DNS lookup failed for ... Error
Vojoor
Post by Vojoor »
Hi! I'm on an M2Max Mac and started folding again. I'm using the current open Beta (Client 8.3.5) and have an issue with uploading my results.
Downloading WU and folding works fine, but uploading keeps failing.
I tried changing my DNS settings on my Mac, but that didn't help.
Another issue that might be related: this Mac shows as disconnected when i log in to beta.foldingathome.org on another device. My other (intel iMac) machine shows up fine there (and can upload WUs).
Error Log down below
14:41:38:I1:Account websocket closed: NONE msg=Connection failed
14:41:43:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
14:41:46:W :CON194:DNS lookup failed for ds03.scs.illinois.edu:443
14:41:46:E :OUT194:Failed response: CONNECT
14:41:46:I1:WU20:Uploading WU results
14:42:01:W :CON195:DNS lookup failed for 129.32.209.206:80
14:42:01:E :OUT195:Failed response: CONNECT
14:42:01:I1:WU20:Uploading WU results
14:42:16:W :CON196:DNS lookup failed for ds01.scs.illinois.edu:443
14:42:16:E :OUT196:Failed response: CONNECT
14:42:16:I1:WU20:Uploading WU results
14:42:31:W :CON197:DNS lookup failed for vav24.fah.temple.edu:443
14:42:31:E :OUT197:Failed response: CONNECT
14:42:31:I1:WU20:Uploading WU results
14:42:43:I1:Account websocket closed: NONE msg=Connection failed
14:42:46:W :CON198:DNS lookup failed for highland3.seas.upenn.edu:443
14:42:46:E :OUT198:Failed response: CONNECT
14:42:46:I1:WU20:Uploading WU results
14:43:01:W :CON199:DNS lookup failed for 129.32.209.200:80
14:43:01:E :OUT199:Failed response: CONNECT
14:43:01:I1:WU20:Uploading WU results
14:43:03:W :CON1:DNS lookup failed for node1.foldingathome.org:443
14:43:03:I1:Account websocket closed: NONE msg=Connection failed
14:43:08:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
14:43:16:W :CON200:DNS lookup failed for 129.32.209.201:80
14:43:16:E :OUT200:Failed response: CONNECT
14:43:16:I1:WU20:Uploading WU results
14:43:31:W :CON201:DNS lookup failed for 129.32.209.204:80
14:43:31:E :OUT201:Failed response: CONNECT
14:43:31:I1:WU20:Uploading WU results
14:43:46:W :CON202:DNS lookup failed for fah1.innovatr.ca:443
14:43:46:E :OUT202:Failed response: CONNECT
14:43:46:I1:WU20:Uploading WU results
14:44:01:W :CON203:DNS lookup failed for vav20.fah.temple.edu:443
14:44:01:E :OUT203:Failed response: CONNECT
14:44:01:I1:WU20:Uploading WU results
14:44:08:I1:Account websocket closed: NONE msg=Connection failed
14:44:16:W :CON204:DNS lookup failed for 129.32.209.202:80
14:44:16:E :OUT204:Failed response: CONNECT
14:44:16:I1:WU20:Uploading WU results
14:44:24:I1:WU21:Requesting WU assignment for user a8b34pg7ulla team 234980
14:44:28:W :CON1:DNS lookup failed for node1.foldingathome.org:443
14:44:28:I1:Account websocket closed: NONE msg=Connection failed
14:44:31:W :CON205:DNS lookup failed for highland4.seas.upenn.edu:443
14:44:31:E :OUT205:Failed response: CONNECT
14:44:31:I1:WU20:Uploading WU results
14:44:33:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
14:44:39:W :CON206:DNS lookup failed for assign1.foldingathome.org:443
14:44:39:E :OUT206:Failed response: CONNECT
14:44:39:I1:WU21:Retry #13 in 8 mins 32 secs
14:44:46:W :CON207:DNS lookup failed for ds03.scs.illinois.edu:443
14:44:46:E :OUT207:Failed response: CONNECT
14:44:46:I1:WU20:Uploading WU results
14:45:01:W :CON208:DNS lookup failed for 129.32.209.206:80
14:45:01:E :OUT208:Failed response: CONNECT
14:45:01:I1:WU20:Uploading WU results
14:45:16:W :CON209:DNS lookup failed for ds01.scs.illinois.edu:443
14:45:16:E :OUT209:Failed response: CONNECT
14:45:16:I1:WU20:Uploading WU results
14:45:31:W :CON210:DNS lookup failed for vav24.fah.temple.edu:443
14:45:31:E :OUT210:Failed response: CONNECT
14:45:31:I1:WU20:Uploading WU results
14:45:33:I1:Account websocket closed: NONE msg=Connection failed
