Beta 8.3 Machines tab
jdkdomain
Post by jdkdomain »
I am noticing that not all of the machines I have setup with the current beta are appearing in the machines tab. I have 13 machines setup on the beta, but only 10 are appearing. Is this tab limited to the number of machines it will display?
Also the list of the machines - it appears that the current machine that is logged in is always at the top of the list, followed by the remainder in alphabetical order. Will there be a way to change this order?
Thanks for your help.
Re: Beta 8.3 Machines tab
Post by calxalot »
The local machine is direct connected by web control.
Machines are sorted alphabetically in 3 groups.
First group is direct connections.
Second is connected via node.
Third is disconnected remote machines.
There is a bug where machines can lose their node connection at zero hours UTC.
This is probably why some of your machines are not showing.
Restart the client to make it reconnect.
You can also try the v8.3.8 alpha, but note that alpha builds are sometimes broken.
jdkdomain
Post by jdkdomain »
I can confirm all of the machines are now appearing on the machines tab correctly. Thanks.
