A little help, please...
tcphillips
Hardware configuration: [img]http://folding.extremeoverclocking.com/sigs/sigimage.php?u=296154[/img]
Post by tcphillips »
I am getting "Failed" messages on both my GPU's. Everything is stock, no overclocking at all.
When I reboot, she'll reload WU(s) and grind on her merry way, until....
Below is my config and the message log. Is it hardware? Software? The WU(s)...?
Or worse...insufficient operator intelligence...?
Some insights please...
Thanks in advance...
--Tom
17:57:37:WU00:FS02:0x23:************************************ CBang *************************************
17:57:37:WU00:FS02:0x23:    Version: 1.7.2
17:57:37:WU00:FS02:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:57:37:WU00:FS02:0x23:        Org: Cauldron Development LLC
17:57:37:WU00:FS02:0x23:  Copyright: Cauldron Development LLC, 2003-2023
17:57:37:WU00:FS02:0x23:   Homepage: https://cauldrondevelopment.com/
17:57:37:WU00:FS02:0x23:    License: GPL 2+
17:57:37:WU00:FS02:0x23:       Date: Aug 3 2023
17:57:37:WU00:FS02:0x23:       Time: 08:37:14
17:57:37:WU00:FS02:0x23:   Compiler: Visual C++
17:57:37:WU00:FS02:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:57:37:WU00:FS02:0x23:   Platform: win32 10
17:57:37:WU00:FS02:0x23:       Bits: 64
17:57:37:WU00:FS02:0x23:       Mode: Release
17:57:37:WU00:FS02:0x23:************************************ System ************************************
17:57:37:WU00:FS02:0x23:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:57:37:WU00:FS02:0x23:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:57:37:WU00:FS02:0x23:       CPUs: 16
17:57:37:WU00:FS02:0x23:     Memory: 15.82GiB
17:57:37:WU00:FS02:0x23:Free Memory: 11.32GiB
17:57:37:WU00:FS02:0x23:    Threads: WINDOWS_THREADS
17:57:37:WU00:FS02:0x23: OS Version: 6.2
17:57:37:WU00:FS02:0x23:Has Battery: false
17:57:37:WU00:FS02:0x23: On Battery: false
17:57:37:WU00:FS02:0x23: UTC Offset: -4
17:57:37:WU00:FS02:0x23:        PID: 20740
17:57:37:WU00:FS02:0x23:        CWD: C:\ProgramData\FAHClient\work
17:57:37:WU00:FS02:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
17:57:37:WU00:FS02:0x23:************************************ OpenMM ************************************
17:57:37:WU00:FS02:0x23:    Version: 8.0.0
17:57:37:WU00:FS02:0x23:********************************************************************************
17:57:37:WU00:FS02:0x23:Project: 17646 (Run 24, Clone 0, Gen 264)
17:57:37:WU00:FS02:0x23:Reading tar file core.xml
17:57:37:WU00:FS02:0x23:Reading tar file integrator.xml.bz2
17:57:37:WU00:FS02:0x23:Reading tar file state.xml.bz2
17:57:37:WU00:FS02:0x23:Reading tar file system.xml.bz2
17:57:37:WU00:FS02:0x23:Digital signatures verified
17:57:37:WU00:FS02:0x23:Folding@home GPU Core23 Folding@home Core
17:57:37:WU00:FS02:0x23:Version 8.0.3
17:57:37:WU00:FS02:0x23:  Checkpoint write interval: 125000 steps (5%) [20 total]
17:57:37:WU00:FS02:0x23:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:57:37:WU00:FS02:0x23:  XTC frame write interval: 250000 steps (10%) [10 total]
17:57:37:WU00:FS02:0x23:  Global context and integrator variables write interval: disabled
17:57:37:WU00:FS02:0x23:There are 3 platforms available.
17:57:37:WU00:FS02:0x23:Platform 0: Reference
17:57:37:WU00:FS02:0x23:Platform 1: CPU
17:57:37:WU00:FS02:0x23:Platform 2: CUDA
17:57:37:WU00:FS02:0x23:  cuda-device 1 specified
17:57:37:WU00:FS02:0x23:opencl-device was set but OpenCL platform could not be found.
17:57:39:WU00:FS02:0x23:Attempting to create CUDA context:
17:57:39:WU00:FS02:0x23:  Configuring platform CUDA
17:57:39:WU00:FS02:0x23:Failed to create CUDA context:
17:57:39:WU00:FS02:0x23:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1682502964893\work\platforms\cuda\src\CudaContext.cpp:140
17:57:39:WU00:FS02:0x23:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:57:39:WU00:FS02:0x23:Saving result file ..\logfile_01.txt
17:57:39:WU00:FS02:0x23:Saving result file science.log
17:57:39:WU00:FS02:0x23:Folding@home Core Shutdown: BAD_WORK_UNIT
17:57:40:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:57:40:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:17646 run:24 clone:0 gen:264 core:0x23 unit:0x0000000000000108000044ee00000018
17:57:40:WU00:FS02:Uploading 11.50KiB to 140.163.4.210
17:57:40:WU00:FS02:Connecting to 140.163.4.210:8080
17:57:40:WU01:FS02:Connecting to assign1.foldingathome.org:80
17:57:40:WU00:FS02:Upload complete
17:57:40:WU00:FS02:Server responded WORK_ACK (400)
17:57:40:WU00:FS02:Cleaning up
17:57:41:WU01:FS02:Assigned to work server 206.223.170.146
17:57:41:WU01:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 206.223.170.146
17:57:41:WU01:FS02:Connecting to 206.223.170.146:8080
17:57:41:WU01:FS02:Downloading 25.02MiB
17:57:43:WU01:FS02:Download complete
17:57:43:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12299 run:19 clone:15 gen:128 core:0x23 unit:0x0000000f000000800000300b00000013
17:57:43:WU01:FS02:Starting
17:57:43:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 01 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:57:43:WU01:FS02:Started FahCore on PID 10432
17:57:43:WU01:FS02:Core PID:12948
17:57:43:WU01:FS02:FahCore 0x23 started
17:57:43:WU01:FS02:0x23:*********************** Log Started 2024-06-09T17:57:43Z ***********************
17:57:43:WU01:FS02:0x23:*************************** Core23 Folding@home Core ***************************
17:57:43:WU01:FS02:0x23:       Core: Core23
17:57:43:WU01:FS02:0x23:       Type: 0x23
17:57:43:WU01:FS02:0x23:    Version: 8.0.3
17:57:43:WU01:FS02:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:57:43:WU01:FS02:0x23:  Copyright: 2022 foldingathome.org
17:57:43:WU01:FS02:0x23:   Homepage: https://foldingathome.org/
17:57:43:WU01:FS02:0x23:       Date: Aug 3 2023
17:57:43:WU01:FS02:0x23:       Time: 08:39:06
17:57:43:WU01:FS02:0x23:   Compiler: Visual C++
17:57:43:WU01:FS02:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:57:43:WU01:FS02:0x23:             -DOPENMM_VERSION="\"8.0.0\""
17:57:43:WU01:FS02:0x23:   Platform: win32 10
17:57:43:WU01:FS02:0x23:       Bits: 64
17:57:43:WU01:FS02:0x23:       Mode: Release
17:57:43:WU01:FS02:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:57:43:WU01:FS02:0x23:             <peastman@stanford.edu>
17:57:43:WU01:FS02:0x23:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10432 -checkpoint 30
17:57:43:WU01:FS02:0x23:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:57:43:WU01:FS02:0x23:             nvidia -gpu 1 -gpu-usage 100
17:57:43:WU01:FS02:0x23:************************************ libFAH ************************************
17:57:43:WU01:FS02:0x23:       Time: 08:37:55
17:57:43:WU01:FS02:0x23:************************************ CBang *************************************
17:57:43:WU01:FS02:0x23:    Version: 1.7.2
17:57:43:WU01:FS02:0x23:        Org: Cauldron Development LLC
17:57:43:WU01:FS02:0x23:  Copyright: Cauldron Development LLC, 2003-2023
17:57:43:WU01:FS02:0x23:   Homepage: https://cauldrondevelopment.com/
17:57:43:WU01:FS02:0x23:    License: GPL 2+
17:57:43:WU01:FS02:0x23:       Time: 08:37:14
17:57:43:WU01:FS02:0x23:************************************ System ************************************
17:57:43:WU01:FS02:0x23:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:57:43:WU01:FS02:0x23:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:57:43:WU01:FS02:0x23:       CPUs: 16
17:57:43:WU01:FS02:0x23:     Memory: 15.82GiB
17:57:43:WU01:FS02:0x23:Free Memory: 11.31GiB
17:57:43:WU01:FS02:0x23:    Threads: WINDOWS_THREADS
17:57:43:WU01:FS02:0x23: OS Version: 6.2
17:57:43:WU01:FS02:0x23:Has Battery: false
17:57:43:WU01:FS02:0x23: On Battery: false
17:57:43:WU01:FS02:0x23: UTC Offset: -4
17:57:43:WU01:FS02:0x23:        PID: 12948
17:57:43:WU01:FS02:0x23:        CWD: C:\ProgramData\FAHClient\work
17:57:43:WU01:FS02:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
17:57:43:WU01:FS02:0x23:************************************ OpenMM ************************************
17:57:43:WU01:FS02:0x23:    Version: 8.0.0
17:57:43:WU01:FS02:0x23:********************************************************************************
17:57:43:WU01:FS02:0x23:Project: 12299 (Run 19, Clone 15, Gen 128)
17:57:43:WU01:FS02:0x23:Reading tar file core.xml
17:57:43:WU01:FS02:0x23:Reading tar file integrator.xml
17:57:43:WU01:FS02:0x23:Reading tar file state.xml.bz2
17:57:43:WU01:FS02:0x23:Reading tar file system.xml.bz2
17:57:43:WU01:FS02:0x23:Digital signatures verified
17:57:43:WU01:FS02:0x23:Folding@home GPU Core23 Folding@home Core
17:57:43:WU01:FS02:0x23:Version 8.0.3
17:57:43:WU01:FS02:0x23:  Checkpoint write interval: 25000 steps (2%) [50 total]
17:57:43:WU01:FS02:0x23:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:57:43:WU01:FS02:0x23:  XTC frame write interval: 25000 steps (2%) [50 total]
17:57:43:WU01:FS02:0x23:  Global context and integrator variables write interval: disabled
17:57:43:WU01:FS02:0x23:There are 3 platforms available.
