Web control can use some touch up.
Sandman192
Post by Sandman192 »
Can we do with out the Bus: Device: in Web Control. Hard to tell what GPU in the tabs. Exp: GPU:1:0 GPU102 [GEF and that's it.
And just have it say GPU 0 NVIDIA (1080Ti) - GPU 1 NVIDIA (980), APU 3x (AMD) CPU AMD (Ryzen 7 7700X). Somethin along those lines if you can make it shooter would be ok.
So much of it is cut off and how about widening the page. Even at 4K there's so much of the screen is not used from right to left and gets cut off at the bottom.
The Advance Controls shows all the details.
F@H v7.6.21
Re: Web control can use some touch up.
Work on the v7 client is done, all development work is going towards the v8 client. You can try out the public beta of v8.3.5 - https://foldingathome.org/beta/. It only has a web based control, no FAHControl.
Post by calxalot »
