WU's 12436 (Run 37, Clone 4, Gen 79) is exceeding the timeout, and due to be completed just before the expiration, on an overclocked Raspberry Pi 4B.
It has base points of 17,000, which is around 8,000 points more than most WU's my Pi's have received, and takes around 16 minutes longer per frame.
I will be dumping it.
WU's 12436 exceeds the timeout on a Rasperry Pi 4B
Schrödinger's cat
- Hardware configuration: NVIDIA RTX 4080 Super
20 x Raspberry Pi 5 Model B 2GB RAM - Location: VIC, Australia
Re: WU's 12436 exceeds the timeout on a Rasperry Pi 4B
Not surprising given other posts on this forum.
You probably need a Pi 5 or better to make timeouts.
There might be some constraints that were not applied to this project. I pointed to this thread elsewhere. We’ll see if someone chimes in.
