v8.3.5 Restarted machine FAH fails OpenCL not supported: ... :CUDA not supported: cuInit() returned 100
ElectricVehicle
Post by ElectricVehicle »
Restarted my machine then FAH failed. Worked fine before I restarted.
16:27:23:I1:Listening for HTTP on 127.0.0.1:7396
16:27:23:I3:WU6:Loading work unit 6 with ID NF16WbDYMlWDI_GLrHgk2X-M6xSNELVLzEd4oOtZbr0
16:27:23:I3:Loaded 1 wus.
16:27:23:E :OpenCL not supported: Failed to open dynamic library 'libOpenCL.so': libOpenCL.so: cannot open shared object file: No such file or directory
16:27:24:E :CUDA not supported: cuInit() returned 100
16:27:24:I3:gpus = {
16:27:24:I3: "gpu:03:00:00": {"vendor": 4318, "device": 9989, "type": "nvidia", "supported": false, "description": "AD103 [GeForce RTX 4070 Ti SUPER]"}
Full log
*********************** Log Started 2024-04-21T16:27:23Z ***********************
16:27:23:I1:*********************** Folding@home Client ***********************
16:27:23:I1: Version: 8.3.5
16:27:23:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:27:23:I1: Org: foldingathome.org
16:27:23:I1: Copyright: 2023-2024, foldingathome.org
16:27:23:I1: Homepage: https://foldingathome.org/
16:27:23:I1: License: GPL-3.0-or-later
16:27:23:I1: URL: https://beta.foldingathome.org/
16:27:23:I1: Date: Feb 14 2024
16:27:23:I1: Time: 14:09:03
16:27:23:I1: Revision: 652c05f093c7d9542ec3d2effdfa693c80a77e8d
16:27:23:I1: Branch: master
16:27:23:I1: Compiler: GNU 8.3.0
16:27:23:I1: Options: -faligned-new -std=c++17 -fsigned-char -ffunction-sections
16:27:23:I1: -fdata-sections -O3 -funroll-loops -fno-pie
16:27:23:I1: Platform: linux 4.19.0-26-cloud-amd64
16:27:23:I1: Bits: 64
16:27:23:I1: Mode: Release
16:27:23:I1: Args: --config=/etc/fah-client/config.xml
16:27:23:I1: --log=/var/log/fah-client/log.txt
16:27:23:I1: --log-rotate-dir=/var/log/fah-client/
16:27:23:I1: Config: /etc/fah-client/config.xml
16:27:23:I1:****************************** CBang ******************************
16:27:23:I1: Version: 1.7.2
16:27:23:I1: Org: Cauldron Development LLC
16:27:23:I1: Copyright: Cauldron Development LLC, 2003-2024
16:27:23:I1: Homepage: https://cauldrondevelopment.com/
16:27:23:I1: License: LGPL-2.1-or-later
16:27:23:I1: Time: 13:50:56
16:27:23:I1: Revision: 8f6145ef68f2c46b23df4487130e8f7e4fc8c757
16:27:23:I1: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
16:27:23:I1:***************************** System ******************************
16:27:23:I1: CPU: Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz
16:27:23:I1: CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
16:27:23:I1: CPUs: 12
16:27:23:I1: Memory: 11.66GiB
16:27:23:I1:Free Memory: 10.95GiB
16:27:23:I1: OS Version: 6.5
16:27:23:I1:Has Battery: false
16:27:23:I1: On Battery: false
16:27:23:I1: UTC Offset: -7
16:27:23:I1: PID: 770
16:27:23:I1: CWD: /var/lib/fah-client
16:27:23:I1: Exec: /usr/bin/fah-client
16:27:23:I1:*******************************************************************
16:27:23:I2:<config/>
16:27:23:I1:Opening Database
16:27:23:I1:F@H ID = ...
16:27:23:I3:Loading default group
16:27:23:I3:Loading default resource group
16:27:23:I3:WU6:Loading work unit 6 with ID ...
16:27:24:I3:}
16:27:24:W :CON1:DNS lookup failed for node1.foldingathome.org:443
16:27:24:I1:Account websocket closed: NONE msg=Connection failed
16:27:29:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
16:27:29:I1:Account websocket closed: NONE msg=Connection failed
16:27:34:I3:Connecting to node1.foldingathome.org:443
16:27:34:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
16:27:34:I1:OUT1:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
16:27:34:I1:Logging into node account
Fold On! (with 100% Renewable, 0 Carbon electricity) ElectricVehicle EV1, RAV4 EV, LEAF, Bolt EV, Volt, M3, s4 Simulator
bikeaddict
Re: v8.3.5 Restarted machine FAH fails OpenCL not supported: ... :CUDA not supported: cuInit() returned 100
Post by bikeaddict »
The NVIDIA driver must be installed and the kernel module must be loaded under the current kernel. The module must be compiled and installed again whenever a new kernel is installed. This is usually automated by dkms or akmods. Run
modinfo nvidia
to verify the module is loaded.
The OpenCL devel library is required. Install ocl-icd-opencl-dev (Ubuntu) or ocl-icd-devel (Fedora) or similar package. Run clinfo to show the OpenCL platforms installed.
ElectricVehicle
All the drivers were installed properly and running prior to rebooting the computer.
FAH was running fine. I rebooted and got this error.
Been there done that updated drivers and uninstalled /reinstalled FAH multiple times before when this happened a couple days ago. This needs root cause so the FAH client doesn't fail from a reboot or power failure.