17:57:44:WU01:FS02:0x23:Platform 0: Reference
17:57:44:WU01:FS02:0x23:Platform 1: CPU
17:57:44:WU01:FS02:0x23:Platform 2: CUDA
17:57:44:WU01:FS02:0x23:  cuda-device 1 specified
17:57:44:WU01:FS02:0x23:opencl-device was set but OpenCL platform could not be found.
17:58:10:WU01:FS02:0x23:Attempting to create CUDA context:
17:58:10:WU01:FS02:0x23:  Configuring platform CUDA
17:58:10:WU01:FS02:0x23:Failed to create CUDA context:
17:58:10:WU01:FS02:0x23:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1682502964893\work\platforms\cuda\src\CudaContext.cpp:140
17:58:10:WU01:FS02:0x23:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:58:10:WU01:FS02:0x23:Saving result file ..\logfile_01.txt
17:58:10:WU01:FS02:0x23:Saving result file science.log
17:58:10:WU01:FS02:0x23:Folding@home Core Shutdown: BAD_WORK_UNIT
17:58:10:WARNING:WU01:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:58:10:WU01:FS02:Sending unit results: id:01 state:SEND error:FAULTY project:12299 run:19 clone:15 gen:128 core:0x23 unit:0x0000000f000000800000300b00000013
17:58:10:WU01:FS02:Uploading 11.00KiB to 206.223.170.146
17:58:10:WU01:FS02:Connecting to 206.223.170.146:8080
17:58:11:WU01:FS02:Upload complete
17:58:11:WU01:FS02:Server responded WORK_ACK (400)
17:58:11:WU01:FS02:Cleaning up
17:58:11:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:58:11:WU00:FS02:Assigned to work server 129.32.209.206
17:58:11:WU00:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 129.32.209.206
17:58:11:WU00:FS02:Connecting to 129.32.209.206:8080
17:58:13:WU00:FS02:Downloading 8.90MiB
17:58:13:WU00:FS02:Download complete
17:58:13:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:12456 run:20 clone:5 gen:332 core:0x23 unit:0x4c0100000500000014000000a8300000
17:58:13:WU00:FS02:Starting
17:58:13:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 00 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:58:13:WU00:FS02:Started FahCore on PID 13664
17:58:13:WU00:FS02:Core PID:6112
17:58:13:WU00:FS02:FahCore 0x23 started
17:58:14:WU00:FS02:0x23:*********************** Log Started 2024-06-09T17:58:13Z ***********************
17:58:14:WU00:FS02:0x23:*************************** Core23 Folding@home Core ***************************
17:58:14:WU00:FS02:0x23:       Core: Core23
17:58:14:WU00:FS02:0x23:       Type: 0x23
17:58:14:WU00:FS02:0x23:    Version: 8.0.3
17:58:14:WU00:FS02:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:58:14:WU00:FS02:0x23:  Copyright: 2022 foldingathome.org
17:58:14:WU00:FS02:0x23:   Homepage: https://foldingathome.org/
17:58:14:WU00:FS02:0x23:       Date: Aug 3 2023
17:58:14:WU00:FS02:0x23:       Time: 08:39:06
17:58:14:WU00:FS02:0x23:   Compiler: Visual C++
17:58:14:WU00:FS02:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:58:14:WU00:FS02:0x23:             -DOPENMM_VERSION="\"8.0.0\""
17:58:14:WU00:FS02:0x23:   Platform: win32 10
17:58:14:WU00:FS02:0x23:       Bits: 64
17:58:14:WU00:FS02:0x23:       Mode: Release
17:58:14:WU00:FS02:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:58:14:WU00:FS02:0x23:             <peastman@stanford.edu>
17:58:14:WU00:FS02:0x23:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13664 -checkpoint 30
17:58:14:WU00:FS02:0x23:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:58:14:WU00:FS02:0x23:             nvidia -gpu 1 -gpu-usage 100
17:58:14:WU00:FS02:0x23:************************************ libFAH ************************************
17:58:14:WU00:FS02:0x23:       Time: 08:37:55
17:58:14:WU00:FS02:0x23:************************************ CBang *************************************
17:58:14:WU00:FS02:0x23:    Version: 1.7.2
17:58:14:WU00:FS02:0x23:        Org: Cauldron Development LLC
17:58:14:WU00:FS02:0x23:  Copyright: Cauldron Development LLC, 2003-2023
17:58:14:WU00:FS02:0x23:   Homepage: https://cauldrondevelopment.com/
17:58:14:WU00:FS02:0x23:    License: GPL 2+
17:58:14:WU00:FS02:0x23:       Time: 08:37:14
17:58:14:WU00:FS02:0x23:************************************ System ************************************
17:58:14:WU00:FS02:0x23:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:58:14:WU00:FS02:0x23:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:58:14:WU00:FS02:0x23:       CPUs: 16
17:58:14:WU00:FS02:0x23:     Memory: 15.82GiB
17:58:14:WU00:FS02:0x23:Free Memory: 11.34GiB
17:58:14:WU00:FS02:0x23:    Threads: WINDOWS_THREADS
17:58:14:WU00:FS02:0x23: OS Version: 6.2
17:58:14:WU00:FS02:0x23:Has Battery: false
17:58:14:WU00:FS02:0x23: On Battery: false
17:58:14:WU00:FS02:0x23: UTC Offset: -4
17:58:14:WU00:FS02:0x23:        PID: 6112
17:58:14:WU00:FS02:0x23:        CWD: C:\ProgramData\FAHClient\work
17:58:14:WU00:FS02:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
17:58:14:WU00:FS02:0x23:************************************ OpenMM ************************************
17:58:14:WU00:FS02:0x23:    Version: 8.0.0
17:58:14:WU00:FS02:0x23:********************************************************************************
17:58:14:WU00:FS02:0x23:Project: 12456 (Run 20, Clone 5, Gen 332)
17:58:14:WU00:FS02:0x23:Reading tar file core.xml
17:58:14:WU00:FS02:0x23:Reading tar file integrator.xml
17:58:14:WU00:FS02:0x23:Reading tar file state.xml
17:58:14:WU00:FS02:0x23:Reading tar file system.xml
17:58:14:WU00:FS02:0x23:Digital signatures verified
17:58:14:WU00:FS02:0x23:Folding@home GPU Core23 Folding@home Core
17:58:14:WU00:FS02:0x23:Version 8.0.3
17:58:14:WU00:FS02:0x23:  Checkpoint write interval: 50000 steps (2%) [50 total]
17:58:14:WU00:FS02:0x23:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:58:14:WU00:FS02:0x23:  XTC frame write interval: 2500000 steps (1e+02%) [1 total]
17:58:14:WU00:FS02:0x23:  Global context and integrator variables write interval: disabled
17:58:14:WU00:FS02:0x23:There are 3 platforms available.
17:58:14:WU00:FS02:0x23:Platform 0: Reference
17:58:14:WU00:FS02:0x23:Platform 1: CPU
17:58:14:WU00:FS02:0x23:Platform 2: CUDA
17:58:14:WU00:FS02:0x23:  cuda-device 1 specified
17:58:14:WU00:FS02:0x23:opencl-device was set but OpenCL platform could not be found.
