Project: 3065 (Run 4, Clone 64, Gen 53)
Datsun 1600
Post by Datsun 1600 »
Don't see the 3000 series very often, but this one went belly up and with 533 completed SMP WUs on this Boxen, stability is not an issue.
Datsun 1600
[21:10:22] Completed 247500 out of 250000 steps  (99 percent)
[21:22:55] Writing local files
[21:22:56] Completed 250000 out of 250000 steps  (100 percent)
[21:22:56] Writing final coordinates.
[21:22:56] Past main M.D. loop
[21:22:57] Will end MPI now
[21:23:57]
[21:23:57] Finished Work Unit:
[21:23:57] - Reading up to 21310704 from "work/wudata_04.arc": Read 21310704
[21:23:57] - Reading up to 553136 from "work/wudata_04.xtc": Read 553136
[21:23:57] goefile size: 0
[21:23:57] logfile size: 203294
[21:23:57] Leaving Run
[21:23:59] - Writing 22073506 bytes of core data to disk...
[21:24:00]   ... Done.
[21:24:00] - Failed to delete work/wudata_04.sas
[21:24:00] - Failed to delete work/wudata_04.goe
[21:24:00] Warning:  check for stray files
[21:24:00] - Shutting down core
[21:26:00]
[21:26:00] Folding@home Core Shutdown: FINISHED_UNIT
[21:26:00]
[21:26:04] CoreStatus = 64 (100)
[21:26:04] Sending work to server
[21:26:04] + Attempting to send results
[21:38:26] + Results successfully sent
[21:38:26] Thank you for your contribution to Folding@Home.
[21:38:26] + Number of Units Completed: 533
[21:40:46] - Preparing to get new work unit...
[21:40:46] + Attempting to get work packet
[21:40:46] - Connecting to assignment server
[21:40:48] - Successful: assigned to (171.64.65.63).
[21:40:48] + News From Folding@Home: Welcome to Folding@Home
[21:40:48] Loaded queue successfully.
[21:41:08] + Closed connections
[21:41:08]
[21:41:08] + Processing work unit
[21:41:08] Core required: FahCore_a1.exe
[21:41:08] Core found.
[21:41:08] Working on Unit 05 [July 24 21:41:08]
[21:41:08] + Working ...
[21:41:08]
[21:41:08] *------------------------------*
[21:41:08] Folding@Home Gromacs SMP Core
[21:41:08] Version 1.74 (March 10, 2007)
[21:41:08]
[21:41:08] Preparing to commence simulation
[21:41:08] - Ensuring status. Please wait.
[21:41:25] - Assembly optimizations manually forced on.
[21:41:25] - Not checking prior termination.
[21:41:27] - Expanded 1656642 -> 9524377 (decompressed 574.9 percent)
[21:41:27] - Starting from initial work packet
[21:41:27]
[21:41:27] Project: 3065 (Run 4, Clone 64, Gen 53)
[21:41:27]
[21:41:30] Assembly optimizations on if available.
[21:41:30] Entering M.D.
[21:41:36] Rejecting checkpoint
[21:41:37] lambda5_99sb_big
[21:41:37] Writing local files
[21:41:37] Extra SSE boost OK.