14:45:46:W :CON211:DNS lookup failed for highland3.seas.upenn.edu:443
14:45:46:E :OUT211:Failed response: CONNECT
14:45:46:I1:WU20:Uploading WU results
14:45:53:W :CON1:DNS lookup failed for node1.foldingathome.org:443
14:45:53:I1:Account websocket closed: NONE msg=Connection failed
14:45:58:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
14:46:01:W :CON212:DNS lookup failed for 129.32.209.200:80
14:46:01:E :OUT212:Failed response: CONNECT
14:46:01:I1:WU20:Uploading WU results
14:46:16:W :CON213:DNS lookup failed for 129.32.209.201:80
14:46:16:E :OUT213:Failed response: CONNECT
14:46:16:I1:WU20:Uploading WU results
14:46:31:W :CON214:DNS lookup failed for 129.32.209.204:80
14:46:31:E :OUT214:Failed response: CONNECT
14:46:31:I1:WU20:Uploading WU results
14:46:46:W :CON215:DNS lookup failed for fah1.innovatr.ca:443
14:46:46:E :OUT215:Failed response: CONNECT
14:46:46:I1:WU20:Uploading WU results
14:46:58:I1:Account websocket closed: NONE msg=Connection failed
14:47:01:W :CON216:DNS lookup failed for vav20.fah.temple.edu:443
14:47:01:E :OUT216:Failed response: CONNECT
14:47:01:I1:WU20:Uploading WU results
14:47:16:W :CON217:DNS lookup failed for 129.32.209.202:80
14:47:16:E :OUT217:Failed response: CONNECT
14:47:16:I1:WU20:Uploading WU results
14:47:18:W :CON1:DNS lookup failed for node1.foldingathome.org:443
14:47:18:I1:Account websocket closed: NONE msg=Connection failed
14:47:23:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
14:47:31:W :CON218:DNS lookup failed for highland4.seas.upenn.edu:443
14:47:31:E :OUT218:Failed response: CONNECT
14:47:31:I1:WU20:Uploading WU results
14:47:46:W :CON219:DNS lookup failed for ds03.scs.illinois.edu:443
14:47:46:E :OUT219:Failed response: CONNECT
14:47:46:I1:WU20:Uploading WU results
14:48:01:W :CON220:DNS lookup failed for 129.32.209.206:80
14:48:01:E :OUT220:Failed response: CONNECT
14:48:01:I1:WU20:Uploading WU results
14:48:16:W :CON221:DNS lookup failed for ds01.scs.illinois.edu:443
14:48:16:E :OUT221:Failed response: CONNECT
14:48:16:I1:WU20:Uploading WU results
14:48:23:I1:Account websocket closed: NONE msg=Connection failed
14:48:31:W :CON222:DNS lookup failed for vav24.fah.temple.edu:443
14:48:31:E :OUT222:Failed response: CONNECT
14:48:31:I1:WU20:Uploading WU results
14:48:43:W :CON1:DNS lookup failed for node1.foldingathome.org:443
14:48:43:I1:Account websocket closed: NONE msg=Connection failed
14:48:46:W :CON223:DNS lookup failed for highland3.seas.upenn.edu:443
14:48:46:E :OUT223:Failed response: CONNECT
14:48:46:I1:WU20:Uploading WU results
14:48:48:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
14:49:01:W :CON224:DNS lookup failed for 129.32.209.200:80
14:49:01:E :OUT224:Failed response: CONNECT
14:49:01:I1:WU20:Uploading WU results
14:49:16:W :CON225:DNS lookup failed for 129.32.209.201:80
14:49:16:E :OUT225:Failed response: CONNECT
14:49:16:I1:WU20:Uploading WU results
14:49:31:W :CON226:DNS lookup failed for 129.32.209.204:80
14:49:31:E :OUT226:Failed response: CONNECT
14:49:31:I1:WU20:Uploading WU results
14:49:46:W :CON227:DNS lookup failed for fah1.innovatr.ca:443
14:49:46:E :OUT227:Failed response: CONNECT
14:49:46:I1:WU20:Uploading WU results
14:49:48:I1:Account websocket closed: NONE msg=Connection failed
14:50:01:W :CON228:DNS lookup failed for vav20.fah.temple.edu:443
14:50:01:E :OUT228:Failed response: CONNECT
14:50:01:I1:WU20:Uploading WU results
14:50:08:W :CON1:DNS lookup failed for node1.foldingathome.org:443
14:50:08:I1:Account websocket closed: NONE msg=Connection failed
14:50:13:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
14:50:16:W :CON229:DNS lookup failed for 129.32.209.202:80
14:50:16:E :OUT229:Failed response: CONNECT
14:50:16:I1:WU20:Uploading WU results
Re: DNS lookup failed for ... Error
Post by calxalot »
This might be the network not ready when client launches bug.