17:58:18:WU00:FS02:0x23:Attempting to create CUDA context:
17:58:18:WU00:FS02:0x23:  Configuring platform CUDA
17:58:18:WU00:FS02:0x23:Failed to create CUDA context:
17:58:18:WU00:FS02:0x23:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1682502964893\work\platforms\cuda\src\CudaContext.cpp:140
17:58:18:WU00:FS02:0x23:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:58:18:WU00:FS02:0x23:Saving result file ..\logfile_01.txt
17:58:18:WU00:FS02:0x23:Saving result file science.log
17:58:18:WU00:FS02:0x23:Folding@home Core Shutdown: BAD_WORK_UNIT
17:58:18:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:58:18:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:12456 run:20 clone:5 gen:332 core:0x23 unit:0x4c0100000500000014000000a8300000
17:58:18:WU00:FS02:Uploading 2.52KiB to 129.32.209.206
17:58:18:WU00:FS02:Connecting to 129.32.209.206:8080
17:58:18:WU01:FS02:Connecting to assign1.foldingathome.org:80
17:58:18:WU00:FS02:Upload complete
17:58:19:WU00:FS02:Server responded WORK_ACK (400)
17:58:19:WU00:FS02:Cleaning up
17:58:19:WU01:FS02:Assigned to work server 129.32.209.202
17:58:19:WU01:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 129.32.209.202
17:58:19:WU01:FS02:Connecting to 129.32.209.202:8080
17:58:20:WU01:FS02:Downloading 41.63MiB
17:58:21:WU01:FS02:Download complete
17:58:21:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12426 run:0 clone:59 gen:648 core:0x22 unit:0x880200003b000000000000008a300000
17:58:21:WU01:FS02:Starting
17:58:21:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:58:21:WU01:FS02:Started FahCore on PID 6332
17:58:21:WU01:FS02:Core PID:9780
17:58:21:WU01:FS02:FahCore 0x22 started
17:58:21:WU01:FS02:0x22:*********************** Log Started 2024-06-09T17:58:21Z ***********************
17:58:21:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
17:58:21:WU01:FS02:0x22:       Core: Core22
17:58:22:WU01:FS02:0x22:       Type: 0x22
17:58:22:WU01:FS02:0x22:    Version: 0.0.20
17:58:22:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:58:22:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
17:58:22:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
17:58:22:WU01:FS02:0x22:       Date: Jan 20 2022
17:58:22:WU01:FS02:0x22:       Time: 01:15:36
17:58:22:WU01:FS02:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
17:58:22:WU01:FS02:0x22:     Branch: HEAD
17:58:22:WU01:FS02:0x22:   Compiler: Visual C++
17:58:22:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:58:22:WU01:FS02:0x22:             -DOPENMM_VERSION="\"7.7.0\""
17:58:22:WU01:FS02:0x22:   Platform: win32 10
17:58:22:WU01:FS02:0x22:       Bits: 64
17:58:22:WU01:FS02:0x22:       Mode: Release
17:58:22:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:58:22:WU01:FS02:0x22:             <peastman@stanford.edu>
17:58:22:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6332 -checkpoint 30
17:58:22:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:58:22:WU01:FS02:0x22:             nvidia -gpu 1 -gpu-usage 100
17:58:22:WU01:FS02:0x22:************************************ libFAH ************************************
17:58:22:WU01:FS02:0x22:       Time: 01:14:17
17:58:22:WU01:FS02:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
17:58:22:WU01:FS02:0x22:************************************ CBang *************************************
17:58:22:WU01:FS02:0x22:       Time: 01:13:20
17:58:22:WU01:FS02:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
17:58:22:WU01:FS02:0x22:************************************ System ************************************
17:58:22:WU01:FS02:0x22:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:58:22:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:58:22:WU01:FS02:0x22:       CPUs: 16
17:58:22:WU01:FS02:0x22:     Memory: 15.82GiB
17:58:22:WU01:FS02:0x22:Free Memory: 11.30GiB
17:58:22:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
17:58:22:WU01:FS02:0x22: OS Version: 6.2
17:58:22:WU01:FS02:0x22:Has Battery: false
17:58:22:WU01:FS02:0x22: On Battery: false
17:58:22:WU01:FS02:0x22: UTC Offset: -4
17:58:22:WU01:FS02:0x22:        PID: 9780
17:58:22:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
17:58:22:WU01:FS02:0x22:************************************ OpenMM ************************************
17:58:22:WU01:FS02:0x22:    Version: 7.7.0
17:58:22:WU01:FS02:0x22:********************************************************************************
17:58:22:WU01:FS02:0x22:Project: 12426 (Run 0, Clone 59, Gen 648)
17:58:22:WU01:FS02:0x22:Reading tar file core.xml
17:58:22:WU01:FS02:0x22:Reading tar file integrator.xml
17:58:22:WU01:FS02:0x22:Reading tar file state.xml
17:58:22:WU01:FS02:0x22:Reading tar file system.xml
17:58:22:WU01:FS02:0x22:Digital signatures verified
17:58:22:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
17:58:22:WU01:FS02:0x22:Version 0.0.20
17:58:22:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
17:58:22:WU01:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:58:22:WU01:FS02:0x22:  XTC frame write interval: 500000 steps (20%) [5 total]
17:58:22:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
17:58:22:WU01:FS02:0x22:There are 3 platforms available.
17:58:22:WU01:FS02:0x22:Platform 0: Reference
17:58:22:WU01:FS02:0x22:Platform 1: CPU
17:58:22:WU01:FS02:0x22:Platform 2: CUDA
17:58:22:WU01:FS02:0x22:  cuda-device 1 specified
17:58:22:WU01:FS02:0x22:opencl-device was set but OpenCL platform could not be found.
17:58:25:WU01:FS02:0x22:Attempting to create CUDA context:
17:58:25:WU01:FS02:0x22:  Configuring platform CUDA
17:58:25:WU01:FS02:0x22:Failed to create CUDA context:
17:58:25:WU01:FS02:0x22:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1640541834681\work\platforms\cuda\src\CudaContext.cpp:139
17:58:25:WU01:FS02:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:58:25:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
17:58:25:WU01:FS02:0x22:Saving result file science.log
17:58:25:WU01:FS02:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
17:58:26:WARNING:WU01:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:58:26:WU01:FS02:Sending unit results: id:01 state:SEND error:FAULTY project:12426 run:0 clone:59 gen:648 core:0x22 unit:0x880200003b000000000000008a300000
17:58:26:WU01:FS02:Uploading 11.00KiB to 129.32.209.202
17:58:26:WU01:FS02:Connecting to 129.32.209.202:8080
17:58:26:WU01:FS02:Upload complete
17:58:26:WU01:FS02:Server responded WORK_ACK (400)
17:58:26:WU01:FS02:Cleaning up
17:58:26:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:58:26:WU00:FS02:Assigned to work server 128.174.73.78
17:58:26:WU00:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 128.174.73.78
17:58:26:WU00:FS02:Connecting to 128.174.73.78:8080
17:58:30:WU00:FS02:Downloading 14.38MiB
17:58:30:WU00:FS02:Download complete
17:58:30:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17924 run:17 clone:122 gen:17 core:0x22 unit:0x110000007a0000001100000004460000
17:58:30:WU00:FS02:Starting
17:58:30:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:58:31:WU00:FS02:Started FahCore on PID 17900
17:58:31:WU00:FS02:Core PID:18312
17:58:31:WU00:FS02:FahCore 0x22 started
17:58:31:WU00:FS02:0x22:*********************** Log Started 2024-06-09T17:58:31Z ***********************
17:58:31:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
17:58:31:WU00:FS02:0x22:       Core: Core22
17:58:31:WU00:FS02:0x22:       Type: 0x22
17:58:31:WU00:FS02:0x22:    Version: 0.0.20
17:58:31:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:58:31:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
17:58:31:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
17:58:31:WU00:FS02:0x22:       Date: Jan 20 2022
17:58:31:WU00:FS02:0x22:       Time: 01:15:36
17:58:31:WU00:FS02:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
17:58:31:WU00:FS02:0x22:     Branch: HEAD
17:58:31:WU00:FS02:0x22:   Compiler: Visual C++
17:58:31:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:58:31:WU00:FS02:0x22:             -DOPENMM_VERSION="\"7.7.0\""
17:58:31:WU00:FS02:0x22:   Platform: win32 10
17:58:31:WU00:FS02:0x22:       Bits: 64
17:58:31:WU00:FS02:0x22:       Mode: Release
17:58:31:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:58:31:WU00:FS02:0x22:             <peastman@stanford.edu>
17:58:31:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17900 -checkpoint 30
17:58:31:WU00:FS02:0x22:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:58:31:WU00:FS02:0x22:             nvidia -gpu 1 -gpu-usage 100
17:58:31:WU00:FS02:0x22:************************************ libFAH ************************************
17:58:31:WU00:FS02:0x22:       Time: 01:14:17
17:58:31:WU00:FS02:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
17:58:31:WU00:FS02:0x22:************************************ CBang *************************************
17:58:31:WU00:FS02:0x22:       Time: 01:13:20
17:58:31:WU00:FS02:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
17:58:31:WU00:FS02:0x22:************************************ System ************************************
17:58:31:WU00:FS02:0x22:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:58:31:WU00:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:58:31:WU00:FS02:0x22:       CPUs: 16
17:58:31:WU00:FS02:0x22:     Memory: 15.82GiB
17:58:31:WU00:FS02:0x22:Free Memory: 11.33GiB
17:58:31:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
17:58:31:WU00:FS02:0x22: OS Version: 6.2
17:58:31:WU00:FS02:0x22:Has Battery: false
17:58:31:WU00:FS02:0x22: On Battery: false
17:58:31:WU00:FS02:0x22: UTC Offset: -4
17:58:31:WU00:FS02:0x22:        PID: 18312
17:58:31:WU00:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
17:58:31:WU00:FS02:0x22:************************************ OpenMM ************************************
17:58:31:WU00:FS02:0x22:    Version: 7.7.0
17:58:31:WU00:FS02:0x22:********************************************************************************
17:58:31:WU00:FS02:0x22:Project: 17924 (Run 17, Clone 122, Gen 17)
17:58:31:WU00:FS02:0x22:Reading tar file core.xml
17:58:31:WU00:FS02:0x22:Reading tar file integrator.xml
17:58:31:WU00:FS02:0x22:Reading tar file state.xml
17:58:31:WU00:FS02:0x22:Reading tar file system.xml
17:58:31:WU00:FS02:0x22:Digital signatures verified
17:58:31:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
17:58:31:WU00:FS02:0x22:Version 0.0.20
17:58:31:WU00:FS02:0x22:  Checkpoint write interval: 62500 steps (5%) [20 total]
17:58:31:WU00:FS02:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:58:31:WU00:FS02:0x22:  XTC frame write interval: 25000 steps (2%) [50 total]
17:58:31:WU00:FS02:0x22:  Global context and integrator variables write interval: disabled
17:58:31:WU00:FS02:0x22:There are 3 platforms available.
