GTX 1650 Mobile / Max-Q OpenCL and CUDA Issues
Guanxinated
Post by Guanxinated »
EDIT: Issue has been resolved by updating the client to V.8.3.18.
Tried purging the package with "dpkg -P fah-client" and re-installing the .deb package, but the problem persisted. I then went to the F@H website and downloaded V.8.3.18.deb and that's what solved it for me.
Moral of the story is that if you need to pause folding for whatever reason, you probably should wait until all work units done before restarting your machine.
I'm running F@H V8.3 on Debian 12. Been folding just fine on my GeForce GTX 1650 Mobile / Max-Q, but that all changed today when I stopped the client, rebooted my computer, and turned the F@H Client back on again. Now it says my GPU doesn't support OpenCL and CUDA. I know this isn't a hardware issue because I've been folding on this GPU just fine, but I don't know how to fix it. Pausing and restarting the client doesn't work, neither does rebooting.
Here's the log.
Thanks.
04:14:36:W :Unrecognized option 'gpu'
04:14:36:W :Unrecognized option 'power'
04:14:36:I1:*********************** Folding@home Client ***********************
04:14:36:I1: Version: 8.3.17
04:14:36:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:14:36:I1: Org: foldingathome.org
04:14:36:I1: Copyright: 2023-2024, foldingathome.org
04:14:36:I1: Homepage: https://foldingathome.org/
04:14:36:I1: License: GPL-3.0-or-later
04:14:36:I1: URL: https://v8-3.foldingathome.org/
04:14:36:I1: Date: Jun 24 2024
04:14:36:I1: Time: 13:36:34
04:14:36:I1: Revision: 5c16e77f0d64416eb66fd5be0b9bd1de33e7d1af
04:14:36:I1: Branch: master
04:14:36:I1: Compiler: GNU 8.3.0
04:14:36:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
04:14:36:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
04:14:36:I1: Platform: linux 4.19.0-26-cloud-amd64
04:14:36:I1: Bits: 64
04:14:36:I1: Mode: Release
04:14:36:I1: Args: --config=/etc/fah-client/config.xml
04:14:36:I1: --log=/var/log/fah-client/log.txt
04:14:36:I1: --log-rotate-dir=/var/log/fah-client/
04:14:36:I1: Config: /etc/fah-client/config.xml
04:14:36:I1:****************************** CBang ******************************
04:14:36:I1: Version: 1.7.2
04:14:36:I1: Org: Cauldron Development
04:14:36:I1: Copyright: Cauldron Development, 2003-2024
04:14:36:I1: Homepage: https://cauldrondevelopment.com/
04:14:36:I1: License: LGPL-2.1-or-later
04:14:36:I1: Time: 13:29:44
04:14:36:I1: Revision: 1b05ea96f0ed3043c32b78a66dbf50a9b2002289
04:14:36:I1: -fPIC
04:14:36:I1:***************************** System ******************************
04:14:36:I1: CPU: Intel(R) Core(TM) i5-10500H CPU @ 2.50GHz
04:14:36:I1: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
04:14:36:I1: CPUs: 12
04:14:36:I1: Memory: 7.58GiB
04:14:36:I1:Free Memory: 6.93GiB
04:14:36:I1: OS Version: 6.1
04:14:36:I1:Has Battery: true
04:14:36:I1: On Battery: false
04:14:36:I1: Hostname: Zanarkand
04:14:36:I1: UTC Offset: 9
04:14:36:I1: PID: 1047
04:14:36:I1: CWD: /var/lib/fah-client
04:14:36:I1: Exec: /usr/bin/fah-client
04:14:36:I1:*******************************************************************
04:14:36:I2:<config>
04:14:36:I2: <!-- Project Settings -->
04:14:36:I2: <cause v='CANCER'/>
04:14:36:I2:
04:14:36:I2: <!-- User Information -->
04:14:36:I2: <team v='223518'/>
04:14:36:I2: <user v='Guanxinated'/>
04:14:36:I2:</config>
04:14:36:I1:Opening Database
04:14:36:I1:F@H ID = PXFlgF5OWQRuvRlLikKjgB2_AhQ6ral_CmIZvW48Y2k
04:14:36:I3:Loading default group
04:14:36:I3:Loading default resource group
04:14:36:I1:Listening for HTTP on 127.0.0.1:7396
04:14:36:I3:WU50:Loading work unit 50 with ID jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous
04:14:36:I3:Loaded 1 wus.
