No GPU work for all 3 GPUs
Sandman192
Post by Sandman192 »
Just got the new version of F@H 8.3.18 and tries to download GPU and fails on all GPU work. 980, 1080, and AMD internal GPU. No work.
18:46:37:I1:OUT10:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
18:46:38:I1:OUT10:< HTTP/1.1 200 HTTP_OK
18:46:38:I1:WU2:Received WU assignment WPWLcmQ_ihx2g4tafK6hBweYSfzUZvCYwApWWMPg9Jc
18:46:38:I1:WU2:Downloading WU
18:46:38:I1:OUT11:> POST https://huangfolding1.chem.wisc.edu/api/assign HTTP/1.1
18:46:38:I1:WU1:WARNING:Console control signal 1 on PID 81712
18:46:38:I1:WU1:Exiting, please wait. . .
18:46:40:I1:WU1:Folding@home Core Shutdown: INTERRUPTED
18:46:41:I1:WU1:Core returned INTERRUPTED (102)
18:46:41:I3:WU1:Running FahCore: D:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir H4HiF-wAtmRawm1Ku-9Vd_Bf5bxbtIjYXAWkNSsEFmw -suffix 01 -version 8.3.18 -lifeline 79988 -np 4
18:47:09:I1:WU2:Received WU P16722 R329 C3 G153
18:47:09:I1:Downloading https://cores2.foldingathome.org/openmm ... ar.bz2.crt
18:47:24:W :CON12:DNS lookup failed for cores2.foldingathome.org
18:47:24:E :Exception: No response
Win 11, F@H v8.3.18
Sandman192
Re: No GPU work for all 3 GPUs
More issues. I closed F@H and reopen it and it just dumped my CPU work and not getting anymore CPU work.
Plus, if you open another F@H while there's one already open you get 2 F@H in the System tray.
Sandman192
Now I'm getting 2 GPUs working and no CPU work?
02:15:19:I1:Loaded cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe
02:15:19:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.crt
02:15:19:I3:WU1:Running FahCore: D:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir H4HiF-wAtmRawm1Ku-9Vd_Bf5bxbtIjYXAWkNSsEFmw -suffix 01 -version 8.3.18 -lifeline 87840 -np 4
02:15:19:I3:WU1:Started FahCore on PID 87528
02:15:19:I1:OUT2:> GET https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.crt HTTP/1.1
02:15:19:I1:OUT1:> GET https://api.foldingathome.org/machine/Jz516bY3oib4liXI8MdzhOW5Uzli1tJzJoTL_PVkwRA HTTP/1.1
02:15:19:I1:WU1:*********************** Log Started 2024-08-16T02:15:19Z ***********************
02:15:19:I1:WU1:************************** Gromacs Folding@home Core ***************************
02:15:19:I1:WU1: Core: Gromacs
02:15:19:I1:WU1: Type: 0xa8
02:15:19:I1:WU1: Version: 0.0.12
02:15:19:I1:WU1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:15:19:I1:WU1: Copyright: 2020 foldingathome.org
02:15:19:I1:WU1: Homepage: https://foldingathome.org/
02:15:19:I1:WU1: Date: Jan 16 2021
02:15:19:I1:WU1: Time: 12:29:40
02:15:19:I1:WU1: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
02:15:19:I1:WU1: Branch: master
02:15:19:I1:WU1: Compiler: Visual C++ 2019 16.7
02:15:19:I1:WU1: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
02:15:19:I1:WU1: Platform: win32 10
02:15:19:I1:WU1: Bits: 64
02:15:19:I1:WU1: Mode: Release
02:15:19:I1:WU1: SIMD: avx2_256
02:15:19:I1:WU1: OpenMP: ON
02:15:19:I1:WU1: CUDA: OFF
02:15:19:I1:WU1: Args: -dir H4HiF-wAtmRawm1Ku-9Vd_Bf5bxbtIjYXAWkNSsEFmw -suffix 01