ElectricVehicle
clinfo is not showing up, but again everything worked then all I did was to reboot. (I did add my passkey to my account from another computer - but that's totally unrelated to this.)
mikhexa@HexaMonster:~/Desktop$ modinfo nvidia
filename:       /lib/modules/6.5.0-28-generic/kernel/nvidia-550/nvidia.ko
alias:          char-major-195-*
version:        550.67
supported:      external
license:        NVIDIA
firmware:       nvidia/550.67/gsp_tu10x.bin
firmware:       nvidia/550.67/gsp_ga10x.bin
srcversion:     F5EC64C48073D469011EFCC
alias:          pci:v000010DEd*sv*sd*bc06sc80i00*
alias:          pci:v000010DEd*sv*sd*bc03sc02i00*
alias:          pci:v000010DEd*sv*sd*bc03sc00i00*
depends:        drm
retpoline:      Y
vermagic:       6.5.0-28-generic SMP preempt mod_unload modversions
sig_id:         PKCS#7
signer:         Canonical Ltd. Kernel Module Signing
sig_key:        E9:DF:13:0F:92:92:A9:B7
sig_hashalgo:   sha512
signature:      25:35:18:B5:AA:B6:BD:1D:C0:A0:39:D3:31:87:E4:5D:C0:1B:BD:3E:
		AD:30:5C:76:0E:5E:E5:72:16:A7:74:9D:27:62:24:DA:4B:BA:97:3A:
		99:8D:F2:06:3B:23:28:B8:3D:7E:02:93:30:38:23:8E:6A:F9:34:6B:
		83:BF:9C:B1:61:6B:DE:30:60:55:99:49:33:63:D9:0B:91:DC:8F:26:
		29:E8:AD:7B:1D:14:C0:0A:78:2A:D7:FC:5B:2B:A3:5B:77:E8:3E:B6:
		BE:2F:C1:41:3D:07:5D:32:DD:CE:3A:2C:52:04:F5:99:04:80:E4:30:
		04:DC:C1:D9:6E:55:5B:7B:90:CD:B8:09:EF:89:9F:68:F4:65:6C:69:
		BC:E7:FE:28:C9:52:E5:56:F2:63:ED:4C:EC:8C:CB:02:7D:CF:EB:88:
		C8:2F:AF:CA:48:F6:59:01:29:9D:1B:EC:52:B6:6B:28:60:EE:7F:07:
		33:0C:CF:C8:96:52:CF:A1:5C:64:C1:1A:37:8C:C6:9A:F0:6C:4B:E2:
		89:17:97:72:71:7A:0A:7B:C4:9D:83:B0:8A:1B:D6:30:98:F6:DB:F4:
		AD:C1:B7:CE:5F:82:14:B2:12:12:7B:D2:19:32:43:4D:49:11:65:FE:
		2D:A4:4D:C5:16:17:E7:63:71:ED:EA:FA:8D:C0:A3:B7:ED:5A:68:82:
		BD:2D:04:F7:E4:58:02:91:3C:C8:37:38:96:83:09:B5:09:5C:D3:9A:
		9A:4B:C2:9A:22:24:7E:88:71:CF:1F:6D:88:F5:8C:C7:E3:99:49:40:
		8C:B3:C0:A9:03:67:1B:03:CB:FE:F0:52:13:23:88:B5:32:78:4B:79:
		F6:68:61:C7:42:37:C6:66:06:D7:75:BA:76:50:E9:E9:A3:0B:45:EA:
		55:00:8D:53:A5:43:5A:B4:AA:E6:37:00:AA:BE:AF:CF:A1:17:46:BE:
		08:27:33:B9:91:EC:43:A4:2C:5B:D6:89:D0:0B:05:2C:04:79:37:3F:
		86:B1:8C:7C:83:9C:77:9B:B6:5C:28:B9:D3:A8:AB:43:4C:82:3B:8F:
		71:EA:2D:9C:99:3C:FC:14:20:A9:CE:CD:EF:89:D9:99:E5:1F:6D:3A:
		6C:20:7D:C4:53:68:89:B4:4A:37:92:B7:00:D4:A9:D8:1F:EA:23:39:
		3C:45:AE:D4:5A:67:CB:C2:77:A6:03:46:51:40:56:AB:F8:B1:CD:2F:
		31:C7:22:DE:A8:D0:35:BC:DA:70:A4:5C:88:1D:1D:40:4A:1C:38:D4:
		56:A6:DD:C4:3C:BB:9D:05:EF:50:72:8D:C5:DA:A6:23:C7:C0:FE:6D:
		29:F1:C6:85:2A:E7:F2:9E:33:ED:7E:D3
parm:           NvSwitchRegDwords:NvSwitch regkey (charp)
parm:           NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm:           NVreg_ResmanDebugLevel:int
parm:           NVreg_RmLogonRC:int
parm:           NVreg_ModifyDeviceFiles:int
parm:           NVreg_DeviceFileUID:int
parm:           NVreg_DeviceFileGID:int
parm:           NVreg_DeviceFileMode:int
parm:           NVreg_InitializeSystemMemoryAllocations:int
parm:           NVreg_UsePageAttributeTable:int
parm:           NVreg_EnablePCIeGen3:int
parm:           NVreg_EnableMSI:int
parm:           NVreg_TCEBypassMode:int
parm:           NVreg_EnableStreamMemOPs:int
parm:           NVreg_RestrictProfilingToAdminUsers:int
parm:           NVreg_PreserveVideoMemoryAllocations:int
parm:           NVreg_EnableS0ixPowerManagement:int
parm:           NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm:           NVreg_DynamicPowerManagement:int
parm:           NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm:           NVreg_EnableGpuFirmware:int
parm:           NVreg_EnableGpuFirmwareLogs:int
parm:           NVreg_OpenRmEnableUnsupportedGpus:int
parm:           NVreg_EnableUserNUMAManagement:int
parm:           NVreg_MemoryPoolSize:int
parm:           NVreg_KMallocHeapMaxSize:int
parm:           NVreg_VMallocHeapMaxSize:int
parm:           NVreg_IgnoreMMIOCheck:int
parm:           NVreg_NvLinkDisable:int
parm:           NVreg_EnablePCIERelaxedOrderingMode:int
parm:           NVreg_RegisterPCIDriver:int
parm:           NVreg_EnableResizableBar:int
parm:           NVreg_EnableDbgBreakpoint:int
parm:           NVreg_EnableNonblockingOpen:int