https://github.com/FoldingAtHome/fah-cl ... issues/223
There have been DNS improvements in alpha v8.3.7.
It works fine on Mac. May be broken on Windows/Linux.
https://foldingathome.org/alpha/
Please try it and let us know how it goes.
Alternative is to restart client service from Terminal after boot:
sudo /bin/launchctl stop org.foldingathome.fahclient
sudo /bin/launchctl start org.foldingathome.fahclient
Linux users can restart client service with
sudo /usr/bin/systemctl restart fah-client
Vojoor
Post by Vojoor »
Thanks! It also didn’t load a new WU. I then reinstalled the fah client and I immediately pulled a new WU and the upload of the previous stuck WU went through (probably just because that restarted the client similar to how the terminal command would) and I have the “Credited” in the log, but it doesn’t show in my stats unfortunately. I’ll try the alpha once the current WU is through, if that one doesn’t upload I’ll try the terminal command to restart the client. Thanks again!
bollix47
Post by bollix47 »
It can take 1-3 hours from upload to showing up in stats. Let us know if it doesn't show up after 3 hours.
A copy of the log section showing the upload and acknowledgement would be helpful.
Vojoor
Post by Vojoor »
Sure I'll update.
The log from when the update went through is below.
I have no luck with the alpha, installing it makes the machine not show up. I tried https://beta.foldingathome.org/machines and https://alpha.foldingathome.org/machines . Installing the Beta version makes it instantly show up again though. Of course I rebooted, uninstalled etc. in between using the different client versions.
*********************** Log Started 2024-04-25T16:59:37Z ***********************
16:59:37:I1:*********************** Folding@home Client ***********************
16:59:37:I1: Version: 8.3.5
16:59:37:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:59:37:I1: Org: foldingathome.org
16:59:37:I1: Copyright: 2023-2024, foldingathome.org
16:59:37:I1: Homepage: https://foldingathome.org/
16:59:37:I1: License: GPL-3.0-or-later
16:59:37:I1: URL: https://beta.foldingathome.org/
16:59:37:I1: Date: Feb 14 2024
16:59:37:I1: Time: 06:08:47
16:59:37:I1: Revision: 652c05f093c7d9542ec3d2effdfa693c80a77e8d
16:59:37:I1: Branch: master
16:59:37:I1: Compiler: GNU Apple LLVM 14.0.0 (clang-1400.0.29.202)
16:59:37:I1: Options: -std=c++17 -fsigned-char -stdlib=libc++ -O3 -funroll-loops -fno-pie
16:59:37:I1: -arch x86_64 -arch arm64 -mmacosx-version-min=10.13
16:59:37:I1: Platform: darwin 21.6.0
16:59:37:I1: Bits: 64
16:59:37:I1: Mode: Release
16:59:37:I1:****************************** CBang ******************************
16:59:37:I1: Version: 1.7.2
16:59:37:I1: Org: Cauldron Development LLC
16:59:37:I1: Copyright: Cauldron Development LLC, 2003-2024
16:59:37:I1: Homepage: https://cauldrondevelopment.com/
16:59:37:I1: License: LGPL-2.1-or-later
16:59:37:I1: Time: 05:51:04
16:59:37:I1: Revision: 8f6145ef68f2c46b23df4487130e8f7e4fc8c757
16:59:37:I1: -arch x86_64 -arch arm64 -mmacosx-version-min=10.13 -fPIC
16:59:37:I1:***************************** System ******************************
16:59:37:I1: CPU: Apple M2 Max
16:59:37:I1: CPU ID: Apple Family 8 Model 0 Stepping 0
16:59:37:I1: CPUs: 12
16:59:37:I1: Memory: 32.00GiB
16:59:37:I1:Free Memory: 20.25GiB
16:59:37:I1: OS Version: 14.4.1
16:59:37:I1:Has Battery: true
16:59:37:I1: On Battery: false
16:59:37:I1: Hostname: louis.local
16:59:37:I1: UTC Offset: 2
16:59:37:I1: PID: 1169
16:59:37:I1: CWD: /Library/Application Support/FAHClient
16:59:37:I1: Exec: /usr/local/bin/fah-client
16:59:37:I1:*******************************************************************
16:59:37:I2:<config/>
16:59:37:I1:Opening Database
16:59:37:I1:F@H ID = 5IQDr-6Fw1BZjQOxB5sFrPvJrT-cPKGNTAh20tQ4Y90
16:59:37:I3:Loading default group
16:59:37:I3:Loading default resource group
16:59:37:I1:Listening for HTTP on 127.0.0.1:7396
16:59:37:I3:WU20:Loading work unit 20 with ID Rnqz6zGVIB8gflPFjkIIQVms887JSjacpma0qwxfQ6k
16:59:37:I3:Loaded 1 wus.