02:15:19:I1:WU1: -version 8.3.18 -lifeline 87840 -np 4
02:15:19:I1:WU1:************************************ libFAH ************************************
02:15:19:I1:WU1: Time: 11:24:13
02:15:19:I1:WU1:************************************ CBang *************************************
02:15:19:I1:WU1: Time: 11:23:53
02:15:19:I1:WU1:************************************ System ************************************
02:15:19:I1:WU1: CPU: AMD Ryzen 7 7700X 8-Core Processor
02:15:19:I1:WU1: CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
02:15:19:I1:WU1: CPUs: 16
02:15:19:I1:WU1: Memory: 31.12GiB
02:15:19:I1:WU1:Free Memory: 14.35GiB
02:15:19:I1:WU1: Threads: WINDOWS_THREADS
02:15:19:I1:WU1: OS Version: 6.2
02:15:19:I1:WU1:Has Battery: false
02:15:19:I1:WU1: On Battery: false
02:15:19:I1:WU1: UTC Offset: -5
02:15:19:I1:WU1: PID: 87528
02:15:19:I1:WU1: CWD: D:\ProgramData\FAHClient\work
02:15:19:I1:WU1:********************************************************************************
02:15:19:I1:WU1:Project: 19228 (Run 2317, Clone 3, Gen 2)
02:15:19:I1:WU1:Unit: 0x00000000000000000000000000000000
02:15:19:I1:WU1:Digital signatures verified
02:15:19:I1:WU1:Calling: mdrun -cpi state.cpt -cpt 5 -nt 4 -ntmpi 1
02:15:19:I1:WU1:Caught signal SIGABRT(22) on PID 87528
02:15:19:I1:WU1:WARNING:Unexpected exit
02:15:19:I1:OUT2:< HTTP/1.1 200 OK
02:15:19:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.sig
02:15:19:I1:OUT3:> GET https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2.sig HTTP/1.1
02:15:19:I1:OUT1:< HTTP/1.1 200 HTTP_OK
02:15:20:I1:OUT3:< HTTP/1.1 200 OK
02:15:20:I1:Downloading https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2
02:15:20:I1:OUT5:> GET https://cores2.foldingathome.org/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3.tar.bz2 HTTP/1.1
02:15:20:W :WU1:Core returned EARLY_UNIT_END (123)
02:15:20:I1:WU1:Sending dump report
02:15:25:I1:OUT6:> POST https://ds01.scs.illinois.edu/api/results HTTP/1.1
02:15:25:I1:OUT6:< HTTP/1.1 200 HTTP_OK
02:15:25:I1:WU1:Dumped
02:15:30:I1:OUT4:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
02:15:30:I1:OUT4:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
02:15:30:I1:Logging into node account
02:18:29:I1:OUT5:< HTTP/1.1 200 OK
02:18:29:I1:Core signature valid
02:19:10:I1:Default:Added new work unit: cpus:4 gpus:gpu:79:00:00,gpu:83:00:00
02:19:10:I3:WU2:Running FahCore: D:\ProgramData\FAHClient\cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/FahCore_23.exe -dir WPWLcmQ_ihx2g4tafK6hBweYSfzUZvCYwApWWMPg9Jc -suffix 01 -version 8.3.18 -lifeline 87840 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
02:19:10:I3:WU2:Started FahCore on PID 83704
02:19:10:I1:WU3:Requesting WU assignment for user Sandman192_GRC_5ccbedab767407e16f4b9caf8730a574 team 57391
02:19:10:I1:WU2:*********************** Log Started 2024-08-16T02:19:10Z ***********************
02:19:10:I1:WU2:*************************** Core23 Folding@home Core ***************************
02:19:10:I1:WU2: Core: Core23
02:19:10:I1:WU2: Type: 0x23