04:14:36:W :OpenCL not supported: clGetPlatformIDs() returned -1001
04:14:36:W :CUDA not supported: cuInit() returned 999
04:14:36:I3:gpus = {
04:14:36:I3: "gpu:00:02:00": {"vendor": 32902, "device": 39876, "type": "intel", "supported": false, "description": "CML GT2 [UHD Graphics]"},
04:14:36:I3: "gpu:02:00:00": {"vendor": 4318, "device": 8093, "type": "nvidia", "supported": false, "description": "TU117M [GeForce GTX 1650 Mobile / Max-Q]"}
04:14:36:I3:}
04:14:36:I1:Loaded cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8
04:14:36:I3:WU50:Running FahCore: /var/lib/fah-client/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01 -version 8.3.17 -lifeline 1047 -np 12
04:14:36:I3:WU50:Started FahCore on PID 1115
04:14:36:I1:WU50:*********************** Log Started 2024-07-13T04:14:36Z ***********************
04:14:36:I1:WU50:************************** Gromacs Folding@home Core ***************************
04:14:36:I1:WU50: Core: Gromacs
04:14:36:I1:WU50: Type: 0xa8
04:14:36:I1:WU50: Version: 0.0.12
04:14:36:I1:WU50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:14:36:I1:WU50: Copyright: 2020 foldingathome.org
04:14:36:I1:WU50: Homepage: https://foldingathome.org/
04:14:36:I1:WU50: Date: Jan 16 2021
04:14:36:I1:WU50: Time: 19:24:44
04:14:36:I1:WU50: Compiler: GNU 8.3.0
04:14:36:I1:WU50: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
04:14:36:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie
04:14:36:I1:WU50: Platform: linux2 4.15.0-128-generic
04:14:36:I1:WU50: Bits: 64
04:14:36:I1:WU50: Mode: Release
04:14:36:I1:WU50: SIMD: avx2_256
04:14:36:I1:WU50: OpenMP: ON
04:14:36:I1:WU50: CUDA: OFF
04:14:36:I1:WU50: Args: -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01
04:14:36:I1:WU50: -version 8.3.17 -lifeline 1047 -np 12
04:14:36:I1:WU50:************************************ libFAH ************************************
04:14:36:I1:WU50: Time: 19:21:38
04:14:36:I1:WU50:************************************ CBang *************************************
04:14:36:I1:WU50: Time: 19:21:24
04:14:36:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
04:14:36:I1:WU50:************************************ System ************************************
04:14:36:I1:WU50: CPU: Intel(R) Core(TM) i5-10500H CPU @ 2.50GHz
04:14:36:I1:WU50: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
04:14:36:I1:WU50: CPUs: 12
04:14:36:I1:WU50: Memory: 7.58GiB
04:14:36:I1:WU50:Free Memory: 6.86GiB
04:14:36:I1:WU50: Threads: POSIX_THREADS
04:14:36:I1:WU50: OS Version: 6.1
04:14:36:I1:WU50:Has Battery: true
04:14:36:I1:WU50: On Battery: false
04:14:36:I1:WU50: UTC Offset: 9
04:14:36:I1:WU50: PID: 1115
04:14:36:I1:WU50: CWD: /var/lib/fah-client/work
04:14:36:I1:WU50:********************************************************************************
04:14:36:I1:WU50:Project: 19227 (Run 2713, Clone 2, Gen 5)
04:14:36:I1:WU50:Unit: 0x00000000000000000000000000000000
04:14:36:I1:WU50:Digital signatures verified
04:14:36:I1:WU50:Calling: mdrun -c md5.gro -s md5.tpr -x md5.xtc -cpi state.cpt -cpt 5 -nt 12 -ntmpi 1
04:14:36:I1:WU50:Steps: first=2500000 total=3000000
04:14:46:I1:WU50:Completed 84562 out of 500000 steps (16%)
04:15:24:I1:WU50:Caught signal SIGINT(2) on PID 1115
04:15:24:I1:WU50:Exiting, please wait. . .
