GPU2 download page incorrectly states ATI is HD26xx+.
legoman666
- Hardware configuration: Gigabyte GA-X38-DS4
Q6600 @ 3.1ghz
1x HD3870 @ 840/1125
1x HD4850 @ Stock
4gb DDR2 1066
XP SP3
2x GPU2 + 1 SMP
GIGABYTE GA-MA69G-S3H
A64 X2 4000+ @ 2.45ghz
1x HD2400 @ Stock
1gb DDR2 1000
XP SP2
1 SMP
MSI K9N6SGM-V
A64 3000+ @ 1.6ghz
7300GS @ Stock
512mb DDR2 800
XP SP2
1 CPU
Lenovo R61
T7200 @ 2.0ghz
2gb DDR2 667
XP SP2
1 SMP
Lenovo ThinkCentre
Q6700 @ 2.67ghz
2gb DDR2 800
XP SP2
4x CPU
Toshiba Laptop
CD T2060 @ 1.6ghz
1gb DDR2 667
Vista
2x CPU
Toshiba Laptop
Pentium M 1.6ghz
512mb DDR 333
XP SP1?
1 CPU
This is incorrect. I have the client running perfectly fine (albeit slowly) on a HD2400.
Foxery
- Hardware configuration: Intel Core2 Quad Q9300 (Intel P35 chipset)
Radeon 3850, 512MB model (Catalyst 8.10)
Windows XP, SP2 - Location: Syracuse, NY
Re: GPU2 download page incorrectly states ATI is HD26xx+.
ATI's driver team also didn't get their release notes quite right for Catalyst 8.7; it only says the 3000 series are supported.
Core2 Quad/Q9300, Radeon 3850/512MB (WinXP SP2)
You should read "HD2xxx, 3xxx and 4xxx"
ChelseaOilman
You must be getting that somewhere else, FAQ maybe.toTOW wrote:You should read "HD2xxx, 3xxx and 4xxx"
This is from the High Performance Clients download page:
Windows: V6 Beta GPU2 (ATI 26xx+, nVidia read this) clients
Windows XP/2003 GPU System tray client w/installer 6.12 beta8
Yep someone needs to update the download page
VijayPande
- Pande Group Member