17:58:31:WU00:FS02:0x22:Platform 0: Reference
17:58:31:WU00:FS02:0x22:Platform 1: CPU
17:58:31:WU00:FS02:0x22:Platform 2: CUDA
17:58:31:WU00:FS02:0x22:  cuda-device 1 specified
17:58:31:WU00:FS02:0x22:opencl-device was set but OpenCL platform could not be found.
17:58:45:WARNING:WU00:FS02:FahCore returned an unknown error code which probably indicates that it crashed
17:58:45:WARNING:WU00:FS02:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
17:58:45:WU00:FS02:Starting
17:58:45:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:58:45:WU00:FS02:Started FahCore on PID 10024
17:58:45:WU00:FS02:Core PID:6340
17:58:45:WU00:FS02:FahCore 0x22 started
17:58:46:WU00:FS02:0x22:*********************** Log Started 2024-06-09T17:58:45Z ***********************
17:58:46:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
17:58:46:WU00:FS02:0x22:       Core: Core22
17:58:46:WU00:FS02:0x22:       Type: 0x22
17:58:46:WU00:FS02:0x22:    Version: 0.0.20
17:58:46:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:58:46:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
17:58:46:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
17:58:46:WU00:FS02:0x22:       Date: Jan 20 2022
17:58:46:WU00:FS02:0x22:       Time: 01:15:36
17:58:46:WU00:FS02:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
17:58:46:WU00:FS02:0x22:     Branch: HEAD
17:58:46:WU00:FS02:0x22:   Compiler: Visual C++
17:58:46:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:58:46:WU00:FS02:0x22:             -DOPENMM_VERSION="\"7.7.0\""
17:58:46:WU00:FS02:0x22:   Platform: win32 10
17:58:46:WU00:FS02:0x22:       Bits: 64
17:58:46:WU00:FS02:0x22:       Mode: Release
17:58:46:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:58:46:WU00:FS02:0x22:             <peastman@stanford.edu>
17:58:46:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10024 -checkpoint 30
17:58:46:WU00:FS02:0x22:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:58:46:WU00:FS02:0x22:             nvidia -gpu 1 -gpu-usage 100
17:58:46:WU00:FS02:0x22:************************************ libFAH ************************************
17:58:46:WU00:FS02:0x22:       Time: 01:14:17
17:58:46:WU00:FS02:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
17:58:46:WU00:FS02:0x22:************************************ CBang *************************************
17:58:46:WU00:FS02:0x22:       Time: 01:13:20
17:58:46:WU00:FS02:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
17:58:46:WU00:FS02:0x22:************************************ System ************************************
17:58:46:WU00:FS02:0x22:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:58:46:WU00:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:58:46:WU00:FS02:0x22:       CPUs: 16
17:58:46:WU00:FS02:0x22:     Memory: 15.82GiB
17:58:46:WU00:FS02:0x22:Free Memory: 11.10GiB
17:58:46:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
17:58:46:WU00:FS02:0x22: OS Version: 6.2
17:58:46:WU00:FS02:0x22:Has Battery: false
17:58:46:WU00:FS02:0x22: On Battery: false
17:58:46:WU00:FS02:0x22: UTC Offset: -4
17:58:46:WU00:FS02:0x22:        PID: 6340
17:58:46:WU00:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
17:58:46:WU00:FS02:0x22:************************************ OpenMM ************************************
17:58:46:WU00:FS02:0x22:    Version: 7.7.0
17:58:46:WU00:FS02:0x22:********************************************************************************
17:58:46:WU00:FS02:0x22:Project: 17924 (Run 17, Clone 122, Gen 17)
17:58:46:WU00:FS02:0x22:Digital signatures verified
17:58:46:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
17:58:46:WU00:FS02:0x22:Version 0.0.20
17:58:46:WU00:FS02:0x22:  Checkpoint write interval: 62500 steps (5%) [20 total]
17:58:46:WU00:FS02:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:58:46:WU00:FS02:0x22:  XTC frame write interval: 25000 steps (2%) [50 total]
17:58:46:WU00:FS02:0x22:  Global context and integrator variables write interval: disabled
17:58:46:WU00:FS02:0x22:There are 3 platforms available.
17:58:46:WU00:FS02:0x22:Platform 0: Reference
17:58:46:WU00:FS02:0x22:Platform 1: CPU
17:58:46:WU00:FS02:0x22:Platform 2: CUDA
17:58:46:WU00:FS02:0x22:  cuda-device 1 specified
17:58:46:WU00:FS02:0x22:opencl-device was set but OpenCL platform could not be found.
17:59:00:WU00:FS02:0x22:Attempting to create CUDA context:
17:59:00:WU00:FS02:0x22:  Configuring platform CUDA
17:59:00:WU00:FS02:0x22:Failed to create CUDA context:
17:59:00:WU00:FS02:0x22:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1640541834681\work\platforms\cuda\src\CudaContext.cpp:139
17:59:00:WU00:FS02:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:59:00:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
17:59:00:WU00:FS02:0x22:Saving result file science.log
17:59:00:WU00:FS02:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
17:59:01:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:59:01:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:17924 run:17 clone:122 gen:17 core:0x22 unit:0x110000007a0000001100000004460000
17:59:01:WU00:FS02:Uploading 2.57KiB to 128.174.73.78
17:59:01:WU00:FS02:Connecting to 128.174.73.78:8080
17:59:01:WU00:FS02:Upload complete
17:59:01:WU00:FS02:Server responded WORK_ACK (400)
17:59:01:WU00:FS02:Cleaning up
17:59:01:WU01:FS02:Connecting to assign1.foldingathome.org:80
17:59:02:WU01:FS02:Assigned to work server 128.174.73.78
17:59:02:WU01:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 128.174.73.78
17:59:02:WU01:FS02:Connecting to 128.174.73.78:8080
17:59:04:WU01:FS02:Downloading 9.57MiB
17:59:04:WU01:FS02:Download complete
17:59:04:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12921 run:17027 clone:0 gen:0 core:0x23 unit:0x00000000000000008342000079320000
17:59:04:WU01:FS02:Starting
17:59:04:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 01 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:59:04:WU01:FS02:Started FahCore on PID 9708
17:59:04:WU01:FS02:Core PID:2744
17:59:04:WU01:FS02:FahCore 0x23 started
17:59:05:WU01:FS02:0x23:*********************** Log Started 2024-06-09T17:59:04Z ***********************
17:59:05:WU01:FS02:0x23:*************************** Core23 Folding@home Core ***************************
17:59:05:WU01:FS02:0x23:       Core: Core23
17:59:05:WU01:FS02:0x23:       Type: 0x23
17:59:05:WU01:FS02:0x23:    Version: 8.0.3
17:59:05:WU01:FS02:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:59:05:WU01:FS02:0x23:  Copyright: 2022 foldingathome.org
17:59:05:WU01:FS02:0x23:   Homepage: https://foldingathome.org/
17:59:05:WU01:FS02:0x23:       Date: Aug 3 2023
17:59:05:WU01:FS02:0x23:       Time: 08:39:06
17:59:05:WU01:FS02:0x23:   Compiler: Visual C++
17:59:05:WU01:FS02:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:59:05:WU01:FS02:0x23:             -DOPENMM_VERSION="\"8.0.0\""
17:59:05:WU01:FS02:0x23:   Platform: win32 10
17:59:05:WU01:FS02:0x23:       Bits: 64
17:59:05:WU01:FS02:0x23:       Mode: Release
17:59:05:WU01:FS02:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:59:05:WU01:FS02:0x23:             <peastman@stanford.edu>
17:59:05:WU01:FS02:0x23:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9708 -checkpoint 30
17:59:05:WU01:FS02:0x23:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:59:05:WU01:FS02:0x23:             nvidia -gpu 1 -gpu-usage 100
17:59:05:WU01:FS02:0x23:************************************ libFAH ************************************
17:59:05:WU01:FS02:0x23:       Time: 08:37:55
17:59:05:WU01:FS02:0x23:************************************ CBang *************************************
17:59:05:WU01:FS02:0x23:    Version: 1.7.2
17:59:05:WU01:FS02:0x23:        Org: Cauldron Development LLC
17:59:05:WU01:FS02:0x23:  Copyright: Cauldron Development LLC, 2003-2023
17:59:05:WU01:FS02:0x23:   Homepage: https://cauldrondevelopment.com/
17:59:05:WU01:FS02:0x23:    License: GPL 2+