parm:           NVreg_RegistryDwords:charp
parm:           NVreg_RegistryDwordsPerDevice:charp
parm:           NVreg_RmMsg:charp
parm:           NVreg_GpuBlacklist:charp
parm:           NVreg_TemporaryFilePath:charp
parm:           NVreg_ExcludedGpus:charp
parm:           NVreg_DmaRemapPeerMmio:int
parm:           NVreg_RmNvlinkBandwidth:charp
parm:           NVreg_ImexChannelCount:int
parm:           rm_firmware_active:charp
mikhexa@HexaMonster:~/Desktop$ clinfo
Command 'clinfo' not found, but can be installed with:
sudo apt install clinfo
ElectricVehicle
mikhexa@HexaMonster:~/Desktop$ sudo apt install ocl-icd-opencl-dev
[sudo] password for mikhexa:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
  dctrl-tools dkms libatomic1:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386
  libdrm-radeon1:i386 libdrm2:i386 libedit2:i386 libelf1:i386 libexpat1:i386 libffi8:i386
  libgl1:i386 libgl1-mesa-dri:i386 libglapi-mesa:i386 libglvnd0:i386 libglx-mesa0:i386
  libglx0:i386 libicu70:i386 libllvm15:i386 libpciaccess0:i386 libsensors5:i386 libstdc++6:i386
  libx11-xcb1:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386
  libxcb-randr0:i386 libxcb-shm0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386 libxfixes3:i386
  libxml2:i386 libxshmfence1:i386 libxxf86vm1:i386 nvidia-firmware-535-535.129.03
  nvidia-firmware-535-535.171.04 nvidia-firmware-535-535.86.05
  nvidia-firmware-550-server-550.54.15
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libegl-dev libgl-dev libgl1-mesa-dev libgles-dev libgles1 libglvnd-core-dev libglvnd-dev
  libglx-dev libopengl-dev libpthread-stubs0-dev libx11-dev libxau-dev libxcb1-dev libxdmcp-dev
  opencl-c-headers opencl-clhpp-headers x11proto-dev xorg-sgml-doctools xtrans-dev
Suggested packages:
  libx11-doc libxcb-doc opencl-clhpp-headers-doc
The following NEW packages will be installed:
  ocl-icd-opencl-dev opencl-c-headers opencl-clhpp-headers x11proto-dev xorg-sgml-doctools
  xtrans-dev
0 upgraded, 20 newly installed, 0 to remove and 4 not upgraded.
Need to get 1,867 kB of archives.
After this operation, 8,810 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 xorg-sgml-doctools all 1:1.11-1.1 [10.9 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 x11proto-dev all 2021.5-1 [604 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libxau-dev amd64 1:1.0.9-1build5 [9,724 B]
Get:4 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libxdmcp-dev amd64 1:1.1.3-0ubuntu5 [26.5 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 xtrans-dev all 1.4.0-1 [68.9 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libpthread-stubs0-dev amd64 0.4-1build2 [5,516 B]
Get:7 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libxcb1-dev amd64 1.14-3ubuntu3 [86.5 kB]
Get:8 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 libx11-dev amd64 2:1.7.5-1ubuntu0.3 [744 kB]
Get:9 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libglx-dev amd64 1.4.0-1 [14.1 kB]
Get:10 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libgl-dev amd64 1.4.0-1 [101 kB]
Get:11 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libegl-dev amd64 1.4.0-1 [18.0 kB]
Get:12 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libgles1 amd64 1.4.0-1 [11.5 kB]
Get:13 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libgles-dev amd64 1.4.0-1 [49.4 kB]
Get:14 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libopengl-dev amd64 1.4.0-1 [3,400 B]
Get:15 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libglvnd-core-dev amd64 1.4.0-1 [12.7 kB]
Get:16 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 libglvnd-dev amd64 1.4.0-1 [3,162 B]
Get:17 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgl1-mesa-dev amd64 23.2.1-1ubuntu3.1~22.04.2 [6,842 B]
Get:18 http://us.archive.ubuntu.com/ubuntu jammy/universe amd64 opencl-c-headers all 3.0~2022.01.04-1 [44.5 kB]
Get:19 http://us.archive.ubuntu.com/ubuntu jammy/universe amd64 opencl-clhpp-headers all 3.0~2.0.15-1ubuntu1 [42.6 kB]
Get:20 http://us.archive.ubuntu.com/ubuntu jammy/universe amd64 ocl-icd-opencl-dev amd64 2.2.14-3 [2,426 B]
Fetched 1,867 kB in 1s (1,680 kB/s)
Selecting previously unselected package xorg-sgml-doctools.