[21:41:37]
[21:41:37] Completed 0 out of 2500000 steps  (0 percent)
[21:51:28] Writing local files
[21:51:28] Completed 25000 out of 2500000 steps  (1 percent)
[22:01:18] Writing local files
[22:01:18] Completed 50000 out of 2500000 steps  (2 percent)
[22:11:08] Writing local files
[22:11:08] Completed 75000 out of 2500000 steps  (3 percent)
[22:20:58] Writing local files
[22:20:58] Completed 100000 out of 2500000 steps  (4 percent)
[22:30:48] Writing local files
[22:30:48] Completed 125000 out of 2500000 steps  (5 percent)
[22:40:39] Writing local files
[22:40:39] Completed 150000 out of 2500000 steps  (6 percent)
[22:50:28] Writing local files
[22:50:29] Completed 175000 out of 2500000 steps  (7 percent)
[23:00:18] Writing local files
[23:00:18] Completed 200000 out of 2500000 steps  (8 percent)
[23:10:08] Writing local files
[23:10:08] Completed 225000 out of 2500000 steps  (9 percent)
[23:19:57] Writing local files
[23:19:57] Completed 250000 out of 2500000 steps  (10 percent)
[23:29:46] Writing local files
[23:29:46] Completed 275000 out of 2500000 steps  (11 percent)
[23:39:35] Writing local files
[23:39:35] Completed 300000 out of 2500000 steps  (12 percent)
[23:49:25] Writing local files
[23:49:25] Completed 325000 out of 2500000 steps  (13 percent)
[23:59:15] Writing local files
[23:59:15] Completed 350000 out of 2500000 steps  (14 percent)
[00:09:05] Writing local files
[00:09:05] Completed 375000 out of 2500000 steps  (15 percent)
[00:18:55] Writing local files
[00:18:55] Completed 400000 out of 2500000 steps  (16 percent)
[00:28:45] Writing local files
[00:28:45] Completed 425000 out of 2500000 steps  (17 percent)
[00:38:36] Writing local files
[00:38:36] Completed 450000 out of 2500000 steps  (18 percent)
[00:48:27] Writing local files
[00:48:27] Completed 475000 out of 2500000 steps  (19 percent)
[00:58:17] Writing local files
[00:58:17] Completed 500000 out of 2500000 steps  (20 percent)
[01:08:06] Writing local files
[01:08:06] Completed 525000 out of 2500000 steps  (21 percent)
[01:17:56] Writing local files
[01:17:56] Completed 550000 out of 2500000 steps  (22 percent)
[01:27:48] Writing local files
[01:27:48] Completed 575000 out of 2500000 steps  (23 percent)
[01:37:40] Writing local files
[01:37:40] Completed 600000 out of 2500000 steps  (24 percent)
[01:47:32] Writing local files
[01:47:32] Completed 625000 out of 2500000 steps  (25 percent)
[01:57:24] Writing local files
[01:57:24] Completed 650000 out of 2500000 steps  (26 percent)
[02:07:16] Writing local files
[02:07:16] Completed 675000 out of 2500000 steps  (27 percent)
[02:17:07] Writing local files
[02:17:07] Completed 700000 out of 2500000 steps  (28 percent)
[02:26:58] Writing local files
[02:26:58] Completed 725000 out of 2500000 steps  (29 percent)
[02:36:29] Warning:  long 1-4 interactions
[02:36:29] Quit 101 - NaN detected: (ener[20])
[02:36:29]
[02:36:29] Simulation instability has been encountered. The run has entered a
[02:36:29]   state from which no further progress can be made.
[02:36:29] This may be the correct result of the simulation, however if you
[02:36:29]   often see other project units terminating early like this
[02:36:29]   too, you may wish to check the stability of your computer (issues
[02:36:29]   such as high temperature, overclocking, etc.).
[02:36:29] Going to send back what have done.
[02:36:29] logfile size: 26808
[02:36:29] - Writing 27358 bytes of core data to disk...
[02:36:29]   ... Done.
[02:36:29] - Failed to delete work/wudata_05.xtc
[02:36:29] No C.P. to delete.
[02:36:29] Warning:  check for stray files
[02:38:29]
[02:38:29] Folding@home Core Shutdown: EARLY_UNIT_END
[02:38:29]
[02:38:32] CoreStatus = 7B (123)
[02:38:32] Client-core communications error: ERROR 0x7b
[02:38:32] Deleting current work unit & continuing...
[02:40:52] - Preparing to get new work unit...
[02:40:52] + Attempting to get work packet
[02:40:52] - Connecting to assignment server
[02:40:55] - Successful: assigned to (171.64.65.64).
[02:40:55] + News From Folding@Home: Welcome to Folding@Home
[02:40:55] Loaded queue successfully.
[02:41:50] + Closed connections
[02:41:55]
[02:41:55] + Processing work unit
[02:41:55] Core required: FahCore_a1.exe
[02:41:55] Core found.
[02:41:55] Working on Unit 06 [July 25 02:41:55]
[02:41:55] + Working ...
[02:41:55]
[02:41:55] *------------------------------*
[02:41:55] Folding@Home Gromacs SMP Core
[02:41:55] Version 1.74 (March 10, 2007)
[02:41:55]
[02:41:55] Preparing to commence simulation
[02:41:55] - Ensuring status. Please wait.
