Onboard GPU 19:0 Raphael [Ryzen 7000]
This adds little to my computing but seems to be source of over heating on my motherboard.
How to I prevent this from folding without shutting off all GPUs?
Stress testing of the CPU alone stays in the Mid 60sC but Folding with the onboard GPU runs at 90C.
Want to keep the AMD Radeon RX 7700 XT folding, fast and running at reasonable temperatures.
Thanks
How to turn off onboard GPU
OstermanDS
- Hardware configuration: CPU AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor Base
CPU Cooler Noctua NH-D15 82.5 CFM CPU Cooler Base
Motherboard MSI MAG B650M MORTAR WIFI Micro ATX AM5 Motherboard Base
Memory G.Skill Ripjaws S5 48 GB (2 x 24 GB) DDR5-6400 CL32 Memory Base
Storage 2X Kingston NV2 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive Base
Storage Western Digital 14TB WD Red Pro NAS Internal Hard Drive HDD - 7200 RPM
Video Card Sapphire PULSE Radeon RX 7700 XT 12 GB Video Card Base
Case Fractal Design Meshify 2 Mini MicroATX Mid Tower Case Base
Power Supply SeaSonic FOCUS Plus Platinum 750 W 80+ Platinum Certified
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: How to turn off onboard GPU
Which version of the folding client do you use? If you use 7.6.xx then you can easily set it to keep that slot paused unless you unpause it manually.
Worst case you can disable it in the bios, but settings vary motherboard to motherboard.
Fold them if you get them!
It's always better to disable iGPUs in the BIOS whenever it's possible.
As toTow mentioned, please disable iGPU in the BIOS
