2662 : Invalid unit
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
2662 : Invalid unit
Post by dschief »
running 6.02 client with -SMP flag set and have gotten 2662 twice, each time an error msg occurs
saying "work unit read from disc is invalid" But the client continues to run it's now at 1%
the project summary has this with GROCVS; Everything else I've run is GRO-SMP
with the -SMP flag set should I even be getting this Wu?
ChelseaOilman
Re: 2662 : Invalid unit
Post by ChelseaOilman »
See this thread: new A2 core released--on advanced methods
I'm not sure why your getting that error message.
dschief
EVGA1060
Post by dschief »
this wu crashed my system again. Mouse & kybd. both locked up.found that 2662 had gotten to 14% then stopped
no error msg or eue.
[21:52:57] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 2
[21:52:57] - Connecting to assignment server
[21:52:57] Connecting to http://assign.stanford.edu:8080/
[21:52:58] Posted data.
[21:52:58] Initial: 40AB; - Successful: assigned to (171.64.65.56).
[21:52:58] + News From Folding@Home: Welcome to Folding@Home
[21:52:58] Loaded queue successfully.
[21:52:58] Connecting to http://171.64.65.56:8080/
[21:53:03] Posted data.
[21:53:03] Initial: 0000; - Receiving payload (expected size: 4920894)
[21:53:34] - Downloaded at ~155 kB/s
[21:53:34] - Averaged speed for that direction ~155 kB/s
[21:53:34] + Received work.
[21:53:34] + Closed connections
[21:53:34]
[21:53:34] + Processing work unit
[21:53:34] Core required: FahCore_a2.exe
[21:53:34] Core found.
[21:53:34] Working on Unit 01 [July 23 21:53:34]
[21:53:34] + Working ...
[21:53:34] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 2957 -version 602'
[21:53:34]
[21:53:34] *------------------------------*
[21:53:34] Folding@Home Gromacs SMP Core
[21:53:34] Version 1.91 (2007)
[21:53:34]
[21:53:34] Preparing to commence simulation
[21:53:34] - Ensuring status. Please wait.
[21:53:34] - Files status OK
[21:53:34] Error: Work unit read from disk is invalid
[21:53:34] Finalizing output
[21:53:35] - Expanded 4920382 -> 24360573 (decompressed 495.0 percent)
[21:53:35]
[21:53:35] Project: 2662 (Run 2, Clone 85, Gen 10)
[21:53:35]
[21:53:35] Assembly optimizations on if available.
[21:53:35] Entering M.D.
[21:53:52]  495.0 percent)
[21:53:52] 3 (decompressed 495.0 percent)
[21:53:53]
[21:53:53] Project: 2662 (Run 2, Clone 85, Gen 10)
[21:53:53]
[21:53:53] Entering M.D.
[21:54:00] Completed 0 out of 250000 steps  (0%)
[22:04:49] eps  (1%)
[22:04:49] 1250 out of 250000 steps  (1%)
[22:19:54] Timer requesting checkpoint
[22:26:23]  steps  (2%)
[22:26:23] 0 out of 250000 steps  (2%)
[22:41:28] Timer requesting checkpoint
[22:47:55] Completed 6250 out of 250000 steps  (3%)
[23:03:00] Timer requesting checkpoint
[23:09:30] Completed 8750 out of 250000 steps  (4%)
[23:24:36] Timer requesting checkpoint
[23:31:05] Completed 11250 out of 250000 steps  (5%)
[23:46:10] Timer requesting checkpoint
[23:52:40] Completed 13750 out of 250000 steps  (6%)
[00:07:45] Timer requesting checkpoint
[00:14:15] Completed 16250 out of 250000 steps  (7%)
[00:29:20] Timer requesting checkpoint
[00:35:50] Completed 18750 out of 250000 steps  (8%)
[00:50:55] Timer requesting checkpoint
[00:57:28] Completed 21250 out of 250000 steps  (9%)
[01:12:32] Timer requesting checkpoint
[01:19:04] Completed 23750 out of 250000 steps  (10%)
[01:34:09] Timer requesting checkpoint
[01:40:38] Completed 26250 out of 250000 steps  (11%)
[01:55:43] Timer requesting checkpoint
[02:02:14] Completed 28750 out of 250000 steps  (12%)
[02:17:19] Timer requesting checkpoint
[02:23:47] Completed 31250 out of 250000 steps  (13%)
[02:38:52] Timer requesting checkpoint
[02:45:22] Completed 33750 out of 250000 steps  (14%)
[jim@localhost fold]$
this was ar 04:04 just after reboot.
ChelseaOilman
Did you read the thread I linked to? You may want to delete your current core so you get the new A2 core.
dschief
EVGA1060
Post by dschief »
ChelseaOilman wrote:Did you read the thread I linked to? You may want to delete your current core so you get the new A2 core.
I did that last night, deleted everything ,got new core,
got the same Wu back again 2662 run 2 clone 85 gen 10. And when I got up this am , the system was froze again. this time at 18%
there is something definately wrong with this Wu and/or A2 core!
I have another rig running 2662 Run 0 Clone 160 Gen 0. And it is hosed also, while the wu is running
other aps are lock out. IE: system Monitor won't open, I can't launch a second terminal etc.
But as soon as I CTRL C the Wu, All of the windows/ terminals I tried to launch suddenly appear
UPDATE: Just shut down a third rig, 2662 again this one froze at 5 %, right after completion and upload of a 2605
Perfect score 3 rigs running 2662 & 3 rigs locked up! Shuting down until 2662 goes away
kasson
Pande Group Member
Post by kasson »
We had a problem with the old core version (1.91) still being posted in some of the download locations. If you delete your old core and try one more time, see if the version # says 2.00 (Linux) or 2.01 (OSX). Hopefully that will fix the problem.
dschief
EVGA1060
Post by dschief »
kasson wrote:We had a problem with the old core version (1.91) still being posted in some of the download locations. If you delete your old core and try one more time, see if the version # says 2.00 (Linux) or 2.01 (OSX). Hopefully that will fix the problem.
Ok, I re-booted all 3, got 2662 R0 CL 160 G 0; 2662 R2 CL 239 G 0 & a 2605
both of the 2662's came with A2 ( 2.0 ) dated 7/9/2008 13:11:25 PDT
On the 2 2662's , mouse ops seem quicker, I can now open & close additional terms.
System Mon. shows 97/98 % usage with a occasional bump to 100%
mem usage is right around 628 Mb
Will post any changes & will check-in if they finish & up-load.
thanks
dschief
EVGA1060
Post by dschief »
Close thread, both wu's ran to 100% . Up-loaded ok; working on a third. new core did the trick