[02:42:12] - Assembly optimizations manually forced on.
[02:42:12] - Not checking prior termination.
[02:42:26] - Expanded 4843180 -> 24810145 (decompressed 512.2 percent)
[02:42:26] - Starting from initial work packet
[02:42:26]
[02:42:26] Project: 2665 (Run 2, Clone 972, Gen 35)
[02:42:26]
[02:42:28] Assembly optimizations on if available.
[02:42:28] Entering M.D.
[02:42:34] Rejecting checkpoint
[02:42:36] Protein: HGG with glycosylations
[02:42:36] Writing local files
[02:42:44] Extra SSE boost OK.
[02:42:44] Writing local files
[02:42:44] Completed 0 out of 250000 steps  (0 percent)
[02:55:45] Writing local files
[02:55:45] Completed 2500 out of 250000 steps  (1 percent)
[03:08:46] Writing local files
[03:08:46] Completed 5000 out of 250000 steps  (2 percent)
[03:21:46] Writing local files
[03:21:46] Completed 7500 out of 250000 steps  (3 percent)
[03:34:47] Writing local files
[03:34:47] Completed 10000 out of 250000 steps  (4 percent)
[03:47:47] Writing local files
[03:47:48] Completed 12500 out of 250000 steps  (5 percent)
[04:00:48] Writing local files
Re: Project: 3065 (Run 4, Clone 64, Gen 53)
No one was able to complete this WU ...
Maybe you could try qfix to send the partial results : viewtopic.php?f=8&t=191 ?
Datsun 1600
It came back again and gave the same result, when do they pull the duds?
Datsun 1600
[06:05:05] + Processing work unit
[06:05:05] Core required: FahCore_a1.exe
[06:05:05] Core found.
[06:05:05] Working on Unit 02 [July 30 06:05:05]
[06:05:05] + Working ...
[06:05:05]
[06:05:05] *------------------------------*
[06:05:05] Folding@Home Gromacs SMP Core
[06:05:05] Version 1.74 (March 10, 2007)
[06:05:05]
[06:05:05] Preparing to commence simulation
[06:05:05] - Ensuring status. Please wait.
[06:05:22] - Assembly optimizations manually forced on.
[06:05:22] - Not checking prior termination.
[06:05:24] - Expanded 1656642 -> 9524377 (decompressed 574.9 percent)
[06:05:24] - Starting from initial work packet
[06:05:24]
[06:05:24] Project: 3065 (Run 4, Clone 64, Gen 53)
[06:05:24]
[06:05:25] Assembly optimizations on if available.
[06:05:25] Entering M.D.
[06:05:31] Rejecting checkpoint
[06:05:31] Protein: 66728 p3065_lambda5_99sb_bigExtra SSE boost OK.
[06:05:31]
[06:05:31] Extra SSE boost OK.
[06:05:31] Writing local files
[06:05:32] Completed 0 out of 2500000 steps  (0 percent)
[06:15:22] Writing local files
[06:15:22] Completed 25000 out of 2500000 steps  (1 percent)
[06:25:12] Writing local files
[06:25:12] Completed 50000 out of 2500000 steps  (2 percent)
[06:35:02] Writing local files
[06:35:02] Completed 75000 out of 2500000 steps  (3 percent)
[06:44:51] Writing local files
[06:44:51] Completed 100000 out of 2500000 steps  (4 percent)
[06:54:40] Writing local files
[06:54:41] Completed 125000 out of 2500000 steps  (5 percent)
[07:04:31] Writing local files
[07:04:31] Completed 150000 out of 2500000 steps  (6 percent)
[07:14:21] Writing local files
[07:14:21] Completed 175000 out of 2500000 steps  (7 percent)
[07:24:10] Writing local files
[07:24:11] Completed 200000 out of 2500000 steps  (8 percent)
[07:34:00] Writing local files
[07:34:00] Completed 225000 out of 2500000 steps  (9 percent)
[07:43:49] Writing local files
[07:43:49] Completed 250000 out of 2500000 steps  (10 percent)
[07:53:38] Writing local files
[07:53:38] Completed 275000 out of 2500000 steps  (11 percent)
[08:03:27] Writing local files
[08:03:27] Completed 300000 out of 2500000 steps  (12 percent)
[08:13:17] Writing local files
[08:13:17] Completed 325000 out of 2500000 steps  (13 percent)
