On the stats page of the web client I suddenly noticed a lower number of 4.548 WUs completed, while I was already over 5000.
When clicking on my name link, the donor stats are correct "I have earned 759.961.044 points by contributing 5.024 work units."
https://stats.foldingathome.org/donor/id/1294477
I just installed the latest fah-client_8.3.18_AMD64.exe .
User stats wrong on webui
Re: User stats wrong on webui
Please check if the stats are correct in the alpha web control:
https://v8-4.foldingathome.org/stats
Edit:
You do not need to be running v8.4 to use its web control.
It's currently backwards compatible.
Edit2:
Web Control 8.4 seems to now show NaN for progress of 8.3 clients and incorrect ETA.
So, not so compatible.
Edit3: Edit2 problem is fixed
Edit:
Edit2:
It's client specific, I do not see it on my other client with version 8.3.17. This links to:
https://beta.foldingathome.org/stats
The alpha web control link you shared also shows the wrong result.
So after upgrading this other client to 8.3.18 it also starts showing wrong results via
https://v8-3.foldingathome.org/stats
When I change this to
It's showing correct again. So in conclusion:
Alpha: bad
Beta: good
Production : bad
Please track all the code changes between these versions, the answer is in the case files.
Alpha: bad
Beta: good
Production : bad
Joseph says web control now only shows WUs completed with the currently set passkey, not all work ever done with your user name.
So, behavior is as intended, confusing though that may be.
Since a few days I have similar problems, all stats are too low
https://folding.extremeoverclocking.com ... &u=1280853
https://photos.app.goo.gl/eW6cCaK9T6riPDeK9
I am using latest versions of the software
- Hardware configuration: 9950x, 9950x3D, 5950x, 5800x3D
7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, Intel B580 - Location: London
Extreme oc stats are not equal to FAH official stats page. They use different methods to output the statisticsAnjo_Zwartkruis wrote: ↑Mon Feb 17, 2025 10:40 am Since a few days I have similar problems, all stats are too low