(Reading database ... 208911 files and directories currently installed.)
Preparing to unpack .../00-xorg-sgml-doctools_1%3a1.11-1.1_all.deb ...
Unpacking xorg-sgml-doctools (1:1.11-1.1) ...
Selecting previously unselected package x11proto-dev.
Preparing to unpack .../01-x11proto-dev_2021.5-1_all.deb ...
Unpacking x11proto-dev (2021.5-1) ...
Selecting previously unselected package libxau-dev:amd64.
Preparing to unpack .../02-libxau-dev_1%3a1.0.9-1build5_amd64.deb ...
Unpacking libxau-dev:amd64 (1:1.0.9-1build5) ...
Selecting previously unselected package libxdmcp-dev:amd64.
Preparing to unpack .../03-libxdmcp-dev_1%3a1.1.3-0ubuntu5_amd64.deb ...
Unpacking libxdmcp-dev:amd64 (1:1.1.3-0ubuntu5) ...
Selecting previously unselected package xtrans-dev.
Preparing to unpack .../04-xtrans-dev_1.4.0-1_all.deb ...
Unpacking xtrans-dev (1.4.0-1) ...
Selecting previously unselected package libpthread-stubs0-dev:amd64.
Preparing to unpack .../05-libpthread-stubs0-dev_0.4-1build2_amd64.deb ...
Unpacking libpthread-stubs0-dev:amd64 (0.4-1build2) ...
Selecting previously unselected package libxcb1-dev:amd64.
Preparing to unpack .../06-libxcb1-dev_1.14-3ubuntu3_amd64.deb ...
Unpacking libxcb1-dev:amd64 (1.14-3ubuntu3) ...
Selecting previously unselected package libx11-dev:amd64.
Preparing to unpack .../07-libx11-dev_2%3a1.7.5-1ubuntu0.3_amd64.deb ...
Unpacking libx11-dev:amd64 (2:1.7.5-1ubuntu0.3) ...
Selecting previously unselected package libglx-dev:amd64.
Preparing to unpack .../08-libglx-dev_1.4.0-1_amd64.deb ...
Unpacking libglx-dev:amd64 (1.4.0-1) ...
Selecting previously unselected package libgl-dev:amd64.
Preparing to unpack .../09-libgl-dev_1.4.0-1_amd64.deb ...
Unpacking libgl-dev:amd64 (1.4.0-1) ...
Selecting previously unselected package libegl-dev:amd64.
Preparing to unpack .../10-libegl-dev_1.4.0-1_amd64.deb ...
Unpacking libegl-dev:amd64 (1.4.0-1) ...
Selecting previously unselected package libgles1:amd64.
Preparing to unpack .../11-libgles1_1.4.0-1_amd64.deb ...
Unpacking libgles1:amd64 (1.4.0-1) ...
Selecting previously unselected package libgles-dev:amd64.
Preparing to unpack .../12-libgles-dev_1.4.0-1_amd64.deb ...
Unpacking libgles-dev:amd64 (1.4.0-1) ...
Selecting previously unselected package libopengl-dev:amd64.
Preparing to unpack .../13-libopengl-dev_1.4.0-1_amd64.deb ...
Unpacking libopengl-dev:amd64 (1.4.0-1) ...
Selecting previously unselected package libglvnd-core-dev:amd64.
Preparing to unpack .../14-libglvnd-core-dev_1.4.0-1_amd64.deb ...
Unpacking libglvnd-core-dev:amd64 (1.4.0-1) ...
Selecting previously unselected package libglvnd-dev:amd64.
Preparing to unpack .../15-libglvnd-dev_1.4.0-1_amd64.deb ...
Unpacking libglvnd-dev:amd64 (1.4.0-1) ...
Selecting previously unselected package libgl1-mesa-dev:amd64.
Preparing to unpack .../16-libgl1-mesa-dev_23.2.1-1ubuntu3.1~22.04.2_amd64.deb ...
Unpacking libgl1-mesa-dev:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
Selecting previously unselected package opencl-c-headers.
Preparing to unpack .../17-opencl-c-headers_3.0~2022.01.04-1_all.deb ...
Unpacking opencl-c-headers (3.0~2022.01.04-1) ...
Selecting previously unselected package opencl-clhpp-headers.
Preparing to unpack .../18-opencl-clhpp-headers_3.0~2.0.15-1ubuntu1_all.deb ...
Unpacking opencl-clhpp-headers (3.0~2.0.15-1ubuntu1) ...
Selecting previously unselected package ocl-icd-opencl-dev:amd64.
Preparing to unpack .../19-ocl-icd-opencl-dev_2.2.14-3_amd64.deb ...
Unpacking ocl-icd-opencl-dev:amd64 (2.2.14-3) ...
Setting up libglvnd-core-dev:amd64 (1.4.0-1) ...
Setting up libpthread-stubs0-dev:amd64 (0.4-1build2) ...
Setting up xtrans-dev (1.4.0-1) ...
Setting up libgles1:amd64 (1.4.0-1) ...