04:15:24:I1:WU50:Folding@home Core Shutdown: INTERRUPTED
04:15:24:I1:WU50:Core returned INTERRUPTED (102)
04:15:25:I3:WU50:Running FahCore: /var/lib/fah-client/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01 -version 8.3.17 -lifeline 1047 -np 12
04:15:25:I3:WU50:Started FahCore on PID 3125
04:15:26:I1:WU50:*********************** Log Started 2024-07-13T04:15:25Z ***********************
04:15:26:I1:WU50:************************** Gromacs Folding@home Core ***************************
04:15:26:I1:WU50: Core: Gromacs
04:15:26:I1:WU50: Type: 0xa8
04:15:26:I1:WU50: Version: 0.0.12
04:15:26:I1:WU50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:15:26:I1:WU50: Copyright: 2020 foldingathome.org
04:15:26:I1:WU50: Homepage: https://foldingathome.org/
04:15:26:I1:WU50: Date: Jan 16 2021
04:15:26:I1:WU50: Time: 19:24:44
04:15:26:I1:WU50: Compiler: GNU 8.3.0
04:15:26:I1:WU50: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
04:15:26:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie
04:15:26:I1:WU50: Platform: linux2 4.15.0-128-generic
04:15:26:I1:WU50: Bits: 64
04:15:26:I1:WU50: Mode: Release
04:15:26:I1:WU50: SIMD: avx2_256
04:15:26:I1:WU50: OpenMP: ON
04:15:26:I1:WU50: CUDA: OFF
04:15:26:I1:WU50: Args: -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01
04:15:26:I1:WU50: -version 8.3.17 -lifeline 1047 -np 12
04:15:26:I1:WU50:************************************ libFAH ************************************
04:15:26:I1:WU50: Time: 19:21:38
04:15:26:I1:WU50:************************************ CBang *************************************
04:15:26:I1:WU50: Time: 19:21:24
04:15:26:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
04:15:26:I1:WU50:************************************ System ************************************
04:15:26:I1:WU50: CPU: Intel(R) Core(TM) i5-10500H CPU @ 2.50GHz
04:15:26:I1:WU50: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
04:15:26:I1:WU50: CPUs: 12
04:15:26:I1:WU50: Memory: 7.58GiB
04:15:26:I1:WU50:Free Memory: 4.29GiB
04:15:26:I1:WU50: Threads: POSIX_THREADS
04:15:26:I1:WU50: OS Version: 6.1
04:15:26:I1:WU50:Has Battery: true
04:15:26:I1:WU50: On Battery: false
04:15:26:I1:WU50: UTC Offset: 9
04:15:26:I1:WU50: PID: 3125
04:15:26:I1:WU50: CWD: /var/lib/fah-client/work
04:15:26:I1:WU50:********************************************************************************
04:15:26:I1:WU50:Project: 19227 (Run 2713, Clone 2, Gen 5)
04:15:26:I1:WU50:Unit: 0x00000000000000000000000000000000
04:15:26:I1:WU50:Digital signatures verified
04:15:26:I1:WU50:Calling: mdrun -c md5.gro -s md5.tpr -x md5.xtc -cpi state.cpt -cpt 5 -nt 12 -ntmpi 1
04:15:26:I1:WU50:Steps: first=2500000 total=3000000
04:15:36:I1:WU50:Completed 84822 out of 500000 steps (16%)
04:15:41:I1:WU50:Caught signal SIGINT(2) on PID 3125
04:15:41:I1:WU50:Exiting, please wait. . .
04:15:42:I1:WU50:Folding@home Core Shutdown: INTERRUPTED
04:15:43:I1:WU50:Core returned INTERRUPTED (102)
04:15:43:I3:WU50:Running FahCore: /var/lib/fah-client/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01 -version 8.3.17 -lifeline 1047 -np 9
04:15:43:I3:WU50:Started FahCore on PID 3143
04:15:44:I1:WU50:*********************** Log Started 2024-07-13T04:15:43Z ***********************
04:15:44:I1:WU50:************************** Gromacs Folding@home Core ***************************
04:15:44:I1:WU50: Core: Gromacs
04:15:44:I1:WU50: Type: 0xa8
04:15:44:I1:WU50: Version: 0.0.12
04:15:44:I1:WU50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:15:44:I1:WU50: Copyright: 2020 foldingathome.org
04:15:44:I1:WU50: Homepage: https://foldingathome.org/
04:15:44:I1:WU50: Date: Jan 16 2021
04:15:44:I1:WU50: Time: 19:24:44
04:15:44:I1:WU50: Compiler: GNU 8.3.0
04:15:44:I1:WU50: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
04:15:44:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie
04:15:44:I1:WU50: Platform: linux2 4.15.0-128-generic
04:15:44:I1:WU50: Bits: 64
04:15:44:I1:WU50: Mode: Release
04:15:44:I1:WU50: SIMD: avx2_256
04:15:44:I1:WU50: OpenMP: ON
04:15:44:I1:WU50: CUDA: OFF
04:15:44:I1:WU50: Args: -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01
04:15:44:I1:WU50: -version 8.3.17 -lifeline 1047 -np 9
04:15:44:I1:WU50:************************************ libFAH ************************************