02:19:11:I1:WU2: Version: 8.0.3
02:19:11:I1:WU2: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:19:11:I1:WU2: Copyright: 2022 foldingathome.org
02:19:11:I1:WU2: Homepage: https://foldingathome.org/
02:19:11:I1:WU2: Date: Aug 3 2023
02:19:11:I1:WU2: Time: 08:39:06
02:19:11:I1:WU2: Compiler: Visual C++
02:19:11:I1:WU2: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
02:19:11:I1:WU2: -DOPENMM_VERSION="\"8.0.0\""
02:19:11:I1:WU2: Platform: win32 10
02:19:11:I1:WU2: Bits: 64
02:19:11:I1:WU2: Mode: Release
02:19:11:I1:WU2:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:19:11:I1:WU2: <peastman@stanford.edu>
02:19:11:I1:WU2: Args: -dir WPWLcmQ_ihx2g4tafK6hBweYSfzUZvCYwApWWMPg9Jc -suffix 01
02:19:11:I1:WU2: -version 8.3.18 -lifeline 87840 -gpu-vendor nvidia -opencl-platform
02:19:11:I1:WU2: 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
02:19:11:I1:WU2:************************************ libFAH ************************************
02:19:11:I1:WU2: Time: 08:37:55
02:19:11:I1:WU2:************************************ CBang *************************************
02:19:11:I1:WU2: Version: 1.7.2
02:19:11:I1:WU2: Org: Cauldron Development LLC
02:19:11:I1:WU2: Copyright: Cauldron Development LLC, 2003-2023
02:19:11:I1:WU2: Homepage: https://cauldrondevelopment.com/
02:19:11:I1:WU2: License: GPL 2+
02:19:11:I1:WU2: Time: 08:37:14
02:19:11:I1:WU2:************************************ System ************************************
02:19:11:I1:WU2: CPU: AMD Ryzen 7 7700X 8-Core Processor
02:19:11:I1:WU2: CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
02:19:11:I1:WU2: CPUs: 16
02:19:11:I1:WU2: Memory: 31.12GiB
02:19:11:I1:WU2:Free Memory: 14.23GiB
02:19:11:I1:WU2: Threads: WINDOWS_THREADS
02:19:11:I1:WU2: OS Version: 6.2
02:19:11:I1:WU2:Has Battery: false
02:19:11:I1:WU2: On Battery: false
02:19:11:I1:WU2: UTC Offset: -5
02:19:11:I1:WU2: PID: 83704
02:19:11:I1:WU2: CWD: D:\ProgramData\FAHClient\work
02:19:11:I1:WU2: Exec: D:\ProgramData\FAHClient\cores\openmm-core-23\windows-10-64bit\release\fahcore-23-windows-10-64bit-release-8.0.3\FahCore_23.exe
02:19:11:I1:WU2:************************************ OpenMM ************************************
02:19:11:I1:WU2: Version: 8.0.0
02:19:11:I1:WU2:********************************************************************************
02:19:11:I1:WU2:Project: 16722 (Run 329, Clone 3, Gen 153)
02:19:11:I1:WU2:Reading tar file core.xml
02:19:11:I1:WU2:Reading tar file integrator.xml
02:19:11:I1:WU2:Reading tar file state.xml
02:19:11:I1:WU2:Reading tar file system.xml
02:19:11:I1:WU2:Digital signatures verified
02:19:11:I1:WU2:Folding@home GPU Core23 Folding@home Core
02:19:11:I1:WU2:Version 8.0.3
02:19:11:I1:WU2: Checkpoint write interval: 100000 steps (4%) [25 total]
02:19:11:I1:WU2: JSON viewer frame write interval: 25000 steps (1%) [100 total]
02:19:11:I1:WU2: XTC frame write interval: 10000 steps (0.4%) [250 total]
02:19:11:I1:WU2: Global context and integrator variables write interval: disabled
02:19:11:I1:WU2:There are 4 platforms available.