Setting up opencl-c-headers (3.0~2022.01.04-1) ...
Setting up xorg-sgml-doctools (1:1.11-1.1) ...
Setting up libopengl-dev:amd64 (1.4.0-1) ...
Setting up opencl-clhpp-headers (3.0~2.0.15-1ubuntu1) ...
Setting up ocl-icd-opencl-dev:amd64 (2.2.14-3) ...
Processing triggers for sgml-base (1.30) ...
Setting up x11proto-dev (2021.5-1) ...
Setting up libxau-dev:amd64 (1:1.0.9-1build5) ...
Processing triggers for libc-bin (2.35-0ubuntu3.7) ...
Processing triggers for man-db (2.10.2-1) ...
Setting up libxdmcp-dev:amd64 (1:1.1.3-0ubuntu5) ...
Setting up libxcb1-dev:amd64 (1.14-3ubuntu3) ...
Setting up libx11-dev:amd64 (2:1.7.5-1ubuntu0.3) ...
Setting up libglx-dev:amd64 (1.4.0-1) ...
Setting up libgl-dev:amd64 (1.4.0-1) ...
Setting up libegl-dev:amd64 (1.4.0-1) ...
Setting up libgles-dev:amd64 (1.4.0-1) ...
Setting up libglvnd-dev:amd64 (1.4.0-1) ...
Setting up libgl1-mesa-dev:amd64 (23.2.1-1ubuntu3.1~22.04.2) ...
mikhexa@HexaMonster:~/Desktop$ sudo apt install clinfo
  clinfo
0 upgraded, 1 newly installed, 0 to remove and 4 not upgraded.
Need to get 53.7 kB of archives.
After this operation, 174 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu jammy/universe amd64 clinfo amd64 3.0.21.02.21-1 [53.7 kB]
Fetched 53.7 kB in 0s (141 kB/s)
Selecting previously unselected package clinfo.
(Reading database ... 209334 files and directories currently installed.)
Preparing to unpack .../clinfo_3.0.21.02.21-1_amd64.deb ...
Unpacking clinfo (3.0.21.02.21-1) ...
Setting up clinfo (3.0.21.02.21-1) ...
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 3.0 CUDA 12.4.125
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info cl_khr_external_semaphore cl_khr_external_memory cl_khr_external_semaphore_opaque_fd cl_khr_external_memory_opaque_fd
  Platform Extensions with Version                cl_khr_global_int32_base_atomics                                 0x400000 (1.0.0)
                                                  cl_khr_global_int32_extended_atomics                             0x400000 (1.0.0)
                                                  cl_khr_local_int32_base_atomics                                  0x400000 (1.0.0)
                                                  cl_khr_local_int32_extended_atomics                              0x400000 (1.0.0)
                                                  cl_khr_fp64                                                      0x400000 (1.0.0)
                                                  cl_khr_3d_image_writes                                           0x400000 (1.0.0)
                                                  cl_khr_byte_addressable_store                                    0x400000 (1.0.0)
                                                  cl_khr_icd                                                       0x400000 (1.0.0)
                                                  cl_khr_gl_sharing                                                0x400000 (1.0.0)
                                                  cl_nv_compiler_options                                           0x400000 (1.0.0)
                                                  cl_nv_device_attribute_query                                     0x400000 (1.0.0)
                                                  cl_nv_pragma_unroll                                              0x400000 (1.0.0)
                                                  cl_nv_copy_opts                                                  0x400000 (1.0.0)
                                                  cl_nv_create_buffer                                              0x400000 (1.0.0)
                                                  cl_khr_int64_base_atomics                                        0x400000 (1.0.0)
                                                  cl_khr_int64_extended_atomics                                    0x400000 (1.0.0)
                                                  cl_khr_device_uuid                                               0x400000 (1.0.0)
                                                  cl_khr_pci_bus_info                                              0x400000 (1.0.0)
                                                  cl_khr_external_semaphore                                          0x9000 (0.9.0)
                                                  cl_khr_external_memory                                             0x9000 (0.9.0)
                                                  cl_khr_external_semaphore_opaque_fd                                0x9000 (0.9.0)
                                                  cl_khr_external_memory_opaque_fd                                   0x9000 (0.9.0)
  Platform Numeric Version                        0xc00000 (3.0.0)
  Platform Extensions function suffix             NV
  Platform Host timer resolution                  0ns
  Device Name                                     NVIDIA GeForce RTX 4070 Ti SUPER
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 3.0 CUDA
  Device UUID                                     c1494514-427c-5df5-a651-07d7cb08ab72
  Driver UUID                                     c1494514-427c-5df5-a651-07d7cb08ab72
  Valid Device LUID                               No
  Device LUID                                     6d69-637300000000
  Device Node Mask                                0
  Device Numeric Version                          0xc00000 (3.0.0)
  Driver Version                                  550.67
  Device OpenCL C Version                         OpenCL C 1.2
  Device OpenCL C all versions                    OpenCL C                                                         0x400000 (1.0.0)
                                                  OpenCL C                                                         0x401000 (1.1.0)
                                                  OpenCL C                                                         0x402000 (1.2.0)
                                                  OpenCL C                                                         0xc00000 (3.0.0)
  Device OpenCL C features                        __opencl_c_fp64                                                  0xc00000 (3.0.0)
                                                  __opencl_c_images                                                0xc00000 (3.0.0)
                                                  __opencl_c_int64                                                 0xc00000 (3.0.0)
                                                  __opencl_c_3d_image_writes                                       0xc00000 (3.0.0)
