000 steps  (53 percent)
[18:17:04] Writing local files
[18:17:04] Completed 135000 out of 250000 steps  (54 percent)
[18:31:00] Writing local files
[18:31:01] Completed 137500 out of 250000 steps  (55 percent)
[18:44:58] Writing local files
[18:44:58] Completed 140000 out of 250000 steps  (56 percent)
[18:58:54] Writing local files
[18:58:54] Completed 142500 out of 250000 steps  (57 percent)
[19:12:51] Writing local files
[19:12:51] Completed 145000 out of 250000 steps  (58 percent)
[19:26:49] Writing local files
[19:26:49] Completed 147500 out of 250000 steps  (59 percent)
[19:40:48] Writing local files
[19:40:48] Completed 150000 out of 250000 steps  (60 percent)
[19:54:46] Writing local files
[19:54:46] Completed 152500 out of 250000 steps  (61 percent)
[20:08:43] Writing local files
[20:08:43] Completed 155000 out of 250000 steps  (62 percent)
[20:22:41] Writing local files
[20:22:41] Completed 157500 out of 250000 steps  (63 percent)
[20:36:34] Writing local files
[20:36:35] Completed 160000 out of 250000 steps  (64 percent)
[20:50:31] Writing local files
[20:50:31] Completed 162500 out of 250000 steps  (65 percent)
[21:04:30] Writing local files
[21:04:30] Completed 165000 out of 250000 steps  (66 percent)
[21:18:28] Writing local files
[21:18:28] Completed 167500 out of 250000 steps  (67 percent)
[21:32:27] Writing local files
[21:32:27] Completed 170000 out of 250000 steps  (68 percent)
[21:46:26] Writing local files
[21:46:26] Completed 172500 out of 250000 steps  (69 percent)
[22:00:24] Writing local files
[22:00:25] Completed 175000 out of 250000 steps  (70 percent)
[22:14:23] Writing local files
[22:14:23] Completed 177500 out of 250000 steps  (71 percent)
[22:28:22] Writing local files
[22:28:22] Completed 180000 out of 250000 steps  (72 percent)
[22:42:20] Writing local files
[22:42:20] Completed 182500 out of 250000 steps  (73 percent)
[22:56:19] Writing local files
[22:56:19] Completed 185000 out of 250000 steps  (74 percent)
[23:10:13] Writing local files
[23:10:13] Completed 187500 out of 250000 steps  (75 percent)
[23:24:11] Writing local files
[23:24:11] Completed 190000 out of 250000 steps  (76 percent)
[23:38:08] Writing local files
[23:38:08] Completed 192500 out of 250000 steps  (77 percent)
[23:52:05] Writing local files
[23:52:05] Completed 195000 out of 250000 steps  (78 percent)
[00:06:03] Writing local files
[00:06:03] Completed 197500 out of 250000 steps  (79 percent)
[00:20:01] Writing local files
[00:20:01] Completed 200000 out of 250000 steps  (80 percent)
[00:34:00] Writing local files
[00:34:00] Completed 202500 out of 250000 steps  (81 percent)
[00:47:58] Writing local files
[00:47:58] Completed 205000 out of 250000 steps  (82 percent)
[01:01:55] Writing local files
[01:01:55] Completed 207500 out of 250000 steps  (83 percent)
[01:15:53] Writing local files
[01:15:53] Completed 210000 out of 250000 steps  (84 percent)
[01:29:51] Writing local files
[01:29:51] Completed 212500 out of 250000 steps  (85 percent)
[01:43:44] Writing local files
[01:43:44] Completed 215000 out of 250000 steps  (86 percent)
[01:57:43] Writing local files
[01:57:43] Completed 217500 out of 250000 steps  (87 percent)
[02:11:41] Writing local files
[02:11:41] Completed 220000 out of 250000 steps  (88 percent)
[02:25:38] Writing local files