17:59:05:WU01:FS02:0x23:       Time: 08:37:14
17:59:05:WU01:FS02:0x23:************************************ System ************************************
17:59:05:WU01:FS02:0x23:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:59:05:WU01:FS02:0x23:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:59:05:WU01:FS02:0x23:       CPUs: 16
17:59:05:WU01:FS02:0x23:     Memory: 15.82GiB
17:59:05:WU01:FS02:0x23:Free Memory: 11.27GiB
17:59:05:WU01:FS02:0x23:    Threads: WINDOWS_THREADS
17:59:05:WU01:FS02:0x23: OS Version: 6.2
17:59:05:WU01:FS02:0x23:Has Battery: false
17:59:05:WU01:FS02:0x23: On Battery: false
17:59:05:WU01:FS02:0x23: UTC Offset: -4
17:59:05:WU01:FS02:0x23:        PID: 2744
17:59:05:WU01:FS02:0x23:        CWD: C:\ProgramData\FAHClient\work
17:59:05:WU01:FS02:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
17:59:05:WU01:FS02:0x23:************************************ OpenMM ************************************
17:59:05:WU01:FS02:0x23:    Version: 8.0.0
17:59:05:WU01:FS02:0x23:********************************************************************************
17:59:05:WU01:FS02:0x23:Project: 12921 (Run 17027, Clone 0, Gen 0)
17:59:05:WU01:FS02:0x23:Reading tar file core.xml
17:59:05:WU01:FS02:0x23:Reading tar file integrator.xml
17:59:05:WU01:FS02:0x23:Reading tar file state.xml
17:59:05:WU01:FS02:0x23:Reading tar file system.xml
17:59:05:WU01:FS02:0x23:Digital signatures verified
17:59:05:WU01:FS02:0x23:Folding@home GPU Core23 Folding@home Core
17:59:05:WU01:FS02:0x23:Version 8.0.3
17:59:05:WU01:FS02:0x23:  Checkpoint write interval: 125000 steps (5%) [20 total]
17:59:05:WU01:FS02:0x23:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:59:05:WU01:FS02:0x23:  XTC frame write interval: 50000 steps (2%) [50 total]
17:59:05:WU01:FS02:0x23:  Global context and integrator variables write interval: disabled
17:59:05:WU01:FS02:0x23:There are 3 platforms available.
17:59:05:WU01:FS02:0x23:Platform 0: Reference
17:59:05:WU01:FS02:0x23:Platform 1: CPU
17:59:05:WU01:FS02:0x23:Platform 2: CUDA
17:59:05:WU01:FS02:0x23:  cuda-device 1 specified
17:59:05:WU01:FS02:0x23:opencl-device was set but OpenCL platform could not be found.
17:59:11:WU01:FS02:0x23:Attempting to create CUDA context:
17:59:11:WU01:FS02:0x23:  Configuring platform CUDA
17:59:11:WU01:FS02:0x23:Failed to create CUDA context:
17:59:11:WU01:FS02:0x23:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1682502964893\work\platforms\cuda\src\CudaContext.cpp:140
17:59:11:WU01:FS02:0x23:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:59:11:WU01:FS02:0x23:Saving result file ..\logfile_01.txt
17:59:11:WU01:FS02:0x23:Saving result file science.log
17:59:11:WU01:FS02:0x23:Folding@home Core Shutdown: BAD_WORK_UNIT
17:59:11:WARNING:WU01:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:59:11:WU01:FS02:Sending unit results: id:01 state:SEND error:FAULTY project:12921 run:17027 clone:0 gen:0 core:0x23 unit:0x00000000000000008342000079320000
17:59:11:WU01:FS02:Uploading 2.52KiB to 128.174.73.78
17:59:11:WU01:FS02:Connecting to 128.174.73.78:8080
17:59:11:WU01:FS02:Upload complete
17:59:11:WU01:FS02:Server responded WORK_ACK (400)
17:59:11:WU01:FS02:Cleaning up
17:59:11:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:59:11:WU00:FS02:Assigned to work server 128.174.73.78
17:59:11:WU00:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 128.174.73.78
17:59:11:WU00:FS02:Connecting to 128.174.73.78:8080
17:59:14:WU00:FS02:Downloading 9.59MiB
17:59:14:WU00:FS02:Download complete
17:59:14:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:12921 run:17028 clone:0 gen:0 core:0x23 unit:0x00000000000000008442000079320000
17:59:14:WU00:FS02:Starting
17:59:14:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/openmm-core-23/windows-10-64bit/release/0x23-8.0.3/Core_23.fah/FahCore_23.exe -dir 00 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:59:15:WU00:FS02:Started FahCore on PID 4520
17:59:15:WU00:FS02:Core PID:1992
17:59:15:WU00:FS02:FahCore 0x23 started
17:59:15:WU00:FS02:0x23:*********************** Log Started 2024-06-09T17:59:15Z ***********************
17:59:15:WU00:FS02:0x23:*************************** Core23 Folding@home Core ***************************
17:59:15:WU00:FS02:0x23:       Core: Core23
17:59:15:WU00:FS02:0x23:       Type: 0x23
17:59:15:WU00:FS02:0x23:    Version: 8.0.3
17:59:15:WU00:FS02:0x23:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:59:15:WU00:FS02:0x23:  Copyright: 2022 foldingathome.org
17:59:15:WU00:FS02:0x23:   Homepage: https://foldingathome.org/
17:59:15:WU00:FS02:0x23:       Date: Aug 3 2023
17:59:15:WU00:FS02:0x23:       Time: 08:39:06
17:59:15:WU00:FS02:0x23:   Compiler: Visual C++
17:59:15:WU00:FS02:0x23:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:59:15:WU00:FS02:0x23:             -DOPENMM_VERSION="\"8.0.0\""
17:59:15:WU00:FS02:0x23:   Platform: win32 10
17:59:15:WU00:FS02:0x23:       Bits: 64
17:59:15:WU00:FS02:0x23:       Mode: Release
17:59:15:WU00:FS02:0x23:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:59:15:WU00:FS02:0x23:             <peastman@stanford.edu>
17:59:15:WU00:FS02:0x23:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4520 -checkpoint 30
17:59:15:WU00:FS02:0x23:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:59:15:WU00:FS02:0x23:             nvidia -gpu 1 -gpu-usage 100
17:59:15:WU00:FS02:0x23:************************************ libFAH ************************************
17:59:15:WU00:FS02:0x23:       Time: 08:37:55
17:59:15:WU00:FS02:0x23:************************************ CBang *************************************
17:59:15:WU00:FS02:0x23:    Version: 1.7.2
17:59:15:WU00:FS02:0x23:        Org: Cauldron Development LLC
17:59:15:WU00:FS02:0x23:  Copyright: Cauldron Development LLC, 2003-2023
17:59:15:WU00:FS02:0x23:   Homepage: https://cauldrondevelopment.com/
17:59:15:WU00:FS02:0x23:    License: GPL 2+
17:59:15:WU00:FS02:0x23:       Time: 08:37:14
17:59:15:WU00:FS02:0x23:************************************ System ************************************
17:59:15:WU00:FS02:0x23:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:59:15:WU00:FS02:0x23:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:59:15:WU00:FS02:0x23:       CPUs: 16
17:59:15:WU00:FS02:0x23:     Memory: 15.82GiB
17:59:15:WU00:FS02:0x23:Free Memory: 11.29GiB
17:59:15:WU00:FS02:0x23:    Threads: WINDOWS_THREADS
17:59:15:WU00:FS02:0x23: OS Version: 6.2
17:59:15:WU00:FS02:0x23:Has Battery: false
17:59:15:WU00:FS02:0x23: On Battery: false
17:59:15:WU00:FS02:0x23: UTC Offset: -4
17:59:15:WU00:FS02:0x23:        PID: 1992
17:59:15:WU00:FS02:0x23:        CWD: C:\ProgramData\FAHClient\work
17:59:15:WU00:FS02:0x23:       Exec: C:\ProgramData\FAHClient\cores\cores.foldingathome.org\openmm-core-23\windows-10-64bit\release\0x23-8.0.3\Core_23.fah\FahCore_23.exe
17:59:15:WU00:FS02:0x23:************************************ OpenMM ************************************
17:59:15:WU00:FS02:0x23:    Version: 8.0.0
17:59:15:WU00:FS02:0x23:********************************************************************************
17:59:15:WU00:FS02:0x23:Project: 12921 (Run 17028, Clone 0, Gen 0)
17:59:15:WU00:FS02:0x23:Reading tar file core.xml
17:59:15:WU00:FS02:0x23:Reading tar file integrator.xml
17:59:15:WU00:FS02:0x23:Reading tar file state.xml
17:59:15:WU00:FS02:0x23:Reading tar file system.xml
17:59:15:WU00:FS02:0x23:Digital signatures verified
17:59:15:WU00:FS02:0x23:Folding@home GPU Core23 Folding@home Core
17:59:15:WU00:FS02:0x23:Version 8.0.3
17:59:15:WU00:FS02:0x23:  Checkpoint write interval: 125000 steps (5%) [20 total]
17:59:15:WU00:FS02:0x23:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:59:15:WU00:FS02:0x23:  XTC frame write interval: 50000 steps (2%) [50 total]
17:59:15:WU00:FS02:0x23:  Global context and integrator variables write interval: disabled
17:59:15:WU00:FS02:0x23:There are 3 platforms available.