04:15:44:I1:WU50: Time: 19:21:38
04:15:44:I1:WU50:************************************ CBang *************************************
04:15:44:I1:WU50: Time: 19:21:24
04:15:44:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
04:15:44:I1:WU50:************************************ System ************************************
04:15:44:I1:WU50: CPU: Intel(R) Core(TM) i5-10500H CPU @ 2.50GHz
04:15:44:I1:WU50: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
04:15:44:I1:WU50: CPUs: 12
04:15:44:I1:WU50: Memory: 7.58GiB
04:15:44:I1:WU50:Free Memory: 4.25GiB
04:15:44:I1:WU50: Threads: POSIX_THREADS
04:15:44:I1:WU50: OS Version: 6.1
04:15:44:I1:WU50:Has Battery: true
04:15:44:I1:WU50: On Battery: false
04:15:44:I1:WU50: UTC Offset: 9
04:15:44:I1:WU50: PID: 3143
04:15:44:I1:WU50: CWD: /var/lib/fah-client/work
04:15:44:I1:WU50:********************************************************************************
04:15:44:I1:WU50:Project: 19227 (Run 2713, Clone 2, Gen 5)
04:15:44:I1:WU50:Unit: 0x00000000000000000000000000000000
04:15:44:I1:WU50:Digital signatures verified
04:15:44:I1:WU50:Calling: mdrun -c md5.gro -s md5.tpr -x md5.xtc -cpi state.cpt -cpt 5 -nt 9 -ntmpi 1
04:15:44:I1:WU50:Steps: first=2500000 total=3000000
04:15:45:I1:WU50:Caught signal SIGINT(2) on PID 3143
04:15:45:I1:WU50:Exiting, please wait. . .
04:15:54:I1:WU50:Completed 84882 out of 500000 steps (16%)
04:15:55:I1:WU50:Folding@home Core Shutdown: INTERRUPTED
04:15:56:I1:WU50:Core returned INTERRUPTED (102)
04:15:56:I3:WU50:Running FahCore: /var/lib/fah-client/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01 -version 8.3.17 -lifeline 1047 -np 12
04:15:56:I3:WU50:Started FahCore on PID 3163
04:15:56:I1:WU50:*********************** Log Started 2024-07-13T04:15:56Z ***********************
04:15:56:I1:WU50:************************** Gromacs Folding@home Core ***************************
04:15:56:I1:WU50: Core: Gromacs
04:15:56:I1:WU50: Type: 0xa8
04:15:56:I1:WU50: Version: 0.0.12
04:15:56:I1:WU50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:15:56:I1:WU50: Copyright: 2020 foldingathome.org
04:15:56:I1:WU50: Homepage: https://foldingathome.org/
04:15:56:I1:WU50: Date: Jan 16 2021
04:15:56:I1:WU50: Time: 19:24:44
04:15:56:I1:WU50: Compiler: GNU 8.3.0
04:15:56:I1:WU50: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
04:15:56:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie
04:15:56:I1:WU50: Platform: linux2 4.15.0-128-generic
04:15:56:I1:WU50: Bits: 64
04:15:56:I1:WU50: Mode: Release
04:15:56:I1:WU50: SIMD: avx2_256
04:15:56:I1:WU50: OpenMP: ON
04:15:56:I1:WU50: CUDA: OFF
04:15:56:I1:WU50: Args: -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01
04:15:56:I1:WU50: -version 8.3.17 -lifeline 1047 -np 12
04:15:56:I1:WU50:************************************ libFAH ************************************
04:15:56:I1:WU50: Time: 19:21:38
04:15:56:I1:WU50:************************************ CBang *************************************
04:15:56:I1:WU50: Time: 19:21:24
04:15:56:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
04:15:56:I1:WU50:************************************ System ************************************
04:15:56:I1:WU50: CPU: Intel(R) Core(TM) i5-10500H CPU @ 2.50GHz
04:15:56:I1:WU50: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
04:15:56:I1:WU50: CPUs: 12
04:15:56:I1:WU50: Memory: 7.58GiB
04:15:56:I1:WU50:Free Memory: 4.24GiB
04:15:56:I1:WU50: Threads: POSIX_THREADS
04:15:56:I1:WU50: OS Version: 6.1
04:15:56:I1:WU50:Has Battery: true
04:15:56:I1:WU50: On Battery: false
04:15:56:I1:WU50: UTC Offset: 9
04:15:56:I1:WU50: PID: 3163
04:15:56:I1:WU50: CWD: /var/lib/fah-client/work
04:15:56:I1:WU50:********************************************************************************
04:15:56:I1:WU50:Project: 19227 (Run 2713, Clone 2, Gen 5)
04:15:56:I1:WU50:Unit: 0x00000000000000000000000000000000
04:15:56:I1:WU50:Digital signatures verified
04:15:56:I1:WU50:Calling: mdrun -c md5.gro -s md5.tpr -x md5.xtc -cpi state.cpt -cpt 5 -nt 12 -ntmpi 1
04:15:56:I1:WU50:Steps: first=2500000 total=3000000
04:16:06:I1:WU50:Completed 84892 out of 500000 steps (16%)
04:16:19:I1:WU50:Completed 85000 out of 500000 steps (17%)
04:17:00:I1:WU50:Caught signal SIGINT(2) on PID 3163
04:17:00:I1:WU50:Exiting, please wait. . .