[02:25:39] Completed 222500 out of 250000 steps  (89 percent)
[02:39:35] Writing local files
[02:39:35] Completed 225000 out of 250000 steps  (90 percent)
[02:53:31] Writing local files
[02:53:31] Completed 227500 out of 250000 steps  (91 percent)
[03:07:28] Writing local files
[03:07:28] Completed 230000 out of 250000 steps  (92 percent)
[03:21:23] Writing local files
[03:21:23] Completed 232500 out of 250000 steps  (93 percent)
[03:35:18] Writing local files
[03:35:18] Completed 235000 out of 250000 steps  (94 percent)
[03:49:12] Writing local files
[03:49:12] Completed 237500 out of 250000 steps  (95 percent)
[04:03:06] Writing local files
[04:03:06] Completed 240000 out of 250000 steps  (96 percent)
[04:16:55] Writing local files
[04:16:55] Completed 242500 out of 250000 steps  (97 percent)
[04:30:50] Writing local files
[04:30:50] Completed 245000 out of 250000 steps  (98 percent)
[04:44:45] Writing local files
[04:44:45] Completed 247500 out of 250000 steps  (99 percent)
[04:58:41] Writing local files
[04:58:41] Completed 250000 out of 250000 steps  (100 percent)
[04:58:41] Writing final coordinates.
[04:58:42] Past main M.D. loop
[04:58:42] Will end MPI now
[04:59:42]
[04:59:42] Finished Work Unit:
[04:59:42] - Reading up to 21310704 from "work/wudata_00.arc": Read 21310704
[04:59:43] - Reading up to 554768 from "work/wudata_00.xtc": Read 554768
[04:59:43] goefile size: 0
[04:59:43] logfile size: 203301
[04:59:43] Leaving Run
[04:59:46] - Writing 22075145 bytes of core data to disk...
[04:59:46]   ... Done.
[04:59:46] - Failed to delete work/wudata_00.sas
[04:59:46] - Failed to delete work/wudata_00.goe
[04:59:46] Warning:  check for stray files
[04:59:46] - Shutting down core
[05:01:46]
[05:01:46] Folding@home Core Shutdown: FINISHED_UNIT
[05:01:46]
[05:01:49] CoreStatus = 64 (100)
[05:01:49] Sending work to server
[05:01:49] + Attempting to send results
[05:06:51] + Results successfully sent
[05:06:51] Thank you for your contribution to Folding@Home.
[05:06:51] + Number of Units Completed: 87
[05:08:55] - Preparing to get new work unit...
[05:08:55] + Attempting to get work packet
[05:08:55] - Connecting to assignment server
[05:08:55] - Successful: assigned to (171.64.65.64).
[05:08:55] + News From Folding@Home: Welcome to Folding@Home
[05:08:55] Loaded queue successfully.
[05:09:08] + Closed connections
[05:09:08]
[05:09:08] + Processing work unit
[05:09:08] Core required: FahCore_a1.exe
[05:09:08] Core found.
[05:09:08] Working on Unit 01 [July 22 05:09:08]
[05:09:08] + Working ...
[05:09:09]
[05:09:09] *------------------------------*
[05:09:09] Folding@Home Gromacs SMP Core
[05:09:09] Version 1.74 (March 10, 2007)
[05:09:09]
[05:09:09] Preparing to commence simulation
[05:09:09] - Ensuring status. Please wait.
[05:09:13] - Starting from initial work packet
[05:09:13]
[05:09:13] Project: 2665 (Run 3, Clone 92, Gen 29)
[05:09:13]
[05:09:14] Assembly optimizations on if available.
[05:09:14] Entering M.D.
[05:09:37] 1 percent)
[05:09:37] - Starting from initial work packet
[05:09:37]
Note the above was the 3 or so WUs before the mess above... showing that the computer is stable...
Try qfix to submit partial results : viewtopic.php?f=8&t=191 ...
No one was able to return this WU :(
Sunin
Post by Sunin »
downloaded will try this shortly after breakfast :)