  Latest comfornace test passed                   v2023-10-10-00
  Device Topology (NV)                            PCI-E, 0000:03:00.0
  Max compute units                               66
  Max clock frequency                             2640MHz
  Compute Capability (NV)                         8.9
    Max number of sub-devices                     1
    Supported affinity domains                    (n/a)
  Max work item sizes                             1024x1024x64
  Max work group size                             1024
  Preferred work group size multiple (device)     32
  Preferred work group size multiple (kernel)     32
  Warp size (NV)                                  32
  Max sub-groups per work group                   0
    char                                                 1 / 1
    short                                                1 / 1
    half                                                 0 / 0        (n/a)
  Half-precision Floating-point support           (n/a)
  Global memory size                              16851402752 (15.69GiB)
  Max memory allocation                           4212850688 (3.924GiB)
  Integrated memory (NV)                          No
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   No
    Fine-grained system sharing                   No
    Atomics                                       No
  Alignment of base address                       4096 bits (512 bytes)
  Preferred alignment for atomics
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Atomic memory capabilities                      relaxed, work-group scope
  Atomic fence capabilities                       relaxed, acquire/release, work-group scope
  Max size for global variable                    0
  Preferred total size of global vars             0
  Global Memory cache size                        1892352 (1.805MiB)
  Global Memory cache line size                   128 bytes
    Max number of samplers per kernel             32
    Max size for 1D images from buffer            268435456 pixels
    Max 1D or 2D image array size                 2048 images
    Max 2D image size                             32768x32768 pixels
    Max 3D image size                             16384x16384x16384 pixels
    Max number of read image args                 256
    Max number of write image args                32
    Max number of read/write image args           0
  Pipe support                                    No
  Max number of pipe args                         0
  Max active pipe reservations                    0
  Max pipe packet size                            0
  Local memory size                               49152 (48KiB)
  Registers per block (NV)                        65536
  Max number of constant args                     9
  Max constant buffer size                        65536 (64KiB)
  Generic address space support                   No
  Max size of kernel argument                     32764 (32KiB)
  Queue properties (on host)
    Out-of-order execution                        Yes
  Device enqueue capabilities                     (n/a)
  Queue properties (on device)
    Profiling                                     No
    Preferred size                                0
    Max size                                      0
  Max queues on device                            0
  Max events on device                            0
  Prefer user sync for interop                    No
  Profiling timer resolution                      1000ns
  Execution capabilities
    Non-uniform work-groups                       No
    Work-group collective functions               No
    Sub-group independent forward progress        No
    Kernel execution timeout (NV)                 Yes
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  2
    IL version                                    (n/a)
    ILs with version                              <printDeviceInfo:186: get CL_DEVICE_ILS_WITH_VERSION : error -30>
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels                                (n/a)
  Built-in kernels with version                   <printDeviceInfo:190: get CL_DEVICE_BUILT_IN_KERNELS_WITH_VERSION : error -30>
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info cl_khr_external_semaphore cl_khr_external_memory cl_khr_external_semaphore_opaque_fd cl_khr_external_memory_opaque_fd
  Device Extensions with Version                  cl_khr_global_int32_base_atomics                                 0x400000 (1.0.0)
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  NVIDIA CUDA
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [NV]
  clCreateContext(NULL, ...) [default]            Success [NV]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  Invalid device type for platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  No platform
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.14
  ICD loader Profile                              OpenCL 3.0
ElectricVehicle
Had to stop and restart fah-client to reload and use the newly installed ocl-icd-opencl-dev .
sudo systemctl stop fah-client
sudo systemctl restart fah-client
mikhexa@HexaMonster:~/Desktop$ systemctl status --no-pager -l fah-client
● fah-client.service - Folding@home Client
     Loaded: loaded (/lib/systemd/system/fah-client.service; enabled; vendor preset: enabled)
     Active: active (running) since Sun 2024-04-21 09:27:23 PDT; 3h 29min ago
   Main PID: 770 (fah-client)
      Tasks: 3 (limit: 14239)
     Memory: 149.4M
        CPU: 6.560s
     CGroup: /system.slice/fah-client.service
             └─770 /usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah-client/
Apr 21 09:27:23 HexaMonster systemd[1]: Started Folding@home Client.
mikhexa@HexaMonster:~/Desktop$ sudo systemctl stop fah-client
mikhexa@HexaMonster:~/Desktop$ sudo systemctl restart fah-client
     Active: active (running) since Sun 2024-04-21 12:58:09 PDT; 26s ago
   Main PID: 5468 (fah-client)
      Tasks: 60 (limit: 14239)
     Memory: 1.5G
        CPU: 40.924s
             ├─5468 /usr/bin/fah-client --config=/etc/fah-client/config.xml --log=/var/log/fah-client/log.txt --log-rotate-dir=/var/log/fah-client/
             └─5474 /var/lib/fah-client/cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23 -dir NF16WbDYMlWDI_GLrHgk2X-M6xSNELVLzEd4oOtZbr0 -suffix 01 -version 8.3.5 -lifeline 5468 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
Apr 21 12:58:09 HexaMonster systemd[1]: Started Folding@home Client.