16:59:37:I1:WU20:Uploading WU results
16:59:37:I3:Connecting to node1.foldingathome.org:443
16:59:38:I1:OUT2:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
16:59:38:I3:Connecting to vav20.fah.temple.edu:443
16:59:38:I1:OUT3:> POST https://vav20.fah.temple.edu/api/results HTTP/1.1
16:59:38:I1:OUT2:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
16:59:38:I1:Logging into node account
17:00:49:I1:Default:Added new work unit: cpus:8 gpus:
17:00:49:I1:WU24:Requesting WU assignment for user a8b34pg7ulla team 234980
17:00:49:I3:Connecting to assign1.foldingathome.org:443
17:00:49:I1:OUT6:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
17:00:50:I1:OUT6:< HTTP/1.1 200 HTTP_OK
17:00:50:I1:WU24:Received WU assignment pn5NKvXhHuRQP6J_orftw_xF_SoDEa9evwsnalNnGZc
17:00:50:I1:WU24:Downloading WU
17:00:50:I3:Connecting to vav19.fah.temple.edu:443
17:00:50:I1:OUT7:> POST https://vav19.fah.temple.edu/api/assign HTTP/1.1
17:00:51:I1:OUT7:< HTTP/1.1 200 HTTP_OK
17:00:51:I1:WU24:Received WU
17:00:51:I1:Loaded cores/fahcore-a8-osx-64bit-aarch64-0.0.12/FahCore_a8
17:00:51:I3:WU24:Running FahCore: "/Library/Application Support/FAHClient/cores/fahcore-a8-osx-64bit-aarch64-0.0.12/FahCore_a8" -dir pn5NKvXhHuRQP6J_orftw_xF_SoDEa9evwsnalNnGZc -suffix 01 -version 8.3.5 -lifeline 1169 -np 8
17:00:51:I3:WU24:Started FahCore on PID 1179
17:00:52:I1:WU24:*********************** Log Started 2024-04-25T17:00:51Z ***********************
17:00:52:I1:WU24:************************** Gromacs Folding@home Core ***************************
17:00:52:I1:WU24: Core: Gromacs
17:00:52:I1:WU24: Type: 0xa8
17:00:52:I1:WU24: Version: 0.0.12
17:00:52:I1:WU24: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:00:52:I1:WU24: Copyright: 2020 foldingathome.org
17:00:52:I1:WU24: Homepage: https://foldingathome.org/
17:00:52:I1:WU24: Date: Jan 16 2021
17:00:52:I1:WU24: Time: 21:35:50
17:00:52:I1:WU24: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:00:52:I1:WU24: Branch: master
17:00:52:I1:WU24: Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
17:00:52:I1:WU24: Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
17:00:52:I1:WU24: -funroll-loops -fno-pie -mmacosx-version-min=11.0
17:00:52:I1:WU24: Platform: darwin 20.2.0
17:00:52:I1:WU24: Bits: 64
17:00:52:I1:WU24: Mode: Release
17:00:52:I1:WU24: SIMD: arm_neon_asimd
17:00:52:I1:WU24: OpenMP: ON
17:00:52:I1:WU24: CUDA: OFF
17:00:52:I1:WU24: Args: -dir pn5NKvXhHuRQP6J_orftw_xF_SoDEa9evwsnalNnGZc -suffix 01
17:00:52:I1:WU24: -version 8.3.5 -lifeline 1169 -np 8
17:00:52:I1:WU24:************************************ libFAH ************************************
17:00:52:I1:WU24: Time: 21:35:27
17:00:52:I1:WU24:************************************ CBang *************************************
17:00:52:I1:WU24: Time: 21:35:02
17:00:52:I1:WU24: -funroll-loops -fno-pie -mmacosx-version-min=11.0 -fPIC
17:00:52:I1:WU24:************************************ System ************************************
17:00:52:I1:WU24: CPU: Apple
17:00:52:I1:WU24: CPU ID: Apple Family 8 Model 0 Stepping 0
17:00:52:I1:WU24: CPUs: 12
17:00:52:I1:WU24: Memory: 32.00GiB
17:00:52:I1:WU24:Free Memory: 20.17GiB
17:00:52:I1:WU24: Threads: POSIX_THREADS
17:00:52:I1:WU24: OS Version: 14.4
17:00:52:I1:WU24:Has Battery: true
17:00:52:I1:WU24: On Battery: false
