eGPU and folding
ilpostino
eGPU and folding
Post by ilpostino »
I hope I am posting this is the right part of the forum.
I recently bought a Blackmagic eGPU pro that I have installed and used on my Surface pro with windows 11. Is it possible to use the eGPU for folding when I am not using the Surface pro?
Re: eGPU and folding
Post by muziqaz »
Yes, as long as everything is recognised as actual GPU
FAH Omega tester
arisu
Post by arisu »
Just be aware that the lower bandwidth of the Thunderbolt connection to the eGPU can limit folding performance (it claim 40 Gb/s, but the PCIe connection of a dedicated GPU is >100 Gb/s). It won't decrease efficiency, but it can decrease maximum utilization of the card.
ilpostino
Post by ilpostino »
muziqaz wrote: Sat Jun 29, 2024 1:43 pm Yes, as long as everything is recognised as actual GPU
I finally ot around to test ut out on my Surface pro. It is recognised by the computer, and the latest AMD Adrelanin is installed. But it is greyed out in the web application.
See image on this link: https://1drv.ms/i/s!Ala2aiXqBOeetbQ1l7E ... w?e=F5K3HT
Post by muziqaz »
go to adrenalin control panel, click on the cog in right top corner, expand Software & Driver Details on the right hand side. See what it says about various API support
FAH Omega tester
