I've copied the extract from the logfile here:-
[10:19:46] Project: 2665 (Run 1, Clone 187, Gen 33)
[10:19:46]
[10:19:47] Assembly optimizations on if available.
[10:19:47] Entering M.D.
[10:20:09] al work pa- Starting from initial work packet
[10:20:09]
[10:20:09] Project: 2665 (Run 1, Clone 187, Gen 33)
[10:20:09]
[10:20:10] Entering M.D.
[10:20:22] Protein: IBX in water
[10:20:22] Writing local files
[10:20:23] Extra SSE boost OK.
[10:28:31] t triggered.
[10:36:16] Writing local files
[10:36:16] Completed 2500 out of 250000 steps (1 percent)
[15:48:58] Completed 250000 out of 250000 steps (100 percent)
[15:48:58] Writing final coordinates.
[15:48:59] Past main M.D. loop
[15:48:59] Will end MPI now
[15:49:59]
[15:49:59] Finished Work Unit:
[15:49:59] - Reading up to 21193200 from "work/wudata_05.arc": Read 21193200
[15:49:59] - Reading up to 526864 from "work/wudata_05.xtc": Read 526864
[15:49:59] goefile size: 0
[15:49:59] logfile size: 212432
[15:50:00] Leaving Run
[15:50:04] - Writing 21938868 bytes of core data to disk...
[15:50:04] ... Done.
[15:50:04] - Failed to delete work/wudata_05.sas
[15:50:04] - Failed to delete work/wudata_05.goe
[15:50:04] Warning: check for stray files
[15:50:04] - Shutting down core
[15:52:04]
[15:52:04] Folding@home Core Shutdown: FINISHED_UNIT
[15:52:04]
[15:52:08] CoreStatus = 64 (100)
[15:52:08] Unit 5 finished with 79 percent of time to deadline remaining.
[15:52:08] Updated performance fraction: 0.815255
[15:52:08] Sending work to server
[15:52:08] + Attempting to send results
[15:52:08] - Reading file work/wuresults_05.dat from core
[15:52:08] (Read 21938868 bytes from disk)
[15:52:08] Connecting to
http://171.64.65.64:8080/
[15:58:11] Initial: 0000; - Uploaded at ~58 kB/s
[15:58:12] - Averaged speed for that direction ~58 kB/s
[15:58:12] + Results successfully sent
[15:58:12] Thank you for your contribution to Folding@Home.
[15:58:12] + Number of Units Completed: 12
Cheers!
Mark
