Current Beta Release - v8.3.17
Locked
A new Beta release is available v8.3.17 - https://foldingathome.org/beta
Bug reports for the client - https://github.com/FoldingAtHome/fah-cl ... tet/issues
Bug reports for the web control - https://github.com/FoldingAtHome/fah-we ... tet/issues
v8.3 Installation Guide - https://foldingathome.org/v8-3-client-guide/
Change log since previous Beta release:
## v8.3.17
- Fixes for account (un)linking and node changes.
- Fix for repeated "No active" exception.
## v8.3.16
- Fix Linux battery detection. #240
## v8.3.15
- Fix crash caused by failed DNS server. #235
- Improved Linux battery detection. #240
## v8.3.14
- Fix Windows crash. #235
## v8.3.13
- Fix for log updates to Web Control.
## v8.3.12
- Fix Windows and macOS crashing.
- Removed PDB file from Windows release mode installer.
## v8.3.11
- Use LogTracker to follow log instead of reading back files.
- Fixed core log following on macOS. #234
- Fix Windows log rotation. #233
## v8.3.10
- Logging bug fixes.
## v8.3.9
- Fixed ``'wu' not found`` error. #231, #232
- Other bug fixes.
## v8.3.7
- Better DNS error handling and support for IPv6 name servers
## v8.3.6
- Generate new client ID if machine ID has changed. #216
- Rewrite of domain name lookup code. #223
Locked