17:59:15:WU00:FS02:0x23:Platform 0: Reference
17:59:15:WU00:FS02:0x23:Platform 1: CPU
17:59:15:WU00:FS02:0x23:Platform 2: CUDA
17:59:15:WU00:FS02:0x23:  cuda-device 1 specified
17:59:15:WU00:FS02:0x23:opencl-device was set but OpenCL platform could not be found.
17:59:21:WU00:FS02:0x23:Attempting to create CUDA context:
17:59:21:WU00:FS02:0x23:  Configuring platform CUDA
17:59:21:WU00:FS02:0x23:Failed to create CUDA context:
17:59:21:WU00:FS02:0x23:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1682502964893\work\platforms\cuda\src\CudaContext.cpp:140
17:59:21:WU00:FS02:0x23:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:59:21:WU00:FS02:0x23:Saving result file ..\logfile_01.txt
17:59:21:WU00:FS02:0x23:Saving result file science.log
17:59:21:WU00:FS02:0x23:Folding@home Core Shutdown: BAD_WORK_UNIT
17:59:21:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:59:21:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:12921 run:17028 clone:0 gen:0 core:0x23 unit:0x00000000000000008442000079320000
17:59:21:WU00:FS02:Uploading 2.52KiB to 128.174.73.78
17:59:21:WU00:FS02:Connecting to 128.174.73.78:8080
17:59:21:WU00:FS02:Upload complete
17:59:22:WU00:FS02:Server responded WORK_ACK (400)
17:59:22:WU00:FS02:Cleaning up
17:59:22:WU00:FS02:Connecting to assign1.foldingathome.org:80
17:59:22:WU00:FS02:Assigned to work server 160.45.68.201
17:59:22:WU00:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 160.45.68.201
17:59:22:WU00:FS02:Connecting to 160.45.68.201:8080
17:59:23:WU00:FS02:Downloading 1.46MiB
17:59:23:WU00:FS02:Download complete
17:59:24:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:19600 run:1406 clone:0 gen:3423 core:0x22 unit:0x0000000000000d5f00004c900000057e
17:59:24:WU00:FS02:Starting
17:59:24:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 21056 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
17:59:24:WU00:FS02:Started FahCore on PID 5828
17:59:24:WU00:FS02:Core PID:2984
17:59:24:WU00:FS02:FahCore 0x22 started
17:59:24:WU00:FS02:0x22:*********************** Log Started 2024-06-09T17:59:24Z ***********************
17:59:24:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
17:59:24:WU00:FS02:0x22:       Core: Core22
17:59:24:WU00:FS02:0x22:       Type: 0x22
17:59:24:WU00:FS02:0x22:    Version: 0.0.20
17:59:24:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:59:24:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
17:59:24:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
17:59:24:WU00:FS02:0x22:       Date: Jan 20 2022
17:59:24:WU00:FS02:0x22:       Time: 01:15:36
17:59:24:WU00:FS02:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
17:59:24:WU00:FS02:0x22:     Branch: HEAD
17:59:24:WU00:FS02:0x22:   Compiler: Visual C++
17:59:24:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:59:24:WU00:FS02:0x22:             -DOPENMM_VERSION="\"7.7.0\""
17:59:24:WU00:FS02:0x22:   Platform: win32 10
17:59:24:WU00:FS02:0x22:       Bits: 64
17:59:24:WU00:FS02:0x22:       Mode: Release
17:59:24:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:59:24:WU00:FS02:0x22:             <peastman@stanford.edu>
17:59:24:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5828 -checkpoint 30
17:59:24:WU00:FS02:0x22:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
17:59:24:WU00:FS02:0x22:             nvidia -gpu 1 -gpu-usage 100
17:59:24:WU00:FS02:0x22:************************************ libFAH ************************************
17:59:24:WU00:FS02:0x22:       Time: 01:14:17
17:59:24:WU00:FS02:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
17:59:24:WU00:FS02:0x22:************************************ CBang *************************************
17:59:24:WU00:FS02:0x22:       Time: 01:13:20
17:59:24:WU00:FS02:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
17:59:24:WU00:FS02:0x22:************************************ System ************************************
17:59:24:WU00:FS02:0x22:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
17:59:24:WU00:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:59:24:WU00:FS02:0x22:       CPUs: 16
17:59:24:WU00:FS02:0x22:     Memory: 15.82GiB
17:59:24:WU00:FS02:0x22:Free Memory: 11.32GiB
17:59:24:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
17:59:24:WU00:FS02:0x22: OS Version: 6.2
17:59:24:WU00:FS02:0x22:Has Battery: false
17:59:24:WU00:FS02:0x22: On Battery: false
17:59:24:WU00:FS02:0x22: UTC Offset: -4
17:59:24:WU00:FS02:0x22:        PID: 2984
17:59:24:WU00:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
17:59:24:WU00:FS02:0x22:************************************ OpenMM ************************************
17:59:24:WU00:FS02:0x22:    Version: 7.7.0
17:59:24:WU00:FS02:0x22:********************************************************************************
17:59:24:WU00:FS02:0x22:Project: 19600 (Run 1406, Clone 0, Gen 3423)
17:59:24:WU00:FS02:0x22:Reading tar file core.xml
17:59:24:WU00:FS02:0x22:Reading tar file integrator.xml
17:59:24:WU00:FS02:0x22:Reading tar file state.xml.bz2
17:59:24:WU00:FS02:0x22:Reading tar file system.xml.bz2
17:59:24:WU00:FS02:0x22:Digital signatures verified
17:59:24:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
17:59:24:WU00:FS02:0x22:Version 0.0.20
17:59:24:WU00:FS02:0x22:  Checkpoint write interval: 120000 steps (4%) [25 total]
17:59:24:WU00:FS02:0x22:  JSON viewer frame write interval: 30000 steps (1%) [100 total]
17:59:24:WU00:FS02:0x22:  XTC frame write interval: 12500 steps (0.42%) [240 total]
17:59:24:WU00:FS02:0x22:  Global context and integrator variables write interval: disabled
17:59:24:WU00:FS02:0x22:There are 3 platforms available.
17:59:24:WU00:FS02:0x22:Platform 0: Reference
17:59:24:WU00:FS02:0x22:Platform 1: CPU
17:59:24:WU00:FS02:0x22:Platform 2: CUDA
17:59:24:WU00:FS02:0x22:  cuda-device 1 specified
17:59:24:WU00:FS02:0x22:opencl-device was set but OpenCL platform could not be found.
17:59:25:WU00:FS02:0x22:Attempting to create CUDA context:
17:59:25:WU00:FS02:0x22:  Configuring platform CUDA
17:59:25:WU00:FS02:0x22:Failed to create CUDA context:
17:59:25:WU00:FS02:0x22:Error initializing CUDA: CUDA_ERROR_INVALID_VALUE (1) at D:\bld\openmm_1640541834681\work\platforms\cuda\src\CudaContext.cpp:139
17:59:25:WU00:FS02:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:59:25:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
17:59:25:WU00:FS02:0x22:Saving result file science.log
17:59:25:WU00:FS02:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
17:59:25:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:59:25:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:19600 run:1406 clone:0 gen:3423 core:0x22 unit:0x0000000000000d5f00004c900000057e
17:59:25:WU00:FS02:Uploading 11.00KiB to 160.45.68.201
17:59:25:WU00:FS02:Connecting to 160.45.68.201:8080
17:59:25:WU01:FS02:Connecting to assign1.foldingathome.org:80
...cogito ergo complicare
Re: A little help, please...
If you could also provide the first 200 lines of the log file which show the hardware and software configuration, that would be useful. Which version of the GPU drivers do you have installed and is it directly downloaded from Nvidia (usually good) or through MS Windows Update (usually not good)?
tcphillips
You betcha...
PS - temps all show <100C, more in the range of 85C - 90C.