02:19:11:I1:WU2:Platform 0: Reference
02:19:11:I1:WU2:Platform 1: CPU
02:19:11:I1:WU2:Platform 2: OpenCL
02:19:11:I1:WU2: opencl-device 0 specified
02:19:11:I1:WU2:Platform 3: CUDA
02:19:11:I1:WU2: cuda-device 0 specified
02:19:25:W :CON8:DNS lookup failed for assign1.foldingathome.org
02:19:25:E :OUT8:Failed response: CONNECT
02:19:25:I1:WU3:Retry #1 in 2 secs
02:19:27:I1:OUT10:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
02:19:28:I1:OUT10:< HTTP/1.1 200 HTTP_OK
02:19:28:I1:WU3:Received WU assignment KLSZLNrdnSzEIn-3F2ooldKeD5bRz35Z-UFCG7FtL1Y
02:19:28:I1:WU3:Downloading WU
02:19:28:I1:OUT11:> POST https://vav23.fah.temple.edu/api/assign HTTP/1.1
02:19:44:I1:OUT11:< HTTP/1.1 200 HTTP_OK
02:19:44:I1:WU3:Received WU P12459 R8 C1 G644
02:19:44:I1:Default:Added new work unit: cpus:3 gpus:gpu:83:00:00
02:19:44:I3:WU3:Running FahCore: D:\ProgramData\FAHClient\cores/openmm-core-23/windows-10-64bit/release/fahcore-23-windows-10-64bit-release-8.0.3/FahCore_23.exe -dir KLSZLNrdnSzEIn-3F2ooldKeD5bRz35Z-UFCG7FtL1Y -suffix 01 -version 8.3.18 -lifeline 87840 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-platform 0 -cuda-device 1 -gpu 1
02:19:44:I3:WU3:Started FahCore on PID 86884
02:19:45:I1:WU3:*********************** Log Started 2024-08-16T02:19:45Z ***********************
02:19:45:I1:WU3:*************************** Core23 Folding@home Core ***************************
02:19:45:I1:WU3: Core: Core23
02:19:45:I1:WU3: Type: 0x23
02:19:45:I1:WU3: Version: 8.0.3
02:19:45:I1:WU3: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:19:45:I1:WU3: Copyright: 2022 foldingathome.org
02:19:45:I1:WU3: Homepage: https://foldingathome.org/
02:19:45:I1:WU3: Date: Aug 3 2023
02:19:45:I1:WU3: Time: 08:39:06
02:19:45:I1:WU3: Compiler: Visual C++
02:19:45:I1:WU3: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
02:19:45:I1:WU3: -DOPENMM_VERSION="\"8.0.0\""
02:19:45:I1:WU3: Platform: win32 10
02:19:45:I1:WU3: Bits: 64
02:19:45:I1:WU3: Mode: Release
02:19:45:I1:WU3:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:19:45:I1:WU3: <peastman@stanford.edu>
02:19:45:I1:WU3: Args: -dir KLSZLNrdnSzEIn-3F2ooldKeD5bRz35Z-UFCG7FtL1Y -suffix 01
02:19:45:I1:WU3: -version 8.3.18 -lifeline 87840 -gpu-vendor nvidia -opencl-platform
02:19:45:I1:WU3: 0 -opencl-device 1 -cuda-platform 0 -cuda-device 1 -gpu 1
02:19:45:I1:WU3:************************************ libFAH ************************************
02:19:45:I1:WU3: Time: 08:37:55
02:19:45:I1:WU3:************************************ CBang *************************************
02:19:45:I1:WU3: Version: 1.7.2
02:19:45:I1:WU3: Org: Cauldron Development LLC
02:19:45:I1:WU3: Copyright: Cauldron Development LLC, 2003-2023
02:19:45:I1:WU3: Homepage: https://cauldrondevelopment.com/
02:19:45:I1:WU3: License: GPL 2+
02:19:45:I1:WU3: Time: 08:37:14
02:19:45:I1:WU3:************************************ System ************************************
02:19:45:I1:WU3: CPU: AMD Ryzen 7 7700X 8-Core Processor
02:19:45:I1:WU3: CPU ID: AuthenticAMD Family 25 Model 97 Stepping 2
02:19:45:I1:WU3: CPUs: 16
02:19:45:I1:WU3: Memory: 31.12GiB
