HELP!
andorjkiss
HELP!
Post by andorjkiss »
FAH doesn't seem to work at all. I installed in on Ubuntu 22.04 and the FAHControl GUI keeps flashing from Updating to Connecting. Everything else is greyed out.
Please help, there are no instructions.
bollix47
Re: HELP!
Post by bollix47 »
There are currently two versions of FAHClient: 7.6.21 & 8.3.5 .... which one did you install?
After installing did you reboot?
If you are using GPU did you go to Software & Updates > Additional Drivers and install the tested drivers?
Check the following thread for hints on how to ask for help:
viewtopic.php?p=261076#p261076
andorjkiss
Re: HELP!
The Ubuntu SNAP store installs 7.6.21
No, rebooting now.
Using GPU - where is "Software & Updates > Additional Drivers"
The machine has the latest 555 drivers for NVIDIA and CUDA 12.5; installed and runs.
andorjkiss
Re: HELP!
Nope, same behaviour.
bollix47
Re: HELP!
Post by bollix47 »
Post your log.txt file from the fah directory .... it should be at /var/lib/fahclient/log.txt use the code tags offered in Full Editor
To get to software & updates > Additional Drivers click on the 9 dot menu .... on my setup it's on the bottom left of the screen
bollix47
Re: HELP!
Post by bollix47 »
Also, if you didn't tell folding to automatically start then you may have to start the fahclient service manually .... try:
sudo service fahclient start
andorjkiss
Re: HELP!
I can't install the FAHControl DEB; doesn't work with Python3.
Uninstalling. Buggy project. Not recommended.