Tom
*********************** Log Started 2024-06-09T21:21:08Z ***********************
21:21:08:******************************* libFAH ********************************
21:21:08:           Date: Oct 20 2020
21:21:08:           Time: 13:36:55
21:21:08:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
21:21:08:         Branch: master
21:21:08:       Compiler: Visual C++ 2015
21:21:08:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:21:08:       Platform: win32 10
21:21:08:           Bits: 32
21:21:08:           Mode: Release
21:21:08:****************************** FAHClient ******************************
21:21:08:        Version: 7.6.21
21:21:08:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:21:08:      Copyright: 2020 foldingathome.org
21:21:08:       Homepage: https://foldingathome.org/
21:21:08:           Time: 13:41:04
21:21:08:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
21:21:08:           Bits: 32
21:21:08:         Config: C:\ProgramData\FAHClient\config.xml
21:21:08:******************************** CBang ********************************
21:21:08:           Time: 11:36:18
21:21:08:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
21:21:08:           Bits: 32
21:21:08:******************************* System ********************************
21:21:08:            CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
21:21:08:         CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
21:21:08:           CPUs: 16
21:21:08:         Memory: 15.82GiB
21:21:08:    Free Memory: 10.59GiB
21:21:08:        Threads: WINDOWS_THREADS
21:21:08:     OS Version: 6.2
21:21:08:    Has Battery: false
21:21:08:     On Battery: false
21:21:08:     UTC Offset: -4
21:21:08:            PID: 14816
21:21:08:            CWD: C:\ProgramData\FAHClient
21:21:08:  Win32 Service: false
21:21:08:             OS: Windows 10 Home
21:21:08:        OS Arch: AMD64
21:21:08:           GPUs: 2
21:21:08:          GPU 0: Bus:4 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
21:21:08:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:8 GA104 [GeForce RTX 3070 Lite Hash
21:21:08:                 Rate]
21:21:08:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:12.5
21:21:08:  CUDA Device 1: Platform:0 Device:1 Bus:4 Slot:0 Compute:6.1 Driver:12.5
21:21:08:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:555.99
21:21:08:OpenCL Device 1: Platform:0 Device:1 Bus:4 Slot:0 Compute:3.0 Driver:555.99
21:21:08:***********************************************************************
21:21:09:<config>
21:21:09:  <!-- Folding Core -->
21:21:09:  <checkpoint v='30'/>
21:21:09:
21:21:09:  <!-- Network -->
21:21:09:  <proxy v=':8080'/>
21:21:09:
21:21:09:  <!-- Slot Control -->
21:21:09:  <power v='FULL'/>
21:21:09:
21:21:09:  <!-- User Information -->
21:21:09:  <passkey v='*****'/>
21:21:09:  <team v='1287'/>
21:21:09:  <user v='thomas.c.phillips@eaglerivergroup.net'/>
21:21:09:
21:21:09:  <!-- Folding Slots -->
21:21:09:  <slot id='1' type='GPU'>
21:21:09:    <pci-bus v='1'/>
21:21:09:    <pci-slot v='0'/>
21:21:09:  </slot>
21:21:09:  <slot id='2' type='GPU'>
21:21:09:    <pci-bus v='4'/>
21:21:09:  </slot>
21:21:09:</config>
21:21:09:Trying to access database...
21:21:09:Successfully acquired database lock
21:21:09:FS01:Initialized folding slot 01: gpu:1:0 GA104 [GeForce RTX 3070 Lite Hash Rate]
21:21:09:FS02:Initialized folding slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463
21:21:09:WU00:FS01:Connecting to assign1.foldingathome.org:80
21:21:09:WU01:FS02:Connecting to assign1.foldingathome.org:80
21:21:10:WU01:FS02:Assigned to work server 128.174.73.78
21:21:10:WU01:FS02:Requesting new work unit for slot 02: gpu:4:0 GP104 [GeForce GTX 1070] 6463 from 128.174.73.78
21:21:10:WU01:FS02:Connecting to 128.174.73.78:8080
21:21:10:WU00:FS01:Assigned to work server 128.174.73.78
21:21:10:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070 Lite Hash Rate] from 128.174.73.78
21:21:10:WU00:FS01:Connecting to 128.174.73.78:8080
21:21:11:WU01:FS02:Downloading 2.86MiB
21:21:11:WU01:FS02:Download complete
21:21:12:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:12912 run:674 clone:0 gen:184 core:0x22 unit:0xb800000000000000a202000070320000
21:21:12:WU01:FS02:Starting
21:21:12:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 14816 -checkpoint 30 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
21:21:12:WU01:FS02:Started FahCore on PID 3076
21:21:12:WU01:FS02:Core PID:3280
21:21:12:WU01:FS02:FahCore 0x22 started
21:21:12:WU01:FS02:0x22:*********************** Log Started 2024-06-09T21:21:12Z ***********************
21:21:12:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
21:21:12:WU01:FS02:0x22:       Core: Core22
21:21:12:WU01:FS02:0x22:       Type: 0x22
21:21:12:WU01:FS02:0x22:    Version: 0.0.20
21:21:12:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:21:12:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
21:21:12:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
21:21:12:WU01:FS02:0x22:       Date: Jan 20 2022
21:21:12:WU01:FS02:0x22:       Time: 01:15:36
21:21:12:WU01:FS02:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:21:12:WU01:FS02:0x22:     Branch: HEAD
21:21:12:WU01:FS02:0x22:   Compiler: Visual C++
21:21:12:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:21:12:WU01:FS02:0x22:             -DOPENMM_VERSION="\"7.7.0\""
21:21:12:WU01:FS02:0x22:   Platform: win32 10
21:21:12:WU01:FS02:0x22:       Bits: 64
21:21:12:WU01:FS02:0x22:       Mode: Release
21:21:12:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:21:12:WU01:FS02:0x22:             <peastman@stanford.edu>
21:21:12:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3076 -checkpoint 30
21:21:12:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
21:21:12:WU01:FS02:0x22:             nvidia -gpu 1 -gpu-usage 100
21:21:12:WU01:FS02:0x22:************************************ libFAH ************************************
21:21:12:WU01:FS02:0x22:       Time: 01:14:17
21:21:12:WU01:FS02:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:21:12:WU01:FS02:0x22:************************************ CBang *************************************
21:21:12:WU01:FS02:0x22:       Time: 01:13:20
21:21:12:WU01:FS02:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:21:12:WU01:FS02:0x22:************************************ System ************************************
21:21:12:WU01:FS02:0x22:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
21:21:12:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
21:21:12:WU01:FS02:0x22:       CPUs: 16
21:21:12:WU01:FS02:0x22:     Memory: 15.82GiB
21:21:12:WU01:FS02:0x22:Free Memory: 10.57GiB
21:21:12:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
21:21:12:WU01:FS02:0x22: OS Version: 6.2
21:21:12:WU01:FS02:0x22:Has Battery: false
21:21:12:WU01:FS02:0x22: On Battery: false
21:21:12:WU01:FS02:0x22: UTC Offset: -4
21:21:12:WU01:FS02:0x22:        PID: 3280
21:21:12:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
21:21:12:WU01:FS02:0x22:************************************ OpenMM ************************************
21:21:12:WU01:FS02:0x22:    Version: 7.7.0
21:21:12:WU01:FS02:0x22:********************************************************************************
21:21:12:WU01:FS02:0x22:Project: 12912 (Run 674, Clone 0, Gen 184)
21:21:12:WU01:FS02:0x22:Reading tar file core.xml
21:21:12:WU01:FS02:0x22:Reading tar file integrator.xml
21:21:12:WU01:FS02:0x22:Reading tar file state.xml
21:21:12:WU01:FS02:0x22:Reading tar file system.xml
21:21:12:WU01:FS02:0x22:Digital signatures verified
21:21:12:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
21:21:12:WU01:FS02:0x22:Version 0.0.20
21:21:12:WU01:FS02:0x22:  Checkpoint write interval: 500000 steps (5%) [20 total]
21:21:12:WU01:FS02:0x22:  JSON viewer frame write interval: 100000 steps (1%) [100 total]
21:21:12:WU01:FS02:0x22:  XTC frame write interval: 50000 steps (0.5%) [200 total]
21:21:12:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
21:21:12:WU01:FS02:0x22:There are 4 platforms available.