02:19:45:I1:WU3:Free Memory: 13.83GiB
02:19:45:I1:WU3: Threads: WINDOWS_THREADS
02:19:45:I1:WU3: OS Version: 6.2
02:19:45:I1:WU3:Has Battery: false
02:19:45:I1:WU3: On Battery: false
02:19:45:I1:WU3: UTC Offset: -5
02:19:45:I1:WU3: PID: 86884
02:19:45:I1:WU3: CWD: D:\ProgramData\FAHClient\work
02:19:45:I1:WU3: Exec: D:\ProgramData\FAHClient\cores\openmm-core-23\windows-10-64bit\release\fahcore-23-windows-10-64bit-release-8.0.3\FahCore_23.exe
02:19:45:I1:WU3:************************************ OpenMM ************************************
02:19:45:I1:WU3: Version: 8.0.0
02:19:45:I1:WU3:********************************************************************************
02:19:45:I1:WU3:Project: 12459 (Run 8, Clone 1, Gen 644)
02:19:45:I1:WU3:Reading tar file core.xml
02:19:45:I1:WU3:Reading tar file integrator.xml
02:19:45:I1:WU3:Reading tar file state.xml
02:19:45:I1:WU3:Reading tar file system.xml
02:19:45:I1:WU3:Digital signatures verified
02:19:45:I1:WU3:Folding@home GPU Core23 Folding@home Core
02:19:45:I1:WU3:Version 8.0.3
02:19:45:I1:WU3: Checkpoint write interval: 50000 steps (2%) [50 total]
02:19:45:I1:WU3: JSON viewer frame write interval: 25000 steps (1%) [100 total]
02:19:45:I1:WU3: XTC frame write interval: 2500000 steps (1e+02%) [1 total]
02:19:45:I1:WU3: Global context and integrator variables write interval: disabled
02:19:45:I1:WU3:There are 4 platforms available.
02:19:45:I1:WU3:Platform 0: Reference
02:19:45:I1:WU3:Platform 1: CPU
02:19:45:I1:WU3:Platform 2: OpenCL
02:19:45:I1:WU3: opencl-device 1 specified
02:19:45:I1:WU3:Platform 3: CUDA
02:19:45:I1:WU3: cuda-device 1 specified
02:19:46:I1:WU2:Attempting to create CUDA context:
02:19:46:I1:WU2: Configuring platform CUDA
02:19:55:I1:WU2: Using CUDA on CUDA Platform and gpu 0
02:19:55:I1:WU2: GPU info: Platform: CUDA
02:19:55:I1:WU2: GPU info: PlatformIndex: 0
02:19:55:I1:WU2: GPU info: Device: NVIDIA GeForce GTX 1080 Ti
02:19:55:I1:WU2: GPU info: DeviceIndex: 0
02:19:55:I1:WU2: GPU info: Vendor: 0x10de
02:19:55:I1:WU2: GPU info: PCI: 01:00:00
02:19:55:I1:WU2: GPU info: Compute: 6.1
02:19:55:I1:WU2: GPU info: Driver: 12.5
02:19:55:I1:WU2: GPU info: GPU: true
02:19:55:I1:WU2:Completed 0 out of 2500000 steps (0%)
02:19:56:I1:WU3:Attempting to create CUDA context:
02:19:56:I1:WU3: Configuring platform CUDA
02:19:57:I1:WU2:Checkpoint completed at step 0
02:19:59:W :CON12:DNS lookup failed for assign3.foldingathome.org
02:19:59:E :OUT12:Failed response: CONNECT
02:19:59:I1:WU4:Retry #1 in 2 secs
02:20:01:I1:WU3: Using CUDA on CUDA Platform and gpu 1
02:20:01:I1:WU3: GPU info: Platform: CUDA
02:20:01:I1:WU3: GPU info: PlatformIndex: 0
02:20:01:I1:WU3: GPU info: Device: NVIDIA GeForce GTX 980
02:20:01:I1:WU3: GPU info: DeviceIndex: 1
02:20:01:I1:WU3: GPU info: Vendor: 0x10de
02:20:01:I1:WU3: GPU info: PCI: 79:00:00
02:20:01:I1:WU3: GPU info: Compute: 5.2
02:20:01:I1:WU3: GPU info: Driver: 12.5
02:20:01:I1:WU3: GPU info: GPU: true
02:20:01:I1:WU3:Completed 0 out of 2500000 steps (0%)
02:20:02:I1:OUT13:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
02:20:02:I1:WU3:Checkpoint completed at step 0
