I have 7.6.21 loaded on a Fedora 39. Ip address of said machine is 192.168.1.5. I am trying to use web control from another pc on same network and I use http://192.168.1.5:7396 all I get is a blank webpage.
Here is my config.xml file
<config>
<!--Client Control-->
<fold-anon value="false"/>
<!--Folding Slot Configuration-->
<gpu value="false"/>
<!--slot Control-->
<power value="Full"/>
<!-- User Information -->
<user value="********"/>
<team value="**"/>
<passkey value="**********************"/>
<!-- Folding Slots-->
<slot id="0" type="CPU"/>
<!--Remote Web Access-->
<allow v='192.168.0.0/24'/>
<command-allow-no-pass v='192.168.0.0/24'/>
</config>
Not sure if I have the config file set right any help would be appreciated. I do have the port 7396 open on the nix box.
Web Control
bikeaddict
Re: Web Control
FAHControl can be used to control remote clients if port 36330 is opened. Not sure if remote web client works.
Re: Web Control
The v7 Web Control is not set up to work remotely like FAHControl. It can be hacked to work, someone posted on that a few years ago. But I don't recall the details beyond that it could be flaky, and can't currently find those old posts.
The v8.3 client's web based control is designed to be used this way. I haven't set it up myself, but there are others here who have.
Re: Web Control
The preferred and far more capable v7 tool is FAHControl.
But you will need python 2 or the 3rd party fork for python 3.
If you want to use the v7 web control anyway, your config.xml needs
<allow v='127.0.0.1 192.168.0.0/24'/>
<deny v='0.0.0.0/0'/>
<command-allow-no-pass v='127.0.0.1'/>
<web-allow v='127.0.0.1 192.168.0.0/24'/>
Re: Web Control
If you don't include 127.0.0.1, you lock out localhost access.
The command-allow-no-pass line will probably disappear from config.xml when the client re-saves it.
All options equal to their built-in default get removed.