ElectricVehicle
There's a bug here -
Either FAH shouldn't start folding and have a clear error message on the missing library and remedy or it shouldn't fail after rebooting. The mere act of rebooting with NO OTHER CHANGE is not an excuse for FAH to fail and derail Science!
Thank you for the WORKAROUNDS to this bug. This is not something normal users should have to deal with.
So it's running and has resumed the GPU WU I was folding before this all failed just from rebooting the computer.
*********************** Log Started 2024-04-21T19:58:09Z ***********************
19:58:09:I1:*********************** Folding@home Client ***********************
19:58:09:I1: Version: 8.3.5
19:58:09:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:58:09:I1: Org: foldingathome.org
19:58:09:I1: Copyright: 2023-2024, foldingathome.org
19:58:09:I1: Homepage: https://foldingathome.org/
19:58:09:I1: License: GPL-3.0-or-later
19:58:09:I1: URL: https://beta.foldingathome.org/
19:58:09:I1: Date: Feb 14 2024
19:58:09:I1: Time: 14:09:03
19:58:09:I1: Revision: 652c05f093c7d9542ec3d2effdfa693c80a77e8d
19:58:09:I1: Branch: master
19:58:09:I1: Compiler: GNU 8.3.0
19:58:09:I1: Options: -faligned-new -std=c++17 -fsigned-char -ffunction-sections
19:58:09:I1: -fdata-sections -O3 -funroll-loops -fno-pie
19:58:09:I1: Platform: linux 4.19.0-26-cloud-amd64
19:58:09:I1: Bits: 64
19:58:09:I1: Mode: Release
19:58:09:I1: Args: --config=/etc/fah-client/config.xml
19:58:09:I1: --log=/var/log/fah-client/log.txt
19:58:09:I1: --log-rotate-dir=/var/log/fah-client/
19:58:09:I1: Config: /etc/fah-client/config.xml
19:58:09:I1:****************************** CBang ******************************
19:58:09:I1: Version: 1.7.2
19:58:09:I1: Org: Cauldron Development LLC
19:58:09:I1: Copyright: Cauldron Development LLC, 2003-2024
19:58:09:I1: Homepage: https://cauldrondevelopment.com/
19:58:09:I1: License: LGPL-2.1-or-later
19:58:09:I1: Time: 13:50:56
19:58:09:I1: Revision: 8f6145ef68f2c46b23df4487130e8f7e4fc8c757
19:58:09:I1: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
19:58:09:I1:***************************** System ******************************
19:58:09:I1: CPU: Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz
19:58:09:I1: CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
19:58:09:I1: CPUs: 12
19:58:09:I1: Memory: 11.66GiB
19:58:09:I1:Free Memory: 7.03GiB
19:58:09:I1: OS Version: 6.5
19:58:09:I1:Has Battery: false
19:58:09:I1: On Battery: false
19:58:09:I1: Hostname: HexaMonster
19:58:09:I1: UTC Offset: -7
19:58:09:I1: PID: 5468
19:58:09:I1: CWD: /var/lib/fah-client
19:58:09:I1: Exec: /usr/bin/fah-client
19:58:09:I1:*******************************************************************
19:58:09:I2:<config/>
19:58:09:I1:Opening Database
19:58:09:I1:F@H ID = ...
19:58:09:I3:Loading default group
19:58:09:I3:Loading default resource group
19:58:09:I1:Listening for HTTP on 127.0.0.1:7396
19:58:09:I3:WU6:Loading work unit 6 with ID ...
19:58:09:I3:Loaded 1 wus.
19:58:09:I3:gpus = {
19:58:09:I3: "gpu:03:00:00": {
19:58:09:I3: "vendor": 4318,
19:58:09:I3: "type": "nvidia",
19:58:09:I3: "description": "NVIDIA GeForce RTX 4070 Ti SUPER",
19:58:09:I3: "uuid": "72ab08cb-d707-51a6-f55d-7c42144549c1",
19:58:09:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "550.67"},
19:58:09:I3: "cuda": {"platform": 0, "device": 0, "compute": "8.9", "driver": "12.4"},
19:58:09:I3: "device": 9989,
19:58:09:I3: "supported": true
19:58:09:I3: }
19:58:09:I3:}
19:58:09:I3:Connecting to node1.foldingathome.org:443
19:58:09:I1:Loaded cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23
19:58:09:I3:WU6:Running FahCore: /var/lib/fah-client/cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23 -dir NF16WbDYMlWDI_GLrHgk2X-M6xSNELVLzEd4oOtZbr0 -suffix 01 -version 8.3.5 -lifeline 5468 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
19:58:09:I3:WU6:Started FahCore on PID 5474
19:58:09:I1:OUT1:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
19:58:09:I1:WU6:*********************** Log Started 2024-04-21T19:58:09Z ***********************
19:58:09:I1:WU6:*************************** Core23 Folding@home Core ***************************
19:58:09:I1:WU6: Core: Core23
19:58:09:I1:WU6: Type: 0x23
19:58:09:I1:WU6: Version: 8.0.3
19:58:09:I1:WU6: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:58:09:I1:WU6: Copyright: 2022 foldingathome.org