[08:23:07] Writing local files
[08:23:07] Completed 350000 out of 2500000 steps  (14 percent)
[08:32:57] Writing local files
[08:32:57] Completed 375000 out of 2500000 steps  (15 percent)
[08:42:46] Writing local files
[08:42:46] Completed 400000 out of 2500000 steps  (16 percent)
[08:52:36] Writing local files
[08:52:36] Completed 425000 out of 2500000 steps  (17 percent)
[09:02:27] Writing local files
[09:02:27] Completed 450000 out of 2500000 steps  (18 percent)
[09:12:17] Writing local files
[09:12:17] Completed 475000 out of 2500000 steps  (19 percent)
[09:22:07] Writing local files
[09:22:07] Completed 500000 out of 2500000 steps  (20 percent)
[09:31:57] Writing local files
[09:31:57] Completed 525000 out of 2500000 steps  (21 percent)
[09:41:46] Writing local files
[09:41:46] Completed 550000 out of 2500000 steps  (22 percent)
[09:51:38] Writing local files
[09:51:38] Completed 575000 out of 2500000 steps  (23 percent)
[10:01:29] Writing local files
[10:01:29] Completed 600000 out of 2500000 steps  (24 percent)
[10:11:22] Writing local files
[10:11:22] Completed 625000 out of 2500000 steps  (25 percent)
[10:21:14] Writing local files
[10:21:14] Completed 650000 out of 2500000 steps  (26 percent)
[10:31:06] Writing local files
[10:31:06] Completed 675000 out of 2500000 steps  (27 percent)
[10:40:57] Writing local files
[10:40:57] Completed 700000 out of 2500000 steps  (28 percent)
[10:50:48] Writing local files
[10:50:48] Completed 725000 out of 2500000 steps  (29 percent)
[11:00:19] Warning:  long 1-4 interactions
[11:00:19] Quit 101 - NaN detected: (ener[20])
[11:00:19]
[11:00:19] Simulation instability has been encountered. The run has entered a
[11:00:19]   state from which no further progress can be made.
[11:00:19] This may be the correct result of the simulation, however if you
[11:00:19]   often see other project units terminating early like this
[11:00:19]   too, you may wish to check the stability of your computer (issues
[11:00:19]   such as high temperature, overclocking, etc.).
[11:00:19] Going to send back what have done.
[11:00:19] logfile size: 26808
[11:00:19] - Writing 27358 bytes of core data to disk...
[11:00:19]   ... Done.
[11:00:19] - Failed to delete work/wudata_02.arc
[11:00:19] - Failed to delete work/wudata_02.xtc
[11:00:19] - Failed to delete work/wudata_02.bed
[11:00:19] - Failed to delete work/wudata_02.chk
[11:00:19] - Failed to delete work/wudata_02.sas
[11:00:19] Warning:  check for stray files
[11:00:19]
[11:00:19] Folding@home Core Shutdown: EARLY_UNIT_END
[11:00:19]
[11:00:23] CoreStatus = 7B (123)
[11:00:23] Client-core communications error: ERROR 0x7b
[11:00:23] Deleting current work unit & continuing...
[11:02:43] - Preparing to get new work unit...
[11:02:43] + Attempting to get work packet
[11:02:43] - Connecting to assignment server
[11:02:49] - Successful: assigned to (171.64.65.64).
[11:02:49] + News From Folding@Home: Welcome to Folding@Home
[11:02:49] Loaded queue successfully.
[11:03:44] + Closed connections
[11:03:49]
[11:03:49] + Processing work unit
[11:03:49] Core required: FahCore_a1.exe
[11:03:49] Core found.
[11:03:49] Working on Unit 03 [July 30 11:03:49]
[11:03:49] + Working ...
[11:03:49]
[11:03:49] *------------------------------*
[11:03:49] Folding@Home Gromacs SMP Core
[11:03:49] Version 1.74 (March 10, 2007)
[11:03:49]
[11:03:49] Preparing to commence simulation
[11:03:49] - Ensuring status. Please wait.
[11:04:06] - Assembly optimizations manually forced on.
[11:04:06] - Not checking prior termination.
