Another 18800 WU causing continual rebooting
Schrödinger's cat
Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM
Post by Schrödinger's cat »
Project: 18800 (Run 0, Clone 137, Gen 560) caused my RPi4B to reboot continually. An obvious indicator of these problem WUs is a credit of just 1000.
Project: 18800 (Run 0, Clone 161, Gen 545) and Project: 18457 (Run 0, Clone 94, Gen 25) are the previous WU's with this specific problem.
Last edited by Schrödinger's cat on Thu Aug 22, 2024 3:36 pm, edited 1 time in total.
Schrödinger's cat
Re: Another 18800 WU causing continual rebooting
After dumping Project: 18800 (Run 0, Clone 137, Gen 560), I received Project: 18800 (Run 0, Clone 91, Gen 706), then Project: 18800 (Run 0, Clone 135, Gen 606). All caused continuous rebooting. 1,000 points for 2 days of processing is the indicator of these problem WUs.
Schrödinger's cat
Project: 18800 (Run 0, Clone 205, Gen 654) also causing rebooting. After dumping that WU I received Project: 18800 (Run 0, Clone 24, Gen 718).
There's clearly a problem with these WU's being assigned to RPi4B's.
Last edited by Schrödinger's cat on Thu Aug 22, 2024 3:35 pm, edited 1 time in total.
Schrödinger's cat
Interestingly, one of my RPI4B's is processing Project: 18800 (Run 0, Clone 131, Gen 549), which will take just over 13.5 hours for 1668 points. I've no idea why this WU has a different result.
Project: 18457 (Run 0, Clone 94, Gen 25) has been completed by someone else.
Project: 18800 (Run 0, Clone 161, Gen 545) has been completed by you on another system.
Project: 18800 (Run 0, Clone 137, Gen 560) has failed 3 times by has finally been completed ...
Schrödinger's cat
toTOW wrote: Sun Aug 25, 2024 5:04 pm Project: 18800 (Run 0, Clone 161, Gen 545) has been completed by you on another system.
Yes, on a different RPI4B. Has a constraint been added to the 18800 WU's. as I haven't had any RPI4B's rebooting continually recently?
I guess the constraints that should have been always set are finally staying in place ...
Schrödinger's cat
toTOW wrote: Mon Sep 02, 2024 9:22 pm I guess the constraints that should have been always set are finally staying in place ...
Actually, I just had to dump Project: 18800 (Run 0, Clone 37, Gen 676) for one of my RPI4B's.