21:21:12:WU01:FS02:0x22:Platform 0: Reference
21:21:12:WU01:FS02:0x22:Platform 1: CPU
21:21:12:WU01:FS02:0x22:Platform 2: OpenCL
21:21:12:WU01:FS02:0x22:  opencl-device 1 specified
21:21:12:WU01:FS02:0x22:Platform 3: CUDA
21:21:12:WU01:FS02:0x22:  cuda-device 1 specified
21:21:13:WU01:FS02:0x22:Attempting to create CUDA context:
21:21:13:WU01:FS02:0x22:  Configuring platform CUDA
21:21:13:WU00:FS01:Downloading 14.37MiB
21:21:14:WU00:FS01:Download complete
21:21:14:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17924 run:17 clone:103 gen:17 core:0x22 unit:0x11000000670000001100000004460000
21:21:14:WU00:FS01:Starting
21:21:14:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 14816 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:21:14:WU00:FS01:Started FahCore on PID 1656
21:21:15:WU00:FS01:Core PID:4772
21:21:15:WU00:FS01:FahCore 0x22 started
21:21:15:WU00:FS01:0x22:*********************** Log Started 2024-06-09T21:21:15Z ***********************
21:21:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:21:15:WU00:FS01:0x22:       Core: Core22
21:21:15:WU00:FS01:0x22:       Type: 0x22
21:21:15:WU00:FS01:0x22:    Version: 0.0.20
21:21:15:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:21:15:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
21:21:15:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
21:21:15:WU00:FS01:0x22:       Date: Jan 20 2022
21:21:15:WU00:FS01:0x22:       Time: 01:15:36
21:21:15:WU00:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
21:21:15:WU00:FS01:0x22:     Branch: HEAD
21:21:15:WU00:FS01:0x22:   Compiler: Visual C++
21:21:15:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:21:15:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
21:21:15:WU00:FS01:0x22:   Platform: win32 10
21:21:15:WU00:FS01:0x22:       Bits: 64
21:21:15:WU00:FS01:0x22:       Mode: Release
21:21:15:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:21:15:WU00:FS01:0x22:             <peastman@stanford.edu>
21:21:15:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1656 -checkpoint 30
21:21:15:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:21:15:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
21:21:15:WU00:FS01:0x22:************************************ libFAH ************************************
21:21:15:WU00:FS01:0x22:       Time: 01:14:17
21:21:15:WU00:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
21:21:15:WU00:FS01:0x22:************************************ CBang *************************************
21:21:15:WU00:FS01:0x22:       Time: 01:13:20
21:21:15:WU00:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
21:21:15:WU00:FS01:0x22:************************************ System ************************************
21:21:15:WU00:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i5-12600KF
21:21:15:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
21:21:15:WU00:FS01:0x22:       CPUs: 16
21:21:15:WU00:FS01:0x22:     Memory: 15.82GiB
21:21:15:WU00:FS01:0x22:Free Memory: 10.35GiB
21:21:15:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:21:15:WU00:FS01:0x22: OS Version: 6.2
21:21:15:WU00:FS01:0x22:Has Battery: false
21:21:15:WU00:FS01:0x22: On Battery: false
21:21:15:WU00:FS01:0x22: UTC Offset: -4
21:21:15:WU00:FS01:0x22:        PID: 4772
21:21:15:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
21:21:15:WU00:FS01:0x22:************************************ OpenMM ************************************
21:21:15:WU00:FS01:0x22:    Version: 7.7.0
21:21:15:WU00:FS01:0x22:********************************************************************************
21:21:15:WU00:FS01:0x22:Project: 17924 (Run 17, Clone 103, Gen 17)
21:21:15:WU00:FS01:0x22:Reading tar file core.xml
21:21:15:WU00:FS01:0x22:Reading tar file integrator.xml
21:21:15:WU00:FS01:0x22:Reading tar file state.xml
21:21:15:WU00:FS01:0x22:Reading tar file system.xml
21:21:15:WU00:FS01:0x22:Digital signatures verified
21:21:15:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:21:15:WU00:FS01:0x22:Version 0.0.20
21:21:15:WU00:FS01:0x22:  Checkpoint write interval: 62500 steps (5%) [20 total]
21:21:15:WU00:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
21:21:15:WU00:FS01:0x22:  XTC frame write interval: 25000 steps (2%) [50 total]
21:21:15:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
21:21:15:WU00:FS01:0x22:There are 4 platforms available.
21:21:15:WU00:FS01:0x22:Platform 0: Reference
21:21:15:WU00:FS01:0x22:Platform 1: CPU
21:21:15:WU00:FS01:0x22:Platform 2: OpenCL
21:21:15:WU00:FS01:0x22:  opencl-device 0 specified
21:21:15:WU00:FS01:0x22:Platform 3: CUDA
21:21:15:WU00:FS01:0x22:  cuda-device 0 specified
21:21:16:WU01:FS02:0x22:  Using CUDA and gpu 1
21:21:16:WU01:FS02:0x22:Completed 0 out of 10000000 steps (0%)
21:21:17:WU01:FS02:0x22:Checkpoint completed at step 0
21:21:29:WU00:FS01:0x22:Attempting to create CUDA context:
21:21:29:WU00:FS01:0x22:  Configuring platform CUDA
21:21:33:WU00:FS01:0x22:  Using CUDA and gpu 0
21:21:33:WU00:FS01:0x22:Completed 0 out of 1250000 steps (0%)
21:21:34:WU00:FS01:0x22:Checkpoint completed at step 0
21:22:04:WU00:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
21:22:37:WU00:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
21:23:10:WU00:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
21:23:24:WU01:FS02:0x22:Completed 100000 out of 10000000 steps (1%)
21:23:44:WU00:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
21:24:20:WU00:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
21:24:22:WU00:FS01:0x22:Checkpoint completed at step 62500
21:24:58:WU00:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
21:25:34:WU00:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
21:25:34:WU01:FS02:0x22:Completed 200000 out of 10000000 steps (2%)
21:26:10:WU00:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
21:26:47:WU00:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
21:27:25:WU00:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
21:27:28:WU00:FS01:0x22:Checkpoint completed at step 125000
21:27:46:WU01:FS02:0x22:Completed 300000 out of 10000000 steps (3%)
21:28:05:WU00:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
21:28:44:WU00:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
21:29:22:WU00:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
21:29:57:WU01:FS02:0x22:Completed 400000 out of 10000000 steps (4%)
21:30:01:WU00:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
21:30:44:WU00:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
21:30:48:WU00:FS01:0x22:Checkpoint completed at step 187500
21:31:29:WU00:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
21:32:10:WU00:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
21:32:23:WU01:FS02:0x22:Completed 500000 out of 10000000 steps (5%)
21:32:24:WU01:FS02:0x22:Checkpoint completed at step 500000
21:32:52:WU00:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
21:33:32:WU00:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
21:34:13:WU00:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
21:34:16:WU00:FS01:0x22:Checkpoint completed at step 250000
21:34:44:WU01:FS02:0x22:Completed 600000 out of 10000000 steps (6%)
21:34:56:WU00:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
21:35:37:WU00:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
21:36:17:WU00:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
21:36:58:WU00:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
21:37:00:WU01:FS02:0x22:Completed 700000 out of 10000000 steps (7%)
21:37:39:WU00:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
21:37:43:WU00:FS01:0x22:Checkpoint completed at step 312500
21:38:23:WU00:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
21:39:04:WU00:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
21:39:20:WU01:FS02:0x22:Completed 800000 out of 10000000 steps (8%)
21:39:45:WU00:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
21:40:26:WU00:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
21:41:07:WU00:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
21:41:10:WU00:FS01:0x22:Checkpoint completed at step 375000
tcphillips
Hardware configuration: [img]http://folding.extremeoverclocking.com/sigs/sigimage.php?u=296154[/img]
Post by tcphillips »
PPS -- Drivers -- all off the NVIDIA site (always). I think it's 555.xx which is current.
--Tom
tcphillips
Re: A little help, please...Resolved...(perhaps)
OK, so you know how you never take a car in for servicing until after you get a car wash...? Wellllll...
Dis-assembled the PC, blew out everything thoroughly.
Re-loaded the NVIDIA drivers v. 599.xx, new download, then clean, complete, from-scratch reload.
Coincidentally, Microsoft downloaded an update about the same time.
Lit 'er back up, and seems to be folding away merrily.
Problem solved...(?)
We shall see.
--Tom
kiore
Post by kiore »
Yesterday I had issues with a normally reliable system that a reboot didn't fix but a update and reboot did, I wonder which thing you changed was the solution.
tcphillips
"...I wonder which thing you changed was the solution?..."
Indeed. It's not clear, or indeed was it a combo of things changed?
And the beast has blown off once (both cards "Failed" (Win 11 (current updates) one 1070 and one 3070 (NVIDIA drivers 599.99 - current))) since the general housekeeping and updates (See messages and log files above.)
Temps remain within decent ranges and my schedule of sacrificing chickens to the PC gods is up to date.
So let's just call it watchful waiting and see if things behave.
--Tom
tcphillips
PS -- I have minimal empirical evidence, but I'm wondering if the problem noted by jchang6 (above, link below) is related.
viewtopic.php?t=41564
--T
tcphillips
...so after a couple more times with one or both GPUs "Failed," I scuttled the current NVIDIA driver 555.99 and re-installed a much older driver 472.12 (It was the only one I could find) and after 36 hours, things are folding along quite nicely.
What prompted me to do that? It was about the only testable variable remaining other than beginning to test for "bad hardware."
What was the problem? No idea.
Watchful waiting continues.
--T
tcphillips
Re: A little help, please...(resolved)
The re-install of an older NVIDIA driver seems to have done the trick...
We're over 96 hours with no hiccups in operation, so we'll call this one "resolved."
What was wrong with the driver/hardware combo? No idea.
Why did a previous version of the driver work, and a newer version not work? No idea.
Moral of the story? Sorry, I don't have one, other than to be a little more judicious about my video driver updates.
--Tom