04:17:01:I1:WU50:Folding@home Core Shutdown: INTERRUPTED
04:17:02:I1:WU50:Core returned INTERRUPTED (102)
04:17:02:I3:WU50:Running FahCore: /var/lib/fah-client/cores/fahcore-a8-lin-64bit-avx2_256-0.0.12/FahCore_a8 -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01 -version 8.3.17 -lifeline 1047 -np 12
04:17:02:I3:WU50:Started FahCore on PID 3331
04:17:03:I1:WU50:*********************** Log Started 2024-07-13T04:17:03Z ***********************
04:17:03:I1:WU50:************************** Gromacs Folding@home Core ***************************
04:17:03:I1:WU50: Core: Gromacs
04:17:03:I1:WU50: Type: 0xa8
04:17:03:I1:WU50: Version: 0.0.12
04:17:03:I1:WU50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:17:03:I1:WU50: Copyright: 2020 foldingathome.org
04:17:03:I1:WU50: Homepage: https://foldingathome.org/
04:17:03:I1:WU50: Date: Jan 16 2021
04:17:03:I1:WU50: Time: 19:24:44
04:17:03:I1:WU50: Compiler: GNU 8.3.0
04:17:03:I1:WU50: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
04:17:03:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie
04:17:03:I1:WU50: Platform: linux2 4.15.0-128-generic
04:17:03:I1:WU50: Bits: 64
04:17:03:I1:WU50: Mode: Release
04:17:03:I1:WU50: SIMD: avx2_256
04:17:03:I1:WU50: OpenMP: ON
04:17:03:I1:WU50: CUDA: OFF
04:17:03:I1:WU50: Args: -dir jomqnPwltG-VnhquGluMVcO-Y1avuApW1eqfBooRous -suffix 01
04:17:03:I1:WU50: -version 8.3.17 -lifeline 1047 -np 12
04:17:03:I1:WU50:************************************ libFAH ************************************
04:17:03:I1:WU50: Time: 19:21:38
04:17:03:I1:WU50:************************************ CBang *************************************
04:17:03:I1:WU50: Time: 19:21:24
04:17:03:I1:WU50: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
04:17:03:I1:WU50:************************************ System ************************************
04:17:03:I1:WU50: CPU: Intel(R) Core(TM) i5-10500H CPU @ 2.50GHz
04:17:03:I1:WU50: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
04:17:03:I1:WU50: CPUs: 12
04:17:03:I1:WU50: Memory: 7.58GiB
04:17:03:I1:WU50:Free Memory: 4.15GiB
04:17:03:I1:WU50: Threads: POSIX_THREADS
04:17:03:I1:WU50: OS Version: 6.1
04:17:03:I1:WU50:Has Battery: true
04:17:03:I1:WU50: On Battery: false
04:17:03:I1:WU50: UTC Offset: 9
04:17:03:I1:WU50: PID: 3331
04:17:03:I1:WU50: CWD: /var/lib/fah-client/work
04:17:03:I1:WU50:********************************************************************************
04:17:03:I1:WU50:Project: 19227 (Run 2713, Clone 2, Gen 5)
04:17:03:I1:WU50:Unit: 0x00000000000000000000000000000000
04:17:03:I1:WU50:Digital signatures verified
04:17:03:I1:WU50:Calling: mdrun -c md5.gro -s md5.tpr -x md5.xtc -cpi state.cpt -cpt 5 -nt 12 -ntmpi 1
04:17:03:I1:WU50:Steps: first=2500000 total=3000000
04:17:13:I1:WU50:Completed 85372 out of 500000 steps (17%)
Reason: change Quote tags to Code