19:58:09:I1:WU6: Homepage: https://foldingathome.org/
19:58:09:I1:WU6: Date: Aug 3 2023
19:58:09:I1:WU6: Time: 08:28:22
19:58:09:I1:WU6: Revision: 199cb870317d05441d0a301287d9ef61254fa32b
19:58:09:I1:WU6: Branch: HEAD
19:58:09:I1:WU6: Compiler: GNU 7.5.0
19:58:09:I1:WU6: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
19:58:09:I1:WU6: -fdata-sections -O3 -funroll-loops -fno-pie
19:58:09:I1:WU6: -DOPENMM_VERSION="\"8.0.0\""
19:58:09:I1:WU6: Platform: linux 5.15.0-1041-azure
19:58:09:I1:WU6: Bits: 64
19:58:09:I1:WU6: Mode: Release
19:58:09:I1:WU6:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:58:09:I1:WU6: <peastman@stanford.edu>
19:58:09:I1:WU6: Args: -dir NF16WbDYMlWDI_GLrHgk2X-M6xSNELVLzEd4oOtZbr0 -suffix 01
19:58:09:I1:WU6: -version 8.3.5 -lifeline 5468 -gpu-vendor nvidia -opencl-platform 0
19:58:09:I1:WU6: -opencl-device 0 -cuda-platform 0 -cuda-device 0 -gpu 0
19:58:09:I1:WU6:************************************ libFAH ************************************
19:58:09:I1:WU6: Time: 08:27:48
19:58:09:I1:WU6: Revision: 112c2234abe20611a05652defc3c7f854cbf927f
19:58:09:I1:WU6:************************************ CBang *************************************
19:58:09:I1:WU6: Version: 1.7.2
19:58:09:I1:WU6: Org: Cauldron Development LLC
19:58:09:I1:WU6: Copyright: Cauldron Development LLC, 2003-2023
19:58:09:I1:WU6: Homepage: https://cauldrondevelopment.com/
19:58:09:I1:WU6: License: GPL 2+
19:58:09:I1:WU6: Time: 08:27:30
19:58:09:I1:WU6: Revision: eae4b58965bdd4d54ea9eb77972674352b37a547
19:58:09:I1:WU6: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
19:58:09:I1:WU6:************************************ System ************************************
19:58:09:I1:WU6: CPU: Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz
19:58:09:I1:WU6: CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
19:58:09:I1:WU6: CPUs: 12
19:58:09:I1:WU6: Memory: 11.66GiB
19:58:09:I1:WU6:Free Memory: 6.98GiB
19:58:09:I1:WU6: Threads: POSIX_THREADS
19:58:09:I1:WU6: OS Version: 6.5
19:58:09:I1:WU6:Has Battery: false
19:58:09:I1:WU6: On Battery: false
19:58:09:I1:WU6: UTC Offset: -7
19:58:09:I1:WU6: PID: 5474
19:58:09:I1:WU6: CWD: /var/lib/fah-client/work
19:58:09:I1:WU6: Exec: /var/lib/fah-client/cores/openmm-core-23/centos-7.9.2009-64bit/release/fahcore-23-centos-7.9.2009-64bit-release-8.0.3/FahCore_23
19:58:09:I1:WU6:************************************ OpenMM ************************************
19:58:09:I1:WU6: Version: 8.0.0
19:58:09:I1:WU6:********************************************************************************
19:58:09:I1:WU6:Project: 18220 (Run 11063, Clone 1, Gen 10)
19:58:09:I1:WU6:Digital signatures verified
19:58:09:I1:WU6:Folding@home GPU Core23 Folding@home Core
19:58:09:I1:WU6:Version 8.0.3
19:58:09:I1:WU6: Checkpoint write interval: 25000 steps (2%) [50 total]
19:58:09:I1:WU6: JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:58:09:I1:WU6: XTC frame write interval: 10000 steps (0.8%) [125 total]
19:58:09:I1:WU6: Global context and integrator variables write interval: disabled
19:58:09:I1:WU6:There are 4 platforms available.
19:58:09:I1:WU6:Platform 0: Reference
19:58:09:I1:WU6:Platform 1: CPU
19:58:09:I1:WU6:Platform 2: OpenCL
19:58:09:I1:WU6: opencl-device 0 specified
19:58:09:I1:WU6:Platform 3: CUDA
19:58:09:I1:WU6: cuda-device 0 specified
19:58:09:I1:OUT1:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
19:58:09:I1:Logging into node account
19:58:21:I1:WU6:Attempting to create CUDA context:
19:58:21:I1:WU6: Configuring platform CUDA
19:58:29:I1:WU6: Using CUDA on CUDA Platform and gpu 0
19:58:29:I1:WU6: GPU info: Platform: CUDA
19:58:29:I1:WU6: GPU info: PlatformIndex: 0
19:58:29:I1:WU6: GPU info: Device: NVIDIA GeForce RTX 4070 Ti SUPER
19:58:29:I1:WU6: GPU info: DeviceIndex: 0
19:58:29:I1:WU6: GPU info: Vendor: 0x10de
19:58:29:I1:WU6: GPU info: PCI: 03:00:00
19:58:29:I1:WU6: GPU info: Compute: 8.9
19:58:29:I1:WU6: GPU info: Driver: 12.4
19:58:29:I1:WU6: GPU info: GPU: true
19:58:29:I1:WU6:Completed 775000 out of 1250000 steps (62%)
19:59:05:I1:WU6:Completed 787500 out of 1250000 steps (63%)
19:59:41:I1:WU6:Completed 800000 out of 1250000 steps (64%)
The developer doesn't read this forum, open a ticket here : https://github.com/FoldingAtHome/fah-cl ... tet/issues