17:00:52:I1:WU24: UTC Offset: 2
17:00:52:I1:WU24: PID: 1179
17:00:52:I1:WU24: CWD: /Library/Application Support/FAHClient/work
17:00:52:I1:WU24:********************************************************************************
17:00:52:I1:WU24:Project: 18429 (Run 7, Clone 178, Gen 153)
17:00:52:I1:WU24:Unit: 0x00000000000000000000000000000000
17:00:52:I1:WU24:Reading tar file core.xml
17:00:52:I1:WU24:Reading tar file frame153.tpr
17:00:52:I1:WU24:Digital signatures verified
17:00:52:I1:WU24:Calling: mdrun -c frame153.gro -s frame153.tpr -x frame153.xtc -cpt 5 -nt 8 -ntmpi 1
17:00:52:I1:WU24:Steps: first=382500000 total=385000000
17:00:52:I1:WU24:Completed 1 out of 2500000 steps (0%)
17:01:16:I1:OUT3:< HTTP/1.1 200 HTTP_OK
17:01:16:I1:WU20:Credited
17:02:09:I1:WU24:Completed 25000 out of 2500000 steps (1%)
17:03:26:I1:WU24:Completed 50000 out of 2500000 steps (2%)
bollix47
Post by bollix47 »
Another place to look and verify your info:
https://beta.foldingathome.org/account
Vojoor
Post by Vojoor »
Yeah I checked there and all the info is correct.
I have two machines, an older Intel iMac that’s done 2 WUs on that account no problem and the M2 Max MBP that’s having the issues. They both show up under https://beta.foldingathome.org/machines so I don’t think there’s an issue with the account configuration as they’re both using the same.
I don’t mind losing the points for 1 or 2 WU but it makes me feel like I didn’t actually contribute anything so that’s kinda sad :( also the M2Max has like 3 times the PPD of the iMac so I’d rather have the MBP actually work, even if there’s no GPU folding (had to say it :ewink:)
bollix47
Post by bollix47 »
Enter you folding username in the following link:
https://apps.foldingathome.org/cpu ... clicking on the Last Returned date will show you WU details.
It should show you your recent returns .... see if there's more than 1 machine listed.
Vojoor
Post by Vojoor »
man, there's a lot of app.foldingathome with good features.. is there a glossary somewhere?
And no, only my iMac is showing nothing from the MBP. Once the current WU is completed I'll update.
When I rebooted my system the MBP didn't show again on https://beta.foldingathome.org/machines on my iMac/Phone but using this:
PLIST=/Library/LaunchDaemons/org.foldingathome.fahclient.plist
PLISTBUDDY=/usr/libexec/PlistBuddy
sudo $PLISTBUDDY -c "Add :ProcessType string 'Interactive'" $PLIST || \
sudo $PLISTBUDDY -c "Set :ProcessType 'Interactive'" $PLIST
sudo $PLISTBUDDY -c "Add :SessionCreate bool true" $PLIST || \
sudo $PLISTBUDDY -c "Set :SessionCreate true" $PLIST
sudo /bin/launchctl unload $PLIST
sudo /bin/launchctl load $PLIST
from here: viewtopic.php?t=37513 fixed it instantly, so maybe that would've worked earlier when failing the upload.
Post by calxalot »
That script that patches the plist is only needed for v7.
The launchctl unload/load does a stop/start.
Vojoor
Post by Vojoor »
calxalot wrote: Thu Apr 25, 2024 8:14 pm That script that patches the plist is only needed for v7.
Yeah I had only used the unload/load, and it did make it show up again. The previous
Did not fix it in comparison.
bollix47
Post by bollix47 »
If you know the Project/Run/Clone/Gen numbers you can check the status at:
https://apps.foldingathome.org/wu