02:20:02:I1:OUT13:< HTTP/1.1 200 HTTP_OK
02:20:02:I1:WU4:Received WU assignment 8jjTXABY3Kh7qMsX0NzfOIGW7AsoW0tQjhE48dZ9pK0
02:20:02:I1:WU4:Downloading WU
02:20:02:I1:OUT14:> POST https://vav23.fah.temple.edu/api/assign HTTP/1.1
02:20:33:I1:OUT14:< HTTP/1.1 200 HTTP_OK
02:20:33:I1:WU4:Received WU P12434 R8 C17 G708
02:20:33:I1:Downloading https://cores2.foldingathome.org/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20.tar.bz2.crt
02:20:33:I1:OUT15:> GET https://cores2.foldingathome.org/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20.tar.bz2.crt HTTP/1.1
02:20:34:I1:OUT15:< HTTP/1.1 200 OK
02:20:34:I1:Downloading https://cores2.foldingathome.org/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20.tar.bz2.sig
02:20:34:I1:OUT16:> GET https://cores2.foldingathome.org/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20.tar.bz2.sig HTTP/1.1
02:20:34:I1:OUT16:< HTTP/1.1 200 OK
02:20:34:I1:OUT17:> GET https://cores2.foldingathome.org/openmm-core-22/fahcore-22-windows-64bit-release-0.0.20.tar.bz2 HTTP/1.1
02:22:10:I1:WU3:Completed 25000 out of 2500000 steps (1%)
02:22:44:I1:WU2:Completed 25000 out of 2500000 steps (1%)
02:24:22:I1:WU3:Completed 50000 out of 2500000 steps (2%)
02:24:22:I1:WU3:Checkpoint completed at step 50000
Reason: change Quote tags to Code
Sandman192
Now it's running all 3 GPUs but only 2 CPUs out of the 5 I want selected.
And I got "!" on the F@H icon in the System tray.
It keeps changing.
Post by muziqaz »
Sandman192 wrote: Thu Aug 15, 2024 7:39 pm <...>
Win 11, F@H v8.3.18
DNS issues are common these days, until developer sorts out server and client issues.
Sandman192 wrote: Fri Aug 16, 2024 2:20 am More issues. I closed F@H and reopen it and it just dumped my CPU work and not getting anymore CPU work.
1st of all don't open another fahclient while one is already running (I know I know, the "bug" report has been reised to not allow 2 instances to be run at the same time).
2nd, if fahclient is dumping your CPU work, you PC is unstable. Besides, it might be dumping because you are runing 2 fahclients at the same time.
Sandman192 wrote: Fri Aug 16, 2024 2:33 am Now I'm getting 2 GPUs working and no CPU work?
You have 2 cores asigned to fold. These days not many projects allow such a low core count anymore. Disable CPU folding altogether
Sandman192 wrote: Fri Aug 16, 2024 2:40 am Now it's running all 3 GPUs but only 2 CPUs out of the 5 I want selected.
It keeps changing.
2 cores are automatically assigned to your 3 GPUs.
I would recommend disabling AMD iGPU, as that one will not get many (if any) work at all as it is too slow.
And screenshot of your web control main page would help too
FAH Omega tester
Sandman192
muziqaz wrote: Sun Aug 18, 2024 3:58 pm My computer is not unstable.
Did not run 2 F@H when the issues started.
I didn't tell F@H to do 2 cores and it was running 2 cores just fine.
I don't mess with DNS and if it's having trouble with that then it's the app having issues.
iGPU and the other 2 GPUS is running just fine after a few relaunches and upping the core count.
It was just a mess when you first start out.