[11:04:19] - Expanded 4617759 -> 24111057 (decompressed 522.1 percent)
[11:04:19] - Starting from initial work packet
[11:04:19]
[11:04:19] Project: 2665 (Run 1, Clone 480, Gen 36)
Did you use qfix as I suggested in previous post :?:
Datsun 1600
Nope, but I am shutting the SMP Clients down slowly but surely.
It has come back again, same result, belly up.
Not real quick at pulling the duds are they?
Datsun 1600
[01:44:45] + Attempting to send results
[01:57:09] + Results successfully sent
[01:57:09] Thank you for your contribution to Folding@Home.
[01:57:09] + Number of Units Completed: 542
[01:59:29] - Preparing to get new work unit...
[01:59:29] + Attempting to get work packet
[01:59:29] - Connecting to assignment server
[01:59:33] - Successful: assigned to (171.64.65.63).
[01:59:33] + News From Folding@Home: Welcome to Folding@Home
[01:59:33] Loaded queue successfully.
[01:59:56] + Closed connections
[01:59:56]
[01:59:56] + Processing work unit
[01:59:56] Core required: FahCore_a1.exe
[01:59:56] Core found.
[01:59:56] Working on Unit 06 [August 2 01:59:56]
[01:59:56] + Working ...
[01:59:56]
[01:59:56] *------------------------------*
[01:59:56] Folding@Home Gromacs SMP Core
[01:59:56] Version 1.74 (March 10, 2007)
[01:59:56]
[01:59:56] Preparing to commence simulation
[01:59:56] - Ensuring status. Please wait.
[02:00:13] - Assembly optimizations manually forced on.
[02:00:13] - Not checking prior termination.
[02:00:15] - Expanded 1656642 -> 9524377 (decompressed 574.9 percent)
[02:00:15] - Starting from initial work packet
[02:00:15]
[02:00:15] Project: 3065 (Run 4, Clone 64, Gen 53)
[02:00:15]
[02:00:16] Assembly optimizations on if available.
[02:00:16] Entering M.D.
[02:00:22] Rejecting checkpoint
[02:00:23] lambda5_99sb_big
[02:00:23] Writing local files
[02:00:23] Extra SSE boost OK.
[02:00:23]
[02:00:23] Completed 0 out of 2500000 steps  (0 percent)
[02:10:13] Writing local files
[02:10:13] Completed 25000 out of 2500000 steps  (1 percent)
[02:20:03] Writing local files
[02:20:03] Completed 50000 out of 2500000 steps  (2 percent)
[02:29:53] Writing local files
[02:29:53] Completed 75000 out of 2500000 steps  (3 percent)
[02:39:42] Writing local files
[02:39:42] Completed 100000 out of 2500000 steps  (4 percent)
[02:49:32] Writing local files
[02:49:32] Completed 125000 out of 2500000 steps  (5 percent)
[02:59:23] Writing local files
[02:59:23] Completed 150000 out of 2500000 steps  (6 percent)
[03:09:12] Writing local files
[03:09:12] Completed 175000 out of 2500000 steps  (7 percent)
[03:19:01] Writing local files
[03:19:01] Completed 200000 out of 2500000 steps  (8 percent)
[03:28:51] Writing local files
[03:28:51] Completed 225000 out of 2500000 steps  (9 percent)
[03:38:40] Writing local files
[03:38:40] Completed 250000 out of 2500000 steps  (10 percent)
[03:48:29] Writing local files
[03:48:29] Completed 275000 out of 2500000 steps  (11 percent)
[03:58:18] Writing local files
[03:58:18] Completed 300000 out of 2500000 steps  (12 percent)
[04:08:07] Writing local files
[04:08:07] Completed 325000 out of 2500000 steps  (13 percent)
[04:17:57] Writing local files
[04:17:58] Completed 350000 out of 2500000 steps  (14 percent)
[04:27:47] Writing local files
[04:27:47] Completed 375000 out of 2500000 steps  (15 percent)
[04:37:36] Writing local files
[04:37:37] Completed 400000 out of 2500000 steps  (16 percent)
[04:47:27] Writing local files
[04:47:27] Completed 425000 out of 2500000 steps  (17 percent)
[04:57:17] Writing local files
[04:57:17] Completed 450000 out of 2500000 steps  (18 percent)
[05:07:07] Writing local files
[05:07:08] Completed 475000 out of 2500000 steps  (19 percent)
[05:16:58] Writing local files
[05:16:58] Completed 500000 out of 2500000 steps  (20 percent)
[05:26:47] Writing local files
[05:26:47] Completed 525000 out of 2500000 steps  (21 percent)
[05:36:37] Writing local files
[05:36:37] Completed 550000 out of 2500000 steps  (22 percent)
[05:46:28] Writing local files
[05:46:28] Completed 575000 out of 2500000 steps  (23 percent)
[05:56:19] Writing local files
[05:56:19] Completed 600000 out of 2500000 steps  (24 percent)
[06:06:12] Writing local files
[06:06:12] Completed 625000 out of 2500000 steps  (25 percent)
[06:16:04] Writing local files
[06:16:04] Completed 650000 out of 2500000 steps  (26 percent)
[06:25:55] Writing local files
[06:25:55] Completed 675000 out of 2500000 steps  (27 percent)
[06:35:46] Writing local files
[06:35:47] Completed 700000 out of 2500000 steps  (28 percent)
[06:45:37] Writing local files
[06:45:37] Completed 725000 out of 2500000 steps  (29 percent)
[06:55:08] Warning:  long 1-4 interactions
[06:55:08] Quit 101 - NaN detected: (ener[20])
[06:55:08]
[06:55:08] Simulation instability has been encountered. The run has entered a
[06:55:08]   state from which no further progress can be made.
[06:55:08] This may be the correct result of the simulation, however if you
[06:55:08]   often see other project units terminating early like this
[06:55:08]   too, you may wish to check the stability of your computer (issues
[06:55:08]   such as high temperature, overclocking, etc.).
[06:55:08] Going to send back what have done.
[06:55:08] logfile size: 26808
[06:55:08] - Writing 27358 bytes of core data to disk...
[06:55:08]   ... Done.
[06:55:08] - Failed to delete work/wudata_06.goe
[06:55:08] Warning:  check for stray files
[06:57:08]
[06:57:08] Folding@home Core Shutdown: EARLY_UNIT_END
[06:57:08]
[06:57:10] CoreStatus = 7B (123)
[06:57:10] Client-core communications error: ERROR 0x7b
[06:57:10] Deleting current work unit & continuing...
[06:59:30] - Preparing to get new work unit...
[06:59:30] + Attempting to get work packet
[06:59:30] - Connecting to assignment server
[06:59:34] - Successful: assigned to (171.64.65.64).
[06:59:34] + News From Folding@Home: Welcome to Folding@Home
[06:59:35] Loaded queue successfully.
[07:00:34] + Closed connections
[07:00:39]
[07:00:39] + Processing work unit
[07:00:39] Core required: FahCore_a1.exe
[07:00:39] Core found.
[07:00:39] Working on Unit 07 [August 2 07:00:39]
[07:00:39] + Working ...
[07:00:39]
[07:00:39] *------------------------------*
[07:00:39] Folding@Home Gromacs SMP Core
[07:00:39] Version 1.74 (March 10, 2007)
[07:00:39]
[07:00:39] Preparing to commence simulation
[07:00:39] - Ensuring status. Please wait.
[07:00:56] - Assembly optimizations manually forced on.
[07:00:56] - Not checking prior termination.
[07:01:10] - Expanded 4815243 -> 24810145 (decompressed 515.2 percent)
[07:01:10] - Starting from initial work packet
[07:01:10]
[07:01:10] Project: 2665 (Run 2, Clone 943, Gen 35)
[07:01:10]
[07:01:12] Assembly optimizations on if available.
[07:01:12] Entering M.D.
[07:01:18] Rejecting checkpoint
[07:01:19] Protein: HGG with glycosylations
[07:01:19] Writing local files
[07:01:27] Extra SSE boost OK.
[07:01:28] Writing local files
[07:01:28] Completed 0 out of 250000 steps  (0 percent)
[07:14:32] Writing local files
[07:14:32] Completed 2500 out of 250000 steps  (1 percent)
If you don't do what we suggest ... there's nothing we can do to help you :(
Datsun 1600
I am only reporting the dud WUs. I am helping myself by shutting down the SMP Boxen and saving electricity by going with a few of the GPU Clients.
Datsun 1600
